solidus1983 Posted May 19, 2022 Posted May 19, 2022 Really strange. I take it screen is still blank? Is the GPU and CPU getting warm on boot? {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 Before I flashed the Bios and EC. It’s getting warm. But now I will check it again. 1 Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 20, 2022 Posted May 20, 2022 Boot is halted before Intel Management Engine is completely loaded. 1. First of all, make sure processor is properly seated and cooled. Reapply thermal paste if needed. 2. Reflash BIOS from the SPI interface with a clip: First erase the BIOS flash chip (U16) via a 3.3V SPI flasher (this clears NV items as well), then flash the full 8,192 KiB* image. May I recommend the P775TM1-G BIOS v 1.07.27, even if it is not latest. Ensure that there are no errors. Voltage supply of the flasher must be stable and configured at the appropriate level (3.3V), do NOT operate from battery. 3. If options 1 and 2 fail, then the entire motherboard needs to be tested to find if a semiconductor has gone faulty. The CPU can be removed and tested on another device. In practice, because JTAG is disabled on commercial devices, a new motherboard may be needed. 2 1
solidus1983 Posted May 20, 2022 Posted May 20, 2022 2 hours ago, harkaz said: Boot is halted before Intel Management Engine is completely loaded. 1. First of all, make sure processor is properly seated and cooled. Reapply thermal paste if needed. 2. Reflash BIOS from the SPI interface with a clip: First erase the BIOS flash chip (U16) via a 3.3V SPI flasher (this clears NV items as well), then flash the full 8,192 KiB* image. May I recommend the P775TM1-G BIOS v 1.07.27, even if it is not latest. Ensure that there are no errors. Voltage supply of the flasher must be stable and configured at the appropriate level (3.3V), do NOT operate from battery. 3. If options 1 and 2 fail, then the entire motherboard needs to be tested to find if a semiconductor has gone faulty. The CPU can be removed and tested on another device. In practice, because JTAG is disabled on commercial devices, a new motherboard may be needed. Now that is some solid solid advise right there. It is a shame about JTAG being disabled in commercial boards as that would help pinpoint the issue. {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 3 hours ago, harkaz said: Boot is halted before Intel Management Engine is completely loaded. 1. First of all, make sure processor is properly seated and cooled. Reapply thermal paste if needed. 2. Reflash BIOS from the SPI interface with a clip: First erase the BIOS flash chip (U16) via a 3.3V SPI flasher (this clears NV items as well), then flash the full 8,192 KiB* image. May I recommend the P775TM1-G BIOS v 1.07.27, even if it is not latest. Ensure that there are no errors. Voltage supply of the flasher must be stable and configured at the appropriate level (3.3V), do NOT operate from battery. 3. If options 1 and 2 fail, then the entire motherboard needs to be tested to find if a semiconductor has gone faulty. The CPU can be removed and tested on another device. In practice, because JTAG is disabled on commercial devices, a new motherboard may be needed. I did that all. But I will try the .27 Bios. The new symptoms started with the new EC Flash. So what’s better? First to flash EC or Bios? And which EC Version is recommend? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 20, 2022 Posted May 20, 2022 I see. Version 1.07.16 is appropriate for the primary EC. There is also a secondary EC (latest firmware for secondary EC is 1.07.02). I assume you programmed the primary EC. EC must be flashed first, then the BIOS (before rebooting the system), as the BIOS can be easily reflashed. If the EC firmware is damaged, then the motherboard should be replaced, short of trying this programmer (for the primary EC chip) - not guaranteed that it will work: https://alexlaptoprepair.com/en/svod-programmer-kbc-ene-spi-i2c-mec-ite-smsc/. There are also two JFLASH connectors (JFLASH1 and JFLASH2) that may allow programming of the 2 EC chips. Interface seems to be I2C (1 clk and 1 data lane), but I am not sure about the tools needed.
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 So which is the U15 EC chip? First or second? Because this is the chip I flashed. i think it’s the second? I flashed there 1.07.16 Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 20, 2022 Posted May 20, 2022 That must be is the secondary EC. I see this is flashable via SPI, so you are in luck. Flash the secondary EC firmware. The primary EC may be flashable with the controller I referred to the previous link (via the keyboard connector).
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 I flashed already the second EC. Before I did that the laptop starts like I said in the first post. Now after I flashed the second EC it turns on and immediately off on battery. With A/C adapter plugged in it turns on and the gpu fan starts after 1 second with 100%. But the gpu stays cold. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 20, 2022 Posted May 20, 2022 Try erasing the second EC flash (U15), and flash the secondary firmware again, after padding the file (ie. adding an appropriate number of 0xFF bytes to the end of the firmware), so the file reaches the exact size of 128 KB. If this has already be done, and the BIOS has been reflashed, then the primary EC firmware must be reflashed with specialized equipment on the primary chip. If that is not cheap, the motherboard should be replaced. EDIT: Padding with 0xFF could be preferable.
