Sup. Bought quadro RTX 4000 for my Alienware 18. But heatsink does not fit for it due to chip is in another place on the GPU (not as in 1060 which i use before) Could you please suggest which mod and how wxactly should i use it? I know that Baddemichi, MR FOX and others has done it. Please, help me.
For now its working but overheating in games , because cooling just lay on the chip unscrewed 1678618750011.thumb.JPEG.d95ef9768360cd5ddae77b2128033cbd.JPEG1678618750292.thumb.JPEG.b8f5a9a0f5c0f052b14fdaee14778685.JPEG1678618750178.thumb.JPEG.b1fb75c159126e94f8fd0183b34eeb8b.JPEG1678618750165.thumb.JPEG.fe3876cf77dfc54146715c3d57df4cb1.JPEG1678618749920.thumb.JPEG.af2362272e601e034e5fedd1f772f2d5.JPEG1678618750032.thumb.JPEG.4d68591abdb7ca9747bc5deee418aee8.JPEG1678618749999.thumb.JPEG.9f659b61a02e7dc6de218740dbff0949.JPEG1678618750011.thumb.JPEG.d95ef9768360cd5ddae77b2128033cbd.JPEG1678618750021.thumb.JPEG.1cde5fae843b2e6740feca9abaaf47e3.JPEG
I think someone here got it working by using m18x r2 gpu heatsink. It barely fits but works fine.
you need to show a picture of the heatsink overlapping the card so we can see where is the naked area that needs to be covered too
Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE)
Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS )
Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD  (MY current )
Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE)   (SOLD)
@razor0601 was the one I think who got one working in aw18 with stock m18x r2 heatsink
hi mate,
I struggled to get the RTX 3000 working on my 18:
Key to success is to cut the fins with a dremel IOT fit the HS into the case (I had to cut at least 3mm of fin to fit the HS). That was a real pain as it's really fragile (wrap the fins into shatterton at first to avoid them breaking when you use the dremel to cut them)
  • 2 months later...
On 3/26/2023 at 12:10 PM, Yarema said:
After reset of bios problem is resolved
my points with RTX 4000 in my alienware 18, I did not upload them before because this test was carried out without my hyperx Fury 2133hertz ram modules and without my i7-4930mx, also I have not installed the drivers correctly, it was only a stress test to test if everything was ok with the GPU. The maximum TDP that this gpu achieved is 95.3 Watts.
oh I almost forgot; It works for PCIe x16 (3.0) for me it's only working for PCIe 8x (3.0), I await your response. 😄
---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS.
---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS.
---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt.
---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M,  1080P, 120 Hz, 3D.
--Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use).
---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt.
Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
Now with my hardware, I don't see that much of a difference, really, but I'm very happy with the performance in games: D
  • 5 weeks later...
On 3/25/2023 at 12:38 PM, Yarema said:
strangely GPU doesnt want to load fully in fire strike and powerlimit jumping from 90 to 60 watts
Could you tell me how to solve the problem, it happened to me recently. :c
Still makes me chuckle to see an 8GB RTX card in a 2013 laptop. That sort of score puts a smile on my face. 1080 Ultra is good enough. I think we are at the end of the line now, we have stretched the hell out of the M18 R2.  With no more RAM and CPU options, this is the end of the line. Even if a new GPU could be used, the CPU will hold it back
  • 2 years later...
On 8/2/2025 at 9:57 AM, zerokool said:
What I find funny is apparently the rtx 3060m MXM and Rx 6600xt 6850xt support lvds
No they don't. If we remove intel HD, it won't even display on the LVDS screen. Will only display externally. Even the 3060 doesn't have an eDP port to begin with.
Weird I've seen people in other threads state the 3060m supports lvds . As well as some 6600xts and 6850xts . The 6850 can be pulled from the weird external GPU for the rog ally . But if that's incorrect then  shucks . One thing I'd find interesting would be to use one of the pin soldered 4980hqs . Sure you'd be limited to 2 slots for ram  * I think * but the iris graphics would be miles ahead of the hd 4600 plus the 128mb cache is great . There are benchmarks online showing the performance . At any rate I'm going to order a 3060m or 6600xt soon . Probably 3060 do to vram
