razor0601 Posted May 18, 2022 Posted May 18, 2022 I have a problem with my P775TM1. When I turn it on the display stays black and after a few seconds the both fans are working with 100%. The orange LED is blinking and after a while the notebook turns off. I remember that someone wrote in NBR that a sensor from the fan can cause this issue. Is that right or could it be another problem? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted May 18, 2022 Posted May 18, 2022 24 minutes ago, razor0601 said: I have a problem with my P775TM1. When I turn it on the display stays black and after a few seconds the both fans are working with 100%. The orange LED is blinking and after a while the notebook turns off. I remember that someone wrote in NBR that a sensor from the fan can cause this issue. Is that right or could it be another problem? hmmm....could be several different things, actually. here is what u could test: - reseat CPU, GPU and RAM. make sure heatsink makes proper contact and that all contact pins are clean / intact. - test with only one stick of RAM. try it in different RAM slots. - check that all fans are connected and functioning properly. Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 6 minutes ago, jaybee83 said: hmmm....could be several different things, actually. here is what u could test: - reseat CPU, GPU and RAM. make sure heatsink makes proper contact and that all contact pins are clean / intact. - test with only one stick of RAM. try it in different RAM slots. - check that all fans are connected and functioning properly. This have I all done. No changes Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted May 18, 2022 Posted May 18, 2022 3 minutes ago, razor0601 said: This have I all done. No changes in that case its likely a defective component... based on probability of failure id wager either gpu or mobo. are u still in warranty? can also try a cmos pull / bios reset, but i doubt thatll change anything... Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 52 minutes ago, jaybee83 said: in that case its likely a defective component... based on probability of failure id wager either gpu or mobo. are u still in warranty? can also try a cmos pull / bios reset, but i doubt thatll change anything... Bios reset have I done yesterday. GPU is working fine in another Laptop. So it could be the fans? Or something that recognizes the GPU and now is not working? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted May 18, 2022 Posted May 18, 2022 2 minutes ago, razor0601 said: Bios reset have I done yesterday. GPU is working fine in another Laptop. So it could be the fans? Or something that recognizes the GPU and now is not working? thats good info @gpu is working. might be a dumb question, but: has this GPU worked before in this machine? or is this a new upgrade? aside from that, can u also test all ram sticks and the cpu in another machine? Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
solidus1983 Posted May 18, 2022 Posted May 18, 2022 It could even EC Firmware being corrupt, although how one will go to flash that if its not even getting through post is another thing. Else if GPU is working fine then it most likely mainboard for sure. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
jaybee83 Posted May 18, 2022 Posted May 18, 2022 5 minutes ago, solidus1983 said: It could even EC Firmware being corrupt, although how one will go to flash that if its not even getting through post is another thing. Else if GPU is working fine then it most likely mainboard for sure. only option i could think of would be flashing directly to the chip... Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
solidus1983 Posted May 18, 2022 Posted May 18, 2022 7 minutes ago, jaybee83 said: only option i could think of would be flashing directly to the chip... Not even sure if there is a clip for that which means finding an adaptor and desoldering the chip. I take it CMOS reset on the clevo's does a EC reset too right ? {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
jaybee83 Posted May 18, 2022 Posted May 18, 2022 9 minutes ago, solidus1983 said: Not even sure if there is a clip for that which means finding an adaptor and desoldering the chip. I take it CMOS reset on the clevo's does a EC reset too right ? it should. but if there is something corrupted in there the reset wouldnt do much. Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 So CPU, RAM and gpu are working fine. And it was no upgrade or something else. It came from alone. next step is for me to try a Bios reflash. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted May 18, 2022 Posted May 18, 2022 1 hour ago, razor0601 said: So CPU, RAM and gpu are working fine. And it was no upgrade or something else. It came from alone. next step is for me to try a Bios reflash. sounds good. might be able to use the clevo Fn+B forced bios flash function before the system starts freaking out. otherwise, it might really be the mobo. Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 So after start holding FN+D and the Bios on a fat32 Stick? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted May 18, 2022 Posted May 18, 2022 if i remember correctly, FN+D resets the bios (equivalent to a cmos pull), whereas FN+B reads the bios file from the usb stick. however, im not sure if u need to rename the bios file to a certain format for it to be recognized properly or not.... Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 Ok then it’s easier for me to flash via programmer 1 Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
solidus1983 Posted May 18, 2022 Posted May 18, 2022 It might be safer to go the SPI Flashing route to see if that helps. However before you do that, probe the Power circuitry just in case as there is no point flashing bios/ec if it turns out to be a power circuitry issue. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
jaybee83 Posted May 18, 2022 Posted May 18, 2022 33 minutes ago, razor0601 said: Ok then it’s easier for me to flash via programmer keep us in the loop! Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
solidus1983 Posted May 18, 2022 Posted May 18, 2022 @razor0601Remember to do the 3 Dumps and checksum checking between them before flashing. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 1 hour ago, solidus1983 said: It might be safer to go the SPI Flashing route to see if that helps. However before you do that, probe the Power circuitry just in case as there is no point flashing bios/ec if it turns out to be a power circuitry issue. Yes, I will download later the schematic. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 1 hour ago, jaybee83 said: keep us in the loop! Yes of course Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted May 18, 2022 Author Posted May 18, 2022 47 minutes ago, solidus1983 said: @razor0601Remember to do the 3 Dumps and checksum checking between them before flashing. 3 Dumps? There are only Bios and EC. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
razor0601 Posted May 19, 2022 Author Posted May 19, 2022 Latest XMG Ultra 17 Bios doesn‘t work. Nothing changed. Where is the EC Chip? Can’t find in the schematic. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
solidus1983 Posted May 19, 2022 Posted May 19, 2022 6 minutes ago, razor0601 said: Latest XMG Ultra 17 Bios doesn‘t work. Nothing changed. Where is the EC Chip? Can’t find in the schematic. For EC chip, your looking for either one marked iTE or ENE its normally near the CPU socket or the PCH and its a square chip with a lot of pins. However an EC chip can fully brick a system if you mess up on the flashing. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
razor0601 Posted May 19, 2022 Author Posted May 19, 2022 Now I flashed also another EC Version. Now on battery it starts for 2-3 Seconds and turns off. On A/C Adapter it turns on without pushing the power button and the fans are spinning with 100%. weird thing Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
runix18 Posted May 19, 2022 Posted May 19, 2022 2 hours ago, razor0601 said: Now I flashed also another EC Version. Now on battery it starts for 2-3 Seconds and turns off. On A/C Adapter it turns on without pushing the power button and the fans are spinning with 100%. weird thing Does it stays on or still shutting down? Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
