solidus1983 Posted July 15, 2022 Author Posted July 15, 2022 Updated links will always be in my signature! Made By: solidus1983 (hacktrix2006) and djlenior Status: Final Release Repack: No CodeName: Zeus Downgrade/Update: Update Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookTalk or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems! Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread! Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results, Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included. Installer: Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe (ONLINE!) Package includes: Realtek UAD 6.0.1.9363.1 Nahimic 1.9.9.0 UWP Nahimic SWC 3.5.1.0 (APO3) Nahimic SWC 4.8.1.0 (APO4) Nahimic Extension 1.1.44.0 (APO3) Nahimic Extension 1.2.53.0 (APO4) Nahimic Mirroring Driver 2.0.0.0 Realtek Audio Console UWP 1.37.275.0 Installer: SHA-1: ede3c2d1600c506c1840c98a5acc1eb0a5dc9dc8 Size: 137734321 bytes (131 MiB) Virus Total: Results For Windows 10 Build: 1909/20H1/20H2/21H1 For Windows 11 Builds (But may be issues) Change Log: Quote Updated Realtek Audio driver from 6.0.1.9305.1 to 6.0.1.9363.1 Updated Realtek Audio Console from 1.35.269.0 to 1.37.275.0 Updated Nahimic UWP from 1.9.5.0 to 1.9.9.0 Supported Systems with this driver pack: Alpha Series: Spoiler Alpha 15 Bravo Series: Spoiler Bravo 15 Bravo 17 GE Series: Spoiler GE60 (Apache) (Pro) GE62 Apache (Pro) GE63 Raider (RGB) GE65 Raider GE66 Raider GE70 (Apache) (Pro) GE72 Apache (Pro) GE73 Raider (RGB) GE75 Raider GE76 Raider GF Series: Spoiler GF62 GF63 (Thin) GF65 Thin GF72 GF75 Thin GL Series: Spoiler GL62 GL63 GL65 (Leopard) GL72 GL73 GL75 (Leopard) GP Series: Spoiler GP60 (Leopard) GP62 Leopard (Pro) GP63 Leopard GP65 Leopard GP70 (Leopard) (Pro) GP72 Leopard (Pro) GP73 Leopard GP75 Leopard GS Series: Spoiler GS40 Phantom GS43 Phantom Pro GS60 Ghost (Pro) GS63 Stealth (Pro) GS65 Stealth (Thin) GS66 Stealth GS70 Stealth (Pro) GS72 Stealth (Pro) GS73 Stealth (Pro) GS75 Stealth GT Series: Spoiler GT60 (Dominator) GT62 Dominator (Pro) GT63 Titan GT72 Dominator (G) (Pro) (VR) GT73 Titan (Pro) GT75 Titan GT76 Titan (DT) GT83 Titan (SLI) (VR) GV Series: Spoiler GV62 GV63 GV72 ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.*** Install instructions: Disconnect from the internet. (Not Required, so very Optional) Reboot System and Enter BIOS/UEFI. Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer! Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!). Now run the Realtek_UAD_6.0.1.9305.1_MSI_Nahimic_UWP_mod.exe Installer Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3 (APO3 Is for Systems Lower then 9th Gen APO4 is 9th Gen Above). Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again! Now head back into your BIOS/UEFI and Re-enable SecureBoot!! Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet) ***[IMPORTANT]**** As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly. Known possible bugs and fixes: Issue: Two Nahimic Mirroring device show up in Device Manager: Solution: run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install. Issue: Nahimic 3 updated via Windows 10 Store and no longer works. Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates, then run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic. Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.9.9.0 UWP effects are not working or its reporting the device is not upto date. Solution: Simply run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: Jack Detection not working. Solution: Simply go to Realtek Audio Console Disable and Re-enable it. Issue: Microphone not working after using Nahimic Optimizer. Solution: Click Reset inside Nahimic Settings section will fix this. Issue: Microsoft Overwritten the installed modded driver. Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run R Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Nahimic 3 reports its device is not compatible basically not working. Solution: Run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: Sound has become muffled/suppressed/distorted. Solution: Run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: I don't want the Nahimic 3 Bloatware! Solution: Run Realtek_UAD_6.0.1.9363.