Nahimic 3 UAD Modified Driver for Unsupported MSI Hardware
Updated links will always be in my signature!
Made By: solidus1983 (hacktrix2006) and djlenior
Status: Final Release
Repack: Yes
CodeName: Zeus
Downgrade/Update: Update
Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookTalk or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems!
Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread!
Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results,
Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included.
Installer: Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe (ONLINE!)
Package includes:
Realtek UAD 6.0.1.9279.1
Nahimic 1.8.13.0 UWP
Nahimic SWC 3.5.0.0 (APO3)
Nahimic SWC 4.6.3.0 (APO4)
Nahimic Extension 1.1.44.0 (APO3)
Nahimic Extension 1.2.53.0 (APO4)
Nahimic Mirroring Driver 2.0.0.0
Realtek Audio Console UWP 1.32.261.0
Installer:
SHA-1: 690ee9c326b09befd04fd9869bfae2881da80211
Size: 122361521 bytes (116 MiB)
Virus Total: Results
For Windows 10 Build: 1909/20H1/20H2/21H1
For Windows 11 Builds (But may be issues)
Change Log:
Updated Realtek Audio driver from 6.0.1.9275.1 to 6.0.1.9279.1
Updated Nahimic SWC 3.5.0.0 to 3.5.1.0 on APO3
Updated Nahimic Extension 1.2.53.0 to 1.2.55.0 on APO4
Supported Systems with this driver pack:
Alpha Series:
Alpha 15
Bravo Series:
Bravo 15
Bravo 17
GE Series:
GE60 (Apache) (Pro)
GE62 Apache (Pro)
GE63 Raider (RGB)
GE65 Raider
GE66 Raider
GE70 (Apache) (Pro)
GE72 Apache (Pro)
GE73 Raider (RGB)
GE75 Raider
GE76 Raider
GF Series:
GF62
GF63 (Thin)
GF65 Thin
GF72
GF75 Thin
GL Series:
GL62
GL63
GL65 (Leopard)
GL72
GL73
GL75 (Leopard)
GP Series:
GP60 (Leopard)
GP62 Leopard (Pro)
GP63 Leopard
GP65 Leopard
GP70 (Leopard) (Pro)
GP72 Leopard (Pro)
GP73 Leopard
GP75 Leopard
GS Series:
GS40 Phantom
GS43 Phantom Pro
GS60 Ghost (Pro)
GS63 Stealth (Pro)
GS65 Stealth (Thin)
GS66 Stealth
GS70 Stealth (Pro)
GS72 Stealth (Pro)
GS73 Stealth (Pro)
GS75 Stealth
GT Series:
GT60 (Dominator)
GT62 Dominator (Pro)
GT63 Titan
GT72 Dominator (G) (Pro) (VR)
GT73 Titan (Pro)
GT75 Titan
GT76 Titan (DT)
GT83 Titan (SLI) (VR)
GV Series:
GV62
GV63
GV72
***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.***
Install instructions:
  •  Disconnect from the internet. (Not Required, so very Optional)
  •  Reboot System and Enter BIOS/UEFI.
  •  Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer!
  •  Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!).
  •  Now run the Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe Installer
  •  Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3.
  •  Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again!
  •  Now head back into your BIOS/UEFI and Re-enable SecureBoot!!
  •  Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet)
***[IMPORTANT]****
As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly.
Known possible bugs and fixes:
Issue: Two Nahimic Mirroring device show up in Device Manager:
Solution: run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
Issue: Nahimic 3 updated via Windows 10 Store and no longer works.
Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates,
then run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.8.9.0 UWP effects are not working or its reporting the device is not upto date.
Solution: Simply run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Issue: Jack Detection not working.
Solution: Simply go to Realtek Audio Console Disable and Re-enable it.
Issue: Microphone not working after using Nahimic Optimizer.
Solution: Click Reset inside Nahimic Settings section will fix this.
Issue: Microsoft Overwritten the installed modded driver.
Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
Issue: Nahimic 3 reports its device is not compatible basically not working.
Solution: Run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Issue: Sound has become muffled/suppressed/distorted.
Issue: I don't want the Nahimic 3 Bloatware!
Solution: Run Realtek_UAD_6.0.1.9279.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
***[IMPORTANT]****
I would like to thank the following people for whom have helped. I like to personally thank the following users.
Project Programmers:
hacktrix2006
djlenoir
Installer Testers:
DimitriosMSI
TikiThorsen
Ricardo_estep
Driver Suppiler:
MSI
Original Thanks:
epguy3
J95
JeanLegi
LeftEyeNine
Falkentyne
mnomaanw
felix3650
asm1
Bazgrim
ixende
MrBeer
arke yyci
Beemo
senso
Eflatun
HitZ2976
Ivan994
Alanfox2000
OneOnline
OgUrecheK
comradeskeleton (Reddit)
eiraku
  • Thanks 3
{Main System:} The Beast
{Mainboard:} Asrock X670E Pro
{OS:} Windows 11 Pro
Repack: Yes
CodeName: Zeus
Installer:  Realtek_UAD_6.0.1.9289.1_MSI_Nahimic_UWP_mod.exe  (ONLINE!)
