55 minutes ago, Annihilator said:
ok, putted the P5200 in n nothing happen, same issues like with the GTX 880M, not even shown in BIOS, full bios reset etc. done but nothing, the card getting power, heatsink was still warm as i opened the m6800 again....
edit: putted the m6100 back in to test, same issue... maybe mainboard broken? O_o
Remove the CMOS battery, hold the power button for 30 seconds and then try again with the M6100.
will try later, putted the P5200 in my 7720 n works flawless, just doin some benchmarks 🙂
no soo bad for totally unoptimized atm:
NVIDIA Quadro P5200 Grafikkarten Benchmark Resultat - Intel Core i7-7820HQ Processor,Dell Inc. 0F2JMF
Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro
On 2/15/2026 at 6:49 AM, DynamiteZerg said:
Any idea when the more expensive option would be out?
Update: The M6800 GPU heatsink I ordered from ebay has just arrived at my doorstep! Shipping sure is quick! But that's because I'm in Singapore and shipping from China only takes 1-2 days... 😆
It doesn't fit when I put the palmrest.......
Please help, I upgraded to an i7 4910mq, it doesn't work. There are 3 LEDS on the corner of the PC. 1 IS ON, 2ND IS BLINKING AND 3RD IS OFF.
Edit: it's a RAM module error but after swapping to an i7 4700MQ, all the RAM (4/4) are recognized...
Edited by SuperMG
4x 8GB?
maybe the IMC of the 4700 has a better bin then the one from the 4910. do u tried only 2 modules or 4x4GB? possible the IMC from the 4910 has probs with 4x dual-rank(8GB) modules
1 hour ago, Annihilator said:
4x 8GB?
I tested with everything, 1R8, 2R8. It doesn't like dual channel... Waited for nothing and 35€ gone 😞
The heatsink: max 83C core temp, stable TDP (no 40W TDP bug). 150W then 130W then 120W (because of thermal throttling). I didn't use PTM7950 yet and the fan area wasn't really open for intake. Sadly the palmrest won't close because of the heatsink....
3rd heatpipe too much?
No, it's maybe the thickness of it but it's the same thickness as the OEM one, mmmh.
strange
n think i only need a new heatsink in the 7720 when i would put an RTX card in bcs temps r really good(P5200 @ 110W max. 59°c. CPU max. 73°c. at 26°c. ambient temp. - used arctic mx-7 for both)
On 2/5/2026 at 11:15 PM, DynamiteZerg said:
You can get the BE200HMW, it works directly in our usual WLAN card slot without having to go through any adaptor. It supports WIFI 7 and Bluetooth v5.4.
I have one on my M6800!
Just got one of those for my M6800, without antennas, because I really didn't want to take the screen apart too, to swap them out, and now I'm having some problems.
https://www.amazon.com/8774Mbps-Gigabit-Interface-Bluetooth-BE200HMW/dp/B0DNZS761K?th=1
Ubuntu Studio 24.04 LTS booted right up with the new card, but it didn't see any WiFi at all.  lspci says:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-LM (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d4)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d4)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d4)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d4)
00:1c.6 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #7 (rev d4)
00:1c.7 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #8 (rev d4)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM87 Express LPC Controller (rev 04)
00:1f.2 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GP104GLM [Quadro P5000 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
03:00.0 Network controller: Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
11:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
I swapped back to the old card, and it wouldn't boot.  Got stuck on the second Ubuntu Studio splash screen, after auto-login, for loading the user's settings.  Same with no card, and even with the new card again!  It was rock-solid reliable before!  The BIOS says with the new card:
I finally got it to boot again, with the new card, though I don't know how or why.  Didn't change anything.  And I still don't have WiFi.  Fortunately, my home dock is wired, and that still works, but I do need WiFi when I take it places.
Any ideas?
