DynamiteZerg Posted March 24 Posted March 24 I'm uploading the images I got from the seller. Not sure what brand this is but it is a 150W card. I will ask the seller the manufacturer's name and take clearer pictures. Where are you selling the cable mod? @SuperMG Update: Seller just confirmed it is made by ZRT! So now we can get the vbios!
SuperMG Posted March 24 Posted March 24 11 minutes ago, DynamiteZerg said: I'm uploading the images I got from the seller. Not sure what brand this is but it is a 150W card. I will ask the seller the manufacturer's name and take clearer pictures. Where are you selling the cable mod? @SuperMG Update: Seller just confirmed it is made by ZRT! So now we can get the vbios! IT'S ZRT OMG. Please GET THE VBIOSES!! I want to flash on 4080 and 4090 so we can avoid the EDID override method!! Same design as ZRT 100%, not x-vsion, the BIOS chip is in a different place 1
DynamiteZerg Posted March 24 Posted March 24 10 minutes ago, SuperMG said: IT'S ZRT OMG. Please GET THE VBIOSES!! I want to flash on 4080 and 4090 so we can avoid the EDID override method!! Same design as ZRT 100%, not x-vsion, the BIOS chip is in a different place Looks like we have a winner on our hands! I'll ask the seller if he can help to extract the vbios from the card first and shared it with me. 1
SuperMG Posted March 24 Posted March 24 (edited) 26 minutes ago, DynamiteZerg said: Looks like we have a winner on our hands! I'll ask the seller if he can help to extract the vbios from the card first and shared it with me. The seller needs to use GPU-Z and extract from there. He can do it for the 4080 too. It'll generate a download link from techpowerup Because ZRT and other people ignored me for 5 months. I've been trying to get their VBIOSes for 5 months... I just hope the images you got are indeed the right GPU and not the x-vsion one. Do you have the VBIOS version number or a GPU-Z screenshot? For myself I need the 4080 150W VBIOS and 4090 150W VBIOS. But if the seller could dump 135W Max-Q versions why not, everyone will be happy. Edited March 24 by SuperMG
SuperMG Posted March 24 Posted March 24 (edited) On 3/20/2026 at 2:16 AM, Annihilator said: DIY for Dell Precision M6800 GPU heatsink | eBay This is the better version if you're planning to use 150W cards (with PTM7950) + better designed CPU heatsink like the Alienware 17 R1 Ranger design, so better overclocking for the CPU right? Mine will arrive this week, maybe on Friday? It means I'll have a spare "130W" 3 heatpipes that has one badly curved heatpipe. If someone wants it, I can list it for 45€ and then you can modify the heatpipes if you want. @DynamiteZergI sell them on ebay. This is version 1. It allows backlight enable and makes the internal display work again. The newer RTX cards don't have the backlight pins connected from the core. Edited March 24 by SuperMG 2
JadeRover Posted March 24 Posted March 24 5 hours ago, SuperMG said: This is the better version if you're planning to use 150W cards (with PTM7950) + better designed CPU heatsink like the Alienware 17 R1 Ranger design, so better overclocking for the CPU right? Did you managed to get CPU overclocking working ? Also memory overclocking should be possible on m6800. Looking at the IFR extract, with setup_var from grub you can change related profiles to enable XMP on you ram modules. You can also write custom XMP profiles to your non XMP ram sticks, up to 2400Mhz DDR3 if you are feeling lucky ! Writing to DDR3 spd is a lot easier than DDR4 spd btw. Here is a link to the guides and tools + proof that someone got 2400Mhz working on i7-4810mq Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
SuperMG Posted March 24 Posted March 24 4 minutes ago, JadeRover said: Did you managed to get CPU overclocking working ? Also memory overclocking should be possible on m6800. Looking at the IFR extract, with setup_var from grub you can change related profiles to enable XMP on you ram modules. You can also write custom XMP profiles to your non XMP ram sticks, up to 2400Mhz DDR3 if you are feeling lucky ! Writing to DDR3 spd is a lot easier than DDR4 spd btw. Here is a link to the guides and tools + proof that someone got 2400Mhz working on i7-4810mq Can't get 4GHz on all cores so no. I'll test the new heatsink soon
Annihilator Posted March 24 Posted March 24 1 hour ago, SuperMG said: Can't get 4GHz on all cores so no. I'll test the new heatsink soon running into the 61W TDP limit from the board? Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted March 24 Posted March 24 33 minutes ago, Annihilator said: running into the 61W TDP limit from the board? No, running into 45W TDP limit in CPU-Z. 61W is good for me. Using 240W PSU. Getting "EDP CURRENT" error in throttleStop.
