1610ftw Posted October 20, 2025 Posted October 20, 2025 2 hours ago, Aaron44126 said: AFAIK, there is still no manual fan control option for Dell systems released on 2021 or later. It is a sorry state of things that the big three workstation laptop manufacturers Dell, HP and Lenovo seem to have no way to manually control their fans. At least Dell used to be decent when it comes too keeping fans quiet most of the time while not reducing power. HP seems to have an issue going back to the early Zbooks and to a lesser degree Lenovo, too.
win32asmguy Posted October 20, 2025 Posted October 20, 2025 21 minutes ago, 1610ftw said: It is a sorry state of things that the big three workstation laptop manufacturers Dell, HP and Lenovo seem to have no way to manually control their fans. At least Dell used to be decent when it comes too keeping fans quiet most of the time while not reducing power. HP seems to have an issue going back to the early Zbooks and to a lesser degree Lenovo, too. I think they might consider exposing manual fan control a security concern at this point. To be completely honest I was surprised that the Pro Max 18 Plus does not yet have its EFI variables write protected yet like the Zbook and Thinkpad. The fan noise is better than the previous Precision 7780 and also Thinkpad P16 G2. I spent a bunch of time over the weekend trying to find a way to prevent the power adapter performance locking issue. It seems like it will always eventually happen if the system is in performance mode and under any kind of high load scenario where the battery is draining down while plugged in. I have to box it up and send it back as their support said it was "operating as designed". 1 Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, MSI RTX 5090 Gaming Trio OC, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2
1610ftw Posted October 20, 2025 Posted October 20, 2025 5 minutes ago, win32asmguy said: I think they might consider exposing manual fan control a security concern at this point. To be completely honest I was surprised that the Pro Max 18 Plus does not yet have its EFI variables write protected yet like the Zbook and Thinkpad. The fan noise is better than the previous Precision 7780 and also Thinkpad P16 G2. I spent a bunch of time over the weekend trying to find a way to prevent the power adapter performance locking issue. It seems like it will always eventually happen if the system is in performance mode and under any kind of high load scenario where the battery is draining down while plugged in. I have to box it up and send it back as their support said it was "operating as designed". Yes that is possibly true about the manual fan control and I guess that I could live with fans that are as well behaved as the ones in that I had in the 7760. Sorry to hear that you could not get the locking issue fixed. It inspires little confidence to see all of that happening with the workstation that potentially is the most powerful between the big three manufacturers.
Aaron44126 Posted October 20, 2025 Author Posted October 20, 2025 2 hours ago, 1610ftw said: It is a sorry state of things that the big three workstation laptop manufacturers Dell, HP and Lenovo seem to have no way to manually control their fans. Seems like there should be potential for manual fan control. The BIOS system diagnostics includes a test that manipulates the fan speed. If someone could reverse engineer that and figure out what commands that it is sending to the embedded controller, then you'd have a starting point. (The manual fan control solution that existed for earlier systems, used in many tools like SpeedFan, HWiNFO64, and the Linux kernel, was also reverse engineered from a Dell support tool.) I actually spent a good amount of time fighting with embedded controller commands to figure it out. I ended up discovering some endpoints for reading the fan speed (and system temperatures) that no one else had figured out yet. But I couldn't find a control mechanism. My investigation was pretty brute force, not really based on reverse engineering anything, I don't have the skills for that. Fan behavior in the Precision 7770 is a part of what turned me off from this line of systems altogether. There are a lot of things about my MacBook that I wish were different, but fan behavior is not one of them. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
MyPC8MyBrain Posted October 20, 2025 Posted October 20, 2025 Wooohat... manual fan control, did the world gone mad? that is so pedestrian in an era of self driving cars, solid and basic working technology belongs in the 2000 and prior when things didn't have hidden agendas and corner cutting in mind just so a bunch of deadbeat exec's can buy another weekend house. and don't anyone dear to say they didn't do something in their time. 2 the impossible is not impossible, its just haven't been done yet.
