SuperMG Posted December 12, 2024 Author Posted December 12, 2024 On 12/10/2024 at 2:23 PM, Jerryzago said: Yes. Cut accordingly. Trim some, test fit and trim some more. You need these fins as long as possible Not working. I cut all, doesn't fit yet... Yes I talk about the fins, we're at the minimum of the minimum (M18X R2 heatsink)
SuperMG Posted December 12, 2024 Author Posted December 12, 2024 Detected by laptop but no install drivers even after inf mod
Jerryzago Posted December 12, 2024 Posted December 12, 2024 1 hour ago, SuperMG3 said: Not working. I cut all, doesn't fit yet... Yes I talk about the fins, we're at the minimum of the minimum (M18X R2 heatsink) Is it really that offset? I mean it has 2 cm of fins. It should fit since it is an MXM format. Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
Jerryzago Posted December 12, 2024 Posted December 12, 2024 1 minute ago, SuperMG3 said: Detected by laptop but no install drivers even after inf mod That's a lot of progress. Don't mod inf. Use NVcleaninstall instead Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
SuperMG Posted December 12, 2024 Author Posted December 12, 2024 1 minute ago, Jerryzago said: Don't mod inf. Use NVcleaninstall instead What is that? Also the offset from the screws is 0.5-1cm
SuperMG Posted December 12, 2024 Author Posted December 12, 2024 (edited) Sus (M18X R2) if it works on M18X R2, it should work on Alienware 18 R1, I'll try that later once I get the RTX 3080 16GB MXMX work on M18X R2 🙂 Edited December 12, 2024 by SuperMG3
SuperMG Posted December 12, 2024 Author Posted December 12, 2024 The GPU is a 60W variant. Might as well ask the seller for a 90W one lol. It passed passmark at 8900 points.
SuperMG Posted December 12, 2024 Author Posted December 12, 2024 (edited) Hey guys, is it normal my keyboard is working half? I cleaned the ribbon cable but still the same Like jklm doesn't register and some other keys (It's not the ribbon cable! Just the keyboard acts strange) Edited December 12, 2024 by SuperMG3
SuperMG Posted December 13, 2024 Author Posted December 13, 2024 (edited) Hello. The seller doesn't help either. Doesn't provide me with a high TDP VBIOS. It literally says on the listing it can do 130W max but it's 60W max in reality. They get 7700 in 3dmark timespy with PCIE gen3 I get 4185... Even on the mail, the seller confirmed me it was the 130W VERSION!! X-VSION are scammers for the price I've paid. Even the RTX 3000 is better... Edited December 13, 2024 by SuperMG3
sliderfra Posted December 14, 2024 Posted December 14, 2024 495Mhz gpu base clock is criticaly low. It ain't normal as it should be at least 1200Mhz, even with a 80W TDP.
SuperMG Posted December 14, 2024 Author Posted December 14, 2024 Hello. Yes. 1080MHz to be exact for 130W* There's also a 90W version but mine is 60W while the seller told me it's indeed the 130W max TDP. Nvidia panel and GPU-Z are stating max 60W. Sadly there are no compatible VBIOS I can flash without bricking. I can't just use any vendors VBIOS since they probably have a different UEFI partition.
sliderfra Posted December 14, 2024 Posted December 14, 2024 did you pay with paypal? If you did so you can start a dispute to shake things up if the seller is not responding
SuperMG Posted December 14, 2024 Author Posted December 14, 2024 2 hours ago, sliderfra said: did you pay with paypal? If you did so you can start a dispute to shake things up if the seller is not responding Yes. That's what I did yesterday haha! The seller literally woke up after seeing a dispute on paypal
SuperMG Posted December 14, 2024 Author Posted December 14, 2024 Hey people. I ordered the RTX 3080 "130W TDP" from X-VSION again. Is this cooler good for 130W? It's designed for GTX 1070 MXM I'll use it on the M18X R2 instead
panda_zzz Posted December 15, 2024 Posted December 15, 2024 25 minutes ago, SuperMG3 said: Is this cooler good for 130W? You may have a problem with the memory chips to the left of the GPU. You may also need to redo the mounts. In terms of pure heat output, it should be able to handle it 1
Maro97 Posted December 15, 2024 Posted December 15, 2024 I think… No it can’t support rtx 3080 as you can see the gpu photo you have 3 vram areas not two areas if you use rtx 3060 may be can use this heatsink
SuperMG Posted December 15, 2024 Author Posted December 15, 2024 (edited) Well it can cool 2/3 of the VRAM. I can just put some thermal pad on the 1/3 that aren't covered with a heatsink. I did make my RTX A3000 MXM fit for the 100W heatsink (left VRAM wasn't present on this 12GB model) Edited December 15, 2024 by SuperMG3
SuperMG Posted December 15, 2024 Author Posted December 15, 2024 17 minutes ago, panda_zzz said: You may have a problem with the memory chips to the left of the GPU. You may also need to redo the mounts. In terms of pure heat output, it should be able to handle it This heatsink has a bigger coverage than the original 100W heatsink, so no problem on that. Also I just need to trim the heatsink fins to make it fit. No need to redo the mounts.
panda_zzz Posted December 15, 2024 Posted December 15, 2024 9 hours ago, SuperMG3 said: No need to redo the mounts. then try it, it probably will work.
SuperMG Posted December 15, 2024 Author Posted December 15, 2024 22 minutes ago, panda_zzz said: then try it, it probably will work. Hello. It worked for the original 100W for the RTX A3000 (same die and Vram placements), so why not on this custom heatsink that's made to support and cool well the GTX 1070 MXM (120W-125W)
SuperMG Posted December 18, 2024 Author Posted December 18, 2024 Hello. I'm gonna return the RTX A3000 12GB MXM 60W because the seller sent me a wrong one. Once the seller will receive he 60W one, the seller will send me the 130W variant.
sliderfra Posted December 21, 2024 Posted December 21, 2024 On 12/18/2024 at 1:09 PM, SuperMG3 said: Hello. I'm gonna return the RTX A3000 12GB MXM 60W because the seller sent me a wrong one. Once the seller will receive he 60W one, the seller will send me the 130W variant. Hey, Seller is not very professional as you had to force a paypal dispute to get an answer. Cards are different or just vbios differ? Because if cards are the same, and only vbios differs maybe you can flash it with ch341A & 1.8v adapter?
SuperMG Posted December 21, 2024 Author Posted December 21, 2024 3 hours ago, sliderfra said: Hey, Seller is not very professional as you had to force a paypal dispute to get an answer. Cards are different or just vbios differ? Because if cards are the same, and only vbios differs maybe you can flash it with ch341A & 1.8v adapter? Hello. It has a different PCIE ID but the same GA104 die. I tried to flash a 130W VBIOS from techpowerup but it didn't work. GPU not being detected so I had to revert back to the original working 60W VBIOS.
SuperMG Posted December 21, 2024 Author Posted December 21, 2024 Okay remember I was about to buy an RTX 3080 MXM. It's been ONE week and I still haven't got a single tracking number for it... Are they gonna scam me on this one too? Let's see. To be honest they only help when you are filling a dispute thru PayPal. Only pay with PayPal when they only accept bank as an online payment.
SuperMG Posted December 23, 2024 Author Posted December 23, 2024 On 12/18/2024 at 1:09 PM, SuperMG3 said: Hello. I'm gonna return the RTX A3000 12GB MXM 60W because the seller sent me a wrong one. Once the seller will receive he 60W one, the seller will send me the 130W variant. Hello. The shipping was fast for the return. It says delivered to their place but the seller still haven't texted me yet. I think I'll probably get both cards in January:(
