As the thread title say... "PC hardware you should avoid". Please post about your bad experience here. Thanks
  • Papusan changed the title to PC hardware you should avoid. The do not buy list for computer parts.....
Reserved.
All turdbooks. EOM.
Anything made by Alienware. EOM
Add the Patriot Viper 8200 DDR5 kit to the do not buy list. This memory is trash. @tps3443found the same to be true in his testing. I was hoping to replace my generic A-die with a slightly better product, but it is more than slightly inferior. XMP1 and XMP2 both fail TM5 testing and increasing the voltage does not help. Tested with both the Z690 Dark and the Z790 Apex and the outcome is the same on both platforms.
It is ridiculous that the only DDR5 modules that have been good enough to keep are my generic green sticks and the G.SKILL 8000 kit I already own. Everything (literally) I have purchased hoping for something better has been utter trash. I think I am done wasting my time with the endeavor. It's pointless, and shameful how much defective garbage is being offered for sale. Two TeamGroup DDR5 kits (including their so-called Xtreem memory), one G.SKILL 32GB kit and now one Patriot 48GB kit returned as garbage in the past 90 days.
These are the trash sticks to steer away from: https://www.bhphotovideo.com/c/product/1796763-REG/patriot_pvx548g82c38k_viper_xtreme_48gb_8200mt_s.html
^^^poo-poo-cah-cah^^^
Tested these so you don't have to...
On 11/25/2023 at 7:50 PM, Mr. Fox said:
That TeamGroup Xtreem 8000 C38 memory kit was absolute rubbish. It was worse than the cheaper TeamGroup 7200 Expert garbage I returned. It produced errors in TM5 and TestMemPro no matter what settings I used. The XMP profile performed unusually well compared to others, but I am thinking the kit I got was either a bad sample or the marketing information about binning their memory ICs is just a bunch of nonsense, hooey or deliberately lying. It's on its way back to Amazon and I got my money back. So far nothing I have tested in the 16GB A-die memory kits has performed as well as my generic green sticks from AliExpress. Nothing else overclocks as well or is as stable as those modules are, and they're not even a matched "kit" like the retail trash.
After pulling the Xtreme junk modules out and reinstalling my generic sticks, they booted and ran every test error-free using the XMP profile that was unstable with the TG sticks. That is super-disappointing. There should be no silicon lottery when you pay extra from something advertised as being superior. Beyond disappointing, it is an inexcusable and unforgivable lack of QC. If Amazon publishes my review (with memory test error screenshots) they probably won't sell many of these trash sticks.
These were also pretty lackluster, but somewhat forgivable to the extent they are cheap...
On 11/13/2023 at 1:20 AM, Mr. Fox said:
Well, not a bad kit. Quality is fine. The advertisement (even on the box) of a "one piece design" on the heatsink is just straight-up false. It is two pieces. The seam is not obvious at a glance and it looks like one piece. Not sure I am going to keep it because it is not remarkably  better than the RAM I took out of the Dark. It runs the same memory overclock as the G.SKILL kit on the Apex. I will think about it for a day or two. Not really gaining anything for the money spent. The 16GB*2 generic green A-die sticks are basically just as good. The only measurable benefit, which may not even matter in the grand scheme of things, is the extra 16GB of memory capacity. The extra capacity is worth something, but I am not sure that is a good enough basis for keeping versus RMA/refund.
Here is the XMP default.
Here is the memory overclock matching the Apex.
If I keep it then, of course, it will have the heating blankets removed and the water-cooling kit on the generic A-die sticks will be installed on them. Just a matter of whether or not I decide it is worth the extra money and associated hassle. I'm kind of leaning toward "no" but we will see if I change my mind in a few days. I gained nothing on overclocking capacity, but also didn't lose anything except the slightly tighter timings possible with the 16GB first-generation A-die modules.
On 11/13/2023 at 6:24 AM, Mr. Fox said:
Nah... slept on it and do not need to think longer. No overclocking benefit over what I already have. The looser timings and higher voltage are worth mentioning. I don't need the extra 16GB. Sending it back for a refund makes the most sense. It deserves mention that the T-Create modules have dual XMP profiles; the mediocre 7200 and an even more mediocre 6000.
Corsair "Force Series" MP510 2TB SSD
Turned out the Force wasn't with that one unfortunately: clunky software, failed after a few years of very light use.
Lenovo Yoga 2-in-1 Laptop
While Alienwares are not ideal, this thing was something else. First the webcam failed, then the mobo - with even lighter use.
Yikes. I hope my 1TB version of that doesn't meet the same fate. It's a couple of years old.
This one doesn't surprise me. Lenovo's consumer-focused (non-business class) garbage took the bottom feeder's crown in the turdbook cesspool.
Hope the 1 TB version is more robust. I switched to Seagate - class-leading TBW and much better software, also available on Linux. So far so good: 56TB, and "Life: 99%" showing in SeaTools :) I don't remember exactly, but the failed Corsair probably had no more than 10 TB on the clock.
avoid the MSI gs63vr I had two fans go on it in two months. msi refused a refund. utter garbage, and the reason I avoid MSI even if they do have the odd good product
Question
Seagate HDD. Are they still considered overpriced crud? A few years back they were crashing and loosing data like it was on purpose.
