razor0601 Posted September 17, 2023 Posted September 17, 2023 Hello, I have an AU B173ZAN01.0 4K Display in my P775TM1-G with a few stripes. So I want to change the LCD. Are there other cheap LCD‘s which will work? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
Developer79 Posted September 17, 2023 Posted September 17, 2023 In the P870xx and P775xx it is possible up to 144Hz 4k!:-) 1
jaybee83 Posted September 17, 2023 Posted September 17, 2023 4 hours ago, razor0601 said: Hello, I have an AU B173ZAN01.0 4K Display in my P775TM1-G with a few stripes. So I want to change the LCD. Are there other cheap LCD‘s which will work? as long as u get the dimensions, the mounting holes and the display connector type correct, u can install any other display that ud like 🙂 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
zex4 Posted September 17, 2023 Posted September 17, 2023 I am also searching for cheapest possible displays...1080 60hz 30p also are fine... Can someone recommend me a good source ?😇
Developer79 Posted September 18, 2023 Posted September 18, 2023 17 hours ago, zex4 said: I am also searching for cheapest possible displays...1080 60hz 30p also are fine... Can someone recommend me a good source ? Aliexpress is probably the cheapest! Since there are several providers think...But costs just duty and everything together
Csupati Posted September 18, 2023 Posted September 18, 2023 On 9/17/2023 at 10:16 PM, zex4 said: I am also searching for cheapest possible displays...1080 60hz 30p also are fine... Can someone recommend me a good source ?😇 Your 4k lcd is 40pin edp, if You want 1080 30pin you have to fully dissasemble the laptop ( remove palmrest). Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
zex4 Posted September 19, 2023 Posted September 19, 2023 Oh no I just realized 😳...actually I wanted to say 4k displays 😅....I searched on ebay bunt there are mostly full hd panels there so I need to check aliexpress delevoper said...
Csupati Posted September 24, 2023 Posted September 24, 2023 On 9/19/2023 at 3:35 PM, zex4 said: Oh no I just realized 😳...actually I wanted to say 4k displays 😅....I searched on ebay bunt there are mostly full hd panels there so I need to check aliexpress delevoper said... Clevo/XMG LCD upgrade chart. But You can use any kind of 4k display that is slim and has mounting on the top and bottor corner like this, and have left side EDP 40pin connector : Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
zex4 Posted September 24, 2023 Posted September 24, 2023 Thats Sound interesting 🤔 Good that I have the 40pin cable... So let's see 👀
Developer79 Posted September 26, 2023 Posted September 26, 2023 Like I said, it goes up to UHD in 144Hz! That is not a problem in the P775xx and P870xx!
Csupati Posted October 14, 2023 Posted October 14, 2023 On 9/24/2023 at 10:18 PM, zex4 said: Thats Sound interesting 🤔 Good that I have the 40pin cable... So let's see 👀 Did you find LCD for the P775 or still looking for one ? Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
zex4 Posted October 14, 2023 Posted October 14, 2023 Sadly did not find any affordable 4k panels 😅...find some qhd but I hate that resolution 😕
Csupati Posted October 14, 2023 Posted October 14, 2023 2 minutes ago, zex4 said: Sadly did not find any affordable 4k panels Sadly 😅...find some qhd but I hate that resolution 😕 Whats you region ? US , EU ? Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Csupati Posted October 14, 2023 Posted October 14, 2023 1 minute ago, zex4 said: Eu austria 🇦🇹 ♥️ You are not far ffrom me , Hungary 😄 Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Csupati Posted October 14, 2023 Posted October 14, 2023 im searching for 4k displays but they are around 230-240 eur 😞 Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
1610ftw Posted October 17, 2023 Posted October 17, 2023 On 9/17/2023 at 2:49 PM, Developer79 said: In the P870xx and P775xx it is possible up to 144Hz 4k!:-) Do you have a panel number for us or a link? And will that panel just go in there and connect to the existing 4K panel cable?
Csupati Posted October 17, 2023 Posted October 17, 2023 39 minutes ago, 1610ftw said: Do you have a panel number for us or a link? And will that panel just go in there and connect to the existing 4K panel cable? My P751TM , was used with FHD 144hz/QHD 120HZ panel , then i birnged my 4k igzo+cable and worked instantly. I used the 4k lcd and cable in a P751DM2 and worked there 2. So if you already have a 40pin edp cable ,then only slim panels with 4 mounting flaps will work to able to secure the lcd . Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
razor0601 Posted October 17, 2023 Author Posted October 17, 2023 I also can say that P751dm2 with 4K cable works with 240Hz FullHD Display. If someone is interested Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
1610ftw Posted October 19, 2023 Posted October 19, 2023 On 10/17/2023 at 9:42 PM, Csupati said: My P751TM , was used with FHD 144hz/QHD 120HZ panel , then i birnged my 4k igzo+cable and worked instantly. I used the 4k lcd and cable in a P751DM2 and worked there 2. So if you already have a 40pin edp cable ,then only slim panels with 4 mounting flaps will work to able to secure the lcd . Thanks, I was looking for the 17.3" panel though and asked @Developer79as it seemed that he had already tested a specific display. Personally I would have preferred a nice QHD display like the one in the X170 series but for the P775TM there is only the not that great AUO TN panel that is pretty bad even by TN panel standards.
