Nahimic 3 UAD Modified Driver for Unsupported MSI Hardware
solidus1983
@alvarock85 Right quickly made a patch up on the files.
- Download the attached file
- Extract to c:\Audio\9492.1\ (overwrite the files)
- Run Launch.exe
- Select Full Install APO3
If this works let me know and i will add the edits to the main ID list files.
alvarock85.zip
{Main System:} The Beast
{Mainboard:} Asrock X670E Pro
{OS:} Windows 11 Pro
Can you make sure the device ID in the APO3/Extension is there just incase I forgot.
Also to clarify that its only Nahimic thats not working ? Can you do a screenshot of the Device Manager Under Software Components section please.
Once i am free to do so i will do.
time to update again.  if you were unable to make a modded 6.0.9500.1 MSI driver, you can now scrap those plans and go straight into doing a 6.0.9514.1 driver instead as the 9514 driver recently came out (as mentioned by Virgoliciul97 several hours ago)
Going the be busy for a while at work for a few weeks. So when and if I have time I will make one.
On 5/5/2023 at 8:49 PM, epguy3 said:
Nahimic APO4 SWC driver version 4.9.10.0 (also released on Cinco de Mayo 2023)
that Nahimic APO4 SWC driver has A-volute extension driver 1.5.14.0 (nearly forgot to mention that last time)
another Nahimic APO4 SWC v4.9.10.0 driver is available from MSI but has slightly newer A-volute extension driver which is 1.5.15.0 (released end of May 2023) instead of 1.5.14.0
  • 4 weeks later...
I have a free day tomorrow, so if you can get me the latest links i can then make a new pack for everyone.
@epguy3 Right will download them links tonight, i was asking due to every other time i do an update they release something new.
I take it there is no additions to APO3 at all just the UAD and APO4
Updated links will always be in my signature!
Made By: solidus1983 (hacktrix2006) and djlenior
Status: Final Release
Repack: Yes
CodeName: Zeus
Downgrade/Update: Update
Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor Notebooktalk or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread!
Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
Installer: Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
Package includes:
Realtek UAD 6.0.1.9514.1
Nahimic UWP 1.9.17.0
Nahimic SWC 3.5.6.0 (APO3)
Nahimic SWC 4.9.6.0 (APO4)
Nahimic Extension 1.1.44.0 (APO3)
Nahimic Extension 1.5.15.0 (APO4)
Nahimic Mirroring Driver 2.0.0.0
Realtek Audio Console UWP 1.44.299.0
Installer:
SHA-1: d9e9543a15fc0c3fb0df566f9d32b5be0c7f1e94
Size: 139338714 bytes (132 MiB)
Virus Total: Result
For Windows 10 Build: 21H1/21H2
For Windows 11 Builds
Change Log:
Updated Realtek Audio driver from 6.0.1.9492.1 to 6.0.1.9514.1
Updated Nahimic Extension (APO4) from 1.5.7.0 to 1.5.15.0
Updated Realtek Audio Console UWP from 1.41.290.0 to 1.44.299.0
Supported Systems with this driver pack:
Alpha Series:
Alpha 15
Bravo Series:
Bravo 15
Bravo 17
GE Series:
GE60 (Apache) (Pro)
GE62 Apache (Pro)
GE63 Raider (RGB)
GE65 Raider
GE66 Raider
GE70 (Apache) (Pro)
GE72 Apache (Pro)
GE73 Raider (RGB)
GE75 Raider
GE76 Raider
GF Series:
GF62
GF63 (Thin)
GF65 Thin
GF72
GF75 Thin
GL Series:
GL62
GL63
GL65 (Leopard)
GL72
GL73
GL75 (Leopard)
GP Series:
GP60 (Leopard)
GP62 Leopard (Pro)
GP63 Leopard
GP65 Leopard
GP70 (Leopard) (Pro)
GP72 Leopard (Pro)
GP73 Leopard
GP75 Leopard
GS Series:
GS40 Phantom
GS43 Phantom Pro
GS60 Ghost (Pro)
GS63 Stealth (Pro)
GS65 Stealth (Thin)
GS66 Stealth
GS70 Stealth (Pro)
GS72 Stealth (Pro)
GS73 Stealth (Pro)
GS75 Stealth
GT Series:
GT60 (Dominator)
GT62 Dominator (Pro)
GT63 Titan
GT72 Dominator (G) (Pro) (VR)
GT73 Titan (Pro)
GT75 Titan
GT76 Titan (DT)
GT83 Titan (SLI) (VR)
GV Series:
GV62
GV63
GV72
***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
Install instructions:
- Disconnect from the internet. (Not Required, so very Optional)
- Reboot System and Enter BIOS/UEFI.
- Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
- Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
- Now run the Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe Installer
- Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
- Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
- Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
- Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
***[IMPORTANT]****
As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly.
Known possible bugs and fixes:
Issue: Two Nahimic Mirroring device show up in Device Manager:
Solution: run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
then run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.8.9.0 UWP effects are not working or its reporting the device is not upto date.
Solution: Simply run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Issue: Jack Detection not working.
Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
Issue: Microphone not working after using Nahimic Optimizer.
Solution: Click Reset inside Nahimic Settings section will fix this.
Issue: Microsoft Overwritten the installed modded driver.
Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
Issue: Nahimic 3 reports its device is not compatible basically not working.
Solution: Run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Issue: Sound has become muffled/suppressed/distorted.
Issue: I don't want the Nahimic 3 Bloatware!
Solution: Run Realtek_UAD_6.0.1.9514.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
***[IMPORTANT]****
I would like to thank the following people for whom have helped. I like to personally thank the following users.
Project Programmers:
hacktrix2006
djlenoir
Installer Testers:
DimitriosMSI
TikiThorsen
Ricardo_estep
Driver Suppiler:
MSI
Original Thanks:
epguy3
J95
JeanLegi
LeftEyeNine
Falkentyne
mnomaanw
felix3650
asm1
Bazgrim
ixende
MrBeer
arke yyci
Beemo
senso
Eflatun
HitZ2976
Ivan994
Alanfox2000
OneOnline
OgUrecheK
comradeskeleton (Reddit)
eiraku
almost 2 months later, looks like MSI finally released a new realtek audio driver - 6.0.9524.1 (for newly released Alpha 17 C7V laptops)
same Nahimic APO4 4.9.10 driver but new extension driver 1.5.16.0 - also for Alpha 17 C7V
also, this manufacturer (not related to MSI) has a Nahimic 1.9.19.0 UWP app in its driver + utility package (MS store version still has 1.9.17.0 of the Nahimic uwp app but later came a 1.9.20 version available either around end of July or in early August)
edit 7/21
edit 2nd time 8/8
On 5/23/2023 at 10:27 AM, Virgoliciul97 said:
v6.0.9514.1 MSI Z490-A PRO Realtek HD Universal Driver
this has been recently updated to v6.0.9553.1 as of TH Sept. 7
A-volute Nahimic 4.10.0.0 AudioProcessingObject [APO4] driver from Microsoft Update Catalog (released early September 2023)
-this new driver version will be listed in the "Audio Processing Objects" section of Device Manager instead of the "Software Components" section; requires at least 64bit Win10 v1809 (build 17763) to install
Nahimic APO4 v4.9.10 driver + A-volute Nahimic extension 1.5.21.0 driver from MSI
time for a new driver update, solidus1983
Sorry, I don't want to seem rude here but I have a lot on my plate both with my personal health and also one of my parents whom I will be visiting in hospital shortly.
So I am afraid the driver will have to wait sorry.
that's ok.  take as much time as you need, solidus1983.
no need to release a new version right away until you are fully ready & have resolved all matters outside the computing world.
I'm dealing with my own personal & family matters as well (though I won't disclose mine here)
-though most of my own issues have been dealt with (aka. resolved)
anyways, I don't see MSI releasing any new audio drivers for a while since the 6.0.9553.1 version from last week.
On 8/22/2023 at 4:02 AM, epguy3 said:
and latest Realtek Audio Console UWP app version is 1.45.304.0 {someone else in this forum posted it}
newest Realtek Audio Console UWP app version is 1.46.306.0 (available somewhere in that other forum link that I mentioned)
looks like I was mistaken about this, so I take this back :classic_sad:
I've just learned that there was a 6.0.9567.1 driver issued thru MSI Live Update (for few select motherboard users w/ recent board models and running the latest MSI Live Update app) and this one is only exclusively available there and not on the main MSI web site, which still has the 6.0.9553.1 version [and the 9553 version would be overwritten by the 9567 version issued by MSI Live Update if that app is used to download & install that version].
