Hello guys
I've got a pretty weird problem with my M18x R2. I already searched the web but couldn't find an answer. A few days ago I changed some settings in the bios, if I remember correctly DMVT Pre-Allocated.
After saving this setting the notebook refuses to even POST. I get no beep errors or anything. If I press the power button the system turns on, the LEDs turn on and then the system shuts itself off. I already reset the CMOS, the IME, tested different hardware configurations and so on. If I remove all the memory sticks I actually get the memory error code. At this point I'm pretty sure that the bios got corrupted for some reason when I saved these settings. Did anyone had a similar problem and got a solution for this? I repaired lots of notebooks but never had an error like this...
EDIT:
The Bios installed is the a15 unlocked which worked fine until recently. Overall there were no problems at all indicating different kind of problems.
I also tried the backflash method with the A03 Bios but the system refuses to read the USB stick. I've used the same stick as last time I reflashed the Bios.
Alienware Area 51 ALX R7 5800X 32GB DDR4 3200MHz RTX 2080 Ti FE (Full Custom Loop)
Alienware M18x R2 I7 3840QM 4.2GHz 16GB DDR3 1600MHz GTX 1070(Zotac MXM, 10 MOSFETs)
Alienware M17x R4 I7 3630QM 16GB DDR3 1600MHz GTX 1080 150W 8GB(Zotac MXM 3.0B)
MacBook Pro 16 2019 I7 9750H 16GB DDR4 2133MHz Radeon Pro 5300M
Cevo P775TM1-G I9 9900K 16GB DDR4 2600MHz RTX 2080
And lot's of other stuff in my hobby corner (old Clevo's 'n' stuff like that)😄
Sounds very similar to this post
How did you clear the CMOS? Did you bridge the CMOS battery connector pins?
It sounds like you've tried the blind flash but maybe you didn't quite do it right
Yes, it’s actually almost the same issue. The only difference is that I had no problems before at all. I changed these setting to get some performance increase as I’m running this thing in SG mode(GTX1070).
I’ve done the CMOS reset in 3 different ways:
1. I unplugged the battery and waited some time.
2. I unplugged the battery and shorted the battery pins on the board.
3. I left the battery in place and shorted the clrcmos and reset ME pins on the board. These pins are hidden under the msata cable. These can also be found in the schematic which is easily available in the internet.
At this moment I rather think it’s the Intel Management Engine firmware which is corrupted. I believe that as this piece of software is absolutely necessary as this initializes CPU. That’s also why it’s not possible to completely disable this junk. For me this would also explain why the reflash method does not work like in the past.
The bad thing about that is that this firmware sits on its own rom on the board, so just taking the bios file and using an external programmer seems impossible without having a dump from that exact rom
I dont know in m18x but in AW18 to reset the BIOS the only way to hard reset its to remove all RAM sticks Power on the lap and when u get the third beep (if am not wrong) u must to put at least One mem Stick before the fourth beep and It Will reboot, was something like this. I dont think that u have an corrupted BIOS or something like that, Just It doesnt work with Ur new settings Better dont mess up ti much with BIOS. Happened to me once hard reset method took me at default options
First of all, is there an A15 unlocked bios for the M18X R2?
Second, try the blind flash method, posted in another post. Most of BIOS problems regarding wrong settings, fix with the blind flash method!
Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000
Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000
I dont know anything about DMVT Pre-Allocated. But this post on reddit says not to do it
https://www.reddit.com/r/gpdwin/comments/5hxgpe/dont_change_dvmt_preallocated_video_memory_in/
Got a little update, it’s working again!
it was actually the bios which was the culprit. I removed the SPI Rom chip and flashed a dump from another machine(thanks to the guy from Reddit who send me the dump). After that the backflash was working again(and necessary) and I downgraded back to A03. After lot’s of beeps I finally got a picture and it’s working fine now 😄
Excellent news! Well done
Yea, here is the link https://www.dell.com/community/Alienware-General-Read-Only/Alienware-18-no-POST-How-to-reset-UEFI-BIOS-when-no-POST/td-p/5521711
The solution was posted 10-16-2013 by a BJFox, is it one in the same as our Bro here alias @MRFox ?!!!
Yes, the very same
  • 2 months later...
  • 3 years later...
Hello I have the same problem with my m18x r2 you had while ago . and as I just bough the device two days ago and it's my first time I had problem running it with gtx 1070 and I changed few settings in bios that made the device dead to me . starting for few seconds then shutdown . blindflashing never worked I tried many times . so I have to go with your method with the dumb for SPI Rom chip can you help me by sending me this dumb as I am stuck here
