jaybee83 Posted September 2, 2022 Posted September 2, 2022 Hey folks, As many of you might have already noticed, we dont really have an option for multi-quotes in replies yet at NBT (at least not when youve already submitted your post). However, there is a workaround that you can use in the meantime. Thanks to @Reciever for pointing out this section to me so that I can post this little step by step guide! Admin Edit: To be more specific, this guide is meant to reflect how to "edit-in" another post into your last post in the event someone added more content or you had simply missed the post and wish to comment on or address it without double posting. The workaround is as follows, and currently has only been verified on Desktop (mobile might depend on the browser / device ure using): - write original message while quoting someone by clicking "quote" button under the message u want to quote (regular single quote) - submit reply - go to second message u want to quote, click on "quote" - in the new second reply window, click on the quote and ull see a small box on the upper left corner like here (thanks to @Mr. Fox for being the guinea pig here 😄) - click on that box, do a Ctrl+X - go back to your first message, click edit, do a Ctrl+V to insert the second quote and off you go! Note: Before inserting the second / third, etc. quote u might want to insert 2-3 empty lines after your previous text, otherwise there will be no additional lines after the new quotes to type. It is a bit annoying but it works! 3 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Mr. Fox Posted September 2, 2022 Posted September 2, 2022 Works perfectly. Thanks for sharing, bro. It's interesting that a right-click copy and Ctrl+C (copy) did not seem to work for me after clicking on the control box in the upper left hand corner, but Ctrl+X (cut) works every time. 1 WRAITH | X870E Apex | 9950X | RTX 5090 (Shunted+EVC2) | 32GB DDR5 @ 8200 | Custom Loop BANSHEE | X870E-E Strix | 4585PX | RTX 4090 | 48GB DDR5 @ 8000 | Custom Loop Hailea Ultra Titan HC-500A Chiller | 5 Gallon Insulated Reservoir Mr. Fox YouTube Channel | Mr. Fox @ HWBOT
Ishayin Posted September 2, 2022 Posted September 2, 2022 4 hours ago, jaybee83 said: 3 hours ago, Mr. Fox said: Huh? Multiquote has always worked fine for me. The only slight issue I find with it is that when you paste in the quotes at the start of a reply, there is then no way that I can find of inserting text before the first quote, unless you start again from scratch and remember to ensure to leave a line break there to begin with. What browser are you using? Spoiler Spoiler Spoiler 1
Reciever Posted September 2, 2022 Posted September 2, 2022 4 hours ago, Ishatix said: Huh? Multiquote has always worked fine for me. The only slight issue I find with it is that when you paste in the quotes at the start of a reply, there is then no way that I can find of inserting text before the first quote, unless you start again from scratch and remember to ensure to leave a line break there to begin with. What browser are you using? Reveal hidden contents Reveal hidden contents Reveal hidden contents I added some clarification into the title and the post, the means to this solution is via multi-quote / quote however the main topic being displayed is how to edit in additional quotes into your last post after having submitted the post proper. Essentially, You submit a post and saw that someone may have replied right before you finished your post and you wish to comment on or address without double-posting, for someone reason the standard means of copy/paste didnt seem to jive well in the forum software (at all). Instead Invision community opted for a CTRL + X combination instead of CTRL + C. If this is something I can change I will attempt to do so its just been a crazy busy season this year. 1 minute ago, jaybee83 said: LOL ive never used the multi-quote function before, i feel very DUH now 🤣 thx for the heads up man, appreciate it haha. but glad my post can still help when wanting to quote after having already posted. 1 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
jaybee83 Posted September 2, 2022 Author Posted September 2, 2022 4 hours ago, Ishatix said: Huh? Multiquote has always worked fine for me. The only slight issue I find with it is that when you paste in the quotes at the start of a reply, there is then no way that I can find of inserting text before the first quote, unless you start again from scratch and remember to ensure to leave a line break there to begin with. What browser are you using? Hide contents Hide contents Hide contents 3 hours ago, Reciever said: I added some clarification into the title and the post, the means to this solution is via multi-quote / quote however the main topic being displayed is how to edit in additional quotes into your last post after having submitted the post proper. Essentially, You submit a post and saw that someone may have replied right before you finished your post and you wish to comment on or address without double-posting, for someone reason the standard means of copy/paste didnt seem to jive well in the forum software (at all). Instead Invision community opted for a CTRL + X combination instead of CTRL + C. If this is something I can change I will attempt to do so its just been a crazy busy season this year. LOL ive never used the multi-quote function before, i feel very DUH now 🤣 thx for the heads up man, appreciate it haha. but glad my post can still help when wanting to quote after having already posted. 1 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Reciever Posted September 2, 2022 Posted September 2, 2022 For example, see my above post, as I was able to edit in @jaybee83's content into the post above. @Aaron44126 not sure if you already knew about this or not, but I know you appreciate functional awareness. 2 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Aaron44126 Posted September 2, 2022 Posted September 2, 2022 17 minutes ago, Reciever said: @Aaron44126 not sure if you already knew about this or not, but I know you appreciate functional awareness. Thanks... I haven't had issue with "mutli-quote" (I just click the quote button and it adds it to the end of the post that I am working on), but add-quote-after-posting that you mention is a little bit tedious. I just start a new post with the quote and cut/paste it into the edit window afterwards. Understand all about busyness. I have a number of projects (both for this community and otherwise) that I simply haven't been able to find time to work on between regular life stuff... 2 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
Reciever Posted September 3, 2022 Posted September 3, 2022 2 hours ago, Aaron44126 said: Thanks... I haven't had issue with "mutli-quote" (I just click the quote button and it adds it to the end of the post that I am working on), but add-quote-after-posting that you mention is a little bit tedious. I just start a new post with the quote and cut/paste it into the edit window afterwards. Understand all about busyness. I have a number of projects (both for this community and otherwise) that I simply haven't been able to find time to work on between regular life stuff... Same -__-, sometimes feels like it will always be that way but ironically, I despise a lacking of purpose as well sooo, striking a balance is I guess the real goal. 1 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