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic ***[IMPORTANT]**** I would like to thank the following people for whom have helped. I like to personally thank the following users. Project Programmers: Spoiler hacktrix2006 djlenoir Installer Testers: Spoiler DimitriosMSI TikiThorsen Ricardo_estep Driver Suppiler: Spoiler MSI Original Thanks: Spoiler epguy3 J95 JeanLegi LeftEyeNine Falkentyne mnomaanw felix3650 asm1 Bazgrim ixende MrBeer arke yyci Beemo senso Eflatun HitZ2976 Ivan994 Alanfox2000 OneOnline OgUrecheK comradeskeleton (Reddit) eiraku 2 {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
solidus1983 Posted July 18, 2022 Author Posted July 18, 2022 Hows the new drivers everyone ? {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
bbb27 Posted July 18, 2022 Posted July 18, 2022 11 hours ago, solidus1983 said: Hows the new drivers everyone ? Just noticed you uploaded a new version. Everything is working good on my end with the latest drivers (9363)(GS73VR, APO3)! 👍 Thank you for your great work! 😊 1
solidus1983 Posted August 11, 2022 Author Posted August 11, 2022 Right the project is on hold for now, firstly the new server i was using had a SATA Controller fault so thats been RMA'd after it killed the SSD's (Data is safe), but also i have now been hired by a Corp and will be discussing about their IP side of things. Don't want to cause issues with the new employer by doing the driver mods and then them getting hit with DMCA's. Once all that is sorted i will then update the thread, if i can't continue the project i will help someone take over said project as not to leave everyone stuck. The last pack i made i did adjust the installer to make it easier should any issues arise and someone needed to take over. I have all the Device ID's that are adding in file names related to which files need changing etc. If i am allowed to continue just please bare in mind that i will be working so replies will be slow but will still be there. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
epguy3 Posted August 11, 2022 Posted August 11, 2022 1 hour ago, solidus1983 said: Right the project is on hold for now, firstly the new server i was using had a SATA Controller fault so thats been RMA'd after it killed the SSD's (Data is safe), but also i have now been hired by a Corp and will be discussing about their IP side of things. Don't want to cause issues with the new employer by doing the driver mods and then them getting hit with DMCA's. Once all that is sorted i will then update the thread, if i can't continue the project i will help someone take over said project as not to leave everyone stuck. awww ok. just saw this unexpectedly from the Station Drivers site a while ago this THU 8/11 - v6.0.9381.1 UAD MSI driver. seems to be for recent MSI laptops (i'm not sure which ones)
solidus1983 Posted August 11, 2022 Author Posted August 11, 2022 3 hours ago, epguy3 said: awww ok. just saw this unexpectedly from the Station Drivers site a while ago this THU 8/11 - v6.0.9381.1 UAD MSI driver. seems to be for recent MSI laptops (i'm not sure which ones) I know its a bummer but i don't want to get fired before my start date now do i. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
epguy3 Posted August 23, 2022 Posted August 23, 2022 that's ok. take your time. I don't see MSI releasing another newer realtek audio driver version until maybe next month. btw, here was the direct link to that 6.0.9381.1 driver from MSI - apparently released for a new MSI Bravo 15 B5E laptop; took me a few weeks to find out MSI mentioned a new laptop model for the Bravo series 1
solidus1983 Posted August 24, 2022 Author Posted August 24, 2022 On 8/23/2022 at 6:14 PM, epguy3 said: that's ok. take your time. I don't see MSI releasing another newer realtek audio driver version until maybe next month. btw, here was the direct link to that 6.0.9381.1 driver from MSI - apparently released for a new MSI Bravo 15 B5E laptop; took me a few weeks to find out MSI mentioned a new laptop model for the Bravo series Thanks for understanding, it's been hectic so only weekends will be my downtime. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
