yslalan Posted April 24 Posted April 24 On 4/3/2026 at 1:59 PM, whyshchuck said: Yes, it did. No I have my motherboard an gpu replaced by dell technician but it didn't help. What helped was forcing computer to use GPU for external screens. But still no ports in TCC: Do you see yours here? This control centre has been deprecated. All settings for USB4 device(i.e., USB4 and USB4V2) have been moved to the USB submenu under Windows Settings. All CPU-integrated Thunderbolt 4 controllers (except for TigerLake CPU), and dedicated Thunderbolt 9000 series(TB4 & TB5) controllers are recognized as USB4/USB4V2 under Windows. Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
yslalan Posted April 24 Posted April 24 On 4/10/2026 at 8:29 AM, Aaron44126 said: Dell hasn't implemented Advanced Optimus into these workstations. It does support and works pretty well on Pro Max Plus. Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
JRS Posted April 25 Posted April 25 On 4/23/2026 at 11:48 AM, river rocket said: My Xeon 7760 with RTX5000 died this week, so I replaced it with a Pro Max 18 Plus Ultra 9 285HX RTX PRO 3000. So far, I'm very happy with the new workstation. I use it mostly for SolidWorks (small assemblies) and Video editing for a YouTube channel I run. I pulled the bottom cover off, started looking at the storage, and I’m trying to figure out if anyone is actually running a Gen5 NVMe in one of these. Which led me to this site and post. Dell only offers up to 2TB now, no 4TB option anymore (was available). My assumption is that’s thermal-related and not a platform limitation. I moved over three 980 Pros from the 7760, and was originally planning to grab a 2TB 990 Pro for the boot drive. But Gen5, pricing looks much cheaper, so it got me thinking and doing some research. The boot drive is isolated to the side, but there’s no dedicated heatsink setup for the drive. Looks like you’re relying on airflow and whatever thermal pads Dell is using. So the real question: Anyone actually running a Gen5 drive in one of these? If so, what drive and what temps are you seeing under sustained load? I'm leaning towards the 9100 since I have all Samsung now. Any throttling issues? I’m less concerned about peak speeds and more about real-world behavior, especially longer writes (video/render workloads). Curious what people are seeing before I go experiment on my own. Thanks in advance. I have the Pro Max 16 Plus which came with a Gen5 drive. Something I discovered by moving the drive around is that one of the NVMe slots is faster than the other two. Physically it's numbered as the second slot although it's numbered as 1 in the UEFI since the UEFI numbering starts at 0. The included drive, which is a Samsung PM9E1, will reach 14500 MB/s in that slot but only around 12500-13000 in the other two. 1
Aaron44126 Posted April 25 Author Posted April 25 14 hours ago, yslalan said: It does support and works pretty well on Pro Max Plus. I stand corrected. This must be "new" for this generation, first I've heard of it. 3 hours ago, JRS said: I have the Pro Max 16 Plus which came with a Gen5 drive. Something I discovered by moving the drive around is that one of the NVMe slots is faster than the other two. Physically it's numbered as the second slot although it's numbered as 1 in the UEFI since the UEFI numbering starts at 0. The included drive, which is a Samsung PM9E1, will reach 14500 MB/s in that slot but only around 12500-13000 in the other two. Typically, one of the drive slots has PCIe lanes attached directly to the CPU, and the others all go through the PCH, so this is not a surprise. Though I can't explain why Dell numbered them the way that they did (assuming that this is actually the reason behind what you are experiencing). Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 26 "Tahoe" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
yslalan Posted April 27 Posted April 27 On 4/25/2026 at 8:44 AM, Aaron44126 said: and the others all go through the PCH Based on the PCIe topology of this generation, it appears that the PCH is not connected to the SSDs. Instead, the NVMe devices are connected directly to the CPU (i.e., two are connected to the IOE tile, and one is connected to the SoC tile). IOE is shared with Thunderbolt 5 and dGPU; PCH is pretty idle from what I can see (WLAN and SDXC reader only). It's not a surprise to see a bandwidth difference across different tiles. 1 Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
perla Posted April 28 Posted April 28 Hello everyone! What are your typical boot times for a Dell Pro Max 16 Plus (MB16250)? Mine is frustratingly slow. Otherwise working great. The power up sequence looks like this: 0. sec: Simple Dell logo for ~9 sec after pushing the power button 9. sec: "Secured with Dell SafeBIOS" text also appears for ~19 sec 28. sec: Windows loading animation for ~23 sec 51. sec: Finally at the logon screen I have the latest BIOS that was set to defaults. The machine has 128 GB CAMM2, so that can probably add some extra boot time, but this much? I can see the ~19 sec "SafeBIOS" time is not unusual: https://www.reddit.com/r/Dell/comments/1sx9xtz/the_new_dell_pro_max_laptops_spend_18_seconds_in/
