2 minutes ago, katalin_2003 said:
I ended up purchasing the Samsung 980 PRO with heatsink, model MZ-V8P2T0CW.
Don’t think that the heatsink will fit.  There’s not much clearance between the drive and the chassis bottom cover.
Oh bummer..
On 1/24/2022 at 6:06 PM, solidus1983 said:
I didn't see that mentioned on their page but nice to know, but then again it didn't state that the 7560 has 3 m.2 slots and on the 7760 it has 4.
On Page 18 of Dell's Precision 7560 Setup and specifications manual one row of the "Table 13. Storage specifications" says:
  • Storage type: M.2 2280 solid-state drive
  • Interface type: PCIe NVMe Gen4 x4
  • Capacity: Up to 4 TB
I replaced the original Dell 256GB drive with a "SAMSUNG 980 PRO M.2 2280 2TB PCIe Gen 4.0 x4, NVMe 1.3c", part #: MZ-V8P2T0B/AM.
  • katalin_2003 changed the title to 2Tb aftermarket SSD for Precision 7560
  • katalin_2003 featured and unfeatured this topic
So I received the Precisions 7560 today and attempted to install the Samsung 980 PRO with heatsink, model MZ-V8P2T0CW, in it.
It protrudes enough to prevent the SSD door from closing.
All is not lost though, I’ll order a heatsink-less one and install this one on my desktop.
@Aaron44126's assumption was correct.
So for whoever reads this, purchase a SSD with thinner heatsink, this one’s not it, or install the one that comes with the OEM drive.
Is there anything noteworthy out there with a thinner heatsink that will fit? Or is a "heatsink-less" the only option here?
GitHub
Currently and formerly owned laptops (specs below):
Razorback                -> MacBook Pro 16" (M4 Pro) (work)
Serenity                    -> Dell Precision 5560
N-1                             -> Dell Precision 5560 (my lady's)
Razor Crest              -> Lenovo ThinkPad P16 (work)
Millenium Falcon    -> Dell Precision 5530 (work)
Axiom                        -> Lenovo ThinkPad P52 (work)
Moldy Crow             -> Dell XPS 15 9550
Razorback: MacBook Pro 16"
    M4 Pro (14-core CPU, 20-core GPU)
    48 GB RAM
    1 TB SSD
    MacOS 15.1
Senenity / N-1: Dell Precision 5560
    i7-11800H CPU
    1x32 GB DDR4 2,666 MHz
    512 GB SSD
    NVIDIA T1200
    FHD+ 1920x1200
    PopOS 22.04
I can’t advise going with one brand or another with these PCIe Gen4 drives as I have no experience with them.
I just ordered a 2Tb Samsung 980 Pro, model MZ-V8P2T0BW. It should arrive this Wednesday.
While it should fit, I can’t recall where I read about them running hot.
I'll let you know how this goes. Maybe I’ll try with the stock heatsink that comes with the OEM drive.
The system should have come with a plain metal plate heatsink for all of the NVMe drive slots (even slots that shipped without a drive in them).  You should use that heatsink with your new drive.  Don't run it without a heatsink at all.  If you move the original OEM drive from the PCIe4 slot to one of the PCIe3 slots, swap the heatsinks around appropriately so that they stay with their original slots.  The PCIe4 slot heatsink is a bit different than the PCIe3 slot heatsinks.
There is rather little clearance.  I'd assume that a NVMe drive that comes with a heatsink attached is intended for desktop use.  I still think that it might be beneficial to put some thick thermal pad on top of the PCIe4 slot heatsink in this system so that there is contact between the heatsink and the chassis (like there is with the PCIe3 slots).  This would probably be better if you have the chassis without the SSD door.  (I have not tested this to see if it really makes a difference, though.)
The 980 Pro is a terrific SSD, more so when I paid less than $200 for a 2 TB one thanks to sale prices, gift cards, and rewards points from Best Buy. I originally had it in my ThinkPad but ended up returning that laptop so it's pulling duty as the boot drive for my desktop. While the 9th-gen Core i7 doesn't support PCI-E Gen 4, once I upgrade to Alder Lake or Ryzen 7000, that won't be an issue. I'll be repurposing my Samsung 970 Evo for laptop duty eventually. I'm currently evaluating the 2022 Asus Zephyrus M16 as a portable gaming/work solution. So far it's decent, but thankfully due to having Best Buy Elite Plus status, I have 45 days to make up my mind.
It does. Good on their part to not only include the extra heatsinks but the thermal pads as well.
Good change from the time of the M17x Alienwares where you had to order caddies and screws separately.
Thanks for the tip. I swapped the RAM earlier and noticed the difference between the heatsinks. 👍🏼
Will swap them out once the new drive arrives.
By the way, while in there earlier, I noticed they got rid of the switch on the motherboard, under the blue tab, the solder pads are there though.
Guess they got too many calls about it.
If you find the stock heatsink is still thermal throttling it is possible to use a 2mm height aftermarket heatsink. It is even a better situation now that you do not have to worry about depressing that drive slot power switch. I also tried 4mm which definitely was too thick with the bottom cover in place.
Good point. I’m going to go this route and look for a thicker aftermarket one.
Thanks!
EDIT: @win32asmguy I was wondering, was the 4mm heatsink you tried the same design as the one in your photo? The reason I’m asking was maybe you could’ve probably saved on the height, by what looks to be 1mm, by running the silicone/rubber bands in the grooves.
I'm seeing all sorts of designs and leaning towards a pure copper one:
https://www.amazon.fr/dp/B092V9GF43/
Edited by katalin_2003
