JadeRover Posted April 27 Posted April 27 Hello eveyrone, Ok so this problem applies only to MXM gpus that have a "pwr" limit (as well as "thrm" limit sometimes) in GPU-Z when doing a benchmark. This is also known as the "40w power bug" Such example : Notice this is not due to hitting the power limit of the card (33% of TDP). Symptoms of the low power bug is a TDP usage around 50% = 40w if you have a TDP of 80w. I think I found the issue. It has to due with a digital signal that is sent to the GPU, the PWR_LEVEL signal : A previous fix was to block the SMB_DAT or SMB_CLK signal so that the EC chip of the laptop wouldn't be able to communicate with the MXM dGPU. This has the disadvantage of stopping all data communication between EC and MXM dGPU = no more thermal data coming in = EC usually ramps up the GPU fan to maximum. According to MXM 3.1 documentation : This signal is not mendatory and it does apply some kind of power reduction when enabled. Therefore I took a gamble and decided to cover it up and see what happens. My fix is to block off the PWR_LEVEL pin with a bit of tape. - I first put some normal paper scotch tape on my plastic desk (to get it nice and flat during cutting process) - I cut it into a thin strip with a very sharp cutter(width of MXM pin) - I removed it from my plastic desk, then applied it with tweezers. The pin is the 9th counting from the first "thin" pin, on the TOP of the MXM module aka side of the MXM gpu where there is the actual GPU die : It's okay if you cover up the 8-5th pin as well as these are reserved pins (no connection inside a laptop) I did this on my dell precision 7720 with GTX 1060M and this has so far resolved the issue, my card can now boost to 100w thanks to the modded bios. Hope this helps someone ! 3 1 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
sliderfra Posted April 28 Posted April 28 Hi, That's great job! Too bad I sold my alienware 17 already, I would've tested it with the RTX 3000, as the TDP bug happened on it.
ssj92 Posted April 30 Posted April 30 On 4/27/2026 at 1:28 PM, JadeRover said: Hello eveyrone, Ok so this problem applies only to MXM gpus that have a "pwr" limit (as well as "thrm" limit sometimes) in GPU-Z when doing a benchmark. This is also known as the "40w power bug" Such example : Notice this is not due to hitting the power limit of the card (33% of TDP). Symptoms of the low power bug is a TDP usage around 50% = 40w if you have a TDP of 80w. I think I found the issue. It has to due with a digital signal that is sent to the GPU, the PWR_LEVEL signal : A previous fix was to block the SMB_DAT or SMB_CLK signal so that the EC chip of the laptop wouldn't be able to communicate with the MXM dGPU. This has the disadvantage of stopping all data communication between EC and MXM dGPU = no more thermal data coming in = EC usually ramps up the GPU fan to maximum. According to MXM 3.1 documentation : This signal is not mendatory and it does apply some kind of power reduction when enabled. Therefore I took a gamble and decided to cover it up and see what happens. My fix is to block off the PWR_LEVEL pin with a bit of tape. - I first put some normal paper scotch tape on my plastic desk (to get it nice and flat during cutting process) - I cut it into a thin strip with a very sharp cutter(width of MXM pin) - I removed it from my plastic desk, then applied it with tweezers. The pin is the 9th counting from the first "thin" pin, on the TOP of the MXM module aka side of the MXM gpu where there is the actual GPU die : It's okay if you cover up the 8-5th pin as well as these are reserved pins (no connection inside a laptop) I did this on my dell precision 7720 with GTX 1060M and this has so far resolved the issue, my card can now boost to 100w thanks to the modded bios. Hope this helps someone ! Interesting, this seems easier than the resistor mod someone else here pointed out. Do you think this would also fix the dual PEG power issue? Where we use a SLI laptop to put a working gpu in slot 1 and a non working gpu in slot 2 to get gpu2 to work? The issue with that one is..the gpu always runs 20-30w less than its power limit. (ex 90w gpu runs at 60w). The other question is....does this allow the gpu to exceed its power limit? would a 115w gpu be able to go higher or is that vbios limited? Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