solidus1983 Posted September 9, 2022 Author Posted September 9, 2022 @epguy3 If there is a new driver let me know as I should be able to pop something out this weekend. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
solidus1983 Posted September 11, 2022 Author Posted September 11, 2022 Updated links will always be in my signature! Made By: solidus1983 (hacktrix2006) and djlenior Status: Final Release Repack: No CodeName: Zeus Downgrade/Update: Update Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookTalk or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems! Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread! Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results, Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included. Installer: Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe (ONLINE!) Package includes: Realtek UAD 6.0.1.9381.1 Nahimic 1.9.10.0 UWP Nahimic SWC 3.5.1.0 (APO3) Nahimic SWC 4.8.1.0 (APO4) Nahimic Extension 1.1.44.0 (APO3) Nahimic Extension 1.2.53.0 (APO4) Nahimic Mirroring Driver 2.0.0.0 Realtek Audio Console UWP 1.39.279.0 Installer: SHA-1: 270b74df9daf51223df9fbe6e47b5ae6e8f7547d Size: 124657317 bytes (118 MiB) Virus Total: Results For Windows 10 Build: 1909/20H1/20H2/21H1 For Windows 11 Builds (But may be issues) Change Log: Quote Updated Realtek Audio driver from 6.0.1.9363.1 to 6.0.1.9381.1 Updated Realtek Audio Console from 1.37.276.0 to 1.39.279.0 Updated Nahimic UWP from 1.9.9.0 to 1.9.10.0 Supported Systems with this driver pack: Alpha Series: Spoiler Alpha 15 Bravo Series: Spoiler Bravo 15 Bravo 17 GE Series: Spoiler GE60 (Apache) (Pro) GE62 Apache (Pro) GE63 Raider (RGB) GE65 Raider GE66 Raider GE70 (Apache) (Pro) GE72 Apache (Pro) GE73 Raider (RGB) GE75 Raider GE76 Raider GF Series: Spoiler GF62 GF63 (Thin) GF65 Thin GF72 GF75 Thin GL Series: Spoiler GL62 GL63 GL65 (Leopard) GL72 GL73 GL75 (Leopard) GP Series: Spoiler GP60 (Leopard) GP62 Leopard (Pro) GP63 Leopard GP65 Leopard GP70 (Leopard) (Pro) GP72 Leopard (Pro) GP73 Leopard GP75 Leopard GS Series: Spoiler GS40 Phantom GS43 Phantom Pro GS60 Ghost (Pro) GS63 Stealth (Pro) GS65 Stealth (Thin) GS66 Stealth GS70 Stealth (Pro) GS72 Stealth (Pro) GS73 Stealth (Pro) GS75 Stealth GT Series: Spoiler GT60 (Dominator) GT62 Dominator (Pro) GT63 Titan GT72 Dominator (G) (Pro) (VR) GT73 Titan (Pro) GT75 Titan GT76 Titan (DT) GT83 Titan (SLI) (VR) GV Series: Spoiler GV62 GV63 GV72 ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.*** Install instructions: Disconnect from the internet. (Not Required, so very Optional) Reboot System and Enter BIOS/UEFI. Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer! Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!). Now run the Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe Installer Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3 (APO3 Is for Systems Lower then 9th Gen APO4 is 9th Gen Above). Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again! Now head back into your BIOS/UEFI and Re-enable SecureBoot!! Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet) ***[IMPORTANT]**** As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly. Known possible bugs and fixes: Issue: Two Nahimic Mirroring device show up in Device Manager: Solution: run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install. Issue: Nahimic 3 updated via Windows 10 Store and no longer works. Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates, then run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic. Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.9.10.0 UWP effects are not working or its reporting the device is not upto date. Solution: Simply run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: Jack Detection not working. Solution: Simply go to Realtek Audio Console Disable and Re-enable it. Issue: Microphone not working after using Nahimic Optimizer. Solution: Click Reset inside Nahimic Settings section will fix this. Issue: Microsoft Overwritten the installed modded driver. Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run R Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Nahimic 3 reports its device is not compatible basically not working. Solution: Run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: Sound has become muffled/suppressed/distorted. Solution: Run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: I don't want the Nahimic 3 Bloatware! Solution: Run Realtek_UAD_6.0.1.9381.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic ***[IMPORTANT]**** I would like to thank the following people for whom have helped. I like to personally thank the following users. Project Programmers: Spoiler hacktrix2006 djlenoir Installer Testers: Spoiler DimitriosMSI TikiThorsen Ricardo_estep Driver Suppiler: Spoiler MSI Original Thanks: Spoiler epguy3 J95 JeanLegi LeftEyeNine Falkentyne mnomaanw felix3650 asm1 Bazgrim ixende MrBeer arke yyci Beemo senso Eflatun HitZ2976 Ivan994 Alanfox2000 OneOnline OgUrecheK comradeskeleton (Reddit) eiraku 1 {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
epguy3 Posted September 22, 2022 Posted September 22, 2022 On 9/9/2022 at 4:04 AM, solidus1983 said: @epguy3 If there is a new driver let me know as I should be able to pop something out this weekend. looks like MSI did release a new realtek audio driver in mid-September 2022 v6.0.9388.1 > for a certain 12th gen intel based MSI PRO desktop pc; should also work on some modern MSI laptops & desktop motherboards as well and the Nahimic APO4 SWC driver will need to be updated as well - to either 4.8.2.0 or 4.8.6.0 from Microsoft MSI still has the outdated 4.8.1 package but has updated 1.3.8.0 extension driver included (haven't seen 4.8.2 or newer from MSI) btw, Windows 11 22H2 (aka. the 2022 update) recently came out on Tue. Sept. 20 also, some of Mokichu's Asus + SS3 (sonic studio 3) based recent Realtek audio drivers include Nahimic APO3 SWC driver v3.5.2.0. won't find that new APO3 driver version anywhere else edit 9/22
bbb27 Posted September 22, 2022 Posted September 22, 2022 I just noticed and tested the new drivers and pretty much everything works as it should (as before), except i don't have any sound on my headphones, even though they are recognized when connected 😐. I already fiddled with pretty much all the options there is on the Realtek Audio Console & Nahimic (deactivating/activating options, changing the sample rate, disabling the audio improvements, etc). The troubleshooting i did (aside from the ones mentioned by solidus1983): Tested the phones on another device, working, so the headphones are good. Rolled back to a previous driver with Full Uninstall (9363), no good. I checked the connector inside and there's nothing stuck, or dust or corrosion, etc. No Windows fresh install though due to my extreme necessity of having my laptop ready and i'm short on time to do it. Don't know if it's coincidence or not, but Windows 10 did make some updates very recently, and i didn't use my headphones (with jack) for a couple of weeks to ensure that it was Windows, and for some reason, i cannot uninstall the latest update 🤨 I'm 95% sure that solidus1983 drivers are not to blame, but i thought i shared my issue here, in case anyone is also having the same problem, or heard/read of it (unless it's the connector that simply reached the end of it's life). I'm using a GS73VR-7RF with Windows 10 21H2 (19044.2075) x64. Appreciate any help in advance 🙂 Cheers
solidus1983 Posted September 23, 2022 Author Posted September 23, 2022 @bbb27 Thanks for the report, As normal i need DXDIAG report and possibly check for anything in event viewer would be the best places to start. Also try another jack or headphones as well, If you have 4 jacks try Jack 1 and jack 4. @epguy3 Could you be so kind and get them files and rub them into one file for me sorry i mean zip them into one zip file for me. Once i have a free second i will gladly then make a new Mod pack. I will not include ASUS's SWC drivers in my builds, only MSI or MS stuff. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
