razor0601 Posted February 28, 2025 Posted February 28, 2025 Good day all. I have a problem with my AW18 and it’s dual GTX 880m. If the HD 4600 is on there is no problem. If I turn on both 880m the screen is flickering weird. But on HDMI there is no issue. Maybe it’s the Display cable? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
sliderfra Posted March 1, 2025 Posted March 1, 2025 hi, could be the lvds cable. If it's not, try to remove SLAVE mxm card and test it. If problem remains, try the SLAVE mxm in MASTER slot. You should then be able to pinpoint the failure on one card.
Jerryzago Posted March 1, 2025 Posted March 1, 2025 Looks like the secondary GPU is on it's way out. If it were the cable, the problem would be there regardless the iGPU or the 880m. Disable SLI for starters to see if the problem is still there. Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
razor0601 Posted March 1, 2025 Author Posted March 1, 2025 Thanks, I will try. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted March 1, 2025 Author Posted March 1, 2025 So, I tried both 880m in the primary slot. Same issue, I tried also a spare Alienware 765m in the primary slot. Also same issue. Again, with only HD 4600 there is no issue on the internal or external screen. what the hell is that? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
sliderfra Posted March 1, 2025 Posted March 1, 2025 did you try with only one mxm card and in SG mode (optimus with intel HD)? Could be the converter chip sending signal from mxm to LVDS in PEG mode. If it works in SG mode, it's most probably this and AW will still be usable in SG mode with MXM card.
razor0601 Posted March 1, 2025 Author Posted March 1, 2025 Ok I will try. But first I have to flash the unlocked Bios. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted March 4, 2025 Author Posted March 4, 2025 Bad news. Also in SG Mode tested with both 880m in Slot 1 it gave me a blank black screen. With Intel HD only it starts normal. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
sliderfra Posted March 4, 2025 Posted March 4, 2025 well that's weird... Gotta be some LVDS converter of some sort. Did you try another LVDS ribbon? Chances are low but could be that also...
razor0601 Posted March 4, 2025 Author Posted March 4, 2025 Unfortunately I have no spare cable. Have to order one. What could it be also? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted March 12, 2025 Author Posted March 12, 2025 Do you know where is the LVDS Converter is located? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
Maks0098 Posted March 12, 2025 Posted March 12, 2025 On 3/4/2025 at 7:45 PM, razor0601 said: Unfortunately I have no spare cable. Have to order one. What could it be also? Have you tried wiping the contacts with an eraser before installing the card? Just in case. Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
Maks0098 Posted March 12, 2025 Posted March 12, 2025 And you can try to set the following settings in the BIOS: Special Features Enabled in Advanced-Video Configuration and in Pci Express Graphic set it like this PowerXpress setting. This needs to be in SG Mode. And if anything, this is from my M18x R2, but your 18 should also have such parameters. Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
razor0601 Posted March 13, 2025 Author Posted March 13, 2025 For what is that PowerXpress setting exactly? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
Maks0098 Posted March 13, 2025 Posted March 13, 2025 4 hours ago, razor0601 said: For what is that PowerXpress setting exactly? In general, it controls which video card will be responsible for video outputs, integrated or discrete, but this is a Fixed scheme, and Dynamic seems to work like a MUX and, let's say, outside the game you have an image from the integrated one, and during the game the discrete one turns on and the image starts to go directly from it, like in PEG mode This is my understanding, let someone correct me if I misunderstood about Dynamic Scheme. Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
razor0601 Posted October 6, 2025 Author Posted October 6, 2025 Hello again, unfortunately it is not the LVDS Ribbon cable. So it’s the LVDS Converter? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted November 3, 2025 Author Posted November 3, 2025 Anyone has a schematic for me? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
sliderfra Posted November 3, 2025 Posted November 3, 2025 Alienware 18 Viking schematics_Compal LA-9332P VAS10 rX02 201119.pdf Does it work in SG mode with the Nvidia card? I mean using the nvidia card for 3D purpose (not just 2D using intel iGPu) There are many signal converter on the board (for IGPu, DGPu, HDMI, DP,...) so most probably the one dealing with DGPu signal is defective (the chip itself or some kind of cms associated). Could be hard to track down.
razor0601 Posted November 7, 2025 Author Posted November 7, 2025 No, it doesn’t work in SG Mode. The problem is with dGPU on internal screen. Everything else is working Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
sliderfra Posted November 8, 2025 Posted November 8, 2025 On 11/7/2025 at 7:44 AM, razor0601 said: No, it doesn’t work in SG Mode. The problem is with dGPU on internal screen. Everything else is working Well there's something wrong in between the MXM & the LVDS MUX then. Problem is finding the issue itself...