@epguy3Thanks bud, just got free 10 minutes before hitting the grind again. As soon as its less hectic i will make a new package. In fact i am in hospital myself on 29th for an operation and have holidays books for 2nd-6th Oct (recovery) so might be able to squeeze a release then.
Right i am on holiday now so i have some free time, going to quickly boot up my VM and update the OS. Has there been any movement in the drivers department aka any new links.
Else i will simply make a new pack based on the last set of links given.
Repack: Yes
CodeName: Zeus
Installer: Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
Package includes:
Realtek UAD 6.0.1.9567.1
Nahimic UWP 1.9.20.0
Nahimic SWC 4.10.0.0 (APO4)
Nahimic Extension 1.5.21.0 (APO4)
Realtek Audio Console UWP 1.47.309.0
Installer:
SHA-1: f70831a12da37e95366d039e55e21cd8a72264a1
Size: 141559695 bytes (135 MiB)
Virus Total: Result
Change Log:
Updated Realtek Audio driver from 6.0.1.9514.1 to 6.0.1.9567.1
Updated Nahimic Extension (APO4) from 1.5.15.0 to 1.5.21.0
Updated Realtek Audio Console UWP from 1.44.299.0 to 1.47.309.0
Updated Nahimic UWP from 1.9.17.0 to 1.9.20.0
Updated Nahimic Mirror Driver from 2.0.0.0 to 2.0.3.0
Alpha Series:
Alpha 15
Bravo Series:
Bravo 15
Bravo 17
GE Series:
GE60 (Apache) (Pro)
GE62 Apache (Pro)
GE63 Raider (RGB)
GE65 Raider
GE66 Raider
GE70 (Apache) (Pro)
GE72 Apache (Pro)
GE73 Raider (RGB)
GE75 Raider
GE76 Raider
GF Series:
GF62
GF63 (Thin)
GF65 Thin
GF72
GF75 Thin
GL Series:
GL62
GL63
GL65 (Leopard)
GL72
GL73
GL75 (Leopard)
GP Series:
GP60 (Leopard)
GP62 Leopard (Pro)
GP63 Leopard
GP65 Leopard
GP72 Leopard (Pro)
GP73 Leopard
GP75 Leopard
GS Series:
GS40 Phantom
GS43 Phantom Pro
GS60 Ghost (Pro)
GS63 Stealth (Pro)
GS65 Stealth (Thin)
GS66 Stealth
GS70 Stealth (Pro)
GS72 Stealth (Pro)
GS73 Stealth (Pro)
GS75 Stealth
GT Series:
GT60 (Dominator)
GT63 Titan
GT73 Titan (Pro)
GT75 Titan
GT76 Titan (DT)
GV Series:
GV62
GV63
GV72
- Now run the Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe Installer
***[IMPORTANT]****
Solution: run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
then run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
Solution: Simply run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
Solution: Run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Solution: Run Realtek_UAD_6.0.1.9567.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
***[IMPORTANT]****
hacktrix2006/solidus1983
djlenoir
Installer Testers:
DimitriosMSI
TikiThorsen
Ricardo_estep
Driver Suppiler:
MSI
Original Thanks:
epguy3
J95
JeanLegi
LeftEyeNine
Falkentyne
mnomaanw
felix3650
asm1
Bazgrim
ixende
MrBeer
arke yyci
Beemo
senso
Eflatun
HitZ2976
Ivan994
Alanfox2000
OneOnline
OgUrecheK
eiraku
I didn't get a chance to mention this earlier cuz of my busy schedule but the 6.0.9567.1 MSI Realtek UAD/DCH driver that was once available only thru the MSI Live Update site was made available on the main MSI download site around end of September {new link to 9567 driver is a slightly different package since it was released for some newly released MSI laptops but same version}
other than that, nothing new from MSI
time for a new Realtek UAD MSI driver update.
this time, a 6.0.9585.1 driver version was recently available thru the MSI Live Update site.
and Realtek Audio Console UWP v1.47.310.0 and Nahimic UWP v1.9.22.0 apps are available