bbb27 Posted September 24, 2022 Posted September 24, 2022 12 hours ago, solidus1983 said: @bbb27 Thanks for the report, As normal i need DXDIAG report and possibly check for anything in event viewer would be the best places to start. Also try another jack or headphones as well, If you have 4 jacks try Jack 1 and jack 4. Of course. DxDiag report is attached. I only have 1 jack output and 1 jack input (it's a laptop, GS73VR-7RF). As soon as i plug in, the jack it's recognized, but there is no sound at all (not muffled or suppressed as you indicate in your troubleshooting guide). I tested the headphones on another device and they work normally. Other headphones tested and it's the same result. Again, don't know if it's drivers issue or if it was Windows newest update or the jack connector broke and maybe it was already like this and i didn't notice before because i didn't use it for a week 😅. Again, thank you for the help 🙂 DxDiag.txt
solidus1983 Posted September 24, 2022 Author Posted September 24, 2022 @bbb27 Does the Volume Control show that its connected ? Does realtek control panel show it plugged in as well? Plug in the Headset and check the volume settings if that doesn't work not sure what else can be done, other then the driver was there any other changes on the system? {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
bbb27 Posted September 25, 2022 Posted September 25, 2022 @solidus1983Yes, Volume Control shows connected and Realtek Control Panel also shows as connected and the moment i connect it, it immediately changes the default device to the S/PDIF Output (as it always done since... forever). Other than the Windows 10 Update (19044.2075), no changes on the system, and for some reason i cannot revert this update 😒... And i cannot afford to format and clean re-install everything due to my lack of free time (and i REALLY need my laptop to work) but i guess that will be the only remain solution for troubleshooting this issue 😩 I'm pretty positive that your drivers are not to blame, because i also reverted to a previous version (9363) which i was sure it was working and the issue remained, so it was either Windows 10 being Windows 10 (as usual 🤷♂️) or the connector simply reached the end of it's life 😅, but since you guys are the experts on this kind of things i just thought it would be better i asked for your opinions ☺️
solidus1983 Posted September 26, 2022 Author Posted September 26, 2022 Sorry @bbb27 i am all out of idea's, do you get a static noise on headphones if the jack is not fully seated? {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
bbb27 Posted September 27, 2022 Posted September 27, 2022 @solidus1983 It's ok, i appreciate your help in this matter. Besides, it's not a critical issue (nothing a wireless headphones won't fix 😄). But answering to your question, yes there is a small static noise while connecting the jack to the connector (when is not fully seated). From the top of my head i believe it always made this (i have other devices that makes the same static noise when connecting a headphones jack).
epguy3 Posted September 29, 2022 Posted September 29, 2022 On 9/23/2022 at 3:05 PM, solidus1983 said: @epguy3 Could you be so kind and get them files and rub them into one file for me sorry i mean zip them into one zip file for me. Once i have a free second i will gladly then make a new Mod pack. I will not include ASUS's SWC drivers in my builds, only MSI or MS stuff. unfortunately I won't be able to put them into one zip package due to MY busy schedule. here's the direct link to the Nahimic APO4 SWC 4.8.6.0 cab download from Microsoft. and the direct link to the Nahimic Mirroring 2.0.1.0 cab download from Microsoft. if you weren't able to make a modded 6.0.9388.1 driver by now, that's ok. abandon or drop plans for that version and concentrate on making a modded 6.0.9414.1 version instead after MSI updated the realtek_audio_R.zip package on Tuesday Sept. 27 to 6.0.9414.1. (after the recent announcements of new MSI desktop boards featuring Intel Z790 & AMD X670 chipsets) edit - MSI has not been updating the realtek_audio_N_APO3 & realtek_audio_N_APO4 zip packages since mid-April 2022 and still contain the outdated 6.0.9336.1 driver version along with outdated Nahimic APO3 & APO4 components (hmm, has MSI been kinda lazy only updating just the realtek_audio_R package but not the other ones that bundle Nahimic?) 1
