ssj92 Posted December 26, 2022 Posted December 26, 2022 Of course I discover these after I get rid of my P4000. Perhaps it's time to play with one again 😄 4 hours ago, TruenoG7 said: the card has its bios stock, the alienware bios A14+ mod, I managed to make it start but in the device manager you don't see the display adapter, it only shows 3d accelerator and audio, it won't let me install the drivers I really don't know what Damn it happens, I put it in my other alienware 18 and everything is perfect, I only have problems with the alienware 17. Is your 17 a eDP 120Hz panel or 60hz panel? Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
TruenoG7 Posted December 26, 2022 Posted December 26, 2022 7 hours ago, ssj92 said: Of course I discover these after I get rid of my P4000. Perhaps it's time to play with one again 😄 Is your 17 a eDP 120Hz panel or 60hz panel? Yes, 120 hertz EDP ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
TruenoG7 Posted December 31, 2022 Posted December 31, 2022 On 12/26/2022 at 9:38 AM, TruenoG7 said: Yes, 120 hertz EDP I was able to make it work, for some reason in the first place, apparently when I put the heatsink on, when I put all the screws correctly, it did not give a signal, when I loosened them, yes, so I left them like that, then when I started windows, only the 3D controller appeared, I did not identify it the card in another way, I forced the installation of the driver, luckily it worked great, and all good for now, temperatures do not exceed 68c with the P3000 ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
chieukhanhok Posted January 19, 2023 Posted January 19, 2023 On 11/26/2022 at 3:43 AM, aldarxt said: OK! got this tucked away in my P4000 folder, When the time comes the m6700 will remove the GTX 980m and it will get a Quadro. I find it funny my m17x and m18x both have Quadro's and m6700 has GTX HAHA Don't tell Dell lol Thanks! I spent a whole day flashing vBIOS for P4000 and it crashed... vBIOS P4000 is .bin extension. It does not have the .rom extension like the usual P5000 and p3000. Anyone have another vBIOS P4000?
Csupati Posted January 20, 2023 Posted January 20, 2023 I did a p3000 upgrade on my 17 as well and then a p3200 , my temps never go above 55C with minimal fans, so your almost 70C is very high. You need early vbios for the p4000 to get work in your m6700. I can dig ip my drive to check it if i have vbios. On 1/19/2023 at 10:44 AM, chieukhanhok said: I spent a whole day flashing vBIOS for P4000 and it crashed... vBIOS P4000 is .bin extension. It does not have the .rom extension like the usual P5000 and p3000. Anyone have another vBIOS P4000? https://drive.google.com/file/d/1cSkLAatyydOZxrcuFDXQBfJ7EGsTxxB9/view?usp=drivesdk There it is . On 1/20/2023 at 7:07 AM, Csupati said: https://drive.google.com/file/d/1cSkLAatyydOZxrcuFDXQBfJ7EGsTxxB9/view?usp=drivesdk Nó đây rồi. Thank you. I have flashed vBIOS for P4000 done. And I mounted it on Dell M6800... It seems to get a bit hot. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Csupati Posted January 21, 2023 Posted January 21, 2023 5 hours ago, chieukhanhok said: Thank you. I have flashed vBIOS for P4000 done. And I mounted it on Dell M6800... It seems to get a bit hot. Its a 75w card so you did something wrong at assembly Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
silverchair Posted February 8, 2023 Posted February 8, 2023 On 8/21/2022 at 1:16 AM, jaybee83 said: DM sent 😉 @jaybee83 I am in need of unlocked vBIOS for my Quadro P5000 16GB GPU as well. Can you help?
SakuraSamurai Posted May 8, 2023 Posted May 8, 2023 Just ordered a Precision 7720 with a Quadro P4000. I'll let you know how it turns out. If it doesn't turn out well I suppose it's just an excuse to spend the money on a P5000 upgrade lol. This will be my first Nvidia GPU as I've always used AMD cards since the ATi days. Is there anything I need to know that's different about Nvidia before I go flashing vbioses and messing with stuff? Currently I have a Firepro M6100 in my Precision M6600 with VRAM at 1780MHz and core at 1320MHz. I have no idea how I managed to finally get afterburner to work but I just thought I'd put it out there's it's possible before I replace the unit.
