TruenoG7 Posted February 1, 2023 Share Posted February 1, 2023 2 hours ago, Clamibot said: Typically what I'll do is some experimentation by starting at the maximum speed I know the CPU is stable at, and then I'll run cinebench and keep increasing the frequency by 100 MHz steps until the system crashes. At whatever frequency the system crashes at, I set the CPU multiplier to match and also increase the voltage by 25mv. I'll then run cinebench again. If the system still crashes, I raise the voltage by additional 25mv steps until the system is stable. I then repeat this process until I run out of thermal headroom. Typically the frequencies you can reach in games will be higher than what you can achieve in cinebench by another few hundred MHz since the load will not be as high. In the end, after so much forcing, I stayed at 4.3, when I reached 4.4 I averaged too much of the current limited processor and it exceeded the temperature reaching 93c, I better stay at 4.3 at 83c, I also asked for 0.75mv to be stable 1 ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q. Link to comment Share on other sites More sharing options...
sliderfra Posted March 19, 2023 Share Posted March 19, 2023 Hi fellas! I just finished my installation of Quadro RTX 3000 on my AW 18, and it rocks!! Modding was a real pain in the arse: - cutting the heatsink was mandatory - cutting the fins was also necessary IOT fit the displaced HS into the chassis - glueing one nut was needed to secure the card on the MB - I also added a piece of metal to streghthen the card onto the MB Modded inf was also needed for driver installation (the easy part actually as I'm used to modding nvidia drivers 🙂 ) Card runs cool despite the fact I have (only) the 75W heatsink, with around 72°C after a run of 3DMark Thanks a lot for the different tutorials, here and on NBRarchive. BTW I have unlocked BIOS A12 (many thanks to ssj92 for sharing all unlocked AW BIOSes here), I wonder if I can extract a bit more juice of my 4810mq (like force max turbo bins or something)? Or do I absolutely need 4930mx for overclocking? 1 1 Link to comment Share on other sites More sharing options...
ssj92 Posted March 19, 2023 Author Share Posted March 19, 2023 15 minutes ago, sliderfra said: Hi fellas! I just finished my installation of Quadro RTX 3000 on my AW 18, and it rocks!! Modding was a real pain in the arse: - cutting the heatsink was mandatory - cutting the fins was also necessary IOT fit the displaced HS into the chassis - glueing one nut was needed to secure the card on the MB - I also added a piece of metal to streghthen the card onto the MB Modded inf was also needed for driver installation (the easy part actually as I'm used to modding nvidia drivers 🙂 ) Card runs cool despite the fact I have (only) the 75W heatsink, with around 72°C after a run of 3DMark Thanks a lot for the different tutorials, here and on NBRarchive. BTW I have unlocked BIOS A12 (many thanks to ssj92 for sharing all unlocked AW BIOSes here), I wonder if I can extract a bit more juice of my 4810mq (like force max turbo bins or something)? Or do I absolutely need 4930mx for overclocking? Run 3dmark firestrike. 4810MQ can be OC using throttlestop to like 3.9ghz or something I think Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
Yarema Posted March 25, 2023 Share Posted March 25, 2023 Hello. My RTX Quadro 4000 should perform better but i got only 12000-15500 grafics score in fire strike, and during test GPU is often works only at half capacity ( 30-60% load of gpu) temps are oc ( no more than 72 degrees) Any suggestions? It should be at least 18000 score at least or even up to 20000 Link to comment Share on other sites More sharing options...
Yarema Posted March 26, 2023 Share Posted March 26, 2023 After reset Bios was able to pull 18+k on fire strike Link to comment Share on other sites More sharing options...
ssj92 Posted March 30, 2023 Author Share Posted March 30, 2023 On 3/26/2023 at 9:09 AM, Yarema said: After reset Bios was able to pull 18+k on fire strike Very nice, but only ~11% faster at best than rtx 4000. I think rtx 5000 is the best upgrade so far (21k score) Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
TruenoG7 Posted April 28, 2023 Share Posted April 28, 2023 On 3/30/2023 at 2:24 AM, ssj92 said: Very nice, but only ~11% faster at best than rtx 4000. I think rtx 5000 is the best upgrade so far (21k score) hi, how to install the drivers so that the software recognizes the GPU? It comes out to me as a generic BGA adapter ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q. Link to comment Share on other sites More sharing options...
ssj92 Posted April 29, 2023 Author Share Posted April 29, 2023 14 hours ago, TruenoG7 said: hi, how to install the drivers so that the software recognizes the GPU? It comes out to me as a generic BGA adapter Submit a ticket to 3dmark support and link to your result. Tell them the GPU. They will fix it in 24 hours and all your results will become valid. 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
Joe Sanchex Posted July 26, 2023 Share Posted July 26, 2023 Hello, can someone please share me the vbios of the Quadro RTX 3000 Dell, update the vbios of my DGFF but it does not have the digital signature Dell 7530 | Xeon E-2176M | 64GB, 2x32GB, 3200MHz, | P1000 | 15.3" IPS | Link to comment Share on other sites More sharing options...
