On 7/28/2024 at 3:49 PM, win32asmguy said:
I have a P16 G2 configured with 13950HX and 4090 mobile. It is pretty quiet running in the default balanced mode under load where the fans max out at 45dB and more importantly have no high pitched whine to them or fan duty pulsing. It can also benefit from replacing the paste on the CPU and GPU with PTM7950.
I will also note that with the P16 G2 if you want a heatsink with a CPU side vapor chamber you have to choose atleast an Ada3500 GPU.
How did you configure the P16 with RTX 4090? It is not even mentioned in the PSREF, and I have no such option here 😞 What was the cost difference vs. the ADA 5000?
ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+
COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20
SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω
MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
It was a refurbished model from Lenovo Outlet:
https://www.lenovo.com/us/outletus/en/p/laptops/thinkpad/thinkpadp/thinkpad-p16-gen-2-16-inch-intel/21fbx03500
It was not actively marketed as an option available as I think Lenovo (or Nvidia) wanted to steer purchasers to the Legion series. Same situation as the Precision 7680/7780. If you contact a sales rep they could probably setup a CTO quote with it. Pricing is likely around what they charge for the Ada4000 option.
Thank you as well Easa. The "bigger chassis = bigger fans" is not something I had considered. After having gone through the TP fan control rabbit hole & ordering the P1G6, G7s again, I found that neither has a "quiet" fan level. I can switch both' fans off, but both are at their lowest, active level near 2400 +-100rpm which is audible + some high pitched noise in the G7. I have ordered a P16v Gen 1 as my last laptop to try & I will keep the most silent of the 3.
Hey Easa,
Thanks for this thorough review!
Sadly, as expected, the new Fury G11 chassis design (fans/venting) is the real culprit here. I can't understand why they keep making these mistakes, especially on a workstation that, by design, needs to have a proper cooling system.
It's a no-go for me, too, just because of this bad design.
On the other hand, as you mentioned, the P16 G2 has a good design but lacks a proper ethernet port (more acceptable to me than constantly buzzing fans).
For anyone's interest. The P16v Gen 1 AMD is indeed a lot more silent & silent enough vs. the P1 G6/7. Thank you very much @win32asmguyfor recommending it. It is also roughly the size of the P1s, so overall a great replacement. The fans still spin at around 2300, but the fan itself is a lot less noisy. The fans also have a slightly different rib structure. While I still hear it, it is the closest to silent among the almost-always-on-fans I have tried & good enough. TP fan control does not appear to work any more though, which is a pity, as it doesn't recognize the fans.
  • 6 months later...
Hi guys! I have a question about HP Zbook Fury 16 G9,
The service manual indicates that 2 types of heatsinks are used: for powerful video cards and for weak video cards. They have different designs: an evaporation chamber and heat pipes.
For use on computer models equipped with an NVIDIA high-range graphics card N19230-001
For use on computer models equipped with an NVIDIA mid-range graphics card N19231-001
Which video cards are classified as "NVIDIA high-range graphics"?
Do laptops with RTX 3000/ RTX 2000 video cards have good heatsinks ( high-range graphics card N19230-001) or are they still weak?
  • 2 months later...
  • 2 months later...
  • Keyboard still needs complete disassembly of the device, but at least its not fixed to the palmrest, there are screws.
  • Hinge / exhaust design looks a bit better, still far from ideal, but better.
  • Keyboard still weird with arrow keys cramped together
  • Power button still part of the keyboard
  • Chassis design and fittment looks to be the same as G10/G11, my previous evaluation might apply here as well
  • Who the hell, in his sane mind, designs a workstation class 16/18" powerhouse, with one, and i repeat, ONE USB-A port? Its not lightweight, nor thin, there should be 3+3 A/C ports at the bare minimum.
This, and the fact how i felt about the G10/G11 when I had the opportunity to try it for two weeks, hard pass. Awaiting P16 Gen3.
  • 2 months later...
  As a long time HP Elitebook 8560/Zbook user, seems like the new trend is P16 gen 3:
https://thinkstation-specs.com/thinkpad/p16-gen-3/
  As it seems to have 3 m.2 slots now and full sized 2.5Gbit pot...
  HP just keeps on putting blocks and barriers like fan control, UV, keyboard replace, only HP screens!!!, whitelists, and adding AI cooling, just being an adversary instead of a partner.
  I bought my first 8560w piece by piece and assembled and was AMAZED by it, with it's peak being the Zbook 15 G3, used in space station, the best laptop ever made!!! Dead silent in full load with UV and Fan Control, excellent sound, keyboard, trackpad, chasis, 3D Drive Guard (tested! :))) ), everything was unparalelled, it can be used in every single domain a PC can be used, with all the ports needed and even more. I exchange my keyboard about every 2 year, due to work and it's a breeze. I can do video editing and 3D navigation in video production softwares just by using the 6 button touchpad with very high speed. It even runs Houdini like a champ with 3 SSD-s and 64 RAM, does not know what bluescreen is, crashes are just to remind to change the outfit as a season has passed (from a 9 year old computer, shame on you, the rest!)!
