raptorddd Posted May 9, 2022 Posted May 9, 2022 am not sure if this is the right place to post this.. is there a place i can get help finding out why my laptop shut down.? or if someone that knows how to read minidump in here.? it shuts down while am watching you tube. am using edge. this happens once in a while.. 050722-6156-01.dmp dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
jaybee83 Posted May 9, 2022 Posted May 9, 2022 when it shuts down, what is the behaviour like? is it an instant shut off? or does windows suddenly decide to initiate the shutdown procedure? have u checked component temperatures (i.e. via HWInfo) when shutdowns happen? when was the last time u serviced your laptop (cleaning out dust, repaste, etc.)? do the shutdowns only happen on battery or on AC power? or both? all this will help us dial down the range of potential culprits. 2 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
raptorddd Posted May 10, 2022 Author Posted May 10, 2022 10 hours ago, jaybee83 said: when it shuts down, what is the behaviour like? is it an instant shut off? or does windows suddenly decide to initiate the shutdown procedure? have u checked component temperatures (i.e. via HWInfo) when shutdowns happen? when was the last time u serviced your laptop (cleaning out dust, repaste, etc.)? do the shutdowns only happen on battery or on AC power? or both? all this will help us dial down the range of potential culprits. instant shut off. event viewer says 6008 i open minindump says DRIVER_POWER_STATE_FAILURE (9f) A driver has failed to complete a power IRP within a specific time. Arguments: Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp subsystem. Arg2: 000000000000012c, Timeout in seconds. Arg3: ffffe703427a9040, The thread currently holding on to the Pnp lock. Arg4: ffffbc010e637880, nt!TRIAGE_9F_PNP on Win7 and higher yes i use realtemp and when it happens they are around 40-50-60c i use log and when it happens temps are fine. clean service like 4 days ago. i have no battery. i can run stress test temps go upto 88c i also found this. i dont know how to read minidump HARDWARE_ID: {5d624f94-8850-40c3-a3fa-a4fd2080baf3}\vwifimp_wfd IMAGE_NAME: vwifibus.sys MODULE_NAME: vwifibus FAULTING_MODULE: fffff80546dd0000 vwifibus 1 dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
jaybee83 Posted May 10, 2022 Posted May 10, 2022 7 hours ago, raptorddd said: instant shut off. event viewer says 6008 i open minindump says DRIVER_POWER_STATE_FAILURE (9f) A driver has failed to complete a power IRP within a specific time. Arguments: Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp subsystem. Arg2: 000000000000012c, Timeout in seconds. Arg3: ffffe703427a9040, The thread currently holding on to the Pnp lock. Arg4: ffffbc010e637880, nt!TRIAGE_9F_PNP on Win7 and higher yes i use realtemp and when it happens they are around 40-50-60c i use log and when it happens temps are fine. clean service like 4 days ago. i have no battery. i can run stress test temps go upto 88c i also found this. i dont know how to read minidump HARDWARE_ID: {5d624f94-8850-40c3-a3fa-a4fd2080baf3}\vwifimp_wfd IMAGE_NAME: vwifibus.sys MODULE_NAME: vwifibus FAULTING_MODULE: fffff80546dd0000 vwifibus ok, so far so good. this seems to be driver related, possibly a faulty driver or component hanging up the system. did you recently install any new components or drivers? when did this start happening? ideally we could fix this by returning your system to an earlier state via system restore. 2 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Eban Posted May 10, 2022 Posted May 10, 2022 Could try this. I installed it but have not had a crash so never tested. https://www.resplendence.com/whocrashed 2 Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
jaybee83 Posted May 10, 2022 Posted May 10, 2022 7 minutes ago, Eban said: Could try this. I installed it but have not had a crash so never tested. https://www.resplendence.com/whocrashed sure, go ahead and lets see if we can get a bit more info 🙂 1 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
raptorddd Posted May 11, 2022 Author Posted May 11, 2022 17 hours ago, jaybee83 said: ok, so far so good. this seems to be driver related, possibly a faulty driver or component hanging up the system. did you recently install any new components or drivers? when did this start happening? ideally we could fix this by returning your system to an earlier state via system restore. ssd. like less than a month. but it has happened before this. i happens but like maybe in 1 week or more. not sure when it started. i just clean installed windows like 3 weeks ago, 16 hours ago, Eban said: Could try this. I installed it but have not had a crash so never tested. https://www.resplendence.com/whocrashed thanks ill try this and will repot back if i get a shut off. dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