Package includes:
Realtek UAD 6.0.1.9289.1
Installer:
SHA-1: 7d672f4114ede39e279eca1a727aeb32fc441699
Size: 122413635 bytes (116 MiB)
Change Log:
Updated Realtek Audio driver from 6.0.1.9279.1 to 6.0.1.9289.1
Alpha Series:
Alpha 15
Bravo Series:
Bravo 15
Bravo 17
GE Series:
GE60 (Apache) (Pro)
GE62 Apache (Pro)
GE63 Raider (RGB)
GE65 Raider
GE66 Raider
GE70 (Apache) (Pro)
GE72 Apache (Pro)
GE73 Raider (RGB)
GE75 Raider
GE76 Raider
GF Series:
GF62
GF63 (Thin)
GF65 Thin
GF72
GF75 Thin
GL Series:
GL62
GL63
GL65 (Leopard)
GL72
GL73
GL75 (Leopard)
GP Series:
GP60 (Leopard)
GP62 Leopard (Pro)
GP63 Leopard
GP65 Leopard
GP72 Leopard (Pro)
GP73 Leopard
GP75 Leopard
GS Series:
GS40 Phantom
GS43 Phantom Pro
GS60 Ghost (Pro)
GS63 Stealth (Pro)
GS65 Stealth (Thin)
GS66 Stealth
GS70 Stealth (Pro)
GS72 Stealth (Pro)
GS73 Stealth (Pro)
GS75 Stealth
GT Series:
GT60 (Dominator)
GT63 Titan
GT73 Titan (Pro)
GT75 Titan
GT76 Titan (DT)
GV Series:
GV62
GV63
GV72
***[IMPORTANT]****
***[IMPORTANT]****
hacktrix2006
djlenoir
Installer Testers:
DimitriosMSI
TikiThorsen
Ricardo_estep
Driver Suppiler:
MSI
Original Thanks:
epguy3
J95
JeanLegi
LeftEyeNine
Falkentyne
mnomaanw
felix3650
asm1
Bazgrim
ixende
MrBeer
arke yyci
Beemo
senso
Eflatun
HitZ2976
Ivan994
Alanfox2000
OneOnline
OgUrecheK
eiraku
  • Thanks 2
6 minutes ago, LeBlackNight said:
Hello everyone!
Glad to have a new home for this project @solidus1983!
Yep it sure is!
2 minutes ago, asm1 said:
I thought this  thread looked a bit familiar 🤪
Welcome back to made house! @asm1 can you please update the OP! thank you.
If anyone spots new drivers let me know. If its a big step up then i will make a new pack, whats a shame is i am going to make the mod pack exclusive to this site as the other site people are complaining about my installer being shady.
I have not registered on the other site, but I have been following. Don't let someone who clearly has never followed the project up to this point get under your skin. You handled it very well though.
I won't let them get under my skin, its a simply fix if people don't like it and think its sus do the work themselves. But yeah going to keep the drivers to one site for now else its going to make things stupid trying to keep both updated.
Ok then here again 😄 looks like i need to switch over here 😄.
The latest mod driver working perfect with a GT76 Titan DT 9SG, GS63VR 6RF and GE73VR 7 RF. If you need help for testing let me know bro Smile.
Would this mod even work with Mainboards from MSI? would it be possible to add Mainboards if this is not to much of work. just a question :).
cheerio
jp
1. Desktop Gaming RIG | i7 13700KF | MSI MEGZ690 Unify | F5-6400 CL32 not testet yet  | M.2_1 SPATIUM M480 PCIe 4.0 NVMe M.2 1TB | MSI RTX 4080 Gaming X Trio white Edition | Lian Li O11D XL with 10 Fan setup | 3 bottom (in-take) | 3 top (in-take) | 3 side (out-take | 1 back (out.take)
2. Mobile Gaming | Raider GE78HX 13VI
3. MSI GS63VR 6RF Stealth
4. MSI GE73VR 7RF Raider with 4K Screen
R.I.P GE76 Raider 11UH-208 UK with BOE CQ NE173QHM-NZ1 WQHD 240Hz
Mainboards should work as long as its an MSI and the Codec Id's are in the .inf files which they should be as Realtek UAD drivers normally have most Codec ID's in them.
The only issue might be the Nahimic 3 side of things as i am no sure if the Mainboards from MSI have Nahimic on them.
Ok, then i will check this with my MEG X570S Ace Max it has the new USB Soundchip but i think that should not be important.
I report back when i test it.
Edit:
Working fine with my Mainboard
cheerio
jp
Edit:
Glad to hear that bud. I guessed it would as the driver from MSI is for all systems they make that accept UAD drivers.