Easa Posted October 21, 2025 Posted October 21, 2025 24 hours with this machine. My feelings and findings so far: The body is really sturdy with amazing torsion strength, does not twist, just acts like an ingot. One screw (front right corner) was loose from the factory. I have not opened the device, yet. As for the problem with the bottom door, well, in the 3D Visualisation on the Dell´s website, the laptop is pictured with some sort of a halved, sliding bottom door (the one that I have posted prior to this post). I do not have this, I have normal bottom cover that is one piece. Anybody here has a PMP18 with this sliding door? Keyboard is...well, its not a ThinkPad but it is not that HP abomination as well. Its quite good. No complaints except for the arrow keys. The 2560x1600 120Hz panel looks amazing color-wise, almost like IPS Black from the new Ultrasharps, but its slow AF. Ghosting is just there. Lenovo had way better panel in the P16G2 regarding this. I miss that screen, it was really good. Touchpad is very pleasant to work with, both its surface and the click feedback are good. Fan behavior is very good, at least during office work and basic multitasking its like passive or just very quiet, have not had a chance to try out some proper loads except benchmarks. Surface temperatures are pleasant. Sound coming from the speakers is nice. Not MacBook Pro level nice, but usable for both movies and some background music. Weirdly bugged Optimus. I have installed iGPU drivers from Dell. They install as a driver only, without the control panel. If I install the control panel for the Intel iGPU manually from MS Store, it results in bugged Optimus, with the dGPU (RTX 4000) running at 8W idle basically non-stop. Have you encountered this as well? The battery life is all over the place, ranging from 2 to 6 hours in idle with no apparent causes. The total system consumption is very wild, going from basically zero to 50W, again, without doing anything other than web browser with a few tabs (brightness at 7 out of 10) Fingerprint reader dropped once in 24 hours, was missing in device manager with no apparent cause, was fixed by a reboot. I hope that I wont have to RMA this week after the delivery. The internal, factory 1TB Gen5 (Samsung PM9E1) drive tops out at +- 8400/4000 R/W and I do not know why. Eventlog keeps getting spammed with "Smart Card Reader 'Microsoft UICC ISO Reader rejected IOCTL TRANSMIT: Parameter is incorrect" - seems like a SIM/eSIM issue, I do not use WWAN currently. Anyone getting these errors on their machine? Same thing with PCI Express Endpoint / PCI Express Legacy Endpoint WHEA Corrected errors. I am unable to find the source of these. Laptop seems to be working fine. Score in Passmark seems okay, getting about 62k / 4.8k MT/ST ratings, which are quite higher than the median for the 285HX. This is just some basic rambling about the machine, I will do a proper review once I feel "at home" with it. That feeling aint coming yet. 1 2 ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
win32asmguy Posted October 21, 2025 Posted October 21, 2025 @Easa nice post! If you happen to run some combined load stress tests could you monitor if it periodically trips the ia: rapl/psyspl2 throttle flag reducing the CPU to around 15w until the power supply is disconnected and reconnected? Oh and for Optimus make sure advanced Optimus is not enabled as it is pretty buggy. Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, MSI RTX 5090 Gaming Trio OC, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2
Aaron44126 Posted October 21, 2025 Author Posted October 21, 2025 2 hours ago, Easa said: This is just some basic rambling about the machine, I will do a proper review once I feel "at home" with it. That feeling aint coming yet. Feedback on some of your questions. 7 — Optimus / ongoing power draw from the dGPU I have had issues like this with every Dell Precision system that I have used. I am not sure if it is just an issue with these things, or with Optimus in general. The dGPU tends to get stuck "on" even when nothing is using it. It might be drawing power even when the NVIDIA system tray thing says that it is off. The fix for this is — after booting the system and logging in, wait a minute or two, then go to Device Manager and disable / re-enable the dGPU. After that, it seems to behave properly for the remainder of the session. (At least for me.) I actually have a script that fires at login and uses DevManView to do this automatically. (DevManView supports command line arguments to do things like disable or enable a device without bringing up the GUI.) Also note that tools that monitor the GPU (like GPU-Z) may keep the GPU awake. So if you're "watching" to see if it is behaving, that might be what is causing the problem. 9 — Fingerprint reader dropped I have experienced this occasionally with multiple Precision systems. (I'm talking on the order of maybe 3-4 times a year.) Hopefully it was just a fluke for you. If it is something that happens every now and then, I don't have hope that replacing any component would fix it. 11 — SmartCard reader errors The SmartCard reader is the long, skinny slot on the side, and doesn't have anything to do with the WWAN card or SIM slot. It's for inserting SmartCards which can be used for authentication or I don't know what else. (I have a family member who works for the VA and she always has a SmartCard inserted in her laptop...) Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
