Well , the project I have been working on. Finally coming to a finished. I present you a full blown mobile gaming desktop.
Specs:
Motherboard: Gigabyte z590I Vision D
Processor: intel i7-10700K
RAM: Adata XPG ROG STRIX DDR4 3600MHZ ( Fubuki )
SSD: 1TB Samsung 970 m.2
Power Supply: 1U 700 Watts 80 Plus Platinum
Keyboard: K65 60% Gaming Keyboard
GPU: RTX 3090 OC Evangelion Edition
LCD: 18.4" 4K 60hz (Driving by a 4K EDP driver board)
Case: Custom Plexi-Glass ..
Now the decision here .. I am set on the 18.4 because it's 4K , but on the other hand , I want a 17" with a high refresh rate. Maybe I can run both LCD lol. Decision , decisions ..
Once I figured out what display I want , I will mount it on top of the case just like a laptop.
New Build also WIP , but 80% finished.
Ryzen 7 9800X3D
RX 7900 XTX
700 Watts Flex 1u PSU
32GB 6400mhz RAM
Scythe Shuriken 3 CPU Cooler ( Noisy fan )
WQHD 240hz LCD with Alienware M18 Lid
240hz Driver Board
Coolermaster Laptop cooler frame and plexi glass casing
Weight might be around 15-20lbs .. I have no scale.
dude thats some serious hardware packed in such a small form factor! do you have a suitcase or similar for it to carry it around easily?
Not yet brother. The size is 17" x 13.5" x 2-3/4 thickness. The weight is about the same as an Alienware area 51m R2 with two power supply. 😂
next gen DTR...since we dont have any true alternatives anymore
Wow, nice setup, really well build, respect!
Maybe an idea is to 3d Print some sort of enclosure, case that you can carry around easly.
Future DTR like @jaybee83said 😎
This looks interesting
How loud does it get? You basically have all the fans right next to the kb, and all in the open. I wonder if you can only game in headphones for it to be comfortable :classic_laugh:
Nevertheless, very nice looking build!
GitHub
Currently and formerly owned laptops (specs below):
Razorback                -> MacBook Pro 16" (M4 Pro) (work)
Serenity                    -> Dell Precision 5560
N-1                             -> Dell Precision 5560 (my lady's)
Razor Crest              -> Lenovo ThinkPad P16 (work)
Millenium Falcon    -> Dell Precision 5530 (work)
Axiom                        -> Lenovo ThinkPad P52 (work)
Moldy Crow             -> Dell XPS 15 9550
Razorback: MacBook Pro 16"
    M4 Pro (14-core CPU, 20-core GPU)
    48 GB RAM
    1 TB SSD
    MacOS 15.1
Senenity / N-1: Dell Precision 5560
    i7-11800H CPU
    1x32 GB DDR4 2,666 MHz
    512 GB SSD
    NVIDIA T1200
    FHD+ 1920x1200
    PopOS 22.04
depends on the fans and their settings i guess. but being a DTR enthusiast, you wouldnt want it any other way than JET ENGINE FULL BLAST 24/7 😄
 With a noctua CPU fan, it's quiet,  but I like the RGB fan  .. and the rtx 3090 .. the fan noise is subtle.
I might just build a square rigid aluminum frame , add handle to it and called it complete lol 😂
Dude, this project is absolutely amazing, and is something I was planning to do myself in the future. What's the case currently made of? Acrylic?
My only gripe is that I can't find any portable 21.5 inch 144 Hz monitors. I like my big screens. Really wish 18 inch laptops would make a comeback.
Yes , I used acrylic sheets. I just placed all the hardware in my desire setup and mark the spot where I would mount the standoff screws to mount all the hardware.
I'm finishing up the screen installation , hopefully by mid day tomorrow. I am currently will use the 18.4" 4K display , but will use also a 17" 360hz display down the road.
Ok .. got the lcd mounted ... I used hinges from a MSI GT76.
Now .. I'm going to put holes on top of the acrylic cover so the cpu and gpu can have some oxygen to breathe.
Possibly I might cut out the slot so the key oard can be accessed or just keep as it is as a slide out keyboard.
dude seriously this just looks so sexy yet so simple 😄 i love it. especially the fact that the gpu takes up like 40% of the footprint hahaha, nice!
Super impressive build! I'm curious, what power supply did you use that can supply enough wattage for a 3090? I love the minimalist aesthetic.
If you want an help with 3d printing, I'm happy to help. No pressure though.
On 10/21/2022 at 11:09 AM, Rengsey R. H. Jr. said:
I suck at 3d printing lol.
Daily Drivers:
JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING)
Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery
14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz
Past Projects:
15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4
17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4
M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz
M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
  • 2 years later...
Better to answer late than never. I had a 700 watts flex 1u psu in that build.
I am working on a 2nd one right now. I'll update with pictures once i get a chance. This time , just , mobo, psu, gpu and 18" screen. I just got my hands on a 850 watts flex psu too.
  • 11 months later...
This build is honestly insane in the best way possible — packing that much power into a “portable” setup is seriously impressive.
I really like the clean acrylic approach too, gives it that raw custom look instead of hiding everything. The RTX 3090 taking up such a big chunk of the space actually makes it look even cooler 😄
For the display choice, I’d say it depends on your main use — if you're more into competitive gaming, the high refresh 17" would be worth it, but for visuals and overall experience, that 4K 18.4" is hard to beat. Running both would be wild though!
Also curious — how are temps holding up under load with that setup?
Great work man, this is a proper next-level DIY DTR 🔥