16 hours ago, Annihilator said:
strange
The only way the palmrest can close it by removing the top left PCB for the sound system... . I even removed one metallic piece that was on its way but that didn't fix the issue. I even removed the 3mm thick thermal pad that was on the mobo
Does anyone knows what is the max dimensions of the MXM card that can be fitted into the M6800?
I am currently discussing with several sellers on Taobao for RTX3080 16GB MXM cards. There's 2 versions that the seller have and one is longer. The shorter version is out of stock at the moment and so is his RTX4090. He does have RTX5000 16GB MXM cards though.
I also just read SuperMG's post above that the new heatsink doesn't fit properly... hmm...
Hello.
Yes the first version have very bad curves.
There's a fixed one, the new 4 heatpipes GPU heatsink and 2 heatpipes Alienware 17 R1 Ranger style CPU heatpipes for the M6800. He finished it. I'll get it in 10 days.
On 2/18/2026 at 1:26 AM, AaronD said:
It appears to be a software issue, as evidenced by the BIOS seeing it, and the output of the Ubuntu community's Wireless Info Script:
https://github.com/UbuntuForums/wireless-info
https://drive.google.com/file/d/1hDamjIeDjaBPvvXzgR65BeXS4hg3Ec9n/view?usp=sharing
So I posted a question over there.  We'll see what they come up with.
Still don't have a good answer to *why*, but it appears to require a version number of firmware that never existed.
Apparently these things don't actually remember their own firmware, but require the OS to push it back into them on every startup, which is fine as long as the OS does have good firmware for it.  If Windows does, then it "just works" over there.  But it appears that either Linux doesn't yet, or gets confused about what's actually required.  Either way, it fails, which results in no WiFi at all.
I put the original back in, just to have *something*.
Please, can you tell me what's the price of these cards (RTX 3080, RTX 5000)?
RTX 5000 (HP) is like between 650-1000€.
RTX 3080 (X-VSION, DP in DP_D): 550-600€ + need backlight mod cable (++€) + need custom M6800 GPU heatsink (++€)
16 hours ago, SuperMG said:
Hello.
Are you able to share where you are getting it?
DIY for Dell Precision M6800 GPU heatsink | eBay
On 3/20/2026 at 9:20 AM, SuperMG said:
This is the 3 heatpipes version, I got the 4 heatpipes version + a new CPU heatsink. Had to pay extra 95USD on top of the 100 I paid initially for the badly made, first edition 3 heatpipes one.
You got the 4 heatpipes version + a new CPU heatsink from the same seller as the 3 heatpipes?
If that's the case, then I need to reach out to him.
10 hours ago, DynamiteZerg said:
You got it from the same seller? If that's the case, then I need to reach out to him.
yeah, he made me a RTX heatsink for my 7720 too...
I meant in chinese yuan (¥), but thank you anyway
I just dived in and bought an NVIDIA GeForce RTX 4090 Laptop GPU from a seller in Taobao and he is working together with me to try to get it working on the M6800. He seems fairly knowledgeable as well.
I should get it in a few days' time and see how it works out. However, I need to make sure the new GPU heatsink that I got from eBay is the newer version that works with the M6800 unlike the older version that SuperMG got from the same seller.
If it works, I will have a few cards to sell... P5000 for the M6800 and a P5200 which I have yet to flash with the vbios that works with the M6800 and an RTX3000.
Hello...
I already made the tests. Precision M6800 eDP with RTX 4080, 4070 works so 4090 will work too but you need the backlight mod cable that I'm selling. You also need to set the BIOS to UEFI and Legacy OPROM to disabled.
You also need a custom powerful 4 heatpipes heatsink from Cicichen.
I REALLY HOPE, YOU BOUGHT THE ZRT CARD! Please confirm!!! We need the VBIOS of the ZRT card! Thank you. X-vsion Vbios is bad and needs EDID override in the OS.
Please man ask the seller if he has RTX 4080 135W/150W and 4090 135W/150W VBIOSes please... They have good eDP support for the Windows drivers. Only the 4060, 4070 from X-VSION have good eDP support the 4080/4090 nope
