5 hours ago, aleksandar said:
Hi everyone, I've been following the upgrade paths for the M6800 here. Has anyone experimented with using an MXM 3.0 to PCle x16 adapter to connect a full-sized desktop GPU?
If this is possible, then our possibilities are truly infinite. Lol
I've actually found some forums where people successfully pulled this off with other laptop models.(2nd and 3rd pic)
Https://notebooktalk.net/topic/1196-clevo-p775dm3-mxm-to-pciex16-gpu-adapter-mod-project/
13973-MXM-To-PCI-e-X16-Extension-Cable-PCI-Express-Cables-50cm-EGPU-Adapter-MXM-8x-16x-jpgQ90-jpg.webp
i had a eGPU on my HP 2570p connected via expresscard slot, just for "whats possible" was nice, but really useless, bcs i never took my eGPU with me 😄  n at home i prefer a real PC
Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro
I imagine that that would be more along the lines of, "I have this machine already, it's not actually going anywhere, and I want to put something in it that doesn't fit.  So instead of buying a whole 'nother machine, I'll put this in what I already have."
I can't see it being easily portable after that mod, because of the heavy brick on a captive cable, the case mods to get that cable out, and the required stand so it doesn't sit on that cable and rock like a 4-legged stool that's missing a foot.  But beyond all that, I can see it being useful for someone.  Doesn't have the hard stop on support like the internal slot does...or at least not until the industry decides to use something other than PCIe...
1 hour ago, aleksandar said:
Can someone guide me regarding vBIOS? Is it required for GPUs like the GTX 970M, GTX 980M, Tesla M6, etc.?
Where can it be downloaded?
Maxwell GPUs don’t require any vBIOS work. Note that Tesla M6 doesn’t support direct display output and can only work through the Intel iGPU via Optimus. Also, you do have to do a little mod to the GPU heatsink to get these cards to fit.
Ah yes, vBIOS.  I'd forgotten about that, despite having a bit of a process to get mine.  vBIOS is like the main BIOS, except it's on the GPU.  (the 'v' is for video)  Essentially, you're reprogramming the GPU so that it behaves like something the main BIOS can work with.  And that could be a hard stop in support, even if the electrical connections are all good.
You can't just stuff a random vBIOS in there.  It has to be made for the card you're putting it on, because it does a lot else too.  So in terms of what *we're* doing, you can kinda think of it as a bridge between the circuitry in the card and the BIOS in the main machine.  Both ends of that bridge have to work, and eventually, you won't be able to get the entire combination.  That's a hard stop.
I've only had the one, and it was on a site that was clearly legacy and specific to the card.  So I can't answer that question directly, but just give you a sense of what you're getting into.
It also required an old version of Linux to actually install the vBIOS, because the periodic cleanup(s) that happened since then removed that support.  Once I did though, modern Linux knew what to do with it.  If you're on Windoze, I couldn't tell you anything anymore; I ditched M$ when Win10 refused to update on my M6800.
On 1/28/2026 at 6:14 PM, SuperMG said:
Hello. I don't know anyone who tried this adapter on the M6700 and the M6800.
Today I'll test my new eDP 120Hz screen on the M6700, if the screen works, I'll test with RTX 3000 then RTX 4080 MXM.
I'll also get a password BIOS locked M6800, eDP screen too. I'll test RTX 3000 and RTX 4080 MXM. I hope these GPUs will work.
Hello. M6700 doesn't work with the RTX Ampère and Ada cards... With the 120Hz eDP screen of course.
M6800 eDP (without IGPU) works with the RTX Ampère and Ada cards. Installed the drivers and did the "EDID manipulation because of the bad X-VSION VBIOS". The card pulled instantly 150W when I launched Furmark, I had to stop at second 3 because of my temporary heatsink test. It throttled so fast when the core reached 100C. I didn't test the HDMI out and DP out, it should work with X-VSION VBIOS. HDMI is DP_C and DP is DP_A.
I'll sell the eDP M6700 120Hz 3D with Core I7 3940XM and 16GB RAM, if someone is interested... This project was expensive.
Hello, good news for M6800 users, a new heatsink has been made that is 2 in 1!
Triple heatpipes for the GPU and full copper plate. Can support standard NVIDIA MXM and the offset center ones! Better performance than the OEM one!
https://ebay.us/m/oFTxSC
I'll be the first one to test it. I'll sell (EUROPE SHIP) it once the tests have been done and once the newer and expensive version is out.
Edit: a more expensive option would be out... 4 heatpipes version, extended fins. CPU heatsink would still have 2 short heatpipes going to the right side and it'll be also full copper with "C-Shells spikes". Would probably cost 50-60USD more...
There is also one for M6700 but the RTX Ampère and Ada won't work in PEG eDP...
Edited by SuperMG
Can someone guide me on installing a Wi-Fi 6 or 7 card? I mainly need a card with modern Bluetooth, version 5 or higher, so that my BT headphones will work.