yslalan Posted April 29 Posted April 29 13 hours ago, perla said: Hello everyone! What are your typical boot times for a Dell Pro Max 16 Plus (MB16250)? Mine is frustratingly slow. Otherwise working great. The power up sequence looks like this: 0. sec: Simple Dell logo for ~9 sec after pushing the power button 9. sec: "Secured with Dell SafeBIOS" text also appears for ~19 sec 28. sec: Windows loading animation for ~23 sec 51. sec: Finally at the logon screen I have the latest BIOS that was set to defaults. The machine has 128 GB CAMM2, so that can probably add some extra boot time, but this much? I can see the ~19 sec "SafeBIOS" time is not unusual: https://www.reddit.com/r/Dell/comments/1sx9xtz/the_new_dell_pro_max_laptops_spend_18_seconds_in/ It's normal Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
SvenC Posted May 6 Posted May 6 After every few Windows Updates my Pro Max 18 Plus "loses" the camera: IR light is constantly flashing in red - it logs me in with Hello but after that it keeps flashing. The camera indicator stays on (white light) but neither the camera app nor Teams get video from the integrated camera. Uninstalling and reinstalling the latest WIndows Update (I use Windows 11 Insider beta channel, currently 25H2, 26220.8340) combined with uninstalling the camera and camera IR devices from device manager sometimes helps. Sometimes I uninstall & reinstall multiple times and at some point the camera device starts working again. Super time consuming procedure to get the laptop working normally again. Anybody with any idea what could cause such a behaviour and how it could be solved without hassle of uninstalling and reinstalling Windows Updates? Typically directly after the latest Windows Update everything is working, but later on, after a reboot or resume from hibernate that camera missbehaviour starts. BIOS is up to date and as far as I see I've got all relevant Dell driver updates installed. Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
JRS Posted May 18 Posted May 18 After using my Pro Max 16 Plus for several weeks, I am disappointed by the performance. The 175W TGP on the RTX 5000 Pro is only sustainable for short periods of time. Under sustained heavy load it will thermal throttle to around 115W, which perhaps not coincidentally, is what hwmonitor reports as the base TGP.
AL123 Posted May 19 Posted May 19 20 hours ago, JRS said: After using my Pro Max 16 Plus for several weeks, I am disappointed by the performance. The 175W TGP on the RTX 5000 Pro is only sustainable for short periods of time. Under sustained heavy load it will thermal throttle to around 115W, which perhaps not coincidentally, is what hwmonitor reports as the base TGP. I saw similar on pro max 16 plus, more like 120-125W with the RTX Pro 4000 IIRC I tested where as in the 18 inch chassis the RTX Pro 4000/5000 ran at 175W sustained in my tests and the fan noise was reasonable in my opinion. Actual performance wasn’t linear though so maybe 10-20% lower for ~50W difference not many options out there in workstations the equivalent HP Zbook fury 16/18 throttled heavily even in the 18 inch chassis I tested and the fan noise was very high! Lenovo have gone backwards with the P16 Gen 3, only equip it with a 180W power supply so never going to do sustained high power 2
yslalan Posted May 26 Posted May 26 On 5/18/2026 at 6:08 PM, JRS said: Under sustained heavy load it will thermal throttle to around 115W, You are right, it's a 115W TGP card with the Dynamic boost to 175W. Same for MB16250 and MB18250. On 5/19/2026 at 7:23 AM, AL123 said: I saw similar on pro max 16 plus, more like 120-125W with the RTX Pro 4000 IIRC I tested where as in the 18 inch chassis the RTX Pro 4000/5000 ran at 175W sustained in my tests and the fan noise was reasonable in my opinion. Actual performance wasn’t linear though so maybe 10-20% lower for ~50W difference I still don't understand this. I have compared vBIOS from 16inch and 18inch, they are identical in binary. Also, the card is switchable between the two devices. It seems that the logic of the EC may limit the draining of power. Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
whyshchuck Posted May 26 Posted May 26 Today Dell told me that Dell Pro Max 18 Plus is not compatible with SD25TB5 unless downgraded to Windows 10 (they really told me that). Before they did I had my motherboard replaced, gpu replaced and then whole unit replaced. There was couple of weeks when hybrid mode worked with dock but now itd don't (on both units). Does anyone of you use this pair of hardware together with success? 1