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 I can erase, flash and read the U15 without adding 0xFF … so I think the first EC has to be reflashed. Do you know which is the correct EC Version for that? 1 Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 20, 2022 Posted May 20, 2022 For BIOS 1.07.27 (or later), it is EC 1.07.16 Padding may be necessary for proper execution of the firmware machine code though (even if the programmer can properly read/write/erase). I had a similar experience with Thunderbolt firmware - padding was necessary for the firmware to be properly initialized. If you take a look at the primary EC fw with a hex editor, you will notice the padding.
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 I flashed the 1.07.16 to the U15. So that was not right? And what is padding? Don‘t understand that word. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 20, 2022 Posted May 20, 2022 No, that was the wrong firmware. You need another file. Search for "2nd_EC10702.zip" Padding. Simply put, means explicitly defining the empty space in the firmware. A firmware file that is intended for Windows/UEFI shell programming may not contain this empty space, so it must be manually added before flashing with a low-level programmer. Padding is done in hex editor. If you need help with that, I can prepare and upload a padded file for you.
razor0601 Posted May 20, 2022 Author Posted May 20, 2022 Ok thanks. So first I will give it a try with the second EC. Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted May 20, 2022 Posted May 20, 2022 *grabs some popcorn while following this thread* keeping fingers crossed here! 🤠 2 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (TG High Perf. IHS) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted May 21, 2022 Author Posted May 21, 2022 I flashed the 2nd EC but nothing changed. So I also tried several EC versions and also the original dump. Nothing changed. So now the first EC has to be reflashed? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 21, 2022 Posted May 21, 2022 Try reflashing the original BIOS dump to the U16 as well, along with the second EC (U15). If nothing changes, then a reflash of the first EC should be attempted.
razor0601 Posted May 23, 2022 Author Posted May 23, 2022 So I reflashed both. Nothing changed. So how to reflash the first EC? On eBay this type of programmer is very expensive And a friend of mine said maybe it’s also the Intel management engine. So a clean Bios reflash is required? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
solidus1983 Posted May 23, 2022 Posted May 23, 2022 Did you disable Intel ME before the issue came about? {Main System:} The Beast Spoiler {Cooling:} Corsair H170i Elite {Mainboard:} Asrock X670E Pro {CPU/GPU:} AMD Ryzen R9 7900x3D / AMD RX 7900 XTX (Asrock Phantom) {RAM/Storage:} 2x 16GB DDR5 Corsair Vengeance 6400MT/s , 13TB WDD SN850X 2x4TB, 2x 2TB, 1x 1TB {PSU/Case:} Corsair RM 1000x V2, Corsair 7000D Airflow (Black) {OS:} Windows 11 Pro Realtek Nahimic 3 Modded Driver for MSI Systems:Latest
razor0601 Posted May 23, 2022 Author Posted May 23, 2022 Can’t remember that. Does anybody know how to flash via these Clevo connector(J_Flash1…)? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 23, 2022 Posted May 23, 2022 13 hours ago, razor0601 said: So I reflashed both. Nothing changed. So how to reflash the first EC? On eBay this type of programmer is very expensive And a friend of mine said maybe it’s also the Intel management engine. So a clean Bios reflash is required? Yes, the 8MB BIOS.ROM from the stock Clevo BIOS should be flashed to U16. Reflashing EC1 is the last step. JFLASH1 most likely requires tools that are part of ITE8587 firmware sources. Note: In the past, in order to disable ME from the unlocked BIOS without a problem similar to the one you described, I have run the Clevo's meset tool first. 2
razor0601 Posted May 24, 2022 Author Posted May 24, 2022 The Clevo stock Bios had I also tried. The right programmer and the needed tools to reflash the Main EC is a pain in the ass and expansive. But there is another option. It is possible to get a preflashed IT8587 chip via eBay. So do I only need the U44 chip? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
harkaz Posted May 24, 2022 Posted May 24, 2022 It might be easier to just replace the board. The ITE8587 chip (U44) must come from another P775TM1 and the firmware version should be appropriate for the BIOS version. Success is not guaranteed (resoldering may cause damage, there may be other defective components on the motherboard).
razor0601 Posted May 24, 2022 Author Posted May 24, 2022 I have a technician who can flash the firmware on the chip and has the needed devices to solder a new chip. so he can take the EC Version from the XMG site? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
