Hello everyone !
linked is my very very very early version of a pascal to ada lovelace vbios editor.
as of right now it can only read bioses !!
UPDATE v1.1 enables you to modify clock values and power values. The program fixes the checksum as well, testing needed !!
Here is the link, the details are explained in the repository
https://github.com/JadeRover/Nvidia-vBIOS-Clock-Power-Tweaker
Get the latest version from the releases :
Releases · JadeRover/Nvidia-vBIOS-Clock-Power-Tweaker
Pictures :
Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz |  1440p165hz (upgrad)
Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
6 hours ago, JadeRover said:
Hello everyone !
Pictures :
Super excited to try this in the future. my rtx 5000 is 90w. t1000 is 50w.
Kinda works on Linux, have to comment out line 25. Great work so far.
Precision 7710: Xeon E3-1505v5 - Quadro P3000 - 32GB - 1TB NVMEx2 - 165Hz IPS QHD - CachyOS
Precision M6800: Core i7-4900HQ - Quadro M4000M - 16GB - 1TB SSD - 256GB mSATA - LVDS FHD - CachyOS (Retired)
EliteBook 8770W: Core i7-3630QM - Quadro M4000M - 16GB - 256GB SSD - LVDS FHD - Windows XP SP3 (Retro Mobile Battlestation)
Yes that bitmap icon is killing me! It prevented me from exporting to a single exe file 😞 I would get an error
Updated the repository -> version 0.3
Now turing cards read properly and the standalone windows exe works.
@ssj92 You can now properly read the clock values of your T1000 and RTX5000
Hello. It really needs the display table views.
A/B/C/D/E, very important for eDP users and for users who want to use DVI/DP externally
Yes, agreed, that info would be crucial.
I had started a draft that would show the display table, all the info relative to "dispkay outputs" is stored in the DCB table :
see here https://nvidia.github.io/open-gpu-doc/DCB/DCB-4.x-Specification.html
Luckily this table has not been updated for a while so it should be compatible with all the bios from the Pascal-Lovelace era.
If you want to help out you can contribute to the github.
What we need is algorithms going through all the table entries and parsing the data in a user friendly format showing :
DP_X = such interface + i2c controls ? (basically if it supports eDP) + enabled ?
I only understand PHP, JS, Node.js, web development. Very hard for me to make random hex into readable data. But yes we need to know what video output is for A/B/C/D/E (type and if it's enabled or not).
With GPU-Z we can read them but we don't know which is A/B/C/D...
I would pay 20€ to someone who can bypass the eDP checks (if enabled or disabled) when the drivers loads (for 4080 and 4090 MXM cards)
My 115w 2070S in my P870TM has been killing me! I never was able to figure out how to up the power limit because I know it can run at 200w with the dual vapor chamber heatsink. If this works in the future, this would be wonderful!
I am willing to do any testing if needed, just let me know. I also have a 1.8v vBIOS programmer if any crazy stuff needs to happen.
Is there anyway to change the outputs in vBIOS?
Example changing eDP from DP_C to DP_D etc? Assuming the physical card/connections are supported of course.
Hello, yes there is a way to do so. The mac rumor vbios have different output table from stock vbios + documentation exists on the "DCB" table (display table) of nvidia vbios, that's the next step of the program is to read and edit these outputs.
Unfortunately when testing with an RTX3000 gpu, my custom vbios did not work, the card would be bricked with error 43.
Moreover, changing 2 adjacent bytes in the bios by doing +1 and -1 to the hex value (so that checksum is the same) results in a brick as well for this Turing card = meaning that Turing has more security checks then Pascal and any custom vbios bricks the card (also this was documented on mac rumors).
AKA turing custom vbios won't be possible 😞
Version 1.0 is released :
Release v1.0 | Nvidia-vBIOS-Clock-Power-Tweaker · JadeRover/Nvidia-vBIOS-Clock-Power-Tweaker
Editing and saving vbios is possible + checksum is fixed.
Therefore I need volunteers with an external flasher to test on pascal cards these modifications !
But could it be possible for the software to sort the Display tables? To know which is A, B, C, D and E?
Yes, the display table has tons of info here is a snippet (non parsed data):
Highlighted is the entire display table, notice this repeating pattern of 6 lines lines 5F10 and 5F60 starting with header "60". These are the DP_X display entries from A to F
I'll test a few pascal cards
that is unfortunate, so even modifying 1 byte causes code 43?
That's right, fixing one byte and then fixing checksum causes error 43.
However I know that upddating the GOP driver found inside the vbios doesn't brick the card GOP Update and Extraction Tool (Turing) - BIOS/UEFI Modding / BIOS Modding/Flashing Tools - Win-Raid Forum
I've tested the utility and it changes the 32 bit checksum but not the 8 bit value of the checksum (modulo 256 checksum is the same).
When is the ETA to see which video port is which video signal output? A to E ports.
So I can test them with my VBIOSes. Very important for DP_D
I bought a Quadro RTX A5500 from X-VSION. It has simple DP in DP_D and can work without having 4G decode in the SBIOS. I want to know if the DP_B is really an HDMI or a DP...
I don't have an ETA. This is a side project I have my active life to attend to.
DP_B is probably DP++ so it can output either DP or HDMi or even DP+HDMi thanks to a demuxer switch on the laptop (splits the DP++ into one DP and one HDMi).
send me vbios when you can and I will tell you the display config
So with HDMI in DP_B, I can output to DP thanks to the DEMUX from MAX? There's a DEMUX + DP Redriver.
Max doesn't state any HDMI in and no dual-links too 😕
Hello, this is P106m card vbios ?
Manual looking at the clock table, it has only one core value of 1290Mhz and all the others are null (FF). For the memory clock it is 1500Mhz (in afterburner clock dual rank mode).
Also the power table is a desktop type with 3 values (not supported by my program). Those I read from your vbios are all at 100w. I can make you a custom vbios to try if you want.
I made one quickly, boost to 1910Mhz (I changed all the instances of 1290Mhz to 1910Mhz) and mem up to 2000 Mhz you can give it a try, the checksum was fixed as well. You will probably hit a vrel limit and be around the 1850Mhz mark
p106m_vbios_checked.rom
Also very important, version 1.0 of my program might be saving the wrong clock values !!
I will be making some actual vbios tests on my p3000 in my m6700 this week end. In the meantine no one should try to flash a custom vbios made from my program.
I'll be testing p3200, p4200 made by your program & the gp106m lol
