AXA Posted January 23, 2022 Share Posted January 23, 2022 Hi there First and foremost, id like to give a huge thanks to Maxware79 for selling me the final part i needed to complete this little project of mine. More on this later. I dont often post on here but figured id share my little rebuild/upgrade project ive been working on and share some insights ive discovered along the way. After getting an M18X R1 last year and upgrading that as far as i could take it (780m) i wanted to get an R2 next. So i kept an eye on ebay to see what would turn up, and found a Nebula Red r2 which i decided to bid on. Cosmetically it looked rather decent aside from some small chips here and there (see pics below), however i noticed it was running on intel graphics so assumed it was missing the GPUs which was fine. However when it arrived, turned out the whole thing had been parted out, leaving just the mother and daughter board with a broken wifi card and a msata ssd, basically enough to make the thing operate and function as a office machine. It also had some weird bootup behaviour which i quickly discovered was due to a dead cmos battery, once that was changed it booted normally. Also whoever parted it out did some weirdness with the cable management (the screen LED cable was under the left hinge and palmrest, and was threaded thru the hole where the GPU heatsink would of sat) it also had the wrong screws in it used in places which i promptly replaced with the correct ones. The battery also only had 20% wear on it, which surprised me. link to spare cmos batteries: https://www.ebay.co.uk/itm/323266730201?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649 So i got to work finding the parts i needed (speakers/ODD cable/new wifi card etc) and installed those, i temporarily put one of my faulty 580m's in there from my r1 to verify the mxm slot was functional which luckily it was. The only nuisance part to sort out was the wifi card, it seems whoever worked on this previous had threaded the screw so badly nothing i tried could remove it. So i taped around the card and held a magnet nearby and used a hand drill (yep one of those ancient things) and slowly drilled out the screw, making sure the magnet was catching the shavings. Afterwards i used the magnet again to collect any stray shavings that might of gotten away. To secure the new card i used a rather ghetto solution of using a matchstick to wedge it in place long enough to test it thoroughly. Once i was satisfied i decided to put a small blob of gel superglue in place of the old screw, figured with this i could easily drill it out again if needed without having to worry about potential shorts from metal shavings. my ghetto wifi card holder: As far as the ODD cable was concerned, luckily i found a seller who was selling a faulty dvd drive with the cable included for 12 bucks or so, with that i simply reused the Blu ray drive i took out of the R1 i had (the R1 is using a HDD adapter in place of the original blu ray drive so no loss there). The lid hinges were also loose resulting in the screen wobbling, found out that this is a common occurrence from Maxware79 . All thats needed is to remove the 2 small screws at the base of the screen assembly which allows the black piece on the lid to slide off, revealing the screws that allow the metal lid to be removed in order to access the hinge screws. Once all those were retightened it was good as new, no more wobble. Now to decide what GPU upgrade i wanted to go with, ultimately i decided on a Quadro P4000 after hearing how they are pretty much plug n play and very similar performance of a cross between a gtx 1060 and 1070. Id like to thank Raidriar for his modded bios, which enabled me to force the machine to run in optimus mode which was a requirement for anything above a 9 series GPU. The GPU arrived promptly from china (probably the fastest parcel ive ever received, took under a week). taishan1980 is the user on ebay for those who also want to go down this route. https://www.ebay.co.uk/itm/264330931952?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649 Pictures of GPU in Question, with the 580m bracket attached: Please ignore the ram, i have already swapped that out with 4x 8GB HyperX the heatsink i bought had no electrical tape on it, so as a precautionary measure i decided to put some scotch 33+ tape around the die to prevent any possible contact between the heatsink and any of the exposed components. I also reused the X-Bracket from the 580m, which worked rather nicely. Again i used a small piece of tape to cover the contact points under the bracket just incase of a short (see pic above), Once installed it booted up no problem and worked perfectly in legacy mode. The drivers were super simple to modify, due to the quadros being used in a wide variety of laptops they only included the GPU code in the inf files, no vendor or subvendor at all, only thing needed was to change the string from 1BB1 to 1BB7 on all relevant entries. Once that was done, drivers installed no problem. I should also mention that in this case, since optimus is being used, the standard inf file needed to be modified rather then the dell/alienware specific one. A word of caution, dont ever use the FN + F7 hotkey. I decided to be curious and try it and it resulted in the laptop not being bootable, but to fix