Annihilator Posted March 24 Posted March 24 14 minutes ago, SuperMG said: No, running into 45W TDP limit in CPU-Z. 61W is good for me. Using 240W PSU. Getting "EDP CURRENT" error in throttleStop. yeah EDP is set by the mainboard... but the limit in the M6800 should be 61W for normal... maybe a dead VRM? Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted March 24 Posted March 24 8 minutes ago, Annihilator said: yeah EDP is set by the mainboard... but the limit in the M6800 should be 61W for normal... maybe a dead VRM? I get 56W max in throttleStop benchmark so I don't know , no bsod
Annihilator Posted March 24 Posted March 24 15 minutes ago, SuperMG said: I get 56W max in throttleStop benchmark so I don't know , no bsod yeah, when VRM temps too high will throttle down the EDP, on the 7720 the VRMs seems to be well cooled, no EDP throttling but still not summer here, pretty sure will happen when temps goin up. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
BYTEHAT248 Posted March 25 Posted March 25 (edited) Tell me, is this fast. I was recording it with my phone but it blew the surge protector on my power strip at 68%. This was with a 330W Adapter. This was done on a AMD FirePro M6100, With a fork of the Mystery Magic V2 VBIOS (1188/1500), I then overclocked it more to 1306/1732 (Core/VRAM). Now I have not finished the fork of the VBIOS, I still need to give it more voltage and loosen the timings on the VRAM a bit, which i will then see if it can handle 1350/1800.I do also need to get new thermal pads and paste for it.I was running the benchmark on Fedora 43 Edited March 25 by BYTEHAT248
SuperMG Posted March 26 Posted March 26 On 3/24/2026 at 4:38 PM, SuperMG said: This is the better version if you're planning to use 150W cards (with PTM7950) + better designed CPU heatsink like the Alienware 17 R1 Ranger design, so better overclocking for the CPU right? Mine will arrive this week, maybe on Friday? It means I'll have a spare "130W" 3 heatpipes that has one badly curved heatpipe. If someone wants it, I can list it for 45€ and then you can modify the heatpipes if you want. Hello here are the results with the new 4 HEATPIPES GPU heatsink. Heaven Benchmark 4.0 (1080p Ultra): 258FPS average Temperature max GPU: 77.5C Temperature max hot spot: 86.5C Max core frequency: 2385MHz Max TDP: 149W FurMark 1 minute 1.37 (1080p): 306FPS average Temperature max GPU: 81.6C Temperature max hot spot: 92.8C Max core frequency: 2370MHz Max TDP: 153W TimeSpy (1080p): GPU Score: 16090 Temperature max GPU: 81C Temperature max hot spot: 92C Max core frequency: 2370MHz Max TDP: 152W No thermal throttles. The only limit is the Power Supply if we run the laptop without battery. The power LED blinks orange and white. To fix that, I need to use a 330W PSU and use a Core i7 4910MQ, since the 4940MX it's useless, uses 10W more and can't overclock well on the M6800. And optionally: use a 135W VBIOS if we can find one... Maybe @DynamiteZergcan get one from ZRT. With the 4910MQ you have turbo bins and can use 3.9GHz all cores with grub, right @JadeRover? 1
DynamiteZerg Posted March 26 Posted March 26 7 hours ago, SuperMG said: Hello here are the results with the new 4 HEATPIPES GPU heatsink. Heaven Benchmark 4.0 (1080p Ultra): 258FPS average Temperature max GPU: 77.5C Temperature max hot spot: 86.5C Max core frequency: 2385MHz Max TDP: 149W FurMark 1 minute 1.37 (1080p): 306FPS average Temperature max GPU: 81.6C Temperature max hot spot: 92.8C Max core frequency: 2370MHz Max TDP: 153W TimeSpy (1080p): GPU Score: 16090 Temperature max GPU: 81C Temperature max hot spot: 92C Max core frequency: 2370MHz Max TDP: 152W No thermal throttles. The only limit is the Power Supply if we run the laptop without battery. The power LED blinks orange and white. To fix that, I need to use a 330W PSU and use a Core i7 4910MQ, since the 4940MX it's useless, uses 10W more and can't overclock well on the M6800. And optionally: use a 135W VBIOS if we can find one... Maybe @DynamiteZergcan get one from ZRT. With the 4910MQ you have turbo bins and can use 3.9GHz all cores with grub, right @JadeRover? It looks like we have a winner here! I need to wait for the eBay seller to make the same heatsink setup for me!