I have only ever used Westerndigital since then for good old fashion HDD.
^^^ Using several Seagate 2.5", alive and well after many years.
Dell Precision 5540 w10 ltsc - Thinkpad P14s G5 w10 ltsc - Thinkpad E14 G5 w11 - HP i5 desktop w10 ltsc - (O&O shutup\Open Shell on all w10\11) - Dell E7440 w8.1 - Tosh Satellite w8.1 - Pixel 8 Pro - Xiaomi 14 Ultra - 2x Samsung A52s - (Netguard on all phones)
Luck of the draw perhaps....seems if it wasn't for bad luck I wouldn't have any at all :classic_wink:
Just on a side note about HDD's...Toshiba has hit big trouble and their HDD's were always good to me.
https://www.theguardian.com/business/2023/dec/20/end-of-era-as-toshiba-delists-from-tokyo-stock-exchange-after-74-years
  • 4 weeks later...
SSD's and flash prices increasing, but this is just dumb. Offer less for more is the modern trend I don't like. This one from Samsung is to be avoided.
Samsung launches the 990 Evo SSDs – slower and more expensive than the 990 Pro
The company's follow-up to the best-selling 970 Evo makes the leap to PCI Express 4.0, but offers rather subdued transfer speeds and confusing pricing.
With scaled-down performance, the devices should move in a lower price range, but here something seems to have gone wrong in Samsung's marketing department. The recommended prices for the 990 Evo land at SEK 1,599 for the 1 TB model and SEK 2,599 for the 2 TB model, i.e. higher price tags "than the top models in the 990 Pro series". Whether Samsung chooses to lower the price in the future remains to be seen.
Looking back at the SSD history, "OCZ's listed MSRP of $499 for the 32GB drive and $1,099 for the 64GB" (+40% in today's money).
Better speed than HD's but no immense revolution, and surely questionable reliability\lifespan.
Early adopters > "You can always tell who the pioneers are because they have arrows in their back and are lying face down in the dirt" :O)
https://arstechnica.com/gadgets/2008/03/ssds-in-2008-fast-speeds-200mbsec-over-price-cuts/
I use a number of seagate drives and so far the only drive to fail me is a Samsung 850 SATA M.2. That being said I did have pretty much all of my "FreeAgent Xtreme" drives fail on me but that was 15-17 years ago.
I have had the same experience with Seagate.  The only Seagate drive to fail on me was a SSHD which was a terrible drive anyways.  The failure rate on them were over 60 percent.  Other than that, I have not had any issues.  I have had WD and Toshiba deathstars fail on me regularly.
Prebuilt computer system you should avoid. This is just awful.
Corsair upgraded RGB control over offering adequate cooling for the GPU's power delivery. Yup, also this one follow the new modern tech trend. Disgusting. And with a price of 5,499.99 euros this is closest you can come perverse. For the records.... 5,499.99 euros is $5,920 USD
Corsair One (i500) in the test: Wooden reboot with hot 4090 and restrained 14900K computerbase.com
Regression in graphics card VRM cooling
Unlike the i300, Corsair no longer cools the VRM (voltage converter) of the graphics card, which has been deprived of its air cooler, in the i500 using its own active cooler - the manufacturer has not even installed passive heat sinks.
RGB lighting with touch controls
The RGB lighting of the Corsair One has also been upgraded: In addition to the two decorative strips on the front of the case, the new One has “underbody lighting”. There are also white LEDs as a “reading lamp” on the back to illuminate the I/O panel.
  • 5 months later...
Here\s a long list of overpriced junk from Razer you should avoid. I have only owned a mouse from Razer many years ago. That was my first and last purchase from razer.
  • 7 months later...
  • 8 months later...
Avoid buy anything from Silicon Power.  @Mr. Fox @electrosoft++++
Silicon Power allegedly deducted 15% from refund after DDR4 memory RMA
According to the user, the kit was purchased for $54.97 and Silicon Power’s message listed a refund of $46.72. That difference matches a 15% deduction from the original purchase price. The user also claims the same kit now lists for $140.97, which would make the refund insufficient to buy a...
Oh I concur, Silicon Power are not great with RMA or warranty promises.
This happened last month.
I bought a 1TB SSD in October 2024 for ¥7780 on Amazon.jp (about USD48.00 at current price exchange, would have been closer to 60 at the time).
Early March this year I pulled that SSD from a panasonic toughbook to install into a PS4. Got half way though installing Playstation OS and it died. I couldn't see it in disk part (or even BIOS) and not with usb to sata cables. Just dead.  So I messaged SP support and they asked for a clear photograph. I sent it. Then they told me that since the drive was manufactured in 2022 the 3 year warranty had expired. I objected and eventually had to get Amazon support to confirm that the warranty starts from my purchase date not the manufactures date. They then wanted to give me a full refund. Which I declined as the price hike made a replacement impossible to purchase.
Anyway I sent it for RMA after a lot of complaining and they sent it back to me again, same argument was made in 2022 so out of warranty. I complained more and then they said it was an internal miscommunication and to send it back to them AGAIN this time COD for RMA. I did and they finally sent a new 1TB SSD....current price is US$180.49 on Amazon
So yeah if you need a warranty return with these guys be polite, but don't say "whatever" and just give up. Push them.
