Reciever Posted May 16, 2022 Posted May 16, 2022 Good Evening Chaps! I wanted to start a discussion regarding cheap and efficient means of ducting heat from say, a mining system in a bedroom, to an obvious outlet. Obviously I would start with my own little project. I am hoping for this thread to be beneficial to other miners who may live in warmer climates. The second order effect to this that I would like to encourage better practices for maintaining Computer components, there is plenty of e-waste as it stands. There will always be a limit to what can be done to keep things viable, no reason to not try! Pictures to follow shortly for the canvas I am currently working with I have a total of 10 GPU's to get sorted 🙂 2 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
aldarxt Posted May 16, 2022 Posted May 16, 2022 2 hours ago, Reciever said: Good Evening Chaps! I wanted to start a discussion regarding cheap and efficient means of ducting heat from say, a mining system in a bedroom, to an obvious outlet. Obviously I would start with my own little project. I am hoping for this thread to be beneficial to other miners who may live in warmer climates. The second order effect to this that I would like to encourage better practices for maintaining Computer components, there is plenty of e-waste as it stands. There will always be a limit to what can be done to keep things viable, no reason to not try! Pictures to follow shortly for the canvas I am currently working with I have a total of 10 GPU's to get sorted 🙂 Depending if you own or rent your options will vary. One possibility is build a corner closet with a vent to the attic. This would aesthetically and give more privacy. But at minimum should be in a box with a duct to the outside possibly through the attic or a wall. It looks like this wont be a short term thing, at least until we get a candy machine that just pops out coins. Just some thoughts as I am going through my own experimentations. Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
Reciever Posted May 16, 2022 Author Posted May 16, 2022 Ah yes, the simple means to the same result is a grow tent. I plan to use freely accessible items (to me) which would be card board, HVAC tape and additional mass from decommissioned systems, such as blade servers and fans from desktops and servers. Everyone's use case will be different, but it will be good to get the idea's out there for others to connect their own dots and share 🙂 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
K4sum1 Posted July 6, 2022 Posted July 6, 2022 This is probably your exact idea, but this is what I'm thinking. Get a big cardboard box, big enough to cover your system. Get two ducts, and cut two holes into your box, one hole for each. Make one duct the intake, and the other the outtake. Likely best to put the intake at the bottom, and the outtake at the top. You would likely want a few big fans to encourage the air to move around. Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
Reciever Posted July 6, 2022 Author Posted July 6, 2022 Yeah I think I'm going to move my desk against the wall, list the gpu stack on top of the desk and bring in my bedside chest to extend my usable area from wall to wall, this way I can I have my window fans pulling heat straight outside without conflicting with my projector One thing I cant get around is I will need another couple pieces of wood to provide more surface area as well as create another duct for my server psu's AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Steerpike Posted July 7, 2022 Posted July 7, 2022 2 hours ago, Reciever said: Yeah I think I'm going to move my desk against the wall, list the gpu stack on top of the desk and bring in my bedside chest to extend my usable area from wall to wall, this way I can I have my window fans pulling heat straight outside without conflicting with my projector One thing I cant get around is I will need another couple pieces of wood to provide more surface area as well as create another duct for my server psu's We need more pictures! Does all this have to be running while you are actually sleeping in the room, or does the mineshaft close down at night?
Reciever Posted July 7, 2022 Author Posted July 7, 2022 Well for me it's while sleeping in the room. While it's not forced air level of dB and pitch it's still uhh noteworthy lol AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Reciever Posted October 2, 2022 Author Posted October 2, 2022 There is 0 ducting going on in all of your post. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Reciever Posted October 3, 2022 Author Posted October 3, 2022 threadcrapping posts removed. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
ryan Posted December 18, 2022 Posted December 18, 2022 Interesting thread. Does anyone use a ac to cool their laptop and how would one duct that..under or against? ZEUS-COMING SOON Omen 16 2021