Easa Posted October 21, 2025 Posted October 21, 2025 6 hours ago, win32asmguy said: @Easa nice post! If you happen to run some combined load stress tests could you monitor if it periodically trips the ia: rapl/psyspl2 throttle flag reducing the CPU to around 15w until the power supply is disconnected and reconnected? Oh and for Optimus make sure advanced Optimus is not enabled as it is pretty buggy. I will certainly try to observe such behavior, once Ill be able to spend more time with the laptop. Could be during this weekend. 5 hours ago, Aaron44126 said: Feedback on some of your questions. 7 — Optimus / ongoing power draw from the dGPU I have had issues like this with every Dell Precision system that I have used. I am not sure if it is just an issue with these things, or with Optimus in general. The dGPU tends to get stuck "on" even when nothing is using it. It might be drawing power even when the NVIDIA system tray thing says that it is off. The fix for this is — after booting the system and logging in, wait a minute or two, then go to Device Manager and disable / re-enable the dGPU. After that, it seems to behave properly for the remainder of the session. (At least for me.) I actually have a script that fires at login and uses DevManView to do this automatically. (DevManView supports command line arguments to do things like disable or enable a device without bringing up the GUI.) Also note that tools that monitor the GPU (like GPU-Z) may keep the GPU awake. So if you're "watching" to see if it is behaving, that might be what is causing the problem. 9 — Fingerprint reader dropped I have experienced this occasionally with multiple Precision systems. (I'm talking on the order of maybe 3-4 times a year.) Hopefully it was just a fluke for you. If it is something that happens every now and then, I don't have hope that replacing any component would fix it. 11 — SmartCard reader errors The SmartCard reader is the long, skinny slot on the side, and doesn't have anything to do with the WWAN card or SIM slot. It's for inserting SmartCards which can be used for authentication or I don't know what else. (I have a family member who works for the VA and she always has a SmartCard inserted in her laptop...) 7 - Yes, exactly this. Nvidia tray monitor says that the GPU is inactive, but it keeps getting active. Once I got rid of the Intel control panel, it is almost always off, but the corellation with the monitoring software is a spot on! Each time that I open HWInfo from tray, the GPU comes alive for a split second. So no hardware monitoring in the background when I want to maximize the battery, okay. 9 - I do not see any eventlog entries for connecting or reconnecting the FP Reader device. It seems like it only becomes active about 3 second after the login screen appears. First, there is only PIN option, but after a few seconds the fingerprint option appears. It is a FIPS reader, so I get that its a slowpoke. 11 - I know where you are aiming at, but I perfectly understand what is the SC slot - I use Smart Card reader for our Govt application. However, I have done my research regarding this issue, and everything points me to the WWAN. The actual SmartCard reader is called "Broadcom Corp Contacted Smart Card 0" and shows under Software Devices in the Device Manager. This SC Reader is also detected by our Govt software that works directly with the SC Readers. It also registers the Contactless one, and then the third one - Microsoft UICC ISO Reader. I believe that it handles the SIM / Virtual eSIM slot as a SmartCard. https://www.dell.com/support/kbdoc/en-us/000200467/inspiron-latitude-and-precision-wwan-with-esim-causes-login-issues-for-smart-cards ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
Easa Posted October 23, 2025 Posted October 23, 2025 Today, a strange thing happened, or two. So, yesterday evening I have been working on the machine, transitioning from the old laptop, moving databases, installing software, etc. I have also opened the laptop to insert a 990 PRO 2TB drive from my former laptop. Everything was working fine at this point. Once everything was properly set up on the new machine, with the old drive already inside it, I have wiped the 990 PRO with DiskPart and then did a complete read test, zero fill and read test again (to check for degraded NAND). No problems there, however, the common read speeds for the 990 PRO were somewhere at PCIE GEN 3.0 level, hovering around 2.500 MB/s. Also, the factory OS Drive (PM9E1 which is an OEM 9100 PRO) runs somewhere