3 hours ago, panda_zzz said:
Don't forget that with this processor, you will be limited to 2 RAM slots and a maximum of 16 gigabytes.
and where is the problem? 16GB is more then enough for everything except big photoshop / video files, n for this the supported CPUs r way to slow atm(except i like to wait for hours 😄
Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro
Every once in a while, I use mine for live FHD video.  (cameras, local sources, etc., with production and encoding all in the moment and all "in the box")  That tends to eat RAM.  And CPU cycles, even if it does offload the encoding part to the GPU.
It's not the sort of thing that can wait either: each frame *must* finish before the next one starts.  But this 10-year-old design with mostly original parts (all except storage, GPU, and OS) does keep up with it!  32GB and an i7-4940MX.
ordered a 4930MX, 20 bucks cheaper then the 4940MX(or the 4980HQ) n the OC results for both r the same, so no need to waste money on that 😄 n found another 2x 4GB 1866 mem in a old 2570P here, so could go for 24GB... but will short the battery life, the reson i only will install the 1TB mPCIe SATA SSD, less power using stuff in the system as possible...
now will think about to optimize the heatsinks... sadly is not from the bottom like HP where u can use the bottom plate as huuuuuge heatsink 😄
On 1/10/2026 at 3:15 AM, Annihilator said:
first parts arrived, ordered a wifi 6/AX BT 5.2 card with native mPCIe so no adapter needed, works pretty well, installed win11 as clean install on a 256GB samsung 850pro which i found in the corner, but a 1TB mPCIe SATA is on da way n will do a fresh install there(since i know is bootable) then n the HDD bays possible will mod to fan-slots for better air flow(like i did with my former elitebooks) when possible. putted my gskill 1866MHz mem in n installed XTU to undervolt the CPU, -0.070V n all core boost on max ended up in 5% singlecore n 6% multicore performance(just quick test with cinebench)
im getting really excited that the NV cooler arrive soon, want try the GTX 880M n still not sure which CPU 4930/4940MX or 4980HQ(yeah u can order socket version for G3 socket = will fit n work in M6800)... in games the 128MB L4 cache from the HQ gives a huge burst(10-40% when no GPU bottleneck), but the open multiplicator from the MX on the other side will give more performance everywhere. next upgrade would be then a P5200, more then enough power for 1080p n mid settings + max details bcs 16GB of vram will be more then enough 😄
U can install a WIFI 7 card (Intel BE200HMW) though. So not sure why you went with WIFI 6. I made the same mistake until I came across a post on this thread of another member successfully installing the Intel BE200HMW and went with it as well.
Like panda_zzz mentioned all 4980HQ CPUs currently on the market, adapted for the socket in the M6800, are limited to 2 RAM slots. Previous reports of one guy being able to use 4 RAM slots are unconfirmed and unlikely to be true at this point as no evidence were furnished to show all 4 RAM slots in use. All postings I come across online all points to being limited to 2 RAM slots and sellers that I spoke to all said the same as well.
If you want to overclock, the 4930MX has better potential than the 4940MX and is cheaper as well. If you want to try an Nvidia GPU, why not start with the GTX 980M or M5000M? They have better performance and are widely available and price is quite reasonable. Unless of course you have a GTX 880M available on hand, then there's no point getting another one.
The P5200 is good but is a power hungry beast and with that produces a lot of heat when running. Depending on the revisions, Rev A & B is about 100W-115W and C & D can go up to 150W. I know as I still have the P5000 (100W) on my M6800 running and it runs pretty hot!
The RTX 3000 might be a better bet as it is cooler (80W) and slightly cheaper and gives you ray tracing and more advance features than the P5200. Though in terms of raw power, it lags behind the P5200 and P5000. I will be swapping to the RTX 3000 soon and just need to find the time to take apart the M6800 to do the swap. I am using a LVDS motherboard and screen and using SG btw.
the wifi 6/ax card i got near by for 5 bucks, n 1500 down n 1400 up(tested) more then enough...
n 2 mem slots more then enough, dont know who set the "32GB needed" thing into the world when not doin video/photo editing, im gamer n even in 4k not one single game i know which need 32GB, n photoshop i only do on the PC, more threads, more mem etc. so 16GB is fine for 99.9% of users.
ordered a 4930MX anyway, goal is 4.5GHz, lets see its possible(with optimized cooling, maybe LM instead of grease)...
yeah, the 880M already here, but want more power 😄 i have the eDP display, so pascal cards should run flawless anyway when seen it right? n the advantage of the RTX3000 is DLSS, at quality mode will already outperform a P5200, big red flag is only 6GB of vmem, will limit even in 1080p in a lot of games. so RTX 4000 or even better 5000 would be the better option(when possible?).