Aaron44126 Posted May 8, 2023 Posted May 8, 2023 33 minutes ago, SakuraSamurai said: Is there anything I need to know that's different about Nvidia before I go flashing vbioses and messing with stuff? Pretty sure Pascal is the first generation where NVIDIA enforces digital signature verification on the vBIOS. So, you can't just dump the vBIOS, "adjust values", and flash it back on. (Well, you can, but the GPU will reject it and won't operate.) You can however cross-flash a different official vBIOS that comes from another P4000 card if it has more desirable behavior than yours. Maybe someone has found a way around this by now but that was the situation when I was messing with a P5000 back in around 2019. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
0tohero04081988 Posted May 14, 2023 Posted May 14, 2023 All versions above are intended for iMac only, it won't work for Dell, and it will report an error. Dell vbios has a different internal structure, where the UEFI/GOP driver is before the power tables. This makes changes in the bios break some checksums that can cause error 43. I tried to modify the hexadecimal code and failed over 20 times. I asked a professional friend for help to fix the checksum error, but it still hasn't been successful. I used a language translation aigpt, sorry.
SakuraSamurai Posted May 14, 2023 Posted May 14, 2023 6 hours ago, 0tohero04081988 said: All versions above are intended for iMac only, it won't work for Dell, and it will report an error. Dell vbios has a different internal structure, where the UEFI/GOP driver is before the power tables. This makes changes in the bios break some checksums that can cause error 43. I tried to modify the hexadecimal code and failed over 20 times. I asked a professional friend for help to fix the checksum error, but it still hasn't been successful. I used a language translation aigpt, sorry. Thanks for the heads up. I got the card and it's working great as is anyway. I wish I could overclock it as even until it's heaviest load like 55C maximum which is amazing but also I feel like there's so much potential wasted. My M6600 by comparison would hover around 80c-85cwith brand new paste.(Mind that the GPU has a 20% overclock on it as well, but it only raised the temps ~8C.)
0tohero04081988 Posted May 15, 2023 Posted May 15, 2023 The GPU cooling system of the M6600 and M6700 is better than that of the M6800, It has 3 copper bars instead of 2 like the M6800. I don't know what your fan speed, but for my M6800, it reaches 4500-4900 RPM and I also use liquid metal thermal. If the GPU temperature is too high, you can use Dell Fan Manager and run the GPU fan at maximum speed.. I'm still trying to modify the vBIOS for the P4000 on the M6800, hoping for results soon. A while back, I used the P3000 and was the first to overclock it to almost the default P4000. But at that time, my family went through a financial crisis and I had to sell my laptop. I didn't have the mental space for anything else and didn't want to back up the overclocked vBIOS of the P3000.
0tohero04081988 Posted May 15, 2023 Posted May 15, 2023 7 hours ago, SakuraSamurai said: Thanks for the heads up. I got the card and it's working great as is anyway. I wish I could overclock it as even until it's heaviest load like 55C maximum which is amazing but also I feel like there's so much potential wasted. My M6600 by comparison would hover around 80c-85cwith brand new paste.(Mind that the GPU has a 20% overclock on it as well, but it only raised the temps ~8C.) I know that veteran members like Aaron44126, TheQuentincc, Mr. Fox, ssj92... have been involved in Dell forums for a very long time, even on other forums. I'm pretty sure they have absolute experience, you can ask for their help
jdngy Posted December 29, 2023 Posted December 29, 2023 On 12/26/2022 at 1:12 AM, ssj92 said: Of course I discover these after I get rid of my P4000. Perhaps it's time to play with one again 😄 Is your 17 a eDP 120Hz panel or 60hz panel? Hello, sorry to bother you but I'm doing the same upgrade myself (p3000 and alienware 17 r1) do I need the 120hz screen to be able to get the card running? It's detected in my bios, but not in device manager.