Developer79 Posted October 19, 2023 Posted October 19, 2023 2 hours ago, 1610ftw said: Thanks, I was looking for the 17.3" panel though and asked @Developer79as it seemed that he had already tested a specific display. It doesn't seem to be just one particular display, I tested it too! AUO makes very good displays. You just have to build appropriate mounts. If you are creative, you can make a solution. The 4k 120Hz display works flawlessly, for example. In my opinion, one of the best displays. Of course, 144Hz is a bit better :-)
1610ftw Posted October 19, 2023 Posted October 19, 2023 1 hour ago, Developer79 said: It doesn't seem to be just one particular display, I tested it too! AUO makes very good displays. You just have to build appropriate mounts. If you are creative, you can make a solution. The 4k 120Hz display works flawlessly, for example. In my opinion, one of the best displays. Of course, 144Hz is a bit better 🙂 Knowing you I kind of thought that you would just take a panel that somehow fits - it is child's play for you compared to the GPU solution 😄 Did you go with displays that have the panel connector in the same place or can the cable also be re-routed for displays that have the connector on the other side?
anassa Posted November 15, 2023 Posted November 15, 2023 Sorry for a late bump - but I was looking for some display information for my P750DM2 and this thread seems to have some good information, so I summarized some of it: On 9/17/2023 at 10:29 AM, jaybee83 said: as long as u get the dimensions, the mounting holes and the display connector type correct, u can install any other display that ud like 🙂 On 9/24/2023 at 6:11 AM, Csupati said: Clevo/XMG LCD upgrade chart. But You can use any kind of 4k display that is slim and has mounting on the top and bottor corner like this, and have left side EDP 40pin connector : On 10/17/2023 at 12:42 PM, Csupati said: then i birnged my 4k igzo+cable and worked instantly. I used the 4k lcd and cable in a P751DM2 and worked there 2. So if you already have a 40pin edp cable ,then only slim panels with 4 mounting flaps will work to able to secure the lcd . On 10/17/2023 at 1:36 PM, razor0601 said: I also can say that P751dm2 with 4K cable works with 240Hz FullHD Display. If someone is interested @razor0601 I find your quote especially interesting - do you know which display it was? It is cool to have these generalities, but having part numbers for display and cables make it easier for other people (like me) to replicate it in the future! I will also eventually update with whichever display I go with and how it worked, so others can see. Previous lives: D900F / P150HM / P150EM / P870DM2 / X170KM Testing/Backup Rig - P750DM2 - **in process** - *Build Thread* Wife's Daily - P750DM2- 4k Panel / 6700k / 1060 GTX / 64GB DDR4 3200Mhz Corsair Vengeance / 1TB Samsung 970 Plus / 2TB WD Black SN770 / Killer Wifi Self Daily - P750DM2 (2016) - Dsanke BIOS / 8700k (2017) / 2080 RTX (2019) / 64GB DDR4 3200Mhz CL16 Ballistix / ETC Determined to keep the socketed 15.6" laptops alive as long as possible!!
razor0601 Posted November 15, 2023 Author Posted November 15, 2023 It’s an BOE NE156FHM-NZ1 But it has no screw holes. So I installed it with double-sided tape. 1 Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
anassa Posted November 15, 2023 Posted November 15, 2023 1 minute ago, razor0601 said: It’s an BOE NE156FHM-NZ1 But it has no screw holes. So I installed it with double-sided tape. Thank you! As long as it works and is stable with it in, who cares if it uses the screw holes! 👍 Previous lives: D900F / P150HM / P150EM / P870DM2 / X170KM Testing/Backup Rig - P750DM2 - **in process** - *Build Thread* Wife's Daily - P750DM2- 4k Panel / 6700k / 1060 GTX / 64GB DDR4 3200Mhz Corsair Vengeance / 1TB Samsung 970 Plus / 2TB WD Black SN770 / Killer Wifi Self Daily - P750DM2 (2016) - Dsanke BIOS / 8700k (2017) / 2080 RTX (2019) / 64GB DDR4 3200Mhz CL16 Ballistix / ETC Determined to keep the socketed 15.6" laptops alive as long as possible!!