SvenC Posted May 27 Posted May 27 8 hours ago, whyshchuck said: Today Dell told me that Dell Pro Max 18 Plus is not compatible with SD25TB5 unless downgraded to Windows 10 (they really told me that). Before they did I had my motherboard replaced, gpu replaced and then whole unit replaced. There was couple of weeks when hybrid mode worked with dock but now itd don't (on both units). Does anyone of you use this pair of hardware together with success? What a bad joke is that?! We replaced a few older Docks with SD25TB5 for some colleagues and I was able to test one, just to check if displays, network and power supply works. Had no problems with Windows 11 Insider Beta channel (build 26220), but I was just using it for an hour or so. Kept my WD19DC which works OK with my MB18250. On rare occasions I get the boot message that the power supply is not sufficient. Had to unplug, power off the dock and retry. But other than that it works. Might be due to my system not having a dGPU, which needs less power. Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
AL123 Posted May 27 Posted May 27 21 hours ago, whyshchuck said: Today Dell told me that Dell Pro Max 18 Plus is not compatible with SD25TB5 unless downgraded to Windows 10 (they really told me that). Before they did I had my motherboard replaced, gpu replaced and then whole unit replaced. There was couple of weeks when hybrid mode worked with dock but now itd don't (on both units). Does anyone of you use this pair of hardware together with success? Absolute rubbish from the dell support. These systems and docks were released well after Dell stopped selling systems with windows 10. We use these for 50+ engineers on pro max plus 16 &18 on windows 11 without issue had some teething problems intially but no complaints for a few months
AL123 Posted May 27 Posted May 27 On 5/26/2026 at 9:34 PM, yslalan said: You are right, it's a 115W TGP card with the Dynamic boost to 175W. Same for MB16250 and MB18250. I still don't understand this. I have compared vBIOS from 16inch and 18inch, they are identical in binary. Also, the card is switchable between the two devices. It seems that the logic of the EC may limit the draining of power. Interesting I’d say the heatsink isn’t quite as capable on the 16 it’s a slightly shrunken version of the heatsink/ fans on 18 inch chassis so maybe thermal limited? I never really looked that hard at GPU thermals or knew where NVIDIA sets the limits, just noted they generally way cooler than Intel CPUs that always push 100 degrees! My workload for testing also likely fluctuated load a bit as it was rendering either a large scene that would get split up into tiles or animation frames which means some small drops from 100% load as it loads the next bit of scene/ frame But I think it’s still a realistic real world GPU compute task, I see similar for GPU accelerated simulation too it’s never a perfect 100% load constantly. i also observed slightly lower sustained CPU power on the pro max 16 plus, not a huge real world performance difference in performance but ~ 5W less sustained power IIRC. This was all early days before we put the systems on our domain, can’t run any tools that aren’t on our allowed software list now!
yslalan Posted May 28 Posted May 28 Today I received another PM16P without the touchscreen option (no quick access bottom door). To my surprise, the top case color is not exactly the same as my other one; one looks slightly off. Another difference is that the surface finish also feels different (for all surfaces, including top case, bottom case, and palmrest): one feels more textured, while the other feels smoother. I’m not sure why this is the case. Maybe it is due to differences in production batches or manufacturing locations. The touchscreen model was made in China, while the new non-touchscreen one was made in Vietnam. Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
yslalan Posted May 28 Posted May 28 6 hours ago, AL123 said: Interesting I’d say the heatsink isn’t quite as capable on the 16 it’s a slightly shrunken version of the heatsink/ fans on 18 inch chassis so maybe thermal limited? I think the GPU portion is software-limited. From what I remember in the leaked promotional materials, the PM16P has a 170 W system TDP, while the PM18P has a 200 W system TDP. In my use case, the GPU does not get very hot, but it still stays around 145–150 W under sustained workloads. As you mentioned, the 18-inch model can stay at 175 W for a longer period. So my guess is that the firmware dynamically manages the power split between the GPU and CPU based on the hard-coded system TDP limit. Dell Pro Max 16 Plus Ultra 9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Dell XPS 16 DA16260 Ultra X7-358H - Arc B390 - 32G LPDDR5X - 3.2K OLED - 1T NVMe
whyshchuck Posted May 28 Posted May 28 On 5/27/2026 at 1:16 PM, AL123 said: Absolute rubbish from the dell support. These systems and docks were released well after Dell stopped selling systems with windows 10. We use these for 50+ engineers on pro max plus 16 &18 on windows 11 without issue had some teething problems intially but no complaints for a few months You use them in defualt hybrid mode or switched them to direct? With what screens resolution? Do you diplay anything with rtx on external display? At both machines I posess screen connected with DP lose identity after wake up (and switches from 2k to fhd) Both computers disconnect docking station after attempt do display anything heavy weight (eg. any modern game) on external screen.
