Hello.
I have a clevo X7200 laptop with a X58 desktop chipset and a Xeon W3680
This laptop has two MXM slots, both can deliver 100W with 100W heatsinks as well.
Officially this laptop works with the GTX 680M as the best MXM GPU. It does work with GTX Fermi as stock and AMD 5000-6000.
Many in the past tried a GTX 780M, 980M but there was nothing on display. But none of them tested the next combo of: putting a Kepler based GTX 670/680/K3000M GPU in the master slot and GTX 780M/980M in the slave slot.
So I tried to put a Quadro P5200 in the first slot, not work.
But If I do a GTX 680M for display + Quadro P5200 for 3d rendering, the laptop boots. Detects both GPU as Nvidia Graphics Card in the BIOS.
So what I did is having a GTX 680 2GB DELL card in the first slot (master) and a Quadro P5200 in the second slot (slave).
So yes, you can add a much recent card in the Clevo X7200 only if you have a compatible GPU for display in the master slot.
I do have one issue. My GPU is performing worse. Like it's averaging 70W in 3dmark and heaven benchmark. In FurMark I did get 84W spike at best.
The GPU has a 110W vBIOS. My temps seems to be good (below 80C on 3d benchmarking), I added thermal paste and thermal pads on VRAMs and VRMs.
@triturbowho sold me the card was able to achieve 110W average with an HP 8740W with an Intel Core i7 740QM and PCIE at 2.0 x16.
My laptop does pull PCIE 2.0 x16 speed for both MXM slots.
I get 3400 points on 3dmark TimeSpy instead of 5700. There is no thermal throttling, GPU is being used at 100% according to GPU-Z.
My AC Adapter is a 300W 20V one and I have a 2024 Nvidia Quadro driver (modded .INF for both GTX 680M and P5200).
How can I achieve 100W average when benchmarking/stress testing, am I power limited? Does the vbios has a bad reading for the target power limit? (Temps sensor work, I hear fan speeding up when doing some benchmarks).
This is the same issue I have in Alienware M18xR1 as well. When using M2000M primary and RTX 5000 as secondary I get 60w TDP limit on RTX 5000.
but in SG mode I can hit full 90W of card.
still haven’t figured out where the issue is unfortunately
Hello, thanks for commenting.
What TDP max is your RTX 5000?
Did you try AMD for the first slot?
Any PSU upgrades or vBIOS mods to the target TDP?
I still haven't try with AMD HD 6XXX and Quadro K3000M as master cards yet...
The RTX 5000 runs at full 90W in SG (Optimus) more perfectly fine in the same laptop. Problem is when using dual cards.
Haven't tried AMD card, I don't have any modern ones.
Laptop can power 2x 113W 880M SLI no issues so it's definitely some weird compatibility issue.
I think with 880M I was getting full TDP. When switching to M2000M it is running lower.
PSU is not an issue. I have 780W Eurocom PSU and this laptop can use more than 330w unlike the newer ones which were hard capped.
Bruh.
I bought dual PSUs for nothing then and Quadro k3000m 75W... Didn't test them yet
Why is there a difference between 880M and M2000M? M2000 should allow more performance because it doesn't use 100W
Bro those AMD HD 5000/6000 are all defectives... Now one is showing big rectangles lines
I can't test anything directX because of this dead AMD gpu.
But I did manage to get 94W max on GPU-z. With the GTX 680M as master, I got 84W max before.
But the performances are the same. When doing 3dmark, I have 70W average...
Tested with a Clevo GTX 485M, Dell GTX 680M, same performance.
I can't even get the GPU-Z 3D test to work with 485M + P5200 combo because it crashes log. But can run FurMark and 3dmark. Performances are same.
I have merged a number of posts.
I will not merge more posts, further infractions will simply result in post deletions.
Please respect the rules we have here on the forums, thanks!
AM4-DD | 5800X3D @ 4.45Ghz | Red Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | Intel X710 DAC @ 10Gbps | EVGA 1300w | Win11 IoT
UNRAID | Xeon Gold 6248 40c/80t | 128GB DDR4 2933Mhz | P1000 | 9300i-16P | Intel X520 | 48TB HDD's | BeQuiet DP 13 1000w
Hello.