TruenoG7 Posted August 4, 2023 Share Posted August 4, 2023 On 3/25/2023 at 1:26 PM, Yarema said: Hello. My RTX Quadro 4000 should perform better but i got only 12000-15500 grafics score in fire strike, and during test GPU is often works only at half capacity ( 30-60% load of gpu) temps are oc ( no more than 72 degrees) Any suggestions? It should be at least 18000 score at least or even up to 20000 Verify that it is working at normal TDP, I had acceleration problems with that GPU, I requested it by putting it in calculation mode, restart and then calculation and graphics mode, so it stopped accelerating. ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q. Link to comment Share on other sites More sharing options...
Jerryzago Posted October 20, 2023 Share Posted October 20, 2023 I also went ahead and installed an RTX 3000. I got my hands on an HP one. It required a lot of modding, but the result was tottaly worth it. Perfomance was in par with my 980m SLI. I will make a post about the install too. Firestrike Result http://www.3dmark.com/3dm/101435071?key=tDFP6R6-PP4AwmVNPe7T0A 1 Spoiler Alienware M18x R2 i7 3720qm -> i7 3940XM Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 4710MQ 880M GTX -> PNY Quadro RTX 3000 HP 8570w i7 3820qm Quadro K2000M HP DV6000 T72000 -> T9500 Link to comment Share on other sites More sharing options...
razor0601 Posted October 20, 2023 Share Posted October 20, 2023 What do you have expected? It’s like an RTX 2060. And an RTX 2060 is like a GTX 1070. And 980m SLI is like a 1070. But now you have Raytracing and a Single Card. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display Link to comment Share on other sites More sharing options...
Jerryzago Posted October 21, 2023 Share Posted October 21, 2023 17 hours ago, razor0601 said: What do you have expected? It’s like an RTX 2060. And an RTX 2060 is like a GTX 1070. And 980m SLI is like a 1070. But now you have Raytracing and a Single Card. It's totally worth it. Having to deal with the scaling problems that SLI has, and the fact trying to figure out the best settings each time, is a win-win upgrade. Plus I no logner need my dual psu mod. Spoiler Alienware M18x R2 i7 3720qm -> i7 3940XM Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 4710MQ 880M GTX -> PNY Quadro RTX 3000 HP 8570w i7 3820qm Quadro K2000M HP DV6000 T72000 -> T9500 Link to comment Share on other sites More sharing options...
s4lem0nsen Posted October 22, 2023 Share Posted October 22, 2023 Hi and thanks for this thread🫶🏻 Undusted my 2014 AW18 with 4700mq and dual 780m. I just bought the 4940mx and a PNY RTX 3000 MXM. I unfortunately can’t find a DDR3 set with 2133mhz anymore in my country. Maybe someone have a good source or eBay? Anyways I will probably ask for help when all parts arrive and I’m doing the bios flash and settings🤣 Happy modding! 1 Link to comment Share on other sites More sharing options...
Jerryzago Posted October 23, 2023 Share Posted October 23, 2023 I also wanted that. They don't sell outside France Spoiler Alienware M18x R2 i7 3720qm -> i7 3940XM Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 4710MQ 880M GTX -> PNY Quadro RTX 3000 HP 8570w i7 3820qm Quadro K2000M HP DV6000 T72000 -> T9500 Link to comment Share on other sites More sharing options...
s4lem0nsen Posted October 23, 2023 Share Posted October 23, 2023 11 hours ago, Jerryzago said: I also wanted that. They don't sell outside France I used Shippn witch works great👍🏻 Link to comment Share on other sites More sharing options...
Jerryzago Posted October 23, 2023 Share Posted October 23, 2023 20 minutes ago, s4lem0nsen said: I used Shippn witch works great👍🏻 Cost is near the cost of the GPU itself. I am trying to find people I know in France to take delivery. Spoiler Alienware M18x R2 i7 3720qm -> i7 3940XM Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 4710MQ 880M GTX -> PNY Quadro RTX 3000 HP 8570w i7 3820qm Quadro K2000M HP DV6000 T72000 -> T9500 Link to comment Share on other sites More sharing options...
s4lem0nsen Posted October 23, 2023 Share Posted October 23, 2023 2 hours ago, Jerryzago said: Cost is near the cost of the GPU itself. I am trying to find people I know in France to take delivery. Ah I’m in Europe so all in all it was like 150 usd. And that’s pretty great for a mxm card of this caliber 👍🏻 2 Link to comment Share on other sites More sharing options...
