Ok, I really don't have high hopes for the clock values as I got them by dividing the 4 bytes of hex by 32768. As it turns out you have to substract 16384 and then multiply by 2... on each 2 byte chunk of the 4 byte clock value ! See here : https://rog-forum.asus.com/t5/rog-gaming-notebooks/laptop-pascal-vbios-unlocks-quot-wip-quot/td-p/658321
I'll make a version only with power editing that way you can test that out (as it should work fingers crossed), while I fix the clock editing.
Here is this [POWER ONLY] version 1.0 Release v1.0 | [POWER ONLY] Nvidia-vBIOS-Clock-Power-Tweaker · JadeRover/Nvidia-vBIOS-Clock-Power-Tweaker
Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz |  1440p165hz (upgrad)
Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
Yes, there is a certification issue, might be possible to bypass using OMGvflash by veil for turing cards, any newer cards will not work unfortunately. Pascal works.
Even with a hardware flasher it will not work, card will refuse to boot and show error 43.
So the P3200 & p4200 bios that was made, the clocks don't go past 139mhz any more.
The gp106 you gave me, memory is good, core clocks don't seem to go up anymore than stock
Ok, only using the power bios ?
no I haven't tried that one yet
Ok, because the v1.0 will not work i made a mistake for the clock calculations
What does the GPU-Z windows show ?
New version Release v1.1 | Nvidia-vBIOS-Clock-Power-Tweaker · JadeRover/Nvidia-vBIOS-Clock-Power-Tweaker
This one should correctly save the clock values, you can give it a try @ssj92. I made sure it would work for the p3200 and p4200, I tested some roms on techpowerup. (clocks are in the correct 2x2 byte format).
OMGVflash work to flash a modified bios in Pascal? i am trying to flash a custom vbios i made, both 32 and 8 bit checksums are identical as original and it gives me a EEPROM fail.
MSI GT60 2OC Intel i7 4930MX, GTX 1060, 15.6" FHD (90Hz OC), 32GB RAM, 1TB mSATA RAID 0 (2x512), 1TB HDD, Intel WiFi 7 BE200 Card
and a good point, the lastest version of your program @JadeRover fix both checksums succesfully by changing the TDP. nice advance since Pascal TDP tweaker have the header bug and fix bad the checksum
a good future option (if you can and you think is useful) is to add a option to modify subsystem ID and vendor in the header. this is useful to make non OEM MXM cards being recognized by drivers and skip NVCLEANSTALL/INF mod. i already tested it modifying monually the VBIOS and putting a MSI subsystem and vendor ID in the VBIOS of my Aetina GTX 1060 made the drivers recognize it.
tesla p6 rom doesn't work. anyway we can increase tdp to 120w and increase clocks on this one?
https://drive.google.com/file/d/1Oy3rtNQWqr8kEZyxk-mQsZxCrh2kzpki/view?usp=sharing
Yep,
base clock is now 1230Mhz and boost is now 2000Mhz (you will hit vrel limit before seing this value)
Memory is now at 4000Mhz
target power is 100w, limit power is 120w and power slider is enabled.
Checksum was fixed as well. You can try this @ssj92
teslap6_OC_power_mod.rom
It should normally. I haven't tested it.
When you say 8 bit checksum, you mean the header checksum ? Or the last 8 bits of the 32bit body checksum ?
Interesting. I might add these IDs but as a read only to see what card is recognized, especially for P6 and other cards that have a non standard clock layout and need different calculations in order to display the correct values.
Here is an updated version (core clocks are in the correct format). Set to 2000Mhz (again vrel limit before seing this value)
You said the memory was good, it boosted to 2000/4000Mhz ? Because checking again my custom memory clock was not in the expected format, strange that it still worked.
I change the memory clock in this _1 version. It is in the expected format in version _1. In version _2 it is in the same format as my last p106m vbios.
if you can give both a try that would be good.
p106m_OC_checked_1.bin p106m_OC_checked_2.bin
p106m_OC_checked_1.bin 252.5 kB · 1 download p106m_OC_checked_2.bin 252.5 kB · 1 download
both gp106 same behavior. clock is 1290mhz, memory is 4006mhz
tesla p6 allows adjusting slider but clocks stuck at 455mhz core &  405mhz memory
8 bit checksum of the entire vbios, i modified a new one with 32 and 8bit checksum identical as original and OMGVflash give me a error of EEPROM
OK that is unfortunate. No clue why memory clocks work on p106m but not on p6 as the actual hex values are the same.
Same thing for the core clocks on p6. Maybe 2000mhz is too high, we can try 1800 mhz next.
Also you can try a custom vbios made with v1.1 on p3200 and p4200 as clock values should now be saved correctly.
BTW what does gpu z show? Because it communicates with the Nvidia driver to get the clock values. Maybe I messed up (again) and have the wrong algorithm to read/write clocks.
It would be nice to see if gpu z shows my custom clocks ore the clocks you are seeing in benchmark. Thanks.
