SuperMG Posted December 14, 2025 Author Posted December 14, 2025 3 hours ago, Tetsu said: I previously purchased a modified heatsink (for 150W) for the P570WM, and also purchased a cable for modifying the display, but I'm waiting for it to arrive. I'm also considering purchasing an RTX4090 from X-vision along with this. However, I came across a post on another forum mentioning a problem with the VBIOS. Is it still impossible to use the MXM card in the X-vision model without rewriting the VBIOS? The laptop I'm using is a P570WM eDP type. Other shops I am considering buying from are ZRT or ENBIK, but I don't know if they are available for individual purchase. You can use X-VSION 4090 but with EDID OVERRIDE. You'll lose 2/3 of the external output because of the VBIOS display tables. Which is very annoying. ZRT have better display tables and working eDP. Purchase the good 4090. Please message ZRT by contacting leidongting from ZRT thru email or thru Blibli. You can also get the Enbik one too (same as ZRT). If you could do that, can you extract the VBIOS? Thanks.
Tetsu Posted December 14, 2025 Posted December 14, 2025 There seems to be a store called peladn, but they don't carry the RTX 4080 or 4090. They do carry the 4050-4070, but they seem to only carry half-size MXM cards. The heatsink I purchased doesn't seem to be compatible. First of all, we will try to make it possible to purchase from ZRT or ENBIK.
SuperMG Posted December 14, 2025 Author Posted December 14, 2025 34 minutes ago, Tetsu said: There seems to be a store called peladn, but they don't carry the RTX 4080 or 4090. They do carry the 4050-4070, but they seem to only carry half-size MXM cards. The heatsink I purchased doesn't seem to be compatible. First of all, we will try to make it possible to purchase from ZRT or ENBIK. Peladn they have nothing in stock anyway. The RTX 4050 to 4070 are using the same VBIOS as ZRT and X-VSION which are working great for DP/DP/HDMI/eDP(enabled)! Only ZRT and Enbik have good working 4080 and 4090 with DP/DP/HDMI/eDP(enabled) X-VSION has DP/HDMI/HDMI/eDP(disabled) for their 4080 and 4090. Yes the heatsink was made for RTX 3060/3060/3080/A4500/4080/4090 MXM cards with offset center cores
Tetsu Posted December 15, 2025 Posted December 15, 2025 I have unfortunate news. I received a reply from ZRT. It appears that ZRT does not sell to individual customers. I sent a quote directly to ZRT, but received no reply, so I contacted them through a website called directindustry. The reply I received from there said that they cannot assist with individual projects. The only other option is ENBIK, which is unlikely. If you are using directindustry, please go ahead and use it. https://www.directindustry.com/prod/zrt-technology/product-4598281-2684723.html
SuperMG Posted December 15, 2025 Author Posted December 15, 2025 2 hours ago, Tetsu said: I have unfortunate news. I received a reply from ZRT. It appears that ZRT does not sell to individual customers. I sent a quote directly to ZRT, but received no reply, so I contacted them through a website called directindustry. The reply I received from there said that they cannot assist with individual projects. The only other option is ENBIK, which is unlikely. If you are using directindustry, please go ahead and use it. https://www.directindustry.com/prod/zrt-technology/product-4598281-2684723.html Hello, thanks for the update. They don't want to sell one as a sample to buy? And, Did Enbik reply to you?
Tetsu Posted December 15, 2025 Posted December 15, 2025 So far, there has been no response from ENBIK.
SuperMG Posted December 15, 2025 Author Posted December 15, 2025 20 minutes ago, Tetsu said: So far, there has been no response from ENBIK. Hello. Same they didn't reply to me. And so ZRT, so nothing new on my end. You said ZRT replied to you? Can't you buy one card? It's possible to buy one, their buying process is like XVSION, it's either PayPal or bank transfer. I don't recommend X-VSION 4080/4090 due to the VBIOS as the display tables aren't good and eDP is set to disabled.