raptorddd Posted May 11, 2022 Author Posted May 11, 2022 Crash Dump Analysis Crash dumps are enabled on your computer. Crash dump directories: C:\Windows C:\Windows\Minidump On Sat 5/7/2022 11:50:53 PM your computer crashed or a problem was reported Crash dump file: C:\Windows\MEMORY.DMP (Kernel memory dump) Bugcheck code: 0x9F(0x4, 0x12C, 0xFFFFE703427A9040, 0xFFFFBC010E637880) Bugcheck name: DRIVER_POWER_STATE_FAILURE Driver or module in which error occurred: intelppm.sys (intelppm+0x138f) File path: C:\Windows\System32\drivers\intelppm.sys Description: Processor Device Driver Product: Microsoft® Windows® Operating System Company: Microsoft Corporation Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. Analysis: The power state transition timed out waiting to synchronize with the PnP subsystem. This is likely caused by a hardware problem, but there is a possibility that this is caused by a misbehaving driver. This bugcheck indicates that a timeout has occurred. This may be caused by a hardware failure such as a thermal issue or a bug in a driver for a hardware device. Read this article on thermal issues A full memory dump will likely provide more useful information on the cause of this particular bugcheck. The crash took place in a Microsoft module. The description of the module may give a hint about a non responding device in the system. On Sat 5/7/2022 11:50:53 PM your computer crashed or a problem was reported Crash dump file: C:\Windows\Minidump\050722-6156-01.dmp (Minidump) Bugcheck code: 0x1000009F(0x4, 0x12C, 0xFFFFE703427A9040, 0xFFFFBC010E637880) Bugcheck name: CUSTOM_ERROR Analysis: Conclusion 2 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you. Read the suggestions displayed in the bugcheck analysis above. The analysis process took 0:00:05 (h:mm:ss). dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
jaybee83 Posted May 11, 2022 Posted May 11, 2022 5 hours ago, raptorddd said: Crash Dump Analysis Crash dumps are enabled on your computer. Crash dump directories: C:\Windows C:\Windows\Minidump On Sat 5/7/2022 11:50:53 PM your computer crashed or a problem was reported Crash dump file: C:\Windows\MEMORY.DMP (Kernel memory dump) Bugcheck code: 0x9F(0x4, 0x12C, 0xFFFFE703427A9040, 0xFFFFBC010E637880) Bugcheck name: DRIVER_POWER_STATE_FAILURE Driver or module in which error occurred: intelppm.sys (intelppm+0x138f) File path: C:\Windows\System32\drivers\intelppm.sys Description: Processor Device Driver Product: Microsoft® Windows® Operating System Company: Microsoft Corporation Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. Analysis: The power state transition timed out waiting to synchronize with the PnP subsystem. This is likely caused by a hardware problem, but there is a possibility that this is caused by a misbehaving driver. This bugcheck indicates that a timeout has occurred. This may be caused by a hardware failure such as a thermal issue or a bug in a driver for a hardware device. Read this article on thermal issues A full memory dump will likely provide more useful information on the cause of this particular bugcheck. The crash took place in a Microsoft module. The description of the module may give a hint about a non responding device in the system. On Sat 5/7/2022 11:50:53 PM your computer crashed or a problem was reported Crash dump file: C:\Windows\Minidump\050722-6156-01.dmp (Minidump) Bugcheck code: 0x1000009F(0x4, 0x12C, 0xFFFFE703427A9040, 0xFFFFBC010E637880) Bugcheck name: CUSTOM_ERROR Analysis: Conclusion 2 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you. Read the suggestions displayed in the bugcheck analysis above. The analysis process took 0:00:05 (h:mm:ss). Go ahead and try these steps here with regards to intelppm.sys: https://thegeekpage.com/fix-blue-screen-error-intelppm-sys-in-windows-10/ Sounds to me like some files might have been corrupted. Either that or its some kind of hardware failure causing the respective drivers to hiccup and timeout. 2 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Vasudev Posted May 26, 2022 Posted May 26, 2022 I'd suggest installing Intel chipset driver and uinstalling dptf driver if its present. Are you using any third party power plan optimizer that is interfering intel speedstep driver? 1 Vasudev Menon YouTube Channel
