raptorddd Posted July 17 Posted July 17 just as the tile says are the m4600 fans and m4800 fan compatible meaning i could use the m4800 in the m4600.? they look just like the same. dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
Aaron44126 Posted July 18 Posted July 18 I tried using a M6800 fan in the M6700. They are physically similar enough to fit, and the connector physically fits into the motherboard, but Dell changed the pinout, so the M6800 fan won't operate in the M6700. This to say, I would not expect it to work just because they look the same. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 26 "Tahoe" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
raptorddd Posted July 18 Author Posted July 18 4 hours ago, Aaron44126 said: I tried using a M6800 fan in the M6700. They are physically similar enough to fit, and the connector physically fits into the motherboard, but Dell changed the pinout, so the M6800 fan won't operate in the M6700. This to say, I would not expect it to work just because they look the same. i had my doubts cause AI said yes and sometimes no. and i needed to order one and get it by monday but all had delivery to august i guess comes from china in amazon. thanks dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
SuperMG Posted July 18 Posted July 18 The M6800 has 2 different fans for the GPU. 5.6 CFM and 10.3 CFM. I had a spare 10.3 lying around, a free upgrade from the 5.6 CFM. 1
Nowan Posted August 8 Posted August 8 I tryout a experiment 4 years ago with a dell m6700 cpu first avc fan then delta fan for my m6600 but i forgot to do the "see the different temps after sacrificing the m6600 cpu fan connector" before do this mod😅, what i remember at that time the fan able to go 100% fan speed at time of how high the fans can go. it able to turn on and off normally. now currently the fan hasn't gone up 100% as I now I'm using a different thermal paste gc-extreme and not the mx 4, and put thermal pad to send some of the heat from cpu to the palm rest. i haven't post about this mod cause i didn't have proper test results and its currently using optimus with p4000 cause the amd m6100 gave up so temp are different vs the time i was testing it. the cpu is i7-2760qm. if possible if the fan can fit and the holes align on your m4600 if u want to trying out the experiment on m4600 but there risk if not done right. as i wasn't using m6600 as my main laptop. i was able to solder the cables to the position where the delta fans old cables suppose to as the delta cables had color marking nearing the solder pads for which cables go to where. If u do try it make sure the fan can turn on n off/lower the fan rpm as my first test on the delta fan i had to go adjust the solder of the cable to able to turn off/sends commands to lower the rpm properly when the temps goes down enough. 1
Nowan Posted August 8 Posted August 8 forgot to mention i had to elongate a bit on the holes on the delta to able to screw in the bolt near the fan connector. 1
raptorddd Posted 9 hours ago Author Posted 9 hours ago On 8/8/2026 at 2:00 PM, Nowan said: forgot to mention i had to elongate a bit on the holes on the delta to able to screw in the bolt near the fan connector. cool i end up getting the actual m4600 fans.. i do like mods if you could get a better fan then the stock i might think about it. dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2
SuperMG Posted 8 hours ago Posted 8 hours ago M4700 GPU fan isn't compatible with the M4800. Since the GND and DATA lines are inversed. Fix: You need to change the wires order from that JST connector and it'll work! (I tested)
