Will Posted November 14, 2025 Posted November 14, 2025 Ever since I found out about mobile workstations, I've always wanted to have a Dell Precision 7720, both because of its design, which I personally think is really cool (especially its internal layout), and because its the last Precision with an MXM slot before Dell switched to the DGFF format starting with the 7XX30 series. Then one day, while browsing OLX, I was lucky enough to find a Dell Precision 7710 for a low price. The laptop was listed as "for parts" and untested, and its specifications weren’t provided, but from the pictures in the listing, it was clear that many parts were missing, such as the heatsink + fans, keyboard, RAM, SSD, AC adapter, etc. Even so, I thought it was a good deal, so I bought it. Here are the pictures from the seller: I believe this will be a very interesting project, so in this thread I will post the progress of my journey in refurbishing/upgrading this amazing machine. 1 2
Will Posted November 23, 2025 Author Posted November 23, 2025 UPDATE #1: I've started buying the necessary parts for the refurbishment/upgrade project. I'll be purchasing most of the parts from China, from sites like Taobao, Xianyu, etc. The first parts I bought were: • 240W GaN AC Adapter (DP/N 0YR68) • NVIDIA Heatsink + Fans (DP/N 0YJNJK) • Memory RAM Cover (DP/N AM1DJ000300) As soon as the parts arrived, I installed the heatsink + fans, put in some RAM sticks and an SSD that I already had, and tried to turn the laptop on. To my surprise, it booted, but I immediately noticed that the screen was defective. Aside from the screen, everything works perfectly: speakers, touchpad, USB ports, fingerprint reader, RAM slots, etc. However, when I took the motherboard out to clean it, I had an unpleasant surprise: a component was knocked off, and even worse, apparently the pads were also ripped off: Taking a look at the boardview, this is what I got: This is where I ask you guys for help, does anyone know exactly what this component does? I tested the motherboard's SATA port and it's working perfectly, full speed. I don't have the necessary skills, but I'm thinking of trying to repair it someday. Anyway, I bought a Dell Precision 7720 motherboard with Xeon E3-1535M v6 (I had originally ordered a motherboard with Xeon E3-1575M v5 because of its 128MB L4 cache, but the seller told me it was out of stock, so they offered me the 1535M v6) on Aliexpress and I'm waiting for it to arrive. Just out of curiosity, before I installed the heatsink, I took the opportunity to install a Clevo GTX 670MX with faulty VRAM chips that I had lying around to see if the Precision would recognize it — and yes, it did, and I was able to install the drivers normally on Windows 10. Here are the pictures:
GuitarG Posted November 23, 2025 Posted November 23, 2025 That component turns on sata led activity, in simple answer. Regarding project, have fun and good luck! Few months ago I helped my friend to repaste his Precision 7520. He does have mxm slot too, but unfortunately it’s smaller A version. Nice laptops, though! 1
Will Posted November 23, 2025 Author Posted November 23, 2025 10 hours ago, GuitarG said: That component turns on sata led activity, in simple answer. Regarding project, have fun and good luck! Few months ago I helped my friend to repaste his Precision 7520. He does have mxm slot too, but unfortunately it’s smaller A version. Nice laptops, though! Oh, that's what I thought, so it's nothing critical. Thank you for answering me, your topic about the 8570w is a great inspiration to me! And indeed, they are great laptops.
Will Posted December 7, 2025 Author Posted December 7, 2025 UPDATE #2: The motherboard I bought from Aliexpress has finally arrived. After a visual inspection, I noticed a few things: • Indeed, it's a Precision 7720 motherboard (LA-E321P) • The seller forgot the CPU heatsink mounting bracket • The NS692417 IC chip has a cracked package • The seller told me it was a Xeon motherboard, but the DP/N 05V4K9 indicates it is an i7-7920HQ model. At first, I thought there were two possibilities: either the seller sent me an i7-7920HQ motherboard by mistake, or it's a motherboard that was previously repaired and had its CPU replaced. • Judging by the solder flux residue marks and other details like "bubbles" on the insulation sheet, the latter option is correct: the motherboard has been previously repaired, as expected. After the visual inspection, I installed the motherboard in the chassis and tried to boot it even without the CPU heatsink mounting bracket. After some struggling with shutdowns due to high temperatures caused by improper contact between the heatsink and the CPU die (I didn’t want to take the CPU heatsink mounting bracket from the 7710 motherboard because I want to keep it as "original" as possible), I was able to access the BIOS and got confirmation: the CPU is indeed a Xeon E3-1535M v6, just as the seller told me. NOW IT'S OFFICIALLY A 7720! After that, I booted into Windows and tested all the functions: RAM slots, SSD slots, MXM slot, WLAN slot, etc. Everything is working normally. As for the CPU heatsink mounting bracket, I have already bought a defective 7710 motherboard to remove its bracket. While I was installing the "new" motherboard, I made a mistake. I really wish I had seen this comment earlier: So, the thing is: the 7710 left side IO daughterboard (DP/N 0CJFG2) connected just fine to the 7720 motherboard, but when i tried to connect the right side IO daughterboard (Dell P/N 0GMNG8) to the 7720 motherboard, I noticed that it wasn’t fitting correctly, even though it was perfectly aligned, so I forced it and ended up damaging the plastic guides for the connection. Now somehow I will try to fix that plastic guide, and I think I’ll have to buy a 7720 right side IO daughterboard. Well, despite everything, I consider this 7720 motherboard was a good deal, since it’s working and I got it for really cheap.
