2 hours ago, OneSunOne said:
1- The machine freezes for a split second every few minutes. When audio is playing at the same time, it also makes a buzzing noise through the speakers when it freezes/stutters for the split second.
2- When pushing the machine hard (doing rendering work), it freezes/stutters more often, to the point that it sounds like a popping/crackling noise coming from the speakers.
Run LatencyMon. Go to the Drivers tab. Sort it by "highest execution". After you experience one of these stutters, see which one is at the top of the list. (All drivers should finish their work in less than 1ms, so ideally you wouldn't see anything over 1ms. However, anything over a low single digit milliseconds is especially bad and can lead to audio and system stutters.)
Does anyone have one of these systems who is not experiencing problems with it? This sounds even worse than what I was experiencing with the Precision 7770. (Combined issues from Dell, Intel, NVIDIA, and Microsoft on that system is what forced me to rethink what ecosystem I am even using...)
both 7770 and the later 7780 were before they decided in all their wisdom to stack both dGpu and CPU on top of each other for the perfect "easy bake oven" effect.
Thank you very much for the advice. I ran LatencyMon, can you make sense of the attached results?
@OneSunOne
If your BIOS is set to RAID (Dell's default on many models), it ramps up storport.sys latency. Switching to AHCI mode often drops this dramatically and boosts consistency in I/O-heavy benchmarks. After that, uninstall Intel RST drivers and let Windows use its native NVMe ones.
to do this change you must follow these steps to the T,
if you missed F2 reboot and try again until you get it right
(do not change this bios setting in any other order or you risk bricking your windows boot!)
from windows admin command prompt issue perform the following in this order
Enable Safe Mod:
bcdedit /set {current} safeboot minimal
shutdown /r /t 0
reboot, enter BIOS (Press F2 during post)
Change SATA / Storage mode from RAID / RST → AHCI
Save and exit BIOS
Windows will now continue to boot into Safe Mode, once in Safe mode,
from windows admin command prompt issue this command to Disable Safe Mode and boot back to Windows:
bcdedit /deletevalue {current} safeboot
shutdown /r /t 0
Windows will now boot cleanly in AHCI mode,
if you still have the same issue afterwards report back.
The biggest offender on there by far is ACPI.sys. That value 43ms is way too high. (I care about "highest execution" more than "total execution". This is saying that there was at least one time where ACPI.sys grabbed control of your system for a full 43ms straight. A high number in "total execution" is fine — a driver can do a lot of work as long as it is returning control quickly.)
ACPI is power management. Unfortunately, even having a starting point like this, it can be difficult to figure out "what to do about it".
Question, though. Does your system have an NVIDIA GPU? Can you go without it for a while (assuming graphics switching is turned on)? Try disabling the NVIDIA GPU in Device Manager and see if you still run into the stuttering behavior.
@MyPC8MyBrain is right, disabling RAID in BIOS can help if you don't actually need it. But I don't think that's going to be the main problem here.
absolutely agree!
this is the main reason i didn't suggest more steps atm and was carefully building up to it from the logical starting point.
(i did notice both the ACPI issue and NVIDIA potential)
3 hours ago, MyPC8MyBrain said:
@OneSunOne
Enable Safe Mod:
shutdown /r /t 0
Save and exit BIOS
shutdown /r /t 0
This is great, thank you very much. I've switched to AHCI but I unfortunately still experience the same problem. This is the LatencyMon results after changing to AHCI:
Thanks! Yes, I have the RTX 4000 Blackwell GPU. I've disabled it but still experience the same issue. Do you think the ACPI.sys error points to a hardware or software issue?
I've attached the LatencyMon results after disabling the Nvidia GPU.
some, it confirms storport.sys + iaStorVD.sys were interfering before (a clean fresh windows install after the BIOS change is highly recommended for perfect driver stack)
did you uninstall the Intel Intel Rapid Storage / RST drivers and revert to using windows native drivers?
In Device Manager > Storage controllers > uninstall any remaining Intel RST entries (right-click > uninstall device (select to also delete drivers), reboot).
Let Windows use its standard NVMe driver.
> Rerun LatencyMon - storport/iaStorVD spikes should drop significantly.
ACPI.sys and kernel stuff here point to throttling.
Disable CPU features like Intel SpeedStep or C-States in BIOS to keep things steady during benchmarks.
also for your NVME controller, look for firmware update for it or if possible test with alternate drive just for validation purposes.
as for NVIDIA involvement clean reinstall drivers with DDU tool, and check for power saving modes in NVIDIA Control Panel that might be interfering.
Quick tweaks (do these anyway):
  • Power plan - High Performance (disable all sleep/USB suspend in advanced settings, in particular look for and sleep features for the NVME drive or power saving nonsense).
  • Update BIOS + chipset drivers straight from Dell's site for your your exact model (do not count on the drivers that shipped with the default system).
  • NVIDIA Control Panel > Manage 3D Settings > Power management mode = Prefer maximum performance.
  • Uninstall Dell SupportAssist / Optimizer if installed (known latency contributors).
  • Rerun LatencyMon after each change to confirm drops.
Did anyone with problems under load, sound hick-ups etc. already tried to put the machine under load with Live-Linux? There are different benchmarks as well and might be a good additional argument if there are serious hardware problems or Microsoft, drivers and bloat-bullshit by Dell are more likely to blame.
