FrancoTecno Posted January 12 Posted January 12 hello, here trying to make my own custom nahimic drivers. i am on a MSI GT60 with ALC892, why i need APO3 and not APO4? where i can find the lastest realtek drivers with lastest nahimic APO3 driver? because always i get nahimic not working due to microsoft store automatic update MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 OK, FINALLY I MANAGED A MODIFICATION TO MAKE THIS MODDED DRIVER WORKING WITH THE LASTEST NAHIMIC VERSION! (AT LEAST ON APO3), SOON I AM SHARING MY OWN MODDED DRIVERS WITH @solidus1983 SAME INSTALLER! MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 with newer realtek codec drivers i get some bugs, after powering on the notebook from an S3 state (suspend), i dont have longer audio. now i am testing lastest nahimic UWP app with 2023 realtek driver from the lastest solidus mod and 2024 APO3 driver, the main difference due this mod packed 2023 APO3 dont work on lastest UWP app is because in device manager newer driver appears as different type of device, thats why newer UWP`versions of nahimic dont work with 2023 APO3 nahimic driver. MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 i can add an compatible APO4 driver with newer UWP app and keep older 2023 codec driver to maintain an stable version, due i am not 100% expert to make a fully update of this, but i dont think newer codec drivers makes a high difference really MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 as well, i added the latest UWP app into the installer, Nahimic 1.10.9.0 version from this 2026, i need to test this more further and soon i can upload this stable version to dont get problems due to windows update updating nahimic with the older driver. MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 and really, my msi GT60 2OC with ALC892 and a dedicated audio AMP on board sounds amazing with nahimic. originally this laptop uses soundblaster cinema and boosts audio quality similar to nahimic, but its more basic due its a 2013 software. this nahimic mod its a good enhance! I especially want to thank Solidus for doing this work, and I'll be uploading the fixed version soon. MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 12 Posted January 12 older script dont delete newer APOs drivers fine, and when reinstalling cause failure on nahimic working. i am seeing some registry differences, because driver is correctly deleted (at left, older APO driver, on the right newer one) MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 14 Posted January 14 Made By: solidus1983 (hacktrix2006) and djlenior, Updated by FrancoTecno Status: Untested Release Repack: Yes Downgrade/Update: Update and Hotfix Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookTalk or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems! Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread! FrancoTecno comment; due its a RAR file, i dont submit a VirusTotal test. you can manually inspect files and code from this or scan it with virus total, main source code is created by @solidus1983. i only modified it to make this working in 2026. Installer: Download Here (ONLINE!) Package includes: Realtek UAD 6.0.1.9585.1 Nahimic 1.10.9.0 UWP Nahimic SWC 3.7.2.0 (APO3) Nahimic SWC 4.11.6.0 (APO4) Nahimic Extension 1.1.44.0 (APO3) Nahimic Extension 1.5.51.0 (APO4) Nahimic Mirroring Driver 2.0.5.0 Realtek Audio Console UWP 1.32.261.0 For Windows 10 Build: 21H1/22H2 For Windows 11 Builds (But may be issues) Change Log : Updated Nahimic SWC on APO3 and APO4 Updated Nahimic Extension on APO4 only Updated Nahimic UWP app Modified Uninstall Script Minor text details Supported Systems with this driver pack: Same as latest Solidus release (See page 9 at latest solidus release) Install instructions: Disconnect from the internet. (Not Required, so very Optional) Reboot System and Enter BIOS/UEFI. Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer! Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!). Uncompress .ZIP file and Run "Launch.EXE" Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3. Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again! Now head back into your BIOS/UEFI and Re-enable SecureBoot!! Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet) ***[IMPORTANT]**** As i no longer have a MSI Laptop with APO4. This hotfix and update was tested only in APO 3. I wait user results and testing. This hotfix release is mainly to fix APO3 buggy and outdated driver causing problems in newer Nahimic UWP app versions. I await user feedback and help to release more updated and better builder versions. this is a It's a hotfix released rather quickly without so much elaboration. Expect bugs for this release 2 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted January 14 Posted January 14 I'm waiting to hear from users here who want to collaborate on releasing more updated and better-developed versions. I'm not a programmer, just an enthusiast. I'm doing this quick fix so you can continue enjoying the modification. In case of another hotfix or minor update, I'll release it. I use my MSI GT60 with this software every day. 2 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
epguy3 Posted January 29 Posted January 29 nice. why not update the Nahimic APO4 driver to either 4.15.3.0 or 4.15.4.0, FrancoTecno? or at least the 4.11.6.2 version of the APO4 driver {this one is specifically available from the MSI web site, which seems to be a "hotfix" version of 4.11.6.0} the 4.15.3.0 & higher versions of the APO4 driver no longer include the somewhat annoying "Nahimic companion" app, which was dropped starting from the 4.15.3.0 release.