Hello, great to see this project still alive! and happy to report your latest drivers still work
Well, minus that issue I mentioned on the old forum, where the the last version of the UWP app "RealtekSemiconductorCorp.RealtekAudioControl" is 1.32.261.0.
Are you still having issues with 1.32.261.0?? If so i will downgrade it or if there is a newer one upgrade the UWP for you.
But waiting on my X170KM-G to be fixed (Bent pins on CPU socket), so currently back on old ye faithful right now. Yes its on a VM however i am on Linux right now on the old laptop.
Yes, as before the whole thing install correctly but the Realtek Control Panel does not launch. It is simple to fix it by reinstalling with the old .appxbundle file.
So Nahimic UWP still works its just Realtek Control Panel thats the issue? I will see if i can find another version and get you to test it.
Yes; everything works correctly EXCEPT the Realtek Control Panel app. Very strange.
Not really as RCP UWP can be buggy at best. I have DM'd you a link.
time to do a new modded MSI Realtek driver version as this 6.0.9305.1 MSI driver recently came out
and try to update the Nahimic APO3 & APO4 driver files as well
latest APO3 driver is 3.5.1.0 while latest APO4 driver is 4.7.1.0
maybe Tiki here should update to 9305, which should also update the Realtek Audio Control UWP app to at least 1.35.264.0 or greater
Thanks for the links, however right now time is a tad bit limited.
Repack: No
CodeName: Zeus
Installer:  Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe   (ONLINE!)
Package includes:
Realtek UAD 6.0.1.9305.1
Nahimic 1.9.5.0 UWP
Nahimic SWC 3.5.1.0 (APO3)
Nahimic SWC 4.7.1.0 (APO4)
Realtek Audio Console UWP 1.35.269.0
Installer:
SHA-1: 2a529ba7f01d7383be00a809e4cbf9ac558aeb3b
Size: 133621062 bytes (127 MiB)
Change Log:
Updated Realtek Audio driver from 6.0.1.9289.1 to 6.0.1.9305.1
Updated Realtek Audio Console from 1.32.261.0 to 1.35.269.0
Updated Nahimic SWC APO3 Driver from 3.5.0.0 to 3.5.1.0
Update Nahimic SWC APO4 Driver from 4.6.3.0 to 4.7.1.0
Updated Nahimic UWP from 1.8.13.0 to 1.9.5.0
Alpha Series:
Alpha 15
Bravo Series:
Bravo 15
Bravo 17
GE Series:
GE60 (Apache) (Pro)
GE62 Apache (Pro)
GE63 Raider (RGB)
GE65 Raider
GE66 Raider
GE70 (Apache) (Pro)
GE72 Apache (Pro)
GE73 Raider (RGB)
GE75 Raider
GE76 Raider
GF Series:
GF62
GF63 (Thin)
GF65 Thin
GF72
GF75 Thin
GL Series:
GL62
GL63
GL65 (Leopard)
GL72
GL73
GL75 (Leopard)
GP Series:
GP60 (Leopard)
GP62 Leopard (Pro)
GP63 Leopard
GP65 Leopard
GP72 Leopard (Pro)
GP73 Leopard
GP75 Leopard
GS Series:
GS40 Phantom
GS43 Phantom Pro
GS60 Ghost (Pro)
GS63 Stealth (Pro)
GS65 Stealth (Thin)
GS66 Stealth
GS70 Stealth (Pro)
GS72 Stealth (Pro)
GS73 Stealth (Pro)
GS75 Stealth
GT Series:
GT60 (Dominator)
GT63 Titan
GT73 Titan (Pro)
GT75 Titan
GT76 Titan (DT)
GV Series:
GV62
GV63
GV72
  •  Now run the  Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe Installer
***[IMPORTANT]****
Solution: run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install.
then run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic.
Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.9.5.0 UWP effects are not working or its reporting the device is not upto date.
Solution: Simply run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run R Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Full Install.
Solution: Run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4.
Solution: Run Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic
***[IMPORTANT]****
hacktrix2006
djlenoir
Installer Testers:
DimitriosMSI
TikiThorsen
Ricardo_estep
Driver Suppiler:
MSI
Original Thanks:
epguy3
J95
JeanLegi
LeftEyeNine
Falkentyne
mnomaanw
felix3650
asm1
Bazgrim
ixende
MrBeer
arke yyci
Beemo
senso
Eflatun
HitZ2976
Ivan994
Alanfox2000
OneOnline
OgUrecheK
eiraku
Any reports from people that installed the drivers ?
doh!   grrrrrrrr....
MSI recently and unexpectedly updated their Realtek UAD drivers for recent MSI desktop motherboards to version 6.0.9326.1 (seems like MSI is picking up the pace with some of these driver releases lately)
so time to do another updated modded driver again, solidus1983 (whenever you're ready)
