Hello everyone
The laptop suddenly loses power while I’m playing games, as if I had unplugged the charger from the laptop while the battery is not installed. What could be causing this problem?
can be bad mxm slot ( is taht the one with vapor chamber ?)  or is this one where u put other vga like 980 mxm and so on ?
before conclusion tell us  if  u have more notebook or just one...
notebook pwoer off can be cpu overclock..... try a stable multiplyer for 4.2ghz ....
I have a clevo p870tm with a modded vapour chamber heatsink with the 4 arms adapter to support rtx 3080 it’s a second gpu which i bought from the same seller on ebay the first one worked without no issues before i cracked it
19 minutes ago, Scruffy said:
can be bad chip, but so many of them went bad ? maybe core problem....
try reballing it.
try reballing it.
Hi, this might sound a little weird, but I’ve already encountered something similar a few times and when I wasn’t completely sure if reballing would help, I put the card in an electric oven for 10 minutes at 180 °C. Maybe the artifacts will disappear then. But it’s also possible that one of the memory chips is defective. The GPU core temperature might be very low, but that doesn’t mean the VRAM temperature is the same.
Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000
Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎
Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060
never do reflow... it only stress cpu, vram and all other component. and it's not a proper reballing.
send card tto someone that has the right equipment to do a proper job
hard part is to be able to test the vga .. if they dont have an mxm notebook to try after they do rework and reballing.
3080 available on ebay for like 330€.
Another issue with rtx 3080
The screw connecting the modded vapor chamber heatsink to the adapter was installed without the size-reducing nut, which caused the screw to be the wrong size. Of course, the screw scratched the PCB and caused a short circuit on the GPU.
Therefore, I strongly recommend always installing the nut and making sure it is properly in place before tightening the screw.
The short circuit that happened on the MXM card has been fixed. But a short occurred on the 1.3-volt rail that powers the VRAM, which caused some of the VRAM modules to malfunction. I tested it using MATS. This is the result I got. Can someone tell me how many VRAM chips need to be replaced?
from the second picture, looks like some trace is broken. always use ipa to make the pcb and trace more visible. if u can make a better picture with ipa on it...
My friend, the repair process has already been completed, and I have the MATS test report as the result.
The card had a short circuit, and I already explained everything about it. My question is: based on the MATS report, how many VRAM chips need to be replaced?
i would change probably only c0 and d1 as before u got error on a1 and b0 while not now.
remember that samsung chip have like 13 omh reading...
where do you have the short ? on the coil or on vram nearby caps ?
shorted rail should give no display or also no power at all.. i see u are able to post: are u using a second vga ?
No my friend, this is another graphics card with a different fault. It has damage to the PCB caused by a heatsink screw: a screw of the wrong length was installed on the arm of the modded adapter, which superficially penetrated the PCB and caused a short, permanently cutting off the display data.
And now the short has been removed and the PCB crack has been repaired. Display data appeared on the screen, and I ran a MATS test to find out which VRAM chip is faulty and causing the artifacts on the screen.
The 1.8V VRAM supply rail had a problem because the PCB layers made contact with each other, which caused a short circuit. As a result, the two VRAM chips closest to the crack were damaged.
The two VRAM chips that are most likely faulty are C0 and D1, because they were close to the damaged area.
The remaining low error counts are probably just signal interference, meaning “error ghosting.” I think there is still a good chance the card can be repaired.
You have to check the signal quality on the traces with oscillograph. If the equipment is not available you cannot know with high confidence about signal quality causing data loss. You would have to take the financial risk and remove C0, D1 and re-test VRAM. The best option financially would be to get new used GPU.
I bought a GPU, but it turned out to have a problem, and I don’t know what caused it. So I decided to return it and save myself the headache. Now I’m trying to repair the damaged GPU that was working perfectly and was known to be reliable.