SuperMG Posted March 27 Posted March 27 25 minutes ago, DynamiteZerg said: It looks like we have a winner here! I need to wait for the eBay seller to make the same heatsink setup for me! But... The palmrest doesn't fit and close too... Still the same issue as before because of the VOLUME CONTROL LED board... 1
DynamiteZerg Posted March 27 Posted March 27 That sucks... But we don't really need the volume control we do need the LED board to see the status.
DynamiteZerg Posted March 27 Posted March 27 @SuperMG @Annihilator @Aaron44126 What's the fastest mxm card we can deploy in a M6800 LVDS setup without the mux limiting the performance of the mxm card? P5200? RTX5000? Or?
SuperMG Posted March 27 Posted March 27 2 hours ago, DynamiteZerg said: @SuperMG @Annihilator @Aaron44126 What's the fastest mxm card we can deploy in a M6800 LVDS setup without the mux limiting the performance of the mxm card? P5200? RTX5000? Or? M5000M and 980M
Aaron44126 Posted March 27 Posted March 27 5 hours ago, DynamiteZerg said: What's the fastest mxm card we can deploy in a M6800 LVDS setup without the mux limiting the performance of the mxm card? 3 hours ago, SuperMG said: M5000M and 980M Yes, those are the ones. I don't know if you could fit a full fat 980 in (without the "M"), IIRC is it a weird shape and requires an extra power connector. Everything newer than that is eDP only. [Edit] This is the GeForce 980 (no "M"). Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 26 "Tahoe" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
SuperMG Posted March 27 Posted March 27 12 minutes ago, Aaron44126 said: Yes, those are the ones. I don't know if you could fit a full fat 980 in (without the "M"), IIRC is it a weird shape and requires an extra power connector. Everything newer than that is eDP only. [Edit] This is the GeForce 980 (no "M"). It needs external power, so no.
JadeRover Posted March 27 Posted March 27 3 hours ago, SuperMG said: It needs external power, so no. That's a easy fix, solder big wires from the main power rail (19.5v after 2nd Mosfet) to the power pins of the GPU, GPU is fed main power rail through the MXM slot anyway. 23 hours ago, SuperMG said: With the 4910MQ you have turbo bins and can use 3.9GHz all cores with grub, right Even up to 4.3Ghz all core see the comments at the bottom of this page : Intel Core i7-4910MQ Mobile processor - CW8064701474105 / BX80647I74910MQ This is because this is a "900" series CPU, just like 6920HQ and 7920HQ, these have +6 turbo bins VS the +4 on other i7 mobile CPUs But it sounds like you were hitting a hard power limit/current limit so bumping the turbo bins won't do you much good. Power limit editing on my m6700 worked great, can't help you more from what we said in PM with the m6800 as I don't have the machine (nor the m4800 that should have a similar implementation of power/current limit in the bios) Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
SuperMG Posted March 27 Posted March 27 (edited) 1 hour ago, JadeRover said: That's a easy fix, solder big wires from the main power rail (19.5v after 2nd Mosfet) to the power pins of the GPU, GPU is fed main power rail through the MXM slot anyway. Even up to 4.3Ghz all core see the comments at the bottom of this page : Intel Core i7-4910MQ Mobile processor - CW8064701474105 / BX80647I74910MQ This is because this is a "900" series CPU, just like 6920HQ and 7920HQ, these have +6 turbo bins VS the +4 on other i7 mobile CPUs But it sounds like you were hitting a hard power limit/current limit so bumping the turbo bins won't do you much good. Power limit editing on my m6700 worked great, can't help you more from what we said in PM with the m6800 as I don't have the machine (nor the m4800 that should have a similar implementation of power/current limit in the bios) But the 900 series have a lower designed TDP and at 58W I'll get more performance than what the 4940MX did at 58W in throttleStop bench... The 4900MQ can do 4.2GHz on all cores, so 4GHz on all cores could be more stable and possible than the 4940MX in the M6800? Edit: I undervolted to -80mV and I was able to get 3.7GHz on all cores, instead of 3.6GHz with -40mV. Interesting... Still low, if I had a 4900MQ, maybe I can get 4GHz easily Edited March 27 by SuperMG
JadeRover Posted March 27 Posted March 27 Yes, that is because you are being power/current limited. By undervolting, the CPU can reach higher clocks for the same power/current, you need to investigate all power limiting factors, but in your case it sounds more like current limit as throttlestop shows "EDP other" limit reason Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
SuperMG Posted March 27 Posted March 27 2 minutes ago, JadeRover said: Yes, that is because you are being power/current limited. By undervolting, the CPU can reach higher clocks for the same power/current, you need to investigate all power limiting factors, but in your case it sounds more like current limit as throttlestop shows "EDP other" limit reason Yes and I can't increase that. So it's better having a 4900MQ that's 47W than the 4940mx that's 57W...
