Hi All
Like many, I suffer from micro stutter in games and are just curious if there are particular measures and tweaks to limit it as much as possible? I intend to upgrade to windows enterprise sometime soon as one possible method of performance and stability enhancement, but I am just curious if there are some proven methods for limiting microstuttering. Something I have noticed is that microstutter is notable less when I am in Dgpu mode as opposed to being on hybrid, or dynamic with respect to the mux switch, so is this really a driver issue possible?
With respect to undervolting, I have noticed my system frequency crashes when I got near the limit of what I am able to undervolt with my system, which is about -.75mv, however I now do -.50mv simply because I no longer have system failures and so on. That said, am I really just dealing with a lesser Binned CPU and this is the result? Or is there some way to make a higher undervolt more stable? CPU is i7-10870h. Laptop is max-15 eluktronics.
Can you share the complete list of components that comprise your particular unit?
Telegram / TS3 / Twitter
Windows 10 Enterprise is no different than Pro/Home in this regard.  The difference is simply in licensing and which features are toggled on/off.  The underlying platform is identical, and Enterprise has no special optimizations for performance tuning or stability.  (Enterprise LTSC is a bit different.  I have an article about it linked in my sig.  Though, really any performance or stability improvements from it would just come from the fact that it comes with less cruft installed.)
Regarding stuttering, I've spent a fair amount of time addressing stuttering and optimizing my system.  Here are some things that I can recommend.
  • If you have a higher-end mouse with a high poll rate (>250 Hz), trying turning the poll rate down, or switching to a basic mouse to see if that makes any difference.  Normally, the polling rate can be adjusted in the mouse's control panel / software.  Seems crazy, but my 1000 Hz mouse causes major stuttering in some games and turning it down to 125 Hz eliminates it.  Windows seems to be pretty bad at handling a high poll rate and having certain background apps or game overlays running can exacerbate it.  (Google for "high mouse poll rate stuttering" and you will see tons of people complaining about this.)
  • Check the profile for your game in NVIDIA control panel (Manage 3D Settings -> Program Settings).  Find the setting for "Power management mode" and set it to "Prefer maximum performance".  I've actually seen cases where the NVIDIA GPU can cause stutters while switching power states; this setting should take care of that.
  • Run LatencyMon while you are gaming.  Look at the "Drivers" section afterwards.  Anything reporting more than ≈2ms under "highest execution" should be checked out.  I've used this to tease out issues relating to networking/Wi-Fi drivers, audio drivers, and disk controller drivers.  (What action to take depends on what driver / .sys file you see consuming time.)
  • macOS 26 "Tahoe"
MAX-15, i7-10870h with -.50mv undervolt, 2070 super, gsync, gskill cl16 3000mhz 32gb kit, adata sx8200 pro 1tb, samsung 980pro 1tb.
I have much more stable clocks with the GPU power limits raised.
32" MSI 4k 160HZ IPS display
48GB (2x24) DDR5 6000 CL36
Asus B650E-I motherboard
microstuttering can also be caused by having AF set to a value other than default in nvidia control panel...as for undervolting id say once you have a stable undervolt pull back 1 step, and you should be good.  it should not be a culprit for ms
