Hello people.
I managed to get the RTX 4080 to work on the M6800 eDP UEFI version. No Haswell TDP bugs, displays on eDP and can do 154W max.
The same GPU worked on the Clevo P570WM eDP 120Hz 3D laptop (UEFI, 2012, Ivy bridge)
However, I tried to use this GPU (with the backlight mod cable) on the Dell Precision M6700 with the eDP 120Hz screen and... It doesn't work.
eDP cable is plugged with the backlight mod and the computer doesn't boot, laptop stays on
eDP cable is unplugged with the backlight mod cable computer doesn't boot, laptop stays on
HDMI is plugged, eDP cable is unplugged with the backlight mod and the computer boots to the bios (external display)
The RTX 4080 has eDP on DP_D. The M6700 has eDP set on DP_D. The M6800 also has eDP on DP_D.
So what's the difference between the M6700 and M6800? Why it doesn't work?
The RTX 3000 from HP works on both laptops. So the maximum I can do for the M6700 is RTX Turing from HP?
Any help?
Edited by SuperMG
different eDP ports?
Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro
  • SuperMG changed the title to Dell Precision M6700 RTX Ampère and Ada Lovelace issues
No this is wrong.
Both are eDP, same connectors.
It's eDP on DP_D for both, the same as on the RTX 3000 from HP.
trying a bios on the 4080 with less PL maybe? possible the m4700 cant deliver enough power for the whole system?
No it's not... It doesn't use 100% TDP on the BIOS. This is also wrong. And we're talking about the M6700.
Also no other VBIOS are compatible with this GPU.
just know from desktop, when u hit the power button, the whole system has a peak before bios is loaded... think same for laptop?
may try with only 1 mem module n disconnect all drives to save some power to test.
The laptop stays on, no boot, nothing. Before it does some HDD status led blinking and then nothing. So power isn't an issue because the laptop would immediately force shutdown. Memory isn't an issue. Unplugging the CMOS isn't solving the boot issue.
The pc boots externally in HDMI out by unplugging the eDP LCD cable, so it's none of these issues...
I don't think this is the case here. The laptop turns on and doesn't post unless a certain configuration is used. The laptop fails to detect/work with the video card and doesn't turn on because of that, this isn't a power related problem, more of a vbios / UEFI / Bios setting that comes into play.
Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded
think the m4700 has fallback mode like m4800 has, when dedicated graphics dont work, igpu will set automatically to primary.
iGPU can't be used with eDP displays in this system, only LVDS.
Okay let me try. Everytime I switch the settings, it get resetted maybe because of the CMOS battery, that's why I gave up. Let me switch that.
You can replace it for cheap with a regular cr2032 battery and some tape, see here
I already did that, very hard to remove the soldered joints but was able to get a working battery.
uhhh, so the m6800 is a massive step forward 😄
or u can order this:
Für Himbeer Pi 5 RTC Batterie kasten Echtzeituhr halter mit Batterie/ohne Batterie Echtzeituhr Batterie modul - AliExpress 502
i needed for my old PC, much easier to handle with open, put battery in, n done... when ur system is still plugged in, even no bios data loss. and u need to check the plug size, maybe u need a different model for the m6700
I was referring to M4700/M6700 here. These systems can only use iGPU with an LVDS panel.
Anything eDP is related to the dGPU unlike the M6800. The M6800 can do iGPU or dGPU in eDP. The M6700 has 40 pins and 4 lines so that's good. Easy 1080p 120Hz and 1440p 120Hz.
The M6800 is stuck at 1080p 60Hz.
16RmeIYK578oQRTfzMcaIr8a1Pee9BkB6=s1500
Just get a 100% working CMOS battery, set the bios to UEFI and no LEGACY OPROM and there you go. RTX Ada working on eDP 1080p 120Hz. No Optimus, no MUX Switch.
If we set to UEFI and LEGACY OPROM enabled, the GPU displays 4-5 blinking on the top left corner of the screen and then... Nothing. No boot, laptop stays on.
Now I need to figure out how to disable the LEGACY OPROM. I'll probably disassemble the whole laptop, unplug the eDP LCD and force the boot to HDMI out. Legacy works with HDMI because I tried once and I can disable LEGACY OPROM so I'll obtain the eDP display back.
I enabled the legacy oprom to use the shell grub...
  • Thanks 2
I tested with the Cicichen heatsink, it's poor performance way way poorer than the M6800 with bad heatpipes... Waste of 100 USD to be honest. 3 heatpipes full copper, can't handle 150W...
Heaven benchmark good temperatures but...
On M6800 I get 245FPS and on M6700 I get 170FPS...
Furmark seems similar, mostly throttled because of the thermal throttle.
Userbenchmark doesn't power throttle. I get 86% on M6800 and on M6700 66%. Both laptops can do 150W max on the MXM slot.
I compared the numbers and only one of the benchmark had a bad result, the rest were the same as on M6800.
But I don't understand why there's a big FPS gap in Heaven benchmark... The temperature stayed the same for both M6700 and M6800 heatsinks. The 3940XM is way better than the 4940MX in scores, so that's not a CPU issue.
at same clock n memory speed ivy is 3-9% slower then haswell in games(mostly bcs of reduced cache latency)... n u checked the PCIe speed goin up when starting 3D stuff? had it on desktop once with my old 3060, driver bug n speed was even in 3D at 16x1.0 n not 16x4.0 n was a massive frame drop.
I tested the Quadro RTX 5000 MXM on the M6700 120Hz and I get 185FPS on heaven benchmark... So more than the 4080???
That's strange and yes I didn't use the same drivers. Although I used the same drivers version for the 4080 on the M6700 and M6800.
Furmark:
Quadro RTX 5000: 90FPS
RTX 4080 heavily thermal throttled: 262FPS
(M6800 eDP) 4080 heavily thermal throttled: 290FPS
Furmark:
do u checked with rivatuner the utilization of CPU n GPU during a run?
The GPU was at 80-90W during heaven in the M6700, with a max of 120W. M6800 was at 115-125W during the heaven benchmark, with a max of 150W.
The issue sounds like thermal constraints since power fluctuates, if it was a steady 100w on the m6700 you would now that you are power limited by the MXM slot.
I'm guessing CPU is around 20-40% utilization so that isn't a bottleneck, same for PCIe speeds, both should be at 16x3.0
It could maybe be a driver issue because I didn't have any thermal throttle on the graph.
Because I couldn't even edit anything in the Nvidia control panel, I probably did a bad installation thru NVCLEANSTALL. But anyway this heatsink isn't suitable for the RTX 150W. Even for the 135W ones... But the M6800 heatsink sounds more promising because it has a little bit more of endurance and I have the ones with the bad heatpipes!
Edit: Cicichen didn't answer today for the new heatsink, this person told me that the new heatpipes are made and they need to get soldered. Which means the M6800 heatsink will finally fit.
Edited by SuperMG
