AaronD Posted September 18 Posted September 18 4 hours ago, BoheN said: does it run very hot? Idling, no. The fan stays off. When it's working, the fan runs as expected.
BoheN Posted September 22 Posted September 22 On 12/11/2022 at 3:13 AM, Jers6410 said: Why this sizes? Well that's because the AMD heatsink seems to be of a different height compared to NVIDIA one... And the GPU die was far taller than my previous FirePro M6100 so this was the sizes that worked for me. If someone else find a better sizes for this kind of project please make the corresponding corrections to this post. Iam set on getting the P5000 for my M6800, only picture i seen with new thermal pads is this one using AMD heatsink, which pads should i order for the nvidia heatsink? how tall should they be?
AaronD Posted September 23 Posted September 23 15 hours ago, BoheN said: which pads should i order for the nvidia heatsink? how tall should they be? I replaced nVidia with nVidia, and reused the same original pads. Seems to work just fine. If you're replacing AMD with nVidia, then I wouldn't know.
BoheN Posted September 23 Posted September 23 57 minutes ago, AaronD said: I replaced nVidia with nVidia, and reused the same original pads. Seems to work just fine. If you're replacing AMD with nVidia, then I wouldn't know. Iam replacing old K3100, i bet these pads are quite not good, i want to have a good heat transfer on the P5000, i was looking at 0.2mm high PTM7950 from Honeywell, they should be alright, right?
AaronD Posted September 23 Posted September 23 27 minutes ago, BoheN said: Iam replacing old K3100 I replaced a K5100. The old pads were just fine. They don't degrade, unless you've had water in there, or had it apart before and torn them up. I wouldn't worry about it. Do clean off and replace the grease though, every time that surface separates.
BoheN Posted September 25 Posted September 25 Okay i think i have good news, i disassembled the laptop, took out the heatsinks(to dremel tomorrow) and my K4100 gpu(dell service tag component site lied about that too i guess), after that i saw some suspicious looking cable labeled eDP going from my screen into the mobo, i pulled it out and it goes into the JEDP1, so i guess i do have eDP and Dell service code components page lied to me. Is that good news? should the P5000 (which is already on the way) work even better now? (here is my board model if thats maybe revelant at all)
AaronD Posted September 25 Posted September 25 3 hours ago, BoheN said: should the P5000 (which is already on the way) work even better now? Hardly matters at this point. You'll get what you'll get, and you'll evaluate it then. Stress test or benchmark if you like; I didn't bother with mine, just went straight to using it. Pass/fail regardless. Pass=keep, fail=physical undo.
SuperMG Posted September 26 Posted September 26 3 hours ago, BoheN said: Okay i think i have good news, i disassembled the laptop, took out the heatsinks(to dremel tomorrow) and my K4100 gpu(dell service tag component site lied about that too i guess), after that i saw some suspicious looking cable labeled eDP going from my screen into the mobo, i pulled it out and it goes into the JEDP1, so i guess i do have eDP and Dell service code components page lied to me. Is that good news? should the P5000 (which is already on the way) work even better now? (here is my board model if thats maybe revelant at all) Yes, you can use any RTX 3070/3080/4060/4070/4080 on this laptop with the backlight mod v2 in PEG. I use RTX 4070 on my M4800. The P5000 won't work in your laptop unless you have the eDP DP_D VBIOS that patches the ACPI error.
BoheN Posted September 26 Posted September 26 5 hours ago, SuperMG said: Yes, you can use any RTX 3070/3080/4060/4070/4080 on this laptop with the backlight mod v2 in PEG. I use RTX 4070 on my M4800. The P5000 won't work in your laptop unless you have the eDP DP_D VBIOS that patches the ACPI error. Oh, so the ACPI Error is on Pascal regardless of the display type. I have 2 vBios'es to work with, one from Techpowerup archive and engineerng sample one from here.