that you simply have to remove the cmos battery and short the pins. Plug the battery back in and hold ALT while powering the machine back on, this forces the diagnostics to pop up along with resetting the bios to default values again (the modded bios i used defaults to the iGPU luckily). Heres the GPU-Z Stats: Another thing i decided to do was remove the deteriorating rubberised finish on the palmrest, used WD40 to remove the rubber by scrapping it off. After i polished it with some Mothers VLR and a scouring pad to buff out any leftover rubber/marks. The final part of this laptop i had to fix was the HDD connector and cable, which luckily a user on ebay was selling a bunch of the connectors in batches of 10. I simply took the latches off those and put one onto the existing connector to fix that (took picture before i decided to strip the rubber off the palmrest) The HDD interposer however was a headache. I tried 2 supposedly brand new Interposers from amazon, both of which didnt work properly (one read the bottom-most drive, but only had 15-20mb/s read speed and full write speed and the other cable outright didnt detect the same drive at all) so id suggest avoiding those like the plague. Picture below of said cable: Thankfully Maxware79 mentioned he had a spare cable for sale and he was kind enough to test it prior to sending to verify it worked on his machine, with his cable all 3 drives worked flawlessly. His original cable for point of reference, this is the one you need: Heres a pic of all the drives working, with the new cable in place. the 2 drives which are at roughly 250ish mb/s reads and writes are the mSata SSD and the middle connection on the cable which both run at Sata 2: Overall im very happy with this machine, im glad i was able to restore it to its former glory. As far as gaming is concerned its very similar to my 17 r4 with its gtx 1070, with the added benefit of the m18x specific features and the larger screen real estate. I also have replaced the keyboard, turns out the m18x r2 and the m17x r4 use the same keyboards. Used a Greek M17X R4 keyboard which has the same US layout, which is why it also has the symbols and the updated windows 10 key. Also made a 2nd topic with the MXM to NVMe upgrade, to make it easier to find for those who want to buy one but ill also add it here to complete this guide: 2 1 Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M Link to comment Share on other sites More sharing options...
deadsmiley Posted February 3, 2022 Share Posted February 3, 2022 I love seeing these AW laptops being brought back to working status. Good work! 1 Lenovo Legion Pro 7i | 13900 HX | RTX 4090 | 32GB RAM | 2TB 990 Pro | 4TB WD SN850X | 240Hz Link to comment Share on other sites More sharing options...
AXA Posted February 5, 2022 Author Share Posted February 5, 2022 thanks 🙂 Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M Link to comment Share on other sites More sharing options...
StripeySnake Posted February 25, 2022 Share Posted February 25, 2022 Hey, I run a p4000 too! It's gotta be one of the most underrated MXM gpus out there. When I got mine almost a year ago it was 200 dollars on ebay, and I couldn't find any info on it if it would work. Nowadays it runs closer to a 1070 than 1060, and is always impressively cool considering it's using the stock fan curve. It's awesome to see some more appreciation for such a good GPU. Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3 Link to comment Share on other sites More sharing options...
ssj92 Posted February 25, 2022 Share Posted February 25, 2022 P4000 is a great GPU indeed especially at $200. Even now it can be found on eBay for $280. 1060 can surpass it since 1060 can be overclocked however. P4000 is locked otherwise it would have good potential. https://www.3dmark.com/compare/fs/26323934/fs/25466379/fs/16862474/fs/19775399/fs/4002945 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
AXA Posted February 26, 2022 Author Share Posted February 26, 2022 yeah really wish i could overclock it but im happy regardless, ive also got some more upgrades planned (my MXM to NVMe adapter arrived a few days ago) currently just waiting on buying SSDs Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M Link to comment Share on other sites More sharing options...
ssj92 Posted February 27, 2022 Share Posted February 27, 2022 On 2/25/2022 at 8:22 PM, Azther said: yeah really wish i could overclock it but im happy regardless, ive also got some more upgrades planned (my MXM to NVMe adapter arrived a few days ago) currently just waiting on buying SSDs I'm sure @kenny27will be interested in your results since he also bought a MXM NVMe adapter like you Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
kenny27 Posted February 27, 2022 Share Posted February 27, 2022 55 minutes ago, ssj92 said: I'm sure @kenny27will be interested in your results since he also bought a MXM NVMe adapter like you Yep I sure will, I'm just waiting on a new mobo to come in this week, mine wont boot up with anything in the secondary slot. So was there any potential solution for the constant power draw of the nvme adpater? M18x R2 | 3920XM | 16GB DDR3 @ 2133Mhz | 980M SLI | 256GB Samsung 840 Evo + 1TB HHD | Audioengine D1 | Beyordynamic DT990 | Corsair M65 Link to comment Share on other sites More sharing options...
