Ray Tracing on M18xR2 - RTX 3000 MXM Upgrade!
I have bad news, my m18xr2 is in bad shape, looks like a long project in my path. Getting many BSOD's, system service exception, IRQL not less or equal, Page fault in non paged area, Kmode exception and others I can't keep up with. I was going to shelf it but decided to just make it a "Test Machine" now. It also has a bad 2nd GPU slot, so it needs a new MOBO which I have 1 but was unable to get it to power-up. I tried a GTX 980m in the 1st slot and the RTX 3000 in 2nd but because the 2nd slot is bad I got badly flickering screen. Also that Flat Ribbon HDD cable has to be the Downfall of the m18xr2! If I don't get it sitting just perfectly I have lost DATA on some drives. So I am transferring drives, upgrading other Laptops, reinstalling Blindows and trying to figure out what to do with this RTX 4050. Just feels like a big flop in my face BUT! I still LOVE that m18xr2
So @therhor70 on "RTX 3080 in M18xR2? Should I do it? lol" has suceeded with xvision GPU where I have failed. Hooray! xvision sell good cards!
did you use two cards in PEG or SG mode?
upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`dTesla M6 Oc`d
In past lives:
Most of the first set of problems are related to hard drive communications. I say stop using the HDD caddy, get an msata for boot and place an SSD caddy to your Optical drive. There are options to put an 2230 Nvme to the Msata port via an msata to Nvme adapter. I will try it shortly to see results.
Also the flickering might be if you installed the 980m and RTX3000 and had set the Video settings to SG.
I places in both slots two RTX3000 (HP main slot, PNY secondary). PEG resulted in 8 beeps, SG resulted to flickering.
Thanks @Jerryzago for the confirmation on stop codes!
Looks like a good plan not using the flat ribbon cable. Now the m18xr2 will have a glove compartment lol
I set it in SG with 2 cards
you had to use PEG, SG can't work with two cards (without some complicated manipulations). You had to put in the main slot a card that works in PEG and in the second slot RTX, as you did, but you had to enable PEG.
In past lives:
OK, Thanks, that'll be my next move with the GTX 980m in 1st slot and the RTX 4050 in the 2nd.
Sure do wish I bought the RTX 3080 instead
You should've bought the 4060 since it is cheaper (360$), less tdp and it is more powerful.
X-VSION seller told me that the RTX Ada won't work on M18X R2 and Alienware 18 due to the motherboard's BIOS.
But RTX Ampere works (Quadro and GeForce)
The BIOS should be modded differently. My hypothesis: Add ReBar maybe?
Edited by SuperMG3
A4500 also didn't work for me from Aetina.
If you know how to mod BIOS you can add this module and see if it helps:
https://github.com/xCuri0/ReBarUEFI
I think there's something about UEFI for the BIOS. Most Ampere VBIOS and all Ada won't work on Alienware M17X R4 and M18X R2.
For example, X-VSION Ampere work but not Aetina ones.
Interesting, I’ll have to take a look to see if I can find out what is different in vBIOS
Yeah we need a hero to patch the bios . Since at least on haswell you can use the sleep bug to flash modded bios . Rebar would  be a big win for haswell based Alienware units
Furthermore . I'm in talks with xvision s out the Rx 6600 . They have the xt and non . They are 130 watts so they will be a bit power limited at 110 until resister 004 is soldered . But I'm not sure if they will work on haswell
I can add the ReBar Module to the bios but need someone to test it and be able to flash back their backup bios via programmer is it fails. No clue if it will help booting newer GPUs
I can flash it myself and then if anything with the help of a programmer back. but there you will need an RTX video card for proper testing of this, right?
In past lives:
Yes but the first step will be to confirm the bios was modded correctly and flashes fine. If so I’m sure more people would be willing to try as well
@panda_zzzhello. Is that an X-VSION card? What the heck. On this same forum someone tested the 4060M and it wasn't even detected. Even X-Vsion themself told me it doesn't work
as far as I know on this forum only 4050m has been tried. yes it is a card from X-VSION. originally I took it for m4800 but it is too hot for it and I decided to try it in m17x r4. it needs serious heatsink modification for it because it overheats easily under load.
Was the 4050 from X-VSION as well?
So 4060M works on M4800/M6800 then? So it means it can work on M4700/M6700 damn...
I bought an RTX 3060M 12GB and an RTX 3080M 16GB. It's going to come soon to my home finally. Testing on AW18 R1 and M18X R2
20 hours ago, panda_zzz said:
Interersting...eDP or LVDS mode?