between 6000 to 10.500 MB/s in benchmarks, dont know why. I know that the Sequential R/W is not important, however, I dont know why does it act like this. I yet have to perform a full test in Anvil to see IOPS, but I suspect that the drives are not working to their full potential in this laptop. Could anyone with PMP18 please confirm the drive performance with either CDM, AS SSD or Anvil? After I have finished the work with the drives, I have launched a Passmark Performance Test 3D benchmark to run in a loop till the morning, to test the GPU for possible errors before I fully commit to this machine. This morning (7 hours later) i came to the machine, ended the test, checked HWInfo and tried to restart the OS. When I came back from kitchen, the PC was in recovery mode, unable to post. No luck with startup repair, always loaded just into recovery. The filesystem was fine, the drive was detected, files were accessible. Ran 3 different diagnostics on the OS drive, all fine. Fixed the bootloader partition with bcdboot, everything started working again. I am flabbergasted. Now, is the OS drive failing in some weird, unpredictable way, or it was some Windows shenanigans? ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
MyPC8MyBrain Posted October 23, 2025 Posted October 23, 2025 @Easa The issues regarding NVMe and SSD drive failures, including data loss, have been widely reported and linked primarily to a specific Windows update. The Suspected Update: The update most frequently cited in connection with the drive problems is KB5063878, a security update for Windows 11 version 24H2 (though some reports also mention earlier updates and Windows versions). Symptoms and Conditions: Users reported that after installing the update, drives (NVMe and some SATA SSDs/HDDs) could disappear from the system, fail to boot, or show as RAW/corrupted, leading to data loss. This issue was often observed: During or after large, continuous write loads (e.g., transfers over 50GB). Especially if the drive was more than 60% to 80% full. On systems with specific SSD controllers (particularly Phison, though other brands were mentioned). the impossible is not impossible, its just haven't been done yet.
win32asmguy Posted October 23, 2025 Posted October 23, 2025 I did not have issues with the micron 3500 512gb SSD included with my Pro max, but I also used W10 so maybe that helped with avoiding the SSD issues posted above. I also have a 4tb sn8100 which has worked well in the hydroc g2 but I did not test it in the pro Max. Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, MSI RTX 5090 Gaming Trio OC, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2
al_jabir Posted October 24, 2025 Posted October 24, 2025 Folks, Will this workstation support 8T 9100 PRO SSD NVMe™ M.2 (Samsung)? Thnx
OneSunOne Posted October 25, 2025 Posted October 25, 2025 I recently received my Pro Max 18 Plus, but I’ve been experiencing several persistent issues: The system freezes for a few seconds whenever it switches between the Nvidia Optimus and Intel graphics cards. When streaming video, it periodically freezes for half a second or longer and emits a buzzing sound through the speakers. During these moments, Intel GPU usage spikes noticeably in Task Manager, and the display occasionally goes black for a second or two. Most concerning, the machine freezes and crashes several times a day. It usually begins with the same freezing and buzzing issue, after which the screen goes black. Audio from the video that was playing continues intermittently, but the system never recovers. I have to perform a hard reset each time. I’ve already run multiple hardware diagnostics, but no issues were detected. Any suggestions what I could try? My specs are: Intel 285HX RTX PRO 4000 64gb CSODIMM RAM
1610ftw Posted October 25, 2025 Posted October 25, 2025 1 hour ago, OneSunOne said: I recently received my Pro Max 18 Plus, but I’ve been experiencing several persistent issues: The system freezes for a few seconds whenever it switches between the Nvidia Optimus and Intel graphics cards. When streaming video, it periodically freezes for half a second or longer and emits a buzzing sound through the speakers. During these moments, Intel GPU usage spikes noticeably in Task Manager, and the display occasionally goes black for a second or two. Most concerning, the machine freezes and crashes several times a day. It usually begins with the same freezing and buzzing issue, after which the screen goes black. Audio from the video that was playing continues intermittently, but the system never recovers. I have to perform a hard reset each time. I’ve already run multiple hardware diagnostics, but no issues were detected. Any suggestions what I could try? My specs are: Intel 285HX RTX PRO 4000 64gb CSODIMM RAM is this a setup with external monitors or something else that is connected via Thunderbolt? My X580 does not play nice with my Thunderbolt gear and also crashes but no issues when no Thunderbolt connection is active.
