SuperMG Posted June 21 Author Posted June 21 13 minutes ago, ssj92 said: If the OSD says HDMI IN when you plug it in then it should work. Yes it says that but no signal just a backlight on.
ssj92 Posted June 21 Posted June 21 3 hours ago, SuperMG said: Yes it says that but no signal just a backlight on. So it’s on a black screen? The source is 1080p 60hz or less? Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted June 21 Author Posted June 21 26 minutes ago, ssj92 said: So it’s on a black screen? The source is 1080p 60hz or less? Yes. Source is max 1080p 60Hz. The cables I used, work with The HDMI in of a previous M18X R2 with Windows 10 I had.
ssj92 Posted June 28 Posted June 28 On 6/21/2026 at 4:45 PM, SuperMG said: Yes. Source is max 1080p 60Hz. The cables I used, work with The HDMI in of a previous M18X R2 with Windows 10 I had. I was doing some research, it seems the SK9210-HS model is specific to the OG M14x. The SIL-SK63100 seems to be newer and has fcc listing for AW14/17/18 & M14x/M17x/M18x series. It's possible you have the older card? Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted June 28 Author Posted June 28 3 hours ago, ssj92 said: I was doing some research, it seems the SK9210-HS model is specific to the OG M14x. The SIL-SK63100 seems to be newer and has fcc listing for AW14/17/18 & M14x/M17x/M18x series. It's possible you have the older card? I have the SIL-SK63100. Waiting for the XWH200 to come and I'll test
ssj92 Posted June 29 Posted June 29 6 hours ago, SuperMG said: I have the SIL-SK63100. Waiting for the XWH200 to come and I'll test I still don't understand if there's literally several different models with several different antennas or just 2 models and 2 antennas. For sure M14x uses a different antenna. Then there's the SIL-SK63100 vs SK9210-HS models. M14x for sure uses SK9210-HS model but I am not sure what m18xR1, m17xr3, aw17, aw18, m18xr2 use. If they all use the same SIL-SK63100 model then what about antennas? i found a m17xr4 antenna but no idea if it's the same for m17xr3. I also ordered the vizio receiver/transmitter pack on eBay but now need to figure out the DMC port cards. the part numbers I have for m17xr3 are different from the ones for the other models I found online but some listings show aw14/17/18/m18x/m17x all together Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted June 29 Author Posted June 29 10 hours ago, ssj92 said: I still don't understand if there's literally several different models with several different antennas or just 2 models and 2 antennas. For sure M14x uses a different antenna. Then there's the SIL-SK63100 vs SK9210-HS models. M14x for sure uses SK9210-HS model but I am not sure what m18xR1, m17xr3, aw17, aw18, m18xr2 use. If they all use the same SIL-SK63100 model then what about antennas? i found a m17xr4 antenna but no idea if it's the same for m17xr3. I also ordered the vizio receiver/transmitter pack on eBay but now need to figure out the DMC port cards. the part numbers I have for m17xr3 are different from the ones for the other models I found online but some listings show aw14/17/18/m18x/m17x all together Yes I use the KVR0Y antenna, it's for M17X R4 and it fits in the backside of the top lid. So this is strange the M17X R4 and the 17 R1 are using the same DMC card. But they are using different mux switches. M17X uses a DP MUX: DP to DP to send the output to the DMC. The same MUX it uses to drive the eDP signal. Meanwhile the 17 R1 uses a HDMI MUX: HDMI to HDMI then to a HDMI Redriver and finally sending the output to the DMC. Does the SIL-SK63100 chip interpret the video input as DP++? I think that's what it does. So it means the RTX 3080 I installed can work with the WirelessHD in DP_A
ssj92 Posted June 29 Posted June 29 9 hours ago, SuperMG said: Yes I use the KVR0Y antenna, it's for M17X R4 and it fits in the backside of the top lid. So this is strange the M17X R4 and the 17 R1 are using the same DMC card. But they are using different mux switches. M17X uses a DP MUX: DP to DP to send the output to the DMC. The same MUX it uses to drive the eDP signal. Meanwhile the 17 R1 uses a HDMI MUX: HDMI to HDMI then to a HDMI Redriver and finally sending the output to the DMC. Does the SIL-SK63100 chip interpret the video input as DP++? I think that's what it does. So it means the RTX 3080 I installed can work with the WirelessHD in DP_A It means as long as I order the correct antenna board and cable, the wihd card should also work in M17xR3 then. Someone told me the DMC cards are limited to iGPU but if it's wired through MUX it should work with dGPU. I'm still trying to figure out all the parts. hard to find proper info and a place where I can get all the parts in US Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted June 29 Author Posted June 29 2 hours ago, ssj92 said: It means as long as I order the correct antenna board and cable, the wihd card should also work in M17xR3 then. Someone told me the DMC cards are limited to iGPU but if it's wired through MUX it should work with dGPU. I'm still trying to figure out all the parts. hard to find proper info and a place where I can get all the parts in US I saw in the schematic there's a direct connection between the MXM to the DP MUX to the DMC. Here is a list of Dell P/N https://www.hscott.net/a-60-ghz-phased-array-for-10/ I mean if you're the guy who ordered a 120Hz eDP Alienware with DMC thru Dell back in the day, it should work with the MXM card because the iGPU is disabled.
ssj92 Posted July 3 Posted July 3 On 6/29/2026 at 1:52 PM, SuperMG said: I saw in the schematic there's a direct connection between the MXM to the DP MUX to the DMC. Here is a list of Dell P/N https://www.hscott.net/a-60-ghz-phased-array-for-10/ I mean if you're the guy who ordered a 120Hz eDP Alienware with DMC thru Dell back in the day, it should work with the MXM card because the iGPU is disabled. I bought both part numbers of dmc cards along with a antenna for 17 r1. my m14x r2 already has an antenna so I can test both cards Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