Naberius Posted November 1, 2023 Share Posted November 1, 2023 Looking at the layouts for the PNY rtx 3000 and rtx 5000... what sort of modifications are required to get those to mate with the heatsink (OG heatsink vs the aftermarket pascal heatsinks)? I'm definitely curious now (though for me the target system would be an m17xR4). Edit: Oh... looks like they actually just fit... wild... AW M18 R1 | i9-13900HX | RTX4090 | 64GB DDR5 AW M17XR4 | i7-3940XM | GTX1070 | 32GB DDR3 AW M15X | i7-940XM | GTX970m | 16GB DDR3 Formerly Schurke of NBR and TechInferno Link to comment Share on other sites More sharing options...
Geg Posted November 10, 2023 Share Posted November 10, 2023 On 29/01/2023 at 20:31, TruenoG7 said: Bonjour, je viens d'installer le rtx 3000 hp dans mon alienware 18 (2015) de ceux qui sont en vente sur ebay, j'ai vraiment oublié le dissipateur donc j'ai utilisé le même de l'alienware 18, j'ai modifié certaines choses pour qu'il peut s'adapter Maintenant, je n'ai que 2 questions, quel serait le meilleur Overclock pour mon i7-4940mx ? J'ai actuellement la rtx 3000 et une p3000 sur le 2ème port GPU MXM, et quelle serait la meilleure ram pour cette petite bête ? J'ai le chariot HyperX Impact 32 Go 8x4 DDR3L 1866 MHz, oh j'ai aussi fait quelques modifications au processeur, pour améliorer son refroidissement, j'ai dû utiliser du métal liquide, actuellement je l'ai overclocké à 4.1.; Les modifications du dissipateur thermique du cpu se font avec une colle thermoconductrice Amazing ! Rtx3000 and p3000! I didn't know you could put 2 different GPUs in this machine! But what's the point since they can't work in sli mode it seems to me? How do you switch from one to the other? Link to comment Share on other sites More sharing options...
TruenoG7 Posted November 24, 2023 Share Posted November 24, 2023 On 11/10/2023 at 4:35 AM, Geg said: Amazing ! Rtx3000 and p3000! I didn't know you could put 2 different GPUs in this machine! But what's the point since they can't work in sli mode it seems to me? How do you switch from one to the other? I only had it to fill the slot xD, in the end I removed it, since it gave me problems with the RTX ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q. Link to comment Share on other sites More sharing options...
aldarxt Posted December 24, 2023 Share Posted December 24, 2023 On 11/24/2023 at 3:28 PM, TruenoG7 said: I only had it to fill the slot xD, in the end I removed it, since it gave me problems with the RTX Hey TruenoG7 what kind of problems? I was planning to run a RTX 3000 or RTX 4000 in the 1st and put a P4000 on the 2nd, Only because on my Clevo p879dm3-g I discovered I can run a program Topaz Video AI on the 2nd GTX 1080 not in SLI and still use the 1st GPU to do other things, cause the clevo is in PEG mode. I was also able to run Topaz on the m18xr2 in SG mode and still brows the web Topaz Video AI uses alot of power and can max out the card it is using Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
Mr. Wind Posted December 30, 2023 Share Posted December 30, 2023 Hello, I'm new here and I've been using Alienware M18xR2 for a long time. I was one of the first to upgrade to 980m. Now I see new super different cards. I want to switch to an RTX series card. Which cards have been tried? Does the HP series Quadro RTX 3000-5000 series work? I also saw the new RTX 3060 - 3080mxm. Has anyone tried it? Which card do you think would be better for me to switch to? Link to comment Share on other sites More sharing options...
TruenoG7 Posted December 30, 2023 Share Posted December 30, 2023 On 12/24/2023 at 2:50 PM, aldarxt said: Hey TruenoG7 what kind of problems? I was planning to run a RTX 3000 or RTX 4000 in the 1st and put a P4000 on the 2nd, Only because on my Clevo p879dm3-g I discovered I can run a program Topaz Video AI on the 2nd GTX 1080 not in SLI and still use the 1st GPU to do other things, cause the clevo is in PEG mode. I was also able to run Topaz on the m18xr2 in SG mode and still brows the web Topaz Video AI uses alot of power and can max out the card it is using I had problems with the drivers to be able to run the RTX on the RTX 3000, the P3000 worked without problems ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q. Link to comment Share on other sites More sharing options...
aldarxt Posted December 30, 2023 Share Posted December 30, 2023 18 hours ago, TruenoG7 said: I had problems with the drivers to be able to run the RTX on the RTX 3000, the P3000 worked without problems Did you modify the .inf with both cards on it? A separate line for each card and maybe the section part trying different section #ers. Right now I am waiting to reflash my RTX 4000 max Q cause I lost the original vBios and no other vBios is working so it is dead until I find vbios 90.04.2A.00.0C. Techpowerup does not have it but I tried all they have listed and I had to reflash with neoprogrammer just to get the m18x r2 to even see the card. Now I have 2 P4000s sitting in a box. Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
