cisik88 Posted November 23, 2024 Posted November 23, 2024 Thanks Maks, so i assume programmer only for whole family right? P4000, P4200, P5000, P5200. And it was confirmed that even NVflashk or OMGVflash won't work? 1
loopster Posted November 23, 2024 Posted November 23, 2024 Flashing 86.04.70.00.1B onto P3000 worked with NVflashk on my zbook 17.
Maks0098 Posted November 23, 2024 Posted November 23, 2024 2 hours ago, loopster said: Flashing 86.04.70.00.1B onto P3000 worked with NVflashk on my zbook 17. hey, how did you do it?!) please, can you make some instructions? and did you flash it from stock to unlocked from IMac? Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
loopster Posted November 24, 2024 Posted November 24, 2024 Can't remember honestly... I guess I would have to retry to be sure I probably just did cmd.exe as admin cd into file path nvflashk --protectoff nvflashk -5 -6 newbios.rom, or maybe just nvflashk -6 newbios.rom This was from stock bios to 86.04.70.00.1B, which I took from techpowerup upon reading about it in this thread
sliderfra Posted May 10, 2025 Posted May 10, 2025 On 8/20/2022 at 10:50 AM, TheQuentincc said: Hi, I just came on this thread and found out that there seems to be a some "OC" vbios for the Quadro P4000 and maybe P3000 mobile version : https://forums.macrumors.com/threads/imac-2011-maxwell-and-pascal-gpu-upgrade.2300989/ Don't try to contact them, looks like they are a bit higher up in their mind and doesn't want to deal with "non mac user" hahaha. That said, I didn't tried them, your luck may vary, it might not work on normal laptop, I'm currently investigating how it's modded and might be able to replicate it. Here is a preview of what's this modded vbios is capable on the P4000 : Comparing to it's stock graphics score of about 3900~4000, this is a 20% performance uplift that's above a 1060 level of performance. P3000 + P4000 modded overclocked vbios.zip 1.03 MB · 79 downloads The two p3000 modded bios don’t work on m17x r4 with edp 120hz screen. Got 8 beeps. 86.04.70.00.1B works nicely. But no overclocking possible
TheQuentincc Posted May 27, 2025 Author Posted May 27, 2025 It's not about overclocking unlocking, it's just getting a proper boost frequency out of those core. I remember being locked at 1250MHz on the P4000 I had on the M6700, with theses vbios you should see the card reach 1600+MHz on the core, leading to higher performance (about 20%). That said I didn't tried them, I didn't had a P3000 or a P4000 since I made this thread (nor an MXM laptop) but a few people reported higher clock speed thanks to theses vbios. Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable)