OneSunOne Posted October 25, 2025 Posted October 25, 2025 3 hours ago, 1610ftw said: is this a setup with external monitors or something else that is connected via Thunderbolt? My X580 does not play nice with my Thunderbolt gear and also crashes but no issues when no Thunderbolt connection is active. Thanks for the feedback. Only device connected is a Razer wireless mouse.
1610ftw Posted October 25, 2025 Posted October 25, 2025 1 hour ago, OneSunOne said: Thanks for the feedback. Only device connected is a Razer wireless mouse. Oh, that is bad. You should definitely not have these issues with only a wireless mouse attached to it. Better give Dell a call, they may need to replace it.
Easa Posted October 26, 2025 Posted October 26, 2025 16 hours ago, OneSunOne said: I recently received my Pro Max 18 Plus, but I’ve been experiencing several persistent issues: The system freezes for a few seconds whenever it switches between the Nvidia Optimus and Intel graphics cards. When streaming video, it periodically freezes for half a second or longer and emits a buzzing sound through the speakers. During these moments, Intel GPU usage spikes noticeably in Task Manager, and the display occasionally goes black for a second or two. Most concerning, the machine freezes and crashes several times a day. It usually begins with the same freezing and buzzing issue, after which the screen goes black. Audio from the video that was playing continues intermittently, but the system never recovers. I have to perform a hard reset each time. I have experienced the freeze between Nvidia and Intel GPU switching too, but only when manually doing it through Nvidia control panel (like a software MUX switch), not when launching games and stuff. The buzzing speaker sound I have experienced also, when I am on the battery saving power plan and do some multitasking on the battery whilst listening to spotify through internal speakers. The third issue I have not experienced. ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
OneSunOne Posted October 26, 2025 Posted October 26, 2025 14 hours ago, 1610ftw said: Oh, that is bad. You should definitely not have these issues with only a wireless mouse attached to it. Better give Dell a call, they may need to replace it. Thanks, I'm planning on contacting them tomorrow. I've even tried reinstalling Windows 11 and installing Windows 10 with no resolution to the problem.
OneSunOne Posted October 26, 2025 Posted October 26, 2025 2 hours ago, Easa said: I have experienced the freeze between Nvidia and Intel GPU switching too, but only when manually doing it through Nvidia control panel (like a software MUX switch), not when launching games and stuff. The buzzing speaker sound I have experienced also, when I am on the battery saving power plan and do some multitasking on the battery whilst listening to spotify through internal speakers. The third issue I have not experienced. Thanks for the feedback. When you experience the buzzing speaker issue, could you check if the Intel Gpu's usage shows a spike in task manager ?
OneSunOne Posted November 2, 2025 Posted November 2, 2025 I’m still in discussion with Dell trying to find the cause for this issue. Can I please ask someone with one of these 18inch machines to check if you experience the following: While plugged in and any type of music or video streaming with audio is playing, and you switch power modes, does the speakers make a very slight buzzing noise for a split second every time you change the power mode? You’ll have to listen very carefully for the buzzing noise, it’s not very loud.