The Quadro K3000M arrived but... It's not the K3000M. It was the K3100M instead. Not compatible as it's a newer Kepler card... The listing was for a K3000M 2GB. I'm so unlucky. 3rd GPU that's not working in a row!
@SuperMG3 Hey man, sorry for the late reply. I know you've been trying to get input from me for a bit as I've been tagged multiple times across your posts in multiple threads. I kept forgetting to respond.
So to solve your performance issues with the Quadro P5200, my first suggestion would be to check your power supply. When I upgraded my Alienware 17 from a GTX 860m to a GTX 1060, I ended up having to get a 240 watt power supply, else the card would never kick into its highest performance mode (its P0 state). It would stay stuck at its P2 state (medium performance) no matter what I tried when I had my stock 180 watt pwoer supply connected to my laptop. If you already have a 330 watt power supply, that should be enough, but using dual 330 watt power supplies or one of those Eurocom 780 watt power supplies wouldn't hurt.
We can help diagnose your issue by checking the performance mode the card is going into by using Nvidia Inspector (not Nvidia Profile Inspector!). You should see a section in the program that says P-State, along with the performance state readout of the GPU. From what I remember diagnosing my GTX 1060, there were 3 possible states: P8 (low power state), P2 (medium performance state), and P0 (maximum performance state). Perhaps your Quadro P5200 is getting stuck on the P2 state for some reason like my GTX 1060 was, thereby limiting the maximum power draw. You can try overclocking the P2 state from Nvidia inspector to see if that nets you any gains.
You should be able to force the P0 state using this guide: https://www.xbitlabs.com/force-gpu-p0-state/
If you cannot force the P0 state and the GPU insists on staying in its P2 state, either the card is power starved or something else is wrong. If you've determined the power supply isn't the issue, then we'll have to do some further investigation.
Hello, thanks for reaching. I'll try that later.
I did something earlier, the GPU was cooking.
90W average, 112W MAX on Heaven Benchmark instead of 70W
GTX 485M: Error code 31, drivers broken/missing
Quadro P5200: Drivers installed, DirectX9 doesn't work but the rest it works
FireStrike only runs at 10fps, weird maybe because it has an influence on the first GPU?
TimeSpy didn't try.
Heaven Benchmark, I did see I have 30-40 fps more than before but the GPU hot spot cooked, 99C, I stopped the benchmark.
Indeed it was pulling 90W average with 95W, 98W, 101W readings.
So having the default VGA Windows drivers (none) for 485M and Nvidia driver for P5200, managed for me to unlock the wattage but I can't even execute DirectX 9 titles anymore...
Do you have an idea how did the power get unlocked?
I'm waiting for the HD 7970M to be delivered.
Hello.
Indeed my GPU does P0. With or without regedits.
When the GTX 485M has a driver, P5200 can do max 70w average and without a 485M driver, P5200 does 95W average...
I don't understand. 485M is also at state P0 at the same time as the P5200 while the 485M is doing nothing other than displaying...
Edited by SuperMG3
6 hours ago, SuperMG3 said:
Hello.
I went back to read your previous posts and had a thought. The Quadro P5200 is the slave card and the GTX 485m is the master card, correct?
If that's the case, no wonder your benchmarks aren't as high as expected. You're running your benchmarks purely on the Quadro P5200, correct?
There is a performance and time cost associated with transferring information across the PCIe bus between 2 GPUs. If the master card is tasked with an operation, then sends data to the slave card to then perform another operaiton on that data, then the data is read back to the master card, that will result in a significant performance decrease due to latency penalties. However, in your case, the slave card does the work directly right? There will still be a performance decrease in this case since there's still the readback time cost, but at least only going one way this time (slave card to master card). Since the slave card doesn't output directly to the screen, the work performed by it has to be routed through the master card and passed to the screen. There is a performance cost associated with this as both GPUs have to use their encoder and decoder units to process this transfer of data.
