Csupati Posted May 16 Share Posted May 16 Hi! I will be able to get my hands on an P771ZM with I5 4690k and a 980m 8gb and IPS panel with edp cable. My question is that if im able to buy a Quadro P3000 , the quadro mxm has a built in edp output ? (compared to the Firepro S7100X, witch dont have display output chips). Clevo P751TM1-G \I9-9900@ 3.1ghz 45W\32GB 2666 mhz ramkit\RTX 2080 150W\ 2X500GB nvme SSD's\4K Sharp IGZO screen\ Link to comment Share on other sites More sharing options...
Blacky Posted May 16 Share Posted May 16 It should work. I have a P4200 in my P177SMA. Clevo P177SMA| i7-4940MX@4.10GHz | Nvidia Quadro P4200 | 32GB DDR3 1600 MHz | 17.3" LED TN 1920x1080 | 3TB SSDs | Windows 10 Pro | 5241 TimeSpy Find your perfect laptop! (noteb.com) | Uplift, my Android 3D game! Link to comment Share on other sites More sharing options...
Csupati Posted May 16 Author Share Posted May 16 52 minutes ago, Blacky said: It should work. I have a P4200 in my P177SMA. Yes but the p177sma uses intel hd to give screen, the p771ZM dont have mux and intel hd. Clevo P751TM1-G \I9-9900@ 3.1ghz 45W\32GB 2666 mhz ramkit\RTX 2080 150W\ 2X500GB nvme SSD's\4K Sharp IGZO screen\ Link to comment Share on other sites More sharing options...
razor0601 Posted May 17 Share Posted May 17 I used the P3000 in my old P771DM-G and it works fine. Clevo N960KP, I5-11400, RTX 3060 140w TGP, Samsung 970 EVO Plus 2TB NVMe SSD, Samsung 870 EVO 4TB SATA SSD. Link to comment Share on other sites More sharing options...
Csupati Posted May 17 Author Share Posted May 17 6 hours ago, razor0601 said: I used the P3000 in my old P771DM-G and it works fine. Thanks! So the quadro cards have edp signal output . Clevo P751TM1-G \I9-9900@ 3.1ghz 45W\32GB 2666 mhz ramkit\RTX 2080 150W\ 2X500GB nvme SSD's\4K Sharp IGZO screen\ Link to comment Share on other sites More sharing options...
Csupati Posted May 19 Author Share Posted May 19 Finally got the P771ZM, my biggest suprise was that is has been costumized by a handmade paint Totoro style. 1 Clevo P751TM1-G \I9-9900@ 3.1ghz 45W\32GB 2666 mhz ramkit\RTX 2080 150W\ 2X500GB nvme SSD's\4K Sharp IGZO screen\ Link to comment Share on other sites More sharing options...
Csupati Posted May 24 Author Share Posted May 24 Is there any chance to find a P770ZM Prema V2 unlocked bios for it? Only for the nvme support. Clevo P751TM1-G \I9-9900@ 3.1ghz 45W\32GB 2666 mhz ramkit\RTX 2080 150W\ 2X500GB nvme SSD's\4K Sharp IGZO screen\ Link to comment Share on other sites More sharing options...
