Clevo P775 TM1G Upgrade Help (gtx 1080, i7 8700K to rtx 2080, I9 9900K)
Thanks Jaybee ^_^
A further update after bios and EC, I swapped out the gtx 1080 and i7 8700k with my newer gpu and cpu and
to my surprise it worked great 😄
Instant recognition, only thing that had to be done was restart the PC for driver installation.
So have a good time with your RTX 2080. it’s not much slower than the 3080.
  • 1 year later...
Hello, I will soon be replacing my GTX 1080 with the RTX 2080 in my P775TM1. Do I need to upgrade the motherboard BIOS? Im running curently Unlocked Obsidian-PC 1.07.27
Hi,
you do not need a bios update from Dsanke. You can also use the graphics card without the new bios! The original bios from Clevo works exactly the same. Furthermore, the RTX2080 was also supported for the P775TM by Clevo. The Obsidian Bios supports the RTX2080 anyway! No matter if .20/.25/.27 I think 1.07.27 did not exist! It only went up to .25 if I see it correctly....:-)
.27 Bios exists, but only for P775TM1-G. P775TM-G uses .26 or .28
Anyway, a bios change is not necessary, even if there are the mentioned versions. It is irrelevant it basically works from Clevo!
That’s what I said before.
As I said, even without .26 or .28 goes the RTX20xx series! And it does not have to be a special Obsidian bios. They just make logo changes or similar like XMG or Mifcom or Eurocom. They are not OEM but only resellers. Clevo develops laptops and manufactures them! Dot:-)