  Then they started the downhill, probably just like M$ after W8.1, might said something like "we beat ourselves, now let's just crappify it!" - so barrier after barrier, bad decision one after another. When I bought the G6 it could do undervolt and fan control, but after bios update not only they stopped, but couldn even go back. They made sure of that. Spent 2 years trying to find a full dump of 01.02.02 until gave up on it and sent it away. With the G8 Fury, what to say... I picked it in favor of G9 just because of the still easy removable keyboard, but when they named Fury they probably meant for the noise and the fury of the user being blocked to fully utilise his asset.
 So, yeah, after more that 10 years of being an HP fanboy, as they don't seem to be be on the right track anymore and don't seem to want that, I think it's time to say "P16! This whole thread was just a loong waiting for something that did not come"
  • 4 weeks later...
Well, it seems that both impressions and reviews about the new Zbook Fury G1i line by HP is mixed - especially in direct relation to the new Dell Pro Max Plus and Lenovo's ThinkPad P16 Gen 3.
I have a quite basic question to those of you who already have/had their hands on one device: The main HP-logo on the outside of the top cover (back of the screen), is this simply a sticker or is it something engraved/formed into the cover plate? (Simply speaking, can one remove it and will the top cover remain an even surface?)
HP_ZBook_Fury_16_G11_Mobile_Workstation_PC_whiteBG_NouvelleSilver_nonODD_nonFPR_CoreSet_Rear_M1557230.png
I would say the chances to be a sticker on a flat surface a lower than 1% IMHO, as it has never been the case until now, not on ZBooks and not even on 8560/70w (in those times it was actually emitting light)
Another question on HP's ZBook Fury G1i series arising from our internal evaluation for the next mobile workstations:
The Thunderbolt ports on the ZBooks are all described as "USB Power Delivery" but not any form of power supply (e.g. PD 3.1), as there is the proprietary charging/power supply port on the notebooks. One of my colleagues mentioned that HP also describes the Thunderbolt ports on "smaller" machines solely as "USB Power Delivery" in the respective quick specs - even if they are also constitute the primary charging/power supply ports.
That raised the question if the "large" ZBooks also accept power supply via their Thunderbolt ports (if one does not have the proprietary charger at hand, for example)? If anybody can confirm, do you maybe know which maximum power can be supplied via the Thunderbolt ports?
  • 2 months later...
I’m using HP ZBook Fury 16 G10 with 16" WUXGA (1920×1200) matte IPS BOE panel. My work is mostly PDFs, text, and AutoCAD.
I’m experiencing eye strain and slightly blurry / thin text, almost like an astigmatism effect. The image also feels too bright and somewhat oversaturated, even at low brightness. ClearType, scaling 125%, and color profiles didn’t really help.
Has anyone experienced this with the BOE WUXGA panel?
Is the 4K dream color panel actually better for sensitive eyes, or does scaling make it worse?
Any recommendations for a more eye-friendly panel (Innolux, AUO, low blue light, sRGB)?
@Ronny I would higly recommend you to join the forum at ledstrain.org; lots of controversials infos there, due to the nature of each individual affection, but, with pacience, you might find something usefull.
To give you a bait: it's not just the screen that is to blame for the jittering!
Thanks! I'll look at the forum ledstrain.org. Do you think I'll get better if I change my screen with the 4K dream color?
No way! What you want is no PWM and no dithering algorithms! So a true 8 bit panel PWM free is a first step; next would be no software/firmware dithering, which can be quite a hassle. So, for starters, no OLED, 30bit Dreamcolor, AdobeRGB stuff!
Guys,
I have managed to snatch an "used", basically new, Fury G10. Battery has 3 cycles, protective foils were still on, SSD had like 1 TB written. Looks like new also. No dust inside or out, untouched KBD.
13850HX / FHD / 64GB DDR5 / RTX 2000 ADA
Not the highest spec, but I have paid 1150 EUR and there is still almost a 3 year warranty. In the current times, where 64GB of SODIMM RAM cost 800 EUR, I can call this a bargain.
What amazes me, is how this unit differs from the unit I had for evaluation. The DPC latencies are noticeably better - not exceptional still, but much better. The fan behaviour is very good, the temperatures are fine, even the fittment of the chassis is good. The display looks horrendous, but I will swap that for something proper, probably 2560x1600 165 - 240Hz. Unfortunately that needs eDP cable swap as well, as the current panel is only 30 pin.
