Alienware M17x R4: i7-3940XM | Quadro RTX 3000 | 32gb DDR3 RAM | 60Hz display
On 5/6/2026 at 2:36 PM, Hussain Alhadher said:
for that specific card you should be able to use factory heatsink
Alienware Area-51M R2 : Intel Core i9-10900K                   | nVidia GeForce RTX 2080 SUPER
Alienware Area-51M :      Intel Core i9-9900K @ 5.3Ghz    | nVidia GeForce RTX 2080
Alienware 18 :                   Intel Core i7 4930MX @ 4.5Ghz  | nVidia Quadro RTX 5000
Alienware 17 :                   Intel Core i7 4940MX @ 4.5Ghz  | nVidia GeForce RTX 4090
Alienware M18x R2 :        Intel Core i7 3920XM @ 4.7Ghz  | nVidia GeForce RTX 3080
Alienware M18x :              Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000
Alienware M17xR3 :         Intel Core i7 2920XM @ 4.7Ghz  |  nVidia Quadro RTX 5000
Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6)
  • 2 months later...
I’m looking for advice from anyone who has experience with Turing MXM GPUs in the Alienware M17x R4.
My system
  • Alienware M17x R4
  • BIOS: Unlocked A15+ v1.4 (mfractal & svl7)
  • CPU: Intel i7-3940XM
  • GPU: NVIDIA Quadro RTX 3000 MXM vbios (90.06.5F.00.32)
  • Display: 1920×1080 60 Hz LVDS panel
  • Windows 10 x64
  • NVIDIA Enterprise Driver 596.72 (modified INF)
Current status
The GPU works perfectly once Windows loads.
  • No artifacts
  • Stable in games
  • PCIe x16 Gen3 works correctly (GPU-Z shows x16 3.0 under load)
  • HDMI video works
  • HDMI audio works after reinstalling the Intel HD Graphics package (Intel Display Audio)
The problem
I’m getting intermittent black screens.
There are two scenarios:
1. Cold boot
Sometimes after powering on:
  • Alienware/Dell logo appears.
  • Windows starts loading.
  • Before reaching the login screen, the display goes completely black.
  • Keyboard still responds (Caps Lock works).
  • SSD activity LED continues blinking.
  • The laptop is still running but nothing is displayed.
Sometimes it eventually restarts by itself, sometimes I have to hold the power button.
2. Resume from sleep
After waking from sleep:
  • Screen stays black.
  • Keyboard appears responsive.
  • SSD activity continues.
  • The system never recovers unless I force a shutdown.
Things I’ve already tried
  • Disabled Windows Fast Startup.
  • Disabled hibernation.
  • DDU and clean driver installs.
  • Multiple NVIDIA driver versions.
  • Updated Intel HD Graphics driver.
  • PEG PCIe Link Speed set to Auto.
  • Re-seated the MXM card.
  • Code 43 Fixer (registry patch) resolved the intermittent Code 43 issue.
Current BIOS configuration
  • SG mode (Optimus)
PEG does not work.
If I switch to PEG, the laptop immediately gives 6 beeps during POST.
As far as I know, PEG has never worked with this RTX 3000.
Crash dump
The crash dump consistently reports:
DRIVER_POWER_STATE_FAILURE (0x9F)
Failure Bucket:
0x9F_3_POWER_DOWN_nvlddmkm
IMAGE_NAME:
nvlddmkm.sys
The GPU itself appears healthy:
  • GPU-Z reports correct clocks.
  • PCIe trains correctly.
  • No crashes under gaming or stress testing.
  • Once Windows boots successfully, everything works normally.
This makes me think the issue is related to initialization or power management rather than a defective GPU.
my question is has any one experienced similar black screens with turing MXM cards?
Are there any bios settings that could improve SG stability?
My system
  • Alienware M17x R4
  • Windows 10 x64
Current status
  • No artifacts
  • Stable in games
  • HDMI video works
The problem
1. Cold boot
  • SG mode (Optimus)
PEG does not work.
Crash dump
Failure Bucket:
IMAGE_NAME:
nvlddmkm.sys
Start>Settings>Search for graphics and turn OFF "hardware-accelerated GPU scheduling" or something along those lines, restart and enjoy
I turned it off and sometimes i get code 43 in device manager. Im Not really sure if it is a driver problem although it seems to be working fine.
I analyzed the crash dump with WinDbg. The system consistently crashes with DRIVER_POWER_STATE_FAILURE (0x9F). The blocked power IRP belongs to my Quadro RTX 3000 (PCI\VEN_10DE&DEV_1F76&SUBSYS_05AB1028), serviced by nvlddmkm. The GPU is otherwise completely stable under load, PCIe x16 Gen3 works correctly, and Code 43 sometimes appears. The issue appears only during power-state transitions (sleep/wake and occasionally during boot).
I don’t know if I should flash a vbios that supports uefi. Because the current vbios 90.06.5F.00.32 in GPU-z shows unchecked uefi box. I’m not sure if this is the main problem that made the black screen happen every time i turn on the laptop
Thank you very much.
I flashed the vbios and the laptop boots normally. Then, i did get a black screen after a long sleep. Still haven’t tested after a cold boot. Chatgpt suggested disabling sleep and use hibernation instead. Still looking for other solutions.I got the UEFI box checked now but I don’t know if that will make a difference.
I have done some registry editing to try to reduce the black screen problem from happening. But now im getting code 43 on the quadro rtx 3000 when i boot into windows. So every time i get code 43 i have to restart the laptop. I don’t know if there is something i can do about it.