On 1/9/2026 at 2:49 AM, Will said:
Hey, did you get it installed? Did it work?
Haven't got around to it yet as i had to fix another friend's laptop. Will try it this weekend.
Those cards beyond RTX3000 either have a slightly different offset layout that needs extensive mods on the gpu heatsink or is build a tad too big to fit the M6800.
just took a look, the 4000 card seems impossible without modding chassis from the m6800 bcs mounting holes on different places, the 5000 seems to have everything on the right place, but need soldering some copper plates on the heatsink for proper cooling(but nothing serious) but price of the 5000 card is 🤐
As the 4980HQ is an unsupported CPU with no specific M6800 drivers, is the full performance and L4 cache actually able to be utilized? Are there any caveats such as having to run a specific version of Windows or Linux?
You don't need drivers for a specific CPU. Dell doesn't offer any "CPU" drivers for the Precision M6800 (or any other system). The chipset drivers are there for other onboard components, not the CPU. Cache is managed by the CPU itself, not the OS/drivers. There's no issue running any "compatible" 4th-gen CPU in the M4800, other than the RAM slot limitation that has been mentioned recently.
You are indeed correct about the CPU not needing drivers, apologies as I was thinking about the chipset drivers. Thanks for the further clarifications as well.
just found this, even stock a 4980HQ is faster then a OCed 4770K @ 4.5GHz(which is the same CPU like a 4930MX/4940MX just massive higher TDP / Boost clocks)... so maybe will even order a 4980HQ to get those extra fps.
n found a 5200P for "cheap" maybe will take it... then would be no GPU bottleneck with the 4980HQ 🤩
You can also attempt this to get unlimited multpliers, requires bios mod to inject the microcode however, not sure if it's been done on m6800
https://www.techinferno.com/index.php?/topic/9636-tutorial-4ghz-overclock-i7-4xxxmqh-to-i7-extreme-conversion-intel-haswell-cpu-microcode-bug-hack/
Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded
I don't think I've ever seen anyone talk much about RAM upgrades for the M6800. There was a guy on YouTube who said that he was able to upgrade to 64GB with the only requirements being an i7 processor and the latest BIOS update. As you know the official max is 32GB. However, I bought a 64GB kit of RAM that was the exact same specs as my 32GB, just double in capacity, and it just threw up RAM errors. I tried every stick in every slot combination.
Has anyone else tried 64GB? It makes sense that it could be possible as many E-series Latitudes of that era have been confirmed by multiple YouTubers to be able to take double the officially stated maximum, with for example, 8GB limits actually taking 16GB.
nah n no need for, 16GB is more then enough for everything except vid/photo editing... even when u put a RTX5000 in it n a 4k display n playing maxed out + RT in games, never 16GB will be the limiting part in it(but the CPU will be).  more important is mem speed n timing, 1866 should be the minimum, 2133 the optimum... atm i searching for 2133 modules n will give thaiphoon burner a try to set 2400MHz...
Whether there's a need for it or not is kind of irrelevant, as most of the mods here aren't exactly necessary. I thought it was all about just seeing what was possible? And 16GB is not enough for a lot of people who run mobile workstations, heck the M6800 is literally meant for photo and video editing as part of its reason for even existing.
sure is nice to see whats possible, but the CPU is pain in the a.... for video/photo editing bcs not enough threads, for gaming still an option, bcs most games not use more then 8 threads(some does n u will see at the min fps, but for mobile still ok).
n maybe u should try 1333MHz mem, maybe the IMC will run with 64GB then.
btw. someone tried a NPU in the m6800 yet? seen some modules with mPCIe standard, n some xtra TOPs can be useful in some cases.
Well the CPU had enough cores/threads when it came out and I don't see that things have changed that much with regards to video editing requirements. Unless maybe people insist on editing 4K/8K video.