AL123 Posted May 28 Posted May 28 5 hours ago, whyshchuck said: You use them in defualt hybrid mode or switched them to direct? With what screens resolution? Do you diplay anything with rtx on external display? At both machines I posess screen connected with DP lose identity after wake up (and switches from 2k to fhd) Both computers disconnect docking station after attempt do display anything heavy weight (eg. any modern game) on external screen. Mostly using hybrid mode connected to 2x 1920x1080 24 inch ultra sharp monitors via DisplayPort or HDMI. We had some QHD and 4K monitors but it’s not the standard yet. 3D applications on external displays either displaying graphics or rendering although internal laptop panel is usually the primary display for me it’s mostly my email/ teams I have on that screen. we had some issues a while back with black screen on returning from sleep which meant unplugging the dock and plugging back in. I suffered from that but not seen in in atleast a month likely due to some recent updates. Ultimately keep on at support at some point you will likely have to play the game of resetting windows to prove it’s not a windows/ your environment causing the issue but needs to be escalated if they can’t solve it!
JRS Posted May 30 Posted May 30 On 5/27/2026 at 9:24 PM, yslalan said: I think the GPU portion is software-limited. From what I remember in the leaked promotional materials, the PM16P has a 170 W system TDP, while the PM18P has a 200 W system TDP. In my use case, the GPU does not get very hot, but it still stays around 145–150 W under sustained workloads. As you mentioned, the 18-inch model can stay at 175 W for a longer period. So my guess is that the firmware dynamically manages the power split between the GPU and CPU based on the hard-coded system TDP limit. The 115W TGP under sustained load in my testing was definitely a thermal limit at 87C. I'm disappointed given how thick the chassis is. Believe the Dynamic Boost portion of the TGP has always been software limited as it's shared between CPU/GPU.
Dave Posted August 10 Posted August 10 Hello, I am planning to purchase a Dell Pro Max 16 for work. I use CAD, Visio, and Blender, and I have always used my dad’s Dell workstation at home for school and work. However, I will be assigned to work overseas, so I am not sure which configuration would be best. I have a few questions and would appreciate your advice. CPU: 265HX or 285HX (Not decided yet, but 285HX will not be able to run at sustainable speed for long rendering hours from what I read on reddit - have you experienced any issues with heat?) Memory: DDR5 64GB CSO DIMM at 6400 Mhz (I am debating on whether to go for a single DRAM Module and upgrade later to 128GB or go with dual 32GB x 2). May I confirm whether this laptop can run 128GB at 6400 Mhz? SSD: I will keep the 1TB factory SSD for now GPU: RTX 2000 or RTX 3000 (I have concerns about heat and also seems like the GPU is locked at 115W) Display: Going for 1920 x 1200 (To save battery life on the road/working on construction site) Thanks
delboi Posted September 5 Posted September 5 I’m following this thread because I’m investigating similar WHEA-Logger Event ID 17 behaviour on a Pro Max 16 Plus. One question I have for people who have had Dell work on affected systems: were the removable PCIe devices ever physically isolated or substituted during troubleshooting? In particular: was the NVIDIA DGFF module ever replaced with a known-good module, rather than only changing drivers/settings or replacing the system board? was the Intel BE200 ever physically removed/replaced, rather than only disabled in Windows or BIOS? I’m asking because I’ve seen reports involving the same BE200 PCI ID (8086:272B) on some other recent systems, including Alienware and Acer machines, and I’m interested in whether anyone has compared those cases or performed a true hardware swap test. I’m not suggesting the BE200 is necessarily responsible. For context, Dell has already replaced the system board and NVMe SSD in my system and the behaviour remains. I also ran an Ubuntu Live comparison. Linux enabled PCIe AER and the BE200, NVMe and Intel graphics were present, but I did not observe the same Windows-style AER burst during that session. The NVIDIA GPU was detected but was not fully exercised under the Linux live environment, so I don’t regard that test as proving or excluding any particular component. I’d be interested to hear specifically from anyone who has had either the BE200 or DGFF GPU physically swapped or removed and whether that changed the WHEA behaviour or the intermittent stuttering.
JRS Posted September 7 Posted September 7 For those who own a 16 with a dGPU, are the vents on your base cover open over all 3 fans or only 2?