JadeRover Posted April 30 Author Posted April 30 1 hour ago, ssj92 said: Interesting, this seems easier than the resistor mod someone else here pointed out. Do you think this would also fix the dual PEG power issue? Where we use a SLI laptop to put a working gpu in slot 1 and a non working gpu in slot 2 to get gpu2 to work? The issue with that one is..the gpu always runs 20-30w less than its power limit. (ex 90w gpu runs at 60w). The other question is....does this allow the gpu to exceed its power limit? would a 115w gpu be able to go higher or is that vbios limited? Hi, I think for dual gpu laptops it's worth a shot to tape off that PWR_LEVEL pin and see what happens. What is the performance limit reason in gpu z for the affected gpu? If it's "power" when it shouldn't be (seing 60w instead of the real 90w power limit) then it definitely can be the PWR_LEVEL signal causing this. Keep in mind that this fix doesn't give the gpu infinite power limit, you still have the power limit set in the vbios. This fix prevents the EC of the laptop telling the gpu to throttle it's power. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
ssj92 Posted May 1 Posted May 1 9 hours ago, JadeRover said: Hi, I think for dual gpu laptops it's worth a shot to tape off that PWR_LEVEL pin and see what happens. What is the performance limit reason in gpu z for the affected gpu? If it's "power" when it shouldn't be (seing 60w instead of the real 90w power limit) then it definitely can be the PWR_LEVEL signal causing this. Keep in mind that this fix doesn't give the gpu infinite power limit, you still have the power limit set in the vbios. This fix prevents the EC of the laptop telling the gpu to throttle it's power. Yup Dual PEG also constantly has 60w limit with PWR reason. Looks like I have several laptops to test this on. I'm hoping you can figure out the turing quadro vbios as well for your tool so I can increase tdp. flashing 130w lenovo vbios causes code 43 on the hp 90w rtx 5000. Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
DraykB Posted Friday at 07:03 AM Posted Friday at 07:03 AM Hey @ssj92 did this work at all for Alienware 18 r1? I have one I've been messing around with and got one of those hp rtx 5000 gpus, but it does that thermal and power alert. Any info would be great.
ssj92 Posted Friday at 07:33 PM Posted Friday at 07:33 PM 12 hours ago, DraykB said: Hey @ssj92 did this work at all for Alienware 18 r1? I have one I've been messing around with and got one of those hp rtx 5000 gpus, but it does that thermal and power alert. Any info would be great. I still need to test this, probably with rtx 4090 + aw17 first since it's easier to disassmble Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
DraykB Posted Friday at 10:13 PM Posted Friday at 10:13 PM That's fair, been trying to see if there is any way to remedy the issue. The laptop runs great when the issue isn't occurring.. I did also see something about messing with the power or thermal alert pull up resistor? It's in this link at the end: https://notebooktalk.net/topic/2195-rtx-3080-in-m18xr2-should-i-do-it-lol/page/11/
JadeRover Posted Saturday at 07:36 AM Author Posted Saturday at 07:36 AM 9 hours ago, DraykB said: I did also see something about messing with the power or thermal alert pull up resistor? It's in this link at the end: https://notebooktalk.net/topic/2195-rtx-3080-in-m18xr2-should-i-do-it-lol/page/11 Hi, Yes this is the same method as on this thread but the mod is done on the motherboard. Counting the pins on the second picture, pin 27 is actually the 9th pin after the big ground pad of MXM slot, so his method is also blocking the PWR_LVL signal from being sent to the MXM gpu. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
DraykB Posted Saturday at 08:02 AM Posted Saturday at 08:02 AM I did try taping the pin but it was still doing it... Maybe I didn't do it right? Would it also need the thermal alert pin to be covered as well? I don't know a whole lot about mxm signaling, though I have read about that section.