raptorddd Posted May 26, 2022 Author Posted May 26, 2022 1 hour ago, Vasudev said: I'd suggest installing Intel chipset driver and uinstalling dptf driver if its present. Are you using any third party power plan optimizer that is interfering intel speedstep driver? hi. i did the other suggestion but the turbo boost was disaabled not sure. i checked frequencies and stayed at stock. right now i havent faced any shut offs. maybe because while watching you tube i keep clicking on task bar with mouse button. so you suggest to use the dell driver.... i dont know what is dptf.? 1 dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
Vasudev Posted May 28, 2022 Posted May 28, 2022 On 5/27/2022 at 1:25 AM, raptorddd said: hi. i did the other suggestion but the turbo boost was disaabled not sure. i checked frequencies and stayed at stock. right now i havent faced any shut offs. maybe because while watching you tube i keep clicking on task bar with mouse button. so you suggest to use the dell driver.... i dont know what is dptf.? DPTF allows configurable TDP, skin temp limit, acoustics etc. But some OEMs choose to incorporate and some ignore it. If you don't see it listed the model/laptop doesn't support it. 2 Vasudev Menon YouTube Channel
aldarxt Posted June 4, 2022 Posted June 4, 2022 You could also try these cmd (Admin) one line at a time it will refresh windows looking for corrupted files 1 line at a time and let it finish Dism /Online /Cleanup-Image /CheckHealth Dism /Online /Cleanup-Image /ScanHealth DISM /Online /Cleanup-Image /RestoreHealth sfc /scannow check disk chkdsk C: /f /r chkdsk /r does the same thing as chkdsk /f only it also checks for bad sectors on the disk and recovers any readable information. Running chkdsk /r implies that also chkdsk /f is run. chkdsk /f only checks for disk errors, not bad sectors. ________________________________________ Clean and Analyze the WinSXS folder DISM /Online /Cleanup-Image /StartComponentCleanup SFC /SCANNOW DISM /Online /Cleanup-Image /AnalyzeComponentStore SFC /SCANNOW Restart your computer After the restart, open command prompt (as admin) again and run DISM. DISM /Online /Cleanup-Image /RestoreHealth 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
raptorddd Posted June 4, 2022 Author Posted June 4, 2022 2 hours ago, aldarxt said: You could also try these cmd (Admin) one line at a time it will refresh windows looking for corrupted files 1 line at a time and let it finish Dism /Online /Cleanup-Image /CheckHealth Dism /Online /Cleanup-Image /ScanHealth DISM /Online /Cleanup-Image /RestoreHealth sfc /scannow check disk chkdsk 😄 /f /r chkdsk /r does the same thing as chkdsk /f only it also checks for bad sectors on the disk and recovers any readable information. Running chkdsk /r implies that also chkdsk /f is run. chkdsk /f only checks for disk errors, not bad sectors. ________________________________________ Clean and Analyze the WinSXS folder DISM /Online /Cleanup-Image /StartComponentCleanup SFC /SCANNOW DISM /Online /Cleanup-Image /AnalyzeComponentStore SFC /SCANNOW Restart your computer After the restart, open command prompt (as admin) again and run DISM. DISM /Online /Cleanup-Image /RestoreHealth thanks i havent faced this again but if i do ill try this steps. dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
raptorddd Posted June 4, 2022 Author Posted June 4, 2022 2 hours ago, aldarxt said: You could also try these cmd (Admin) one line at a time it will refresh windows looking for corrupted files 1 line at a time and let it finish Dism /Online /Cleanup-Image /CheckHealth Dism /Online /Cleanup-Image /ScanHealth DISM /Online /Cleanup-Image /RestoreHealth sfc /scannow check disk chkdsk 😄 /f /r chkdsk /r does the same thing as chkdsk /f only it also checks for bad sectors on the disk and recovers any readable information. Running chkdsk /r implies that also chkdsk /f is run. chkdsk /f only checks for disk errors, not bad sectors. ________________________________________ Clean and Analyze the WinSXS folder DISM /Online /Cleanup-Image /StartComponentCleanup SFC /SCANNOW DISM /Online /Cleanup-Image /AnalyzeComponentStore SFC /SCANNOW Restart your computer After the restart, open command prompt (as admin) again and run DISM. DISM /Online /Cleanup-Image /RestoreHealth thanks i havent faced this again but if i do ill try this steps. 1 dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