And yes there has been tests done on Windows 10 with an mPCIe form factor Google Coral TPU in the 1/2PP (MC) slot, and an M.2 form factor one with an adapter in the ExpressCard/54 slot. See the newer comments at the post below:
https://www.dell.com/community/en/conversations/precision-mobile-workstations/dell-precision-m6800-slot-motherboard-12mc-pp/647f7f3ff4ccf8a8dedb7309
yeah, not understand me wrong, i still use my 8570P with 3840HQ for photoshop n sometimes sm0l video editing so i know why saying "its slow" 😄
n thx, lets make this old machine to a AI PC 😄
hi. everyone
I have 3 m6800s
One is used in the work place, one is used at home, and one is kept as a spare in case of a breakdown.
It's been a long time since I bought all three.
I didn't buy it new, I bought it one by one about 5-6 years ago.
It was sturdy, expandable, and the performance was not lacking in the range I used it.
This year, instead of buying a new laptop, I decided to upgrade further.
The one with the best performance among the three is the 4910mq k5100m with 32GB memory.
The rest of the devices have the same CPU of 4910mq.
I confirmed that only the GPU is K4100m.
Old materials scattered around the internet, including Reddit and here.
After searching through various forums, I have selected a few upgrade items.
I ordered a GTX 980M from AliExpress.
They're almost identical products, but there's a slight price difference between the M5000M and the 980M.
Reading the posts here has made me more interested in the P5000M, but I'm still hesitant because
the price is still very high.
I was thinking of putting a 980M in one unit and an M5000M in the other,
but I haven't decided on a CPU.
I'm concerned about overheating because the 4930 or 4940MX have higher TDP.
The 4980HQ PGA offers good performance, but it's not manufacturer-level quality,
so there seem to be quite a few cases of CPU failures.
I'm also concerned that the maximum memory is limited to 16GB.
I'm wondering if it will work properly if I add 1866MHz memory to the M6800.
Even if filled with 1866 memory, will the actual operating speed be 1600?
The text is long, but I'm curious about the opinions of those with experience.
thank you
someone knows?: the cpu fan connector, its a "JST 1.25 - 4-Pin"?
and any possible way to set the TDP limit higher for the CPU? the max is 61W, then the mainboard cut it, thats a bit annoying, even with vcore offset from -0.050V n cache voltage offset from -0.015V running at 4100MHz allcore/cache into the powerlimit.
maybe shunt mod possible on the mainboard?
Hello everyone, I'm Mirko from Italy (Venice land) and I'm happy to be now a M6800 owner. It has an AMD m6100 that I would like to upgrade. I went crazy by reading the whole forum and asking informations to AI...i received some missmatching information.
By your precious experience, I'm kindly asking for a card with:
- TDP max 75w (better is 55w)
- H265 support
- at least 4gb of vram
I use it just for light old gaming (2015) and Full HD video streaming.
I just want a card more power efficent than my M6100 (that runs hot)
I also have the heatsink used for a k4100m (I will sell it).
I prefer not to mod the heatsink, just to put proper thermal pads and modded drivers. I'm not skilled enough for flashing bioses using Linux...
I was thinking about a wx7100 and limiting its power, or a p3000 or a gtx 970...
Hearthly thanks in advance.
Mirko
- H265 support
Mirko
for all those cards u mentioned u need to mod the heatsink anyway(bcs of the coils).
for nearly all cards u need to flash another bios... think best for u would be a RTX 3050M 8GB or a 3050 Ti M 8GB, both have max 75W TDP n full feature set.
Hi everyone, I've been following the upgrade paths for the M6800 here. Has anyone experimented with using an MXM 3.0 to PCle x16 adapter to connect a full-sized desktop GPU?
If this is possible, then our possibilities are truly infinite. Lol
I've actually found some forums where people successfully pulled this off with other laptop models.(2nd and 3rd pic)
Https://notebooktalk.net/topic/1196-clevo-p775dm3-mxm-to-pciex16-gpu-adapter-mod-project/
13973-MXM-To-PCI-e-X16-Extension-Cable-PCI-Express-Cables-50cm-EGPU-Adapter-MXM-8x-16x-jpgQ90-jpg.webp
Edited by aleksandar
Hello. I don't know anyone who tried this adapter on the M6700 and the M6800.
Today I'll test my new eDP 120Hz screen on the M6700, if the screen works, I'll test with RTX 3000 then RTX 4080 MXM.
I'll also get a password BIOS locked M6800, eDP screen too. I'll test RTX 3000 and RTX 4080 MXM. I hope these GPUs will work.