Maxware79 Posted February 27, 2022 Share Posted February 27, 2022 4 minutes ago, kenny27 said: Yep I sure will, I'm just waiting on a new mobo to come in this week, mine wont boot up with anything in the secondary slot. So was there any potential solution for the constant power draw of the nvme adpater? How much did a new board set you back? Do you think your secondary MXM port is bad? Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3 Link to comment Share on other sites More sharing options...
kenny27 Posted February 28, 2022 Share Posted February 28, 2022 18 hours ago, Maxware79 said: How much did a new board set you back? Do you think your secondary MXM port is bad? $350USD...should have it today. Had crashing with sli enabled for a long time, swapped my cards around, tried my 7970ms in crossfire same thing, cleaned the mxm slots, eventually it wouldnt boot with anything in the second slot. Hopefully I an get it fixed to have as a spare! M18x R2 | 3920XM | 16GB DDR3 @ 2133Mhz | 980M SLI | 256GB Samsung 840 Evo + 1TB HHD | Audioengine D1 | Beyordynamic DT990 | Corsair M65 Link to comment Share on other sites More sharing options...
Maxware79 Posted February 28, 2022 Share Posted February 28, 2022 Wow, they still ask a lot for a board. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3 Link to comment Share on other sites More sharing options...
AXA Posted March 13, 2022 Author Share Posted March 13, 2022 updated my post with the mxm to nvme link since ive finally gotten around to installing it xD was waiting on buying the SSDs i needed since i was swapping out the blu ray drive and wanted to do all the upgrades in one go. went abit overkill on storage, now sitting at 11TB total across all the SSDs XD Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M Link to comment Share on other sites More sharing options...
AXA Posted April 3, 2022 Author Share Posted April 3, 2022 updated the post with a new cyberpunk video showcasing the performance increase with FSR, however bare in mind, the recording resulted in a performance hit of 5-7fps with the ultra preset and roughly 8-10fps with the high preset. When using Digital Foundry's optimized settings with FSR ultra i consistently get 40-45fps. This is probably the last edit ill make unless i end up getting a RTX card sometime in the future or upgrade to a XM chip. Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M Link to comment Share on other sites More sharing options...
AXA Posted May 6, 2022 Author Share Posted May 6, 2022 Probably my final update to this unless i do a serious hardware change, but added a playlist of various games which will be updated over time for those who want to gauge the performance of the Quadro P4000 if you are still on the fence about upgrading etc 1 Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M Link to comment Share on other sites More sharing options...
Mr. Wind Posted August 29 Share Posted August 29 Hİ, First of all, congratulations, you did a great job. Where can I find this part? Link to comment Share on other sites More sharing options...
Maro97 Posted August 29 Share Posted August 29 I just found this on AliExpress: US $0.99 | 5pcs FFC FPC Socket 0.5mm Vertical Type Ribbon Flat Connector 4/6/8/10/12/14/16/20/24/30/34/40/50 Pin https://a.aliexpress.com/_mLPnul7 Link to comment Share on other sites More sharing options...
Maro97 Posted August 29 Share Posted August 29 I bought from this seller my 0.5mm pitch 30 pins to change my broken one in my M18x r2 Link to comment Share on other sites More sharing options...
Maro97 Posted August 29 Share Posted August 29 I ordered it 3 years ago at 8 Nov 2022 😁 Link to comment Share on other sites More sharing options...
2CPU Posted August 30 Share Posted August 30 Damn reminds me of my m15x which took me from XXX to 680M to 980M. Vivid memories of playing VR w my friends and even my boss during Xmas so long ago. Link to comment Share on other sites More sharing options...