solidus1983 Posted September 29, 2022 Author Posted September 29, 2022 Thanks dude will get this done ASAP {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
solidus1983 Posted September 29, 2022 Author Posted September 29, 2022 Updated links will always be in my signature! Made By: solidus1983 (hacktrix2006) and djlenior Status: Final Release Repack: No CodeName: Zeus Downgrade/Update: Update Disclaimer: This Driver Modification is for MSI Systems listed below! Myself nor NotebookTalk or any other members of the project will not be held liable for any damage caused if this is installed on your system or other branded systems! Due to this being a Modified Driver, support will not be given via Nahimic (SteelSeries) or MSI if your having issues please post in the thread! Please note all releases will come with VirusTotal reports so you can decide if to install the modified drivers or not based on the Results, Although the dedicated server used to create these files is VirusFree! VirusTool can pick up on false positives, but to be fully open to the community reports will now always be included. Installer: Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe (ONLINE!) Package includes: Realtek UAD 6.0.1.9414.1 Nahimic 1.9.10.0 UWP Nahimic SWC 3.5.1.0 (APO3) Nahimic SWC 4.8.6.0 (APO4) Nahimic Extension 1.1.44.0 (APO3) Nahimic Extension 1.2.53.0 (APO4) Nahimic Mirroring Driver 2.0.1.0 Realtek Audio Console UWP 1.39.279.0 Installer: SHA-1: 93d229807776f2ce5c874fe2af5d5d6ee50d566e Size: 129699106 bytes (123 MiB) Virus Total: Results For Windows 10 Build: 1909/20H1/20H2/21H1 For Windows 11 Builds (But may be issues) Change Log: Quote Updated Realtek Audio driver from 6.0.1.9381.1 to 6.0.1.9414.1 Updated Nahimic MIrror Driver from 2.0.0.0 to 2.0.1.0 Updated Nahimic APO4 SWC from 4.8.1.0 to 4.8.6.0 Supported Systems with this driver pack: Alpha Series: Spoiler Alpha 15 Bravo Series: Spoiler Bravo 15 Bravo 17 GE Series: Spoiler GE60 (Apache) (Pro) GE62 Apache (Pro) GE63 Raider (RGB) GE65 Raider GE66 Raider GE70 (Apache) (Pro) GE72 Apache (Pro) GE73 Raider (RGB) GE75 Raider GE76 Raider GF Series: Spoiler GF62 GF63 (Thin) GF65 Thin GF72 GF75 Thin GL Series: Spoiler GL62 GL63 GL65 (Leopard) GL72 GL73 GL75 (Leopard) GP Series: Spoiler GP60 (Leopard) GP62 Leopard (Pro) GP63 Leopard GP65 Leopard GP70 (Leopard) (Pro) GP72 Leopard (Pro) GP73 Leopard GP75 Leopard GS Series: Spoiler GS40 Phantom GS43 Phantom Pro GS60 Ghost (Pro) GS63 Stealth (Pro) GS65 Stealth (Thin) GS66 Stealth GS70 Stealth (Pro) GS72 Stealth (Pro) GS73 Stealth (Pro) GS75 Stealth GT Series: Spoiler GT60 (Dominator) GT62 Dominator (Pro) GT63 Titan GT72 Dominator (G) (Pro) (VR) GT73 Titan (Pro) GT75 Titan GT76 Titan (DT) GT83 Titan (SLI) (VR) GV Series: Spoiler GV62 GV63 GV72 ***Don't panic if the new Laptops/Systems are not in the list they will be supported they are more likely supported, install the drivers and if it works let me know your Model Number and it will get added to the list.*** Install instructions: Disconnect from the internet. (Not Required, so very Optional) Reboot System and Enter BIOS/UEFI. Please DISABLE SECUREBOOT in your BIOS this is now important for this new installer! Once you have booted back into the OS Temporarily disable AV software (Some Anti-Virus tools might false report and delete the file!). Now run the Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe Installer Select either Full Install, Install Without Nahimic, Full Uninstall or Downgrade Nahimic 3 (APO3 Is for Systems Lower then 9th Gen APO4 is 9th Gen Above). Sit back and relax as the UWP's get uninstalled, the driver gets uninstalled and then your system is rebooted into test signing mode and everything is installed and your system is rebooted again! Now head back into your BIOS/UEFI and Re-enable SecureBoot!! Now let