FrancoTecno Posted February 2 Posted February 2 On 1/28/2026 at 11:41 PM, epguy3 said: nice. why not update the Nahimic APO4 driver to either 4.15.3.0 or 4.15.4.0, FrancoTecno? or at least the 4.11.6.2 version of the APO4 driver {this one is specifically available from the MSI web site, which seems to be a "hotfix" version of 4.11.6.0} the 4.15.3.0 & higher versions of the APO4 driver no longer include the somewhat annoying "Nahimic companion" app, which was dropped starting from the 4.15.3.0 release. you have hardware to test APO4 releases? i have only APO3 compatible device MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
Ricardo_estep Posted March 8 Posted March 8 (edited) FrancoTecno, i have just tested your driver pack and it works pretty nice. Effects keep working while "Windows Store" don't ask for more updating. Thanks a lot for the update! 🫡 I think that updating "Realtek HD drivers" maybe will work the same way as you did with "Nahimic", but adding all the "HWIDs" on the driver itself... And without the solidus1983 original list, it could be hard to apply on the files to work... 🤔 PD: "MSI GT72VR 6RE Tobii" - "Windows 11 25H2 26200.7922" -- all software blocks. 🫂 Edited March 8 by Custom90gt F word not needed here
FrancoTecno Posted March 8 Posted March 8 i tested pasting all HWIDs on newer drivers but works buggy. the main issue was the nahimic driver. an newer audio driver dont give better features. but if anyone know how i can make it working with lastest driver i can try making a new pack. I'm glad it was helpful, and let me know if you have any questions or suggestions. 4 hours ago, Ricardo_estep said: FrancoTecno, i have just tested your driver pack and it works pretty nice. Effects keep working while "Windows Store" don't ask for more updating. Thanks a lot for the update! 🫡 I think that updating "Realtek HD drivers" maybe will work the same way as you did with "Nahimic", but adding all the "HWIDs" on the driver itself... And without the solidus1983 original list, it could be hard to apply on the files to work... 🤔 PD: "MSI GT72VR 6RE Tobii" - "Windows 11 25H2 26200.7922" -- all software blocks. 🫂 MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
solidus1983 Posted March 16 Author Posted March 16 @FrancoTecno, Nice work bud. How much hassle was it. I still have the VM i used to make the drivers with all the files if you need the HWID list. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
FrancoTecno Posted March 17 Posted March 17 1 hour ago, solidus1983 said: @FrancoTecno, Nice work bud. How much hassle was it. I still have the VM i used to make the drivers with all the files if you need the HWID list. if you can give me it, i appreciate MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
solidus1983 Posted March 18 Author Posted March 18 @FrancoTecno Here you go directly taken from the VM Nahimic_ID_Files.zip {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
FrancoTecno Posted March 20 Posted March 20 On 3/18/2026 at 6:33 PM, solidus1983 said: @FrancoTecno Here you go directly taken from the VM Nahimic_ID_Files.zip 2.27 kB · 1 download MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
FrancoTecno Posted March 20 Posted March 20 thanks! how do you use the virtual machine to test releases? explain me a little bit On 3/18/2026 at 6:33 PM, solidus1983 said: @FrancoTecno Here you go directly taken from the VM Nahimic_ID_Files.zip 2.27 kB · 1 download MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
