seeing this i think i'm annoyed that Frame Work went with a semi clone of dells proprietary GPU, despite what Linus might have said.
edit: no whiff of intel ARC MXM or AMD MXM? when was the last AMD MXM? Surely a 460 MXM would be leagues better than 980MXM or 1070MXM?
Intel mxm cards exist however the pricing and almost non existent availability just kills it for the few that would have any interest.
is mostly scuttle but about hand fulls of testing and pre production cards or are there pictures of ARC MXM?
X-VSION MXM Embedded Module RTX 4060 GPU Powerful Visual - X-VSION GRAPHICS CARD
Just realized X-VSION now have an MXM type-A RTX 4060 8GB (110w) for $360 🤔 does anyone know anything about the reliability of X-VSION cards?
Edit: Now seen in this thread that @aldarxt has one on order. Very interested to see updates on this!
Dell Precision 7520: Intel Core i7-7920HQ, 32GB RAM, NVIDIA Quadro T1000 4GB, LG LP156QHG (240Hz QHD, 100% sRGB & P3, 400 nits), Intel AX210 WiFi 6E
Dell Precision 3591Intel Core Ultra 7 165H, 64GB RAM, NVIDIA RTX 2000 Ada 8GB
Dell Precision M4800: Intel Core i7-4810MQ, 32GB RAM, NVIDIA Quadro M1200 4GB, Intel AX200 WiFi 6
ThinkPad T440p: Intel Core i7-4980HQ i5-4300M, 16GB RAM, Intel Iris Pro 5200 HD 4600, N140HCE-EN1 Rev.c2 (1080p)
ThinkPad X1 Carbon Gen 2Intel Core i5-4300U, 8GB RAM, Intel HD 4400, QHD
ThinkPad X230: Intel Core i5-3320M, 16GB RAM, Intel HD 4000, 16:10 2K display
ASRock X570M Pro4: Ryzen 9 3900X, 32GB DDR4 3200MHz, NVIDIA GTX 1070 8GB, Corsair Crystal 280X, Xiaomi Mi Curved 34 + Acer Predator Z35
I posted here it did not work in 2 m17xr4"s. Also tried @ssj92 advice to use it in 2nd GPU slot in m18xr2 in SG mode but there is a problem in the 2nd slot and nothing works when a card is installed, just get a bad screen and alot of flickering, my m18xr2 is getting very old.
Not sure how I missed this but good to see it actually arrived! I know it hasn't been long but did you get around to testing the card in your P870DM3-G or M4700? Could be worthwhile to test those before reflashing the VBIOS. Either that or a cheap MXM to PCI-E adapter
I noticed the chip is stated as having a size of 128 bytes on the left panel, isn't this far too small for a 4050 VBIOS? From what I can see, typical 4050/4060 VBIOSes are 2000KB in size. Could the chip's information be incorrectly autodetected, resulting in the buffer size error?
This could also be a good opportunity to see if X-VISN have any after-sales support or troubleshooting steps? You could let them know that other people will likely be interested if compatibility can be sorted out - I'm very interested in the 4060 for my Precision 7520 personally 😈
I'm curious as well; I've been eyeing that 4060 for my Precision 7520 too, and hoping the X-VSION card plays well with eDP
Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1)
Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
Getting so tempting, especially after seeing an X-VSION 3060 was reported successfully booting in @therhor70's M18X R2.
Hopefully there would be a way of limiting the clocks though, 110w through the 7520 heatsink sounds legitimately dangerous 🤣
Had always planned on improving the fans so if I order the GPU, I'll measure them and see if any of the various improved fan blades/motors on Xianyu for the Hasee TX8/TX9 laptops would fit
Didn't see the 110W at first 🤣.  I wonder if the embedded controller sets a limit on power draw?  HW info says my 1650 consumes 35W - I'm not sure whether to believe that.  The M2200 was reputed to have a 55W TDP, which seems like the maximum that the Precision 7520's thermal solution can handle.  An RTX 4060 at 50W performs at ~75% of max performance - if voltage controls are enabled, I could see getting another 5-10% above that.
It's usually a shunt resistor and monitor with an inbuilt limit on the readings on the BIOS. A hardware shunt mod would be a way around this usually.
32" MSI 4k 160HZ IPS display
48GB (2x24) DDR5 6000 CL36
Asus B650E-I motherboard
RTX4090 mxm 150w
  • Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
10 hours ago, ViktorV said:
RTX4090 mxm 150w
This is awesome! Now we just need a version of this for Clevo laptops.
The upgradeability of my SM-G is begging to be utilized.
On 12/14/2024 at 11:59 PM, ViktorV said:
RTX4090 mxm 150w
Where did you buy it?
Seems like same PCB as RTX 3080 from X-Vision. Wonder if it'll work in M18x lol
  • 3 months later...
Wonder if switching out the chip from pcp mxm card with any of those rtx quadro ada gpu's you find workstation laptop changes anything, those one do still have edp support?
On 5/7/2025 at 10:45 AM, panda_zzz said:
x-vsion has the 4080/4090 options up on their website - only $680/910.
Those who want to take a chance can try
https://www.x-vsion.com/product/x-vsion-mxm-embedded-module-rtx-4080m/
Tempting...I messaged them LOL
7 hours ago, panda_zzz said:
I've been wanting one too, but tdp is stopping me for now)
TDP is 150w. Should work fine in M18xR2 and M17xR4
I am talking to them now, maybe I will buy one for testing and post results.
I also want to try RX 660 XT in M17xR3 eDP.
then I'll wait for your results and save up my money😅
1 hour ago, sliderfra said:
@SuperMG3
already gave it a shot and ordered 4070 RTX. He's gonna test it in his M18X R2 and let us know
Can't wait  😃
Hello. Not gonna test in M18X r2, the 3080 stays in.