the system boot up fully and re-enable the internet connection. (Only if you disconnected from the internet) ***[IMPORTANT]**** As i no longer have a MSI Laptop can users please report any and all issues to this forum thread so i can rectify them quickly. Known possible bugs and fixes: Issue: Two Nahimic Mirroring device show up in Device Manager: Solution: run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Uninstall first before using Full Install. Issue: Nahimic 3 updated via Windows 10 Store and no longer works. Solution: Head into Windows 10's Store and Select the 3 Dots, followed by Settings and turn of Windows Store's Auto Application Updates, then run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Downgrade Nahimic. Issue: Ran Nahimic 3 Downgrade option however Nahimic 3 1.9.10.0 UWP effects are not working or its reporting the device is not upto date. Solution: Simply run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe select Uninstall and then after its completed the Uninstall re-run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: Jack Detection not working. Solution: Simply go to Realtek Audio Console Disable and Re-enable it. Issue: Microphone not working after using Nahimic Optimizer. Solution: Click Reset inside Nahimic Settings section will fix this. Issue: Microsoft Overwritten the installed modded driver. Solution: Head to Settings → System → About, Now click System info then Select Advance System Settings → Hardware Tab → Driver Installation Settings, now select NO! save and reboot the system. Then run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Install. Issue: Nahimic 3 reports its device is not compatible basically not working. Solution: Run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: Sound has become muffled/suppressed/distorted. Solution: Run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Uninstall, after it has rebooted your system re-run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Full Install APO3 or APO4. Issue: I don't want the Nahimic 3 Bloatware! Solution: Run Realtek_UAD_6.0.1.9414.1_MSI_Nahimic_UWP_mod.exe and select Install Without Nahimic ***[IMPORTANT]**** I would like to thank the following people for whom have helped. I like to personally thank the following users. Project Programmers: Spoiler hacktrix2006 djlenoir Installer Testers: Spoiler DimitriosMSI TikiThorsen Ricardo_estep Driver Suppiler: Spoiler MSI Original Thanks: Spoiler epguy3 J95 JeanLegi LeftEyeNine Falkentyne mnomaanw felix3650 asm1 Bazgrim ixende MrBeer arke yyci Beemo senso Eflatun HitZ2976 Ivan994 Alanfox2000 OneOnline OgUrecheK comradeskeleton (Reddit) eiraku {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
solidus1983 Posted September 29, 2022 Author Posted September 29, 2022 I will be updating the installer soon as well as i have found the cause of the virustotal flagging issues which is launch.exe which its sole goal was to change permissions to that of user and execute the ahk script. So will make a script to do the same where its not an .exe {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
epguy3 Posted October 13, 2022 Posted October 13, 2022 here's the link to the updated A-volute Nahimic APO3 & APO4 SWC drivers (APO3 v3.5.3.0 & APO4 v4.9.1.0) I decided to pack them into one zip file [APO4 4.9.1.0 became available on MS Update in early October while I found the APO3 3.5.3.0 SWC driver packaged in one of the recent Realtek USB audio driver packs released from Asus for newly released ROG B650 motherboards] on a different note, sometimes I wish I had found this Reddit topic sooner better late than never I guess 1
solidus1983 Posted October 15, 2022 Author Posted October 15, 2022 Thanks will download later as I am about to go out to celebrate becoming full term now at work. Didn't know Clevo used nahamic. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
Elessar47 Posted October 27, 2022 Posted October 27, 2022 Im using this app for months and had no issues at all even improved my audio a bit, my laptop is a GS63VR 6RF. Quite old hardware but it still works, thank you so much 1