pickwick Posted November 2, 2025 Posted November 2, 2025 Hi everyone, I'm interested in the Dell Pro Max 18 Plus as well and have a few questions: 1. Does HDMI work with iGPU only?Are there any relevant display restirctions with iGPU only? I'm not a gamer in theory and might be interested in the dGPU because of AI stuff or maybe CUDA or similar experiments, while that add-on is pretty expensive. So I might as well not use dGPU at all, but I don't fully understand the docs about the different GPU modes and some of those mentioned HDMI using dGPU only. https://www.dell.com/support/manuals/de-de/dell-pro-max-mb18250-laptop/dell-pro-max-18-plus-mb18250-edg/external-display-connection-mode?guid=guid-344c59dd-2d9c-4d7c-89bd-11fb2b02b2ad&lang=en-us 2. Any experiences with Linux-support? I'm considering switching from Windows 10 to Linux, most likely Ubuntu 24.04 LTS for a long time already. Would like to know especially about firmware updates of BIOS, possibly dGPUs and stuff. Have a Thinkpad P15vGen2 at work and that gets firmware updates regularly using a special Windows tool. My current private laptop is out-of-support for many years already, so I can't compare. For a new device, I guess it makes sense to be able to update firmwares somewhat regularly. Other manufactures like Schenker support that using UEFI-shell. Dell seems to publish some firmware updates using Linux infrastructure, but would like to know if anyone used that already and how well it works. https://www.dell.com/support/product-details/de-de/product/dell-pro-max-mb18250-laptop/drivers https://fwupd.org/lvfs/devices/com.dell.uefi96cf79fb.firmware 3. Performance hickups? I'Ve read in two comments about new users who described that their devices either seem to lock CPU+GPU performance under certain conditions or that they get strange delays when switchin GPUs, with strange sounds and stuff. Did anyone else observe sduch behaviour? 4. Slow display with ghosting? One user did describe the display as slow with visibale ghosting, others seem to be pretty happy about. Again, am not a gamer, so does ghosting/slowness happen on Linux/Windows desktops and apps as well? I have somewhat old FHD displays only currently, in my old laptops, the externals displays. So the quality of the Dell display is most likely better than what I have anyway? Thoiugh, my external displays are Eizos, so somehwat high quality at the time when bought. 5. What about Qualcomm NPUs? When reading about the Dell, some Qualcomm NPUs as replacement of the GPUs were mentioned multiple times. But I wasn't able to find any prices or details, only some mentions of 64 GiB RAM and stuff. Did anyone have any news about that? Again, I'm not a gamer, but might(!) be interested in AI. Would be interesting to know a price point compared to the different dGPU possible in the device. 6. Anyone regretting already and why? This device is pretty expensive and currently I'm even a private interestee only... 🙂 OTOH, I went pretty well with my former Fujitsu Celsius H730, which was somewhat similar in price. Many thanks for any of your insights!
pickwick Posted November 2, 2025 Posted November 2, 2025 Missed one thing: 7. Does anyone use Thunderbolt to DVI-D adapters? I'm having two external displays, shared by a business and private laptop. One display has a free HDMI and the other one DVI-D. The Dell has native HDMI in theory, which would leave me with an additional DVI-D to be supported. There seem to exist adapters form thunderbolt/USB-C to DVI-D for small prices. I only need to support 1920*1200. Those adapters should work, shouldn't they?
Aaron44126 Posted November 3, 2025 Author Posted November 3, 2025 13 hours ago, pickwick said: Hi everyone, I'm interested in the Dell Pro Max 18 Plus as well and have a few questions: I can answer a couple. 1. If you get an iGPU-only system, you will be able to use the HDMI port and it will be attached to the iGPU. 2. You can do firmware updates from Linux if capsule updates are enabled in BIOS setup, and you can also do pre-boot BIOS updates (regardless of the OS), if you hit F12 at the boot screen there will be an option to update the BIOS using a file stored on a USB flash drive. Dell very rarely posts gGPU vBIOS updates, most systems never get one. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
SvenC Posted November 3, 2025 Posted November 3, 2025 I have the 18" with iGPU only and love it. Great display indoors and outdoors. Mobility is good for me. Worked in a train, Hotel no problem. WLAN and WWAN are great. Keyboard and touchpad good. Old Dock wd 19 dc works flawlessly with keyboard, LAN and two external displays plus internal display. No regrets 😀 1 Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