Mumbles Posted April 17, 2024 Posted April 17, 2024 Hey everyone, new to the forum but wasn't finding much active discussion on this so i'll leave some info here. I have two of the Alienware 17 r1 (2014) p18e models to mess around with. Both with 60hz screens however i do have a 120hz panel and the eDP cable to try at some point in the future. While optimus does tank some performance, having the intel iGPU available is nice to have as a backup. I recently bought a P4000 to put in one of them. With UEFI boot enabled and CSM disabled, it shows up just fine in windows. First as a generic '3D Video Controller' but worked perfectly after using NVCleanstall. The P4000 came with the 86.04.3A.00.3A vbios version installed. HWInfo claims it never pulls more than 70w under full load but it does achieve a 4003 TimeSpy score. That being said it never tops over 65c and I feel there's a lot more headroom. For 'science' I'm going to be flashing the Mac OC'd bios first to see if things boot and maybe achieve a 4200+ TimeSpy. Worst case i'll just increase the TDP limits using the Pascal TDP Tweaker and flash that to see if anything improves. For flashing I have the venerable CH341A with 1.8v adapter. Plenty of experience using it with desktop boards but realized I needed the 1.8v adapter for this kind of vbios chip. Confirmed first it's a newer revision and actually outputs 1.8v instead of 2-3v. Wish me luck! p.s. @jdngy if i'm not mistaken, you'll be fine with the 60hz screen. The fact it shows up in the bios but not windows means you probably aren't booting with UEFI or have CSM enabled. It also might mean it's showing up in device manager but under a weird category like mine did as a '3D Video Controller' 1
Mumbles Posted April 19, 2024 Posted April 19, 2024 Reporting back with results! I can confirm the OC P4000 vbios for Mac works great on the Alienware p18e (at least the 60hz version). No issues flashing, laptop booted right up and I didn't even need to re-install the NVCleanstall drivers. Bios revision shows as DE.EA.00.BE.EF 😅 - it now boosts to over 1600mhz and pulls over 100w to achieve a TimeSpy GPU score of 4800! https://www.3dmark.com/3dm/110489628 I don't know if the issues @0tohero04081988 had was just with the Precision or if they were trying to flash with software, but i'm very pleased with the results. No need to try the simpler TDP Tweaker bios files as it does not increase boost clocks. The macrumors modder m0bil who uploaded the files also included an experimental 'OC3' version that increases the boost and voltage a bit more. I don't feel any need to try it unless somebody here is curious. The next steps i might try is with the 120hz panel which might require a modded motherboard bios to allow toggling graphic modes. Extra photo of my jank flasher process. Getting the clip seated nicely can be a real pita with a short cable. 2
Ralph Posted April 26, 2024 Posted April 26, 2024 Welcome, Someone has skills to unlock or find voltage values for this Quadro cards? I tried using msi afterburner but voltage curve is not working. There is no problem with that on normal GTX 1060m or higher. Its vbios locked on P4000 mobile. We need someone with hex knowledge to find where is voltage curve located, where are voltage values and how to unlock voltage on Quadro Pascal mobile cards. Me and Mumbles succesfully flashed overclocked bios for P4000. He did it on Alienware and I did it on MSI gt70. Only thing left is to undervolt. People help 😉 -
veiu0107 Posted November 9, 2024 Posted November 9, 2024 Hello, I am new here. I have clevo p750 with moded bios for 8th/9th gen cpu and moded quadro p4000 card (115w tdp and higher clocks). I am currently thinking of moding the capacitors with 10 ohm resistors (I am talking about capacitors that are around ina 3221 chip) since I have seen many people doing it on desktop cards. Has anyone tryed that maybe on laptop cards? ps. I have added few screenshots where you can see my quadro performance.
cisik88 Posted November 19, 2024 Posted November 19, 2024 Hello, what's the current status? Did anyone succeded in getting unlocked vbios for quadro P3000? Is it posssible to flash vbios on these cards using NVFlash?
Maks0098 Posted November 19, 2024 Posted November 19, 2024 3 hours ago, mtvgt said: Hello, what's the current status? Did anyone succeded in getting unlocked vbios for quadro P3000? Is it posssible to flash vbios on these cards using NVFlash? There are overclocked bios for the P3000 from iMac from the Macrumors website. Everything worked flawlessly for me on the Alienware M18x R2. They are flashed only with a programmer, I tried to flash not only with regular NVFlash but also with different modified versions - nothing works, only the programmer (but do not forget that the Pascal chip is 1.8 volt). Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
loopster Posted November 19, 2024 Posted November 19, 2024 I'm tempted to try this on my P3000. Could you do a before/after comparison of performance or benchmarks, please?
Maks0098 Posted November 19, 2024 Posted November 19, 2024 1 hour ago, loopster said: I'm tempted to try this on my P3000. Could you do a before/after comparison of performance or benchmarks, please? https://www.3dmark.com/spy/48230233 https://www.3dmark.com/spy/48553671 but I flashed My P4000 not with the same bios as with Macrumors, but with a slightly different one, but also for iMac. I found it on our forum, with an increased frequency from the already high 1657 (on Macrumors this) to 1772 MHz yet. Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
Maks0098 Posted November 19, 2024 Posted November 19, 2024 1 hour ago, loopster said: I'm tempted to try this on my P3000. Could you do a before/after comparison of performance or benchmarks, please? This is the result with that BIOS for P3000 from Macrumors. with a standard BIOS, your result will be ~2900 graphical score in Time Spy. That is, the increase will be from 2900 to 3600, approximately. Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
loopster Posted November 19, 2024 Posted November 19, 2024 I'm already in that region with 86.04.70.00.1B