Will Posted December 15, 2025 Author Posted December 15, 2025 UPDATE #3: A few more parts have arrived: • Dell Latitude E5550 Keyboard with Backlight (DP/N 0383D7) • Dell Precision 7720 US Keyboard Bezel (DP/N 0KKXK6) • SATA M.2 Interposer Board (DP/N 0WPTND) • SATA M.2 Bracket (DP/N 0Y1WJX) • UHD (4K) eDP LCD Video Ribbon Cable (06GXDN) • Dell Precision 7720 Screw Kit The SATA M.2 Interposer Board is working perfectly. Here’s a speed comparison and a picture of how it looks like installed in the HDD caddy: The keyboard is also working perfectly (I hadn’t installed the keyboard bezel in the picture). Now something I hadn’t noticed before: the Xeon E3-1535M v6 motherboard that I got has a missing SMD electrolytic capacitor: I’ll look for an identical capacitor and try to solder it. I don’t have much knowledge of electronics, so if anyone can tell me exactly how I should search for it to buy the same one, I’d appreciate it.
Annihilator Posted February 14 Posted February 14 just for info: 30 mins ago tried on my 7720 the kingston furyX 3200 C20 2x8GB, main mem slots no post, secundary slots will post but keyboard wont work n freezing at the win boot spinning circle... so 3200 doesnt work with 7720 + 7820HQ, now im looking for 2933(2666 will work anyway bcs is officially in the 7720 specs). when even the 2933 wont work, will go down to the 2666 C15, they r low latency n that will give a boost anyway + 266MHz more to the original 2400 C17. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
JadeRover Posted February 14 Posted February 14 6 hours ago, Annihilator said: just for info: 30 mins ago tried on my 7720 the kingston furyX 3200 C20 2x8GB, main mem slots no post, secundary slots will post but keyboard wont work n freezing at the win boot spinning circle... so 3200 doesnt work with 7720 + 7820HQ, now im looking for 2933(2666 will work anyway bcs is officially in the 7720 specs). when even the 2933 wont work, will go down to the 2666 C15, they r low latency n that will give a boost anyway + 266MHz more to the original 2400 C17. Hello, I would be interested in doing some ram upgrades to my 7720 as well, currently I have a i7-6820hq running 16g of 2666mhz samsung ram (don't know the latency), not sure how dell forces the 6820hq to run with 2666mhz ram as on intel it says 2133mhz max and zbook 17 g3/g4 run it at 2400mhz. I am planning to upgrade to a 7920hq. Do you think this processot can run with higher frequency ram ? 2933mhz, 3200mhz ? An you enable these speeds with nvram edits ? Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
SuperMG Posted February 14 Posted February 14 1 hour ago, JadeRover said: Hello, I would be interested in doing some ram upgrades to my 7720 as well, currently I have a i7-6820hq running 16g of 2666mhz samsung ram (don't know the latency), not sure how dell forces the 6820hq to run with 2666mhz ram as on intel it says 2133mhz max and zbook 17 g3/g4 run it at 2400mhz. I am planning to upgrade to a 7920hq. Do you think this processot can run with higher frequency ram ? 2933mhz, 3200mhz ? An you enable these speeds with nvram edits ? I have 2666MHz max on 7820HQ.