Try enabling "Block S3 Sleep" in the bios and see if that helps. It disables most of the ACPI code pathways for modern standby so if something is getting hung up trying to transition between power states it may help.
On 1/31/2026 at 3:33 PM, OneSunOne said:
What parts did they replace?
I'm also getting tired of this machine. I've been experiencing the following issues:
3. Every now and then when rendering, the machine would crash, forcing a restart.
Dell has replaced the speakers and system board twice.
I also believe it's a platform problem.
They have replaced the motherboard, fan and heatsink with pre-applied TIM.
1 - I am also having this issue but the buzzing is not always there
ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+
COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20
SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω
MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
On 1/31/2026 at 6:31 AM, Easa said:
WHEA and ACPI Errors of the  are still present after each reboot.
WHEA errors are commonly observed in daughterboard designs that rely on PCIe bridges (such as DGFF), especially on PCIe 4.0+ systems. Replacing the motherboard alone will not resolve the underlying signal-integrity issues. I have observed this problem on my Precision 7670/7680, so I am not surprised that it has not been fully addressed by Dell in this generation.
I noticed that Lenovo uses CAMM as the dGPU board interposer. How is your friend’s P16 Gen 3? Has he encountered similar issues?
Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe
Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
The issue I am currently facing is related to the power adapter. When I travel, I use a 28 V 140 W adapter. I have noticed that once the system is connected to the 140 W adapter, the dGPU TGP becomes locked at 115 W, even using the genuine 280W brick. The only way to restore the 175 W TGP profile is to reset the BIOS to factory defaults.
I am not sure how Dell has implemented the relevant BIOS logic, but the overall behavior feels quite buggy.
did you try manually changing PL1 limit?
CPU PowerLimit isn't affected
you're right, i was referencing another scenario in my mind 😅
Follow up: After some mails were exchanged, I was offered a full refund from Dell. I am probably going this way, the machine was frustrating enough.
im glad to hear that 👍
credit where credit is due, at the end of the day no vendors comes close to Dell's customer service standing behind their hardware.
It's literally a 4-cell battery; why does Dell state it comes with a 6-cell battery option?🤣
I'm on a 10+ yr old Precision 7710 m5000m win11 setup.   It's been great and no complaints and it is mint condition.  Although I'm looking to replace the workhorse  for a newer gen.
Based on recent posts, is this Dell Pro Max a good system?  Or is this something I should maybe not consider due to issues I'm reading about?
Here is my use case
I would need windows as the Operating system because I'm a contractor who needs a machine compatible at various  customers.  Although I'm most often in VMware Workstastion pro in a guest Win11 VM which VPNs to my customer network, so that way their VPN won't interfere with my Laptop's host OS and I can keep it isolated from my laptops host OS.
I work heavily in Oracle Linux for installations and upgrading my customers Oracle products such as Oracle DBs, EBS Applications, APEX, etc.
I guess I could have a Linux OS on the laptop as it's host OS and then use a virtualization software to install win11 guest VM.  But I'd prefer to keep the laptop on windows I think, just so I'm not on some fringe edge setup.  I don't need a big GPU, but I do like to game on Steam sometimes.  I'm more an older GOG type though.
I've always liked the Dell Precision laptops, but sounds like alot of weird issues right now with the Max Pro.  I remember the 7x10 series had it's share of issues when they launched, but my 7710 is running great still after 10 yrs.  I just want somthing newer that is fully supported. *My 7710 is not meant to run on Win11 for example, yet it is.
If not the Max Pro, what is another next best? *doesn't even have to be Dell but I'd like it to be a professional series.
thanks.
Benny
you over complicating things, install WSL (Windows Subsystem for Linux) and run any distro you like inside windows
I have not used one personally. However, I haven't heard from anyone who seems to have an overall good impression. 😕
I mean, really the only options in this category are Dell, HP, and Lenovo. At my office, we have switched from Dell Precision to Lenovo P16 for dev workstations. I have not used of the Lenovos myself personally, though, either. I passed on the "upgrade" and I am going to be switching to MacBook Pro for work as soon as I can.
Dell Pro Max 18 Plus with iGPU only works pretty well.
Battery drain is OK - too much is typically caused by virus full scans and Windows Updates and sometimes the Windows search indexer goes crazy - If those processes are "sleeping" I get around 5 to 6 hours on light work with dimmed display.
One glitch with the latest Dell provided Intel graphics driver which turns off the brightness control - brightness always max - Windows UI brightness controls do not work either - had to install the old driver and block Windows Update from installing new drivers automatically - sigh...
So, the hardware seems pretty OK for my tasks - maybe the additional dGPU cause too much stress if CPU and GPU are used.
Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU
previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200
previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
I’m satisfied with what I got from the Pro Max Plus 16-inch model, the build quality and performance are decent. It’s better than any of the Precision machines I’ve owned before, including the 7550, 7760, 7670, 7680, and 7780, in many respects. Plus, the 4K 120Hz Tandem OLED is wild, if you are not sensitive on OLED panel, don't miss that option.
In my opinion, if you’re looking for a true workstation-class machine, I would not recommend the ThinkPad P16 Gen 3. This model is heavily limited by its preset power limits and power adapter. The combined power budget is only 15W for the CPU plus 115W for the GPU. If you don't care about performance, P16 Gen3 is still acceptable.
HP ZBook Fury is probably another option worth exploring. Honestly, I don’t have any experience with HP laptops, so I can’t comment on it.
