PorcGras Posted 25 minutes ago Posted 25 minutes ago Hey guys! I need a bit of help 😞 I recently got a B173QTN01.5 screen (2560x1440 at 120Hz) for my P775DM3 (QTJ1 + 3070)... but it seems stuck at 60Hz (60.025 to be exact). I'm pretty sure I got the right cable: 6-43-P7751-221-1N as I followed the combinations on the Eurocom website. Setting the frequency to 120Hz in either Nvidia Control Panel/CRU makes the screen go crazy (full black + white horizontal lines). Am I missing something? Am I doing something wrong? Thankuu!
harkaz Posted 17 minutes ago Posted 17 minutes ago The Eurocom website lists 6-43-P7751-221-1N for P775TM1/QHD-120Hz and 6-43-P7751-221-1L for P775DM3/QHD-120Hz.
PorcGras Posted 14 minutes ago Author Posted 14 minutes ago 1 minute ago, harkaz said: The Eurocom website lists 6-43-P7751-221-1N for P775TM1/QHD-120Hz and 6-43-P7751-221-1L for P775DM3/QHD-120Hz. I think/hope they are interchangeable... 😞 I mean, the monitor works just fine... just not at the specified spec, I would find it incredibly surprising if that difference would break anything.
harkaz Posted 13 minutes ago Posted 13 minutes ago I don't know the lane routing, just pointed out the difference. Apart from that, it can be a problem with the monitor or the GPU. UPDATE: Check for VRAM errors with tools like mods. 1
PorcGras Posted 11 minutes ago Author Posted 11 minutes ago Maybe its worth to note: I have a secondary Aorus FI27Q monitor that runs just fine at QHD 144Hz. Not sure if that changes anything tho
harkaz Posted 7 minutes ago Posted 7 minutes ago It indicates that GPU VRAMs are most likely working fine on other display routes. Apart from physical damage of the lanes connecting the MXM to the eDP connector on the motherboard, which can be inspected under microscope, it can be incompatible cable/LCD issue.