Annihilator Posted February 15 Posted February 15 2 hours ago, JadeRover said: Hello, I would be interested in doing some ram upgrades to my 7720 as well, currently I have a i7-6820hq running 16g of 2666mhz samsung ram (don't know the latency), not sure how dell forces the 6820hq to run with 2666mhz ram as on intel it says 2133mhz max and zbook 17 g3/g4 run it at 2400mhz. I am planning to upgrade to a 7920hq. Do you think this processot can run with higher frequency ram ? 2933mhz, 3200mhz ? An you enable these speeds with nvram edits ? this mem set the speed automatically via XMP, n the 7920HQ is the same CPU like mine 7820HQ just higher clocks, so i would suppose: nope, n 2933 will see when i get a kit of it, otherwise will put 2666 C15 in, should end up at +2-5% on the AVR frames n up to 12% at the 1% lows compared to the stock 2400 C17(with really bad subtimings) mem. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted February 15 Posted February 15 1 hour ago, SuperMG said: I have 2666MHz max on 7820HQ. do u tried 2933 furys? they r hard to find, its like ddr3l 2133 😄 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted February 16 Posted February 16 P5200 works flawless in the 7720: NVIDIA Quadro P5200 Grafikkarten Benchmark Resultat - Intel Core i7-7820HQ Processor,Dell Inc. 0F2JMF Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
JadeRover Posted February 18 Posted February 18 On 2/15/2026 at 1:19 AM, Annihilator said: do u tried 2933 furys? they r hard to find, its like ddr3l 2133 😄 Do you thing it will work to use 3200Mhz ram (I have a few kits) and then via the programs linked here : create an XMP profile for 2933Mhz and possibly 3200mz ? Since the chips on the 3200mhz jedec stick will support up to 3200mhz ? I already used these programs to OC some DDR3L, there are options for DDR4 too. We just need to hope that the 7720 allows writing to ram spd Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
JadeRover Posted February 18 Posted February 18 @Will Hello, I've been following your 7720 adventure and I think I will soon start mine, upgrading to a 7920HQ motherboard. Do you have the turbo bins overclock number for the xeon CPU you have ? It can be found here in throttlestop -> FIVR windows I would like to know what the value is for your xeon CPU. I know for a fact that the 7920HQ allows up to +6 turbo bins meaning max 1 core speed of 4.1Ghz -> 4.7Ghz possible. This is quite rare, usually i7s have +4 bins, and for XEONS cpus data is basically unavailable. Thanks ! have a good one Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
Annihilator Posted February 18 Posted February 18 4 hours ago, JadeRover said: @Will Hello, I've been following your 7720 adventure and I think I will soon start mine, upgrading to a 7920HQ motherboard. Do you have the turbo bins overclock number for the xeon CPU you have ? It can be found here in throttlestop -> FIVR windows I would like to know what the value is for your xeon CPU. I know for a fact that the 7920HQ allows up to +6 turbo bins meaning max 1 core speed of 4.1Ghz -> 4.7Ghz possible. This is quite rare, usually i7s have +4 bins, and for XEONS cpus data is basically unavailable. Thanks ! have a good one atm i have the 7820HQ, but when i able to run the P5200 finally in my M6800 i will do bi upgrade to the XEON + RTX 3080(maybe 4090, we will see what im willing to spend on it 😄 ) n atm i found a kingston 2933 2x8 kit, when working will take a 2x16 kit, n even seen gskill has a 2800 n a 3000 kit, maybe worth da try too... n when upgrading to RTX will take a 4k display, bcs otherwise the CPU would be a massive bottleneck n at 4k not really matters the CPU only has 3.9GHz Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
JadeRover Posted February 19 Posted February 19 @Annihilator You can try this tool to edit memory profiles from the hidden bios "memory overclocking", you can select 2 XMP profile or even create a custom profile from the menu directly. GitHub - DavidS95/Smokeless_UMAF It should work as in this discussion, this user said it worked on his i5-8300H latitude 5591 Any way this could work on Intel-based models? · DavidS95/Smokeless_UMAF · Discussion #6 · GitHub And I checked, precision 7720 and Latitude 5591 share the exact same hidden memory overclocking menu (looking at the IFR of both laptop's bios dumps). I think what should work best (and for a lesser cost) is buying standard 3200Mhz ram (nothing fancy) and then uses this hidden menu to push the integrated memory controller of the CPU to it's limits by creating custom memory profile @ 2933Mhz and even 3200Mhz if it's possible. more info here, as this tool was used for preecision 7780 -> I'll try myself in a few days when I have access to my 7720 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
JadeRover Posted February 19 Posted February 19 On 12/15/2025 at 1:20 AM, Will said: Now something I hadn’t noticed before: the Xeon E3-1535M v6 motherboard that I got has a missing SMD electrolytic capacitor: @Will, it indeed appears that you are missing a capacitor (compairing to pictures on the internet). I wouldn't worry about it too much, it's just a decoupling capacitor that is there to make sure that the voltage drop that appears on the VRM input when the cpu suddenly turbos (= current spike), isn't too important. You still have another capacitor in // to the one you are missing : see the schematic : If you want to replace it, you'd want to get a "100 micro Farads 25v SMD capacitor". I recommend salvaging one from a dead/spare motherboard, from another laptop, not worth it to buy a new one just for that. Make sure it is 25v and you will be fine, these are quite big and are can be desoldered without problems, just make sure to not touch the dome with you soldering irong, just desolder at the legs. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
Annihilator Posted February 19 Posted February 19 4 hours ago, JadeRover said: @Annihilator You can try this tool to edit memory profiles from the hidden bios "memory overclocking", you can select 2 XMP profile or even create a custom profile from the menu directly. GitHub - DavidS95/Smokeless_UMAF It should work as in this discussion, this user said it worked on his i5-8300H latitude 5591 Any way this could work on Intel-based models? · DavidS95/Smokeless_UMAF · Discussion #6 · GitHub And I checked, precision 7720 and Latitude 5591 share the exact same hidden memory overclocking menu (looking at the IFR of both laptop's bios dumps). I think what should work best (and for a lesser cost) is buying standard 3200Mhz ram (nothing fancy) and then uses this hidden menu to push the integrated memory controller of the CPU to it's limits by creating custom memory profile @ 2933Mhz and even 3200Mhz if it's possible. more info here, as this tool was used for preecision 7780 -> I'll try myself in a few days when I have access to my 7720 when it works let me know... need a bios flashback anyway but i not get it to put the old 1.15.1 files into the 1.40 bios container... 😬 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