JadeRover Posted September 26 Posted September 26 11 hours ago, BoheN said: engineerng sample one from here Yes this one will work, it had eDP on port DP_D. So in the dell bios -> Video, chosing switchable graphics enable or not will result with you getting an image on the internal display. With switchable graphics OFF you will get an FPS boost. Also feel free to overclock the engineering vbios with my utility, I can guide you through the procedure 😉 Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
BoheN Posted September 27 Posted September 27 21 hours ago, JadeRover said: Yes this one will work, it had eDP on port DP_D. So in the dell bios -> Video, chosing switchable graphics enable or not will result with you getting an image on the internal display. Thanks a lot, will post more updates when i get the gpu. 21 hours ago, JadeRover said: Also feel free to overclock the engineering vbios with my utility, I can guide you through the procedure 😉 What utility? how would i do that?
JadeRover Posted September 28 Posted September 28 20 hours ago, BoheN said: What utility? how would i do that? https://github.com/JadeRover/Nvidia-vBIOS-Clock-Power-Tweaker/releases It is pretty self explanatory, if you have any questions don't hesitate. you need CH341a bios programmer with 1.8v add-on module ! Also I recommend you half assemble the laptop (leave the keyboard + keyboard deck removed) to have easy access to the MXM gpu during flashing and testing, making sure the custom vbios works before assembling the laptop entirely. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
BoheN Posted September 28 Posted September 28 1 hour ago, JadeRover said: you need CH341a bios programmer with 1.8v add-on module ! to flash the ES bios for P5000? doesnt linux mint 18.3 with nvflash work? or for the overclocking? 1 hour ago, JadeRover said: Also I recommend you half assemble the laptop (leave the keyboard + keyboard deck removed) to have easy access to the MXM gpu during flashing and testing, making sure the custom vbios works before assembling the laptop entirely. Thank you i will definietly do that, i do need to connect external keyboard for that correct?
JadeRover Posted September 28 Posted September 28 4 hours ago, BoheN said: to flash the ES bios for P5000? doesnt linux mint 18.3 with nvflash work? Yes, you can use linux to flash the stock ES vbios. Overclocked ES vbios requires a hardware flasher. External keyboard is recommended yes. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
BoheN Posted September 28 Posted September 28 I have news, very good ones, the P5000 arrived, i filed the radiator a bit more after i dremeled it yesterday, i put it in, and half-assembled the upper half of laptop. I got into Linux Mint 18.3 and it saw the gpu, with ./nvflash --list then i flashed the vbios just like DynamiteZerg did in 2018 and after the reboot it went straight into Windows10. After some fighting with NVCleaninstall i present you another example of P5000 working in Dell Precision M6800 I want to thank everyone for the provided help, will post some updates later after i reassemble the laptop fully and test it in some benchmarks. 2
DynamiteZerg Posted September 30 Posted September 30 On 9/29/2026 at 12:46 AM, BoheN said: I have news, very good ones, the P5000 arrived, i filed the radiator a bit more after i dremeled it yesterday, i put it in, and half-assembled the upper half of laptop. I got into Linux Mint 18.3 and it saw the gpu, with ./nvflash --list then i flashed the vbios just like DynamiteZerg did in 2018 and after the reboot it went straight into Windows10. After some fighting with NVCleaninstall i present you another example of P5000 working in Dell Precision M6800 I want to thank everyone for the provided help, will post some updates later after i reassemble the laptop fully and test it in some benchmarks. Wow my ancient write up is still helping someone today! Nice! 1 1
BoheN Posted October 12 Posted October 12 Okay its time for an update, i did Steel Nomad benchmark twice, once on Optimus, once on Native. On optimus i got 1066 points On native rendering i got 1086 points I iam using Windows10Update41 from Ghost Spectre, which is a debloated version of the OS. after switching from optims to native i had to reinstall the drivers using NVCleanInstall but with a diffrent device id i found in device manager. I got Witcher 3 Remastered running on it, with non-pascal-supported settings turned off it goes 30-50fps on Uber+ and 50-80fps on High.