I assume I need an mPCIe to M.2 adapter.
https://a.aliexpress.com/_EIK96A0
Does this one fit?
And also a Wi-Fi + BT card, can someone recommend one that definitely works, preferably one that’s available on AliExpress?
Thanks in advance.
I know a BT USB dongle would solve my problem right away, but it will not look professional.
Intel AX200 should be fine. I had one of those in my Precision M6700, with an M.2 adapter, and it worked great. I would think BE200 would also be fine but I haven't tried that one. I think you can even get AX200 in mPCIe form factor (might be harder to find) so you wouldn't need an M.2 adapter.
The M.2 adapter that you linked to won't work. You need an A or E key adapter, and that one is B key. (I made this mistake too.)
Note that you will need adapters for the antenna cables as well. Look for "U.FL to MHF4" adapters.
When I installed a M.2 Wi-Fi card in my M6700 with an adapter, at one point I pressed down too hard and it ended up causing a scratch on the motherboard, which broke a trace and led to me having to replace the motherboard. Be careful with the install. I recommend putting some electrical tape *under* the adapter, between the adapter and the motherboard, just to reduce the chance of damage to the motherboard.
That's great news! Does it mean we can use this CPU heatsink to install the MXM B cards that is offset to towards the centre of the card?
Also keep us updated on the more expensive option when it comes out!
Does this one fit?
Thanks in advance.
You can get the BE200HMW, it works directly in our usual WLAN card slot without having to go through any adaptor. It supports WIFI 7 and Bluetooth v5.4.
I have one on my M6800!
Yes, didn't you see the link? It could be compatible with a big range of GPU formats, even the latest and newest Blackwell GPUs from Aetina/Zotac, so it could also be a 3 in 1 since we have 8 holes for the x-bracket.
Please help cicichen by purchasing one of his heatsinks! It's cheaper than making your own 3D model and submit it to a company.
What do you do for drivers, just use the generic Intel ones? Also, what OS are you running?
Just the generic Intel ones. I'm using Win10.
Just bought one from cicichen! Does it mean we can use the Quadro RTX 5000 or RTX 5090?
https://www.ebay.com/str/cicichen594
cichen's shop details above! Many custom made heatsinks etc available!
If 5090 has the same offset as the RTX 4090 MXM then yes. Quadro RTX 5000 Aetina, PNY, ADLINK will fit too!
It's the holidays for China, maybe contact the seller if an early shipping is possible or not
On 5/28/2024 at 3:09 PM, Reciever said:
That is not true iirc
Ran 32GB in an m6800 with the 4980hq a couple of years ago. 4980hq shines only where L4 cache is utilized.
Long since sold the system though so I can't get validation.
Hello, what version the 4980HQ was? Green PCB? AliExpress SR1ZY PGA?
Is it better than an i7 4910MQ?
I found on the internet that many people got stuck at 16GB DDR3 with 2 sticks of RAM.
I already got the newer RTX Ada to work on eDP on the M6800 with DP and HDMI out. (Just need a fixed VBIOS to enable the eDP that's being disabled by the Nvidia drivers when init)
His case was the only one I can find on the internet with a successful 32GB being ran in the M6800. Sadly though, there's nothing to back his case other than what he mentioned.
Hi all,
I've just recently purchased an M6800 for myself to use as a high performance and durable workstation/gaming/server device. I stumbled upon this thread by accident when I was searching all over the Internet on why my RAM wouldn't do 1866Mhz and only 1600Mhz when I figured it's most likely because on this RAM I purchased (G.SKILL Ripjaws F3-1866C11Q-32GRSL) the greater clock speed is XMP-level and the 1600Mhz is only JEDEC-level.
Upon reading all the posts in this thread so far, I have gathered that @Jers6410 appears to have managed to get even 2133Mhz RAM working in his M6800 (albeit only 16GB), which is amazing and just shows you that CPU and motherboard limits aren't always true. This has got me intrigued because I'd like to do this (unless there's even faster supported RAM, if so please let me know!). Does anyone know if 32GB of this frequency will work too, and if so, does it have to be 2x16GB or does 4x8GB work too?
Many thanks,
Mic
On 5/6/2022 at 12:36 AM, jaybee83 said:
back to the 2133 mhz SPD sticks: Kingston HyperX 2133 mhz were SPD sticks that do not require XMP:
http://geizhals.at/1186628
Where on Earth do you purchase this from? I have looked all over the web! Specifically, I'd like 4x8 for 32GB.
welp its been a while....and currently with the AI RAM apocalypse going down its even more difficult to track down specific sticks.
21 hours ago, MicXTech said:
Hi all,
Many thanks,
Mic
i have 2x 8GB ripjaws V 1866 C10 in my M6800 n works perfect at that speed, they r same like hyperX, plug n play with the programmed speed. just waiting for my 4x 2133 to arrive, got a set for around 150 bucks + shipping, isnt cheap but will push the CPU limit another 2-5% up, depends which game 😄