The confusing bit to me though is the massive performance deficit you're getting versus what you would be getting if the Quadro P5200 was connected directly to your laptop's screen. I would think there would be somewhere between a 10-20% performance decrease from having to pass the output through another graphics card (depending on how good the encoder/decoder units on both cards are). However, you're getting around a 40% performance deficit, so something is definitely wrong. Perhaps the encoder/decoder units on the GTX 485m can't keep up with the thoughput of the Quadro P5200 and that stalls the rendering pipeline? The Quadro P5200 is much more powerful than the GTX 485m, so I have a feeling the GTX 485m is a bottleneck. Have you tried with any other cards as your primary display output card?
Typically with dual GPU configs, you want both cards to have the same amount of processing power or close to the same, as one card will bottleneck the other if the disparity between the cards' capabilities becomes significant. What is the most powerful card that will work in the master slot of your laptop? Were you able to identify any particular reason the Quadro P5200 would not work in the master slot?
Even with a GTX 680M I get the same watt average by the way. Isn't it the same as Intel iGPUs + Nvidia?
Is it because of the VRAM speed? 96-116GB/s (485/680M) vs 230GB/s for P5200. HD 7970M has 156GB/s
I think I can put a RTX 3000/4000 but not worth it.
The thing is, if the master has the generic VGA drivers, the slave gets lots of power by the way. So we probably need to limit the first GPU, but how?
The best master card is: GTX 680M, HD 7970M, K5000M, all 100W
Also I'll test with a HD 7970M in the master slot soon.
Edited by SuperMG3
As I mentioned in my M17xR2 thread, when using nVidia GPU in primary and secondary slot (different cards), there seems to be some weird issue where both GPU TDPs are being combined for some reason.
In my example, it was RTX 3000. It is a 80W TDP card but is it being limited to 55w. Using MSI Afterburner, I can see the primary M2000M is using 20-25W during the benchmarks. If you add 25+55w, you get the 80w TDP.
This of course is just a theory, but considering my M17xR2, M18xR1, and your X7200 are doing the exact same thing, it tells me this isn't a hardware issue itself.
PSU is NOT the issue. I can run 2x880M SLI @ 113w each in M18xR1. I also have 780w Eurocom PSU. The fact that I cannot exceed 55w on GPU2 and GPU1 is using up to 25W tells me the driver is combining their TDPs.
Now for Pascal and older GPUs, what you can do is just increase the TDP of the card. If a P5200 has a 110w TDP just increase to 130w and see if performance improves.
Hello.
Possible to flash with Nvflash (dos or win) without CH341A?
I managed to get 127W with VGA generic drivers for 485M.
You're telling me the same Nvidia drivers are causing the limit issue... But what If I have one AMD + one NVIDIA driver, will that fix or not?
But I still don't understand one thing...
How is your M2000M impacting so much your slave card? But the 880M isn't?
M2000M is a low consumption card compared to the 880M right?
Edited by SuperMG3
@ssj92Hello. I'll probably receive the AMD HD 7970M tomorrow, I'll test.
I hope the card doesn't artifacts nor doing the instant shutdown.
I'll see how well AMD + NVIDIA goes.
Good luck, I’m still waiting on a couple GPUs myself
So increasing the power limit in the vBios didn't work for you?
Didn’t try it, vBios mod causes code 43 error
need premade one but I’m certain TDP increase should help
How did this one made your error 43? Did you flash another VBIOS from another manufacturer? Can't you edit the original vbios for higher TDP?
I modified the TDP using pascal mobile TDP tweaker but the generated vbios causes code 43.
now it’s in my M6600 and I don’t plan to remove it.
only m17x r2 with dual GPUs and m17x r3 with single GPU left to test stuff with.
I still don't understand one thing though.
You're getting full power of your RTX 3000/5000 with 880M + 3000 combo but...
M2000M + 3000/5000 you are getting power limited. How does that happen?
I’m getting power limited with 880M now too. So it only Worked once. Need to figure out what was different
Possible VRAM bandwidth related speed?
Nope it’s definitely a driver issue somewhere