Tetsu Posted December 15, 2025 Posted December 15, 2025 Good morning. When I go to the ZRT homepage, there is a product (RTX4090) page, but it only has buttons to download the datasheet and drivers, and no purchase button.
SuperMG Posted December 15, 2025 Author Posted December 15, 2025 43 minutes ago, Tetsu said: Good morning. When I go to the ZRT homepage, there is a product (RTX4090) page, but it only has buttons to download the datasheet and drivers, and no purchase button. As I said before and on eBay's message, you need to contact them for purchase. Please check eBay's DM for their contact info
Tetsu Posted December 17, 2025 Posted December 17, 2025 Good morning. Another option would be to use a purchasing or import agency. However, fees will be added on, and since the product is expensive, the fees will be quite high. The ZRT 4090 was priced at 300,000 yen (Japanese yen) on the Chinese sales site 1688.com. There is also a non-ZRT 4090, which cost 690 yuan, or about japan yen 15,000 yen. However, I don't know the manufacturer, so I don't know if it will work. It's a bit hard to read, but I've pasted the URL here: https://m.1688.com/offer_search/-6D7033.html?softType=pop&keywords=RTX4090 MXM&filtld=&p4pCount=4
SuperMG Posted December 17, 2025 Author Posted December 17, 2025 1 hour ago, Tetsu said: Good morning. Another option would be to use a purchasing or import agency. However, fees will be added on, and since the product is expensive, the fees will be quite high. The ZRT 4090 was priced at 300,000 yen (Japanese yen) on the Chinese sales site 1688.com. There is also a non-ZRT 4090, which cost 690 yuan, or about japan yen 15,000 yen. However, I don't know the manufacturer, so I don't know if it will work. It's a bit hard to read, but I've pasted the URL here: https://m.1688.com/offer_search/-6D7033.html?softType=pop&keywords=RTX4090 MXM&filtld=&p4pCount=4 Hello. Get ZRT because of the good VBIOS and yes it's indeed between 1400 to 1600€ for one. X-VSION is like 1200€ after taxes The one you saw for dirt cheap is probably a fake listing!!
Tetsu Posted December 17, 2025 Posted December 17, 2025 If I was able to purchase it from ZRT, would you be able to make the VBIOS public? If you could make it public, I'd like to purchase it from X-Vsion and rewrite the VBIOS. Ah, there's a good chance the display won't work. In that case, rewriting the VBIOS won't be easy. I'm currently trying to get a quote from an agent, but the price is so high at this stage that I can't make up my mind to buy it😭
SuperMG Posted December 17, 2025 Author Posted December 17, 2025 1 hour ago, Tetsu said: If I was able to purchase it from ZRT, would you be able to make the VBIOS public? If you could make it public, I'd like to purchase it from X-Vsion and rewrite the VBIOS. Ah, there's a good chance the display won't work. In that case, rewriting the VBIOS won't be easy. I'm currently trying to get a quote from an agent, but the price is so high at this stage that I can't make up my mind to buy it😭 Yes you could. You need to buy the GPU then insert the GPU in the laptop on the second slot as slave, install the same drivers as your master. Then use GPU-Z and extract the VBIOS to online. Give us the download link. Would be great if you could also show some screenshots of GPU-Z (specs, TDP, vbios version number) VBIOS should work because it uses the same GPU ID and memory configuration as X-VSION. Once I confirm everything works, you can return the card and get a refund then buy X-VSION Only by purchasing MXM GPU you can obtain their VBIOS sadly...
SuperMG Posted December 17, 2025 Author Posted December 17, 2025 17 hours ago, Tetsu said: rewriting the VBIOS won't be easy. It's easy actually. Either from nvflashk software or either from CH341A SOP8 flasher, it's just a 2MB rom file to flash!
Tetsu Posted December 18, 2025 Posted December 18, 2025 I was contacted by a purchasing agent, who said that ENBIK does not sell to individual customers and declined my request to purchase.
Tetsu Posted December 18, 2025 Posted December 18, 2025 This contact will come from the import agent.
SuperMG Posted December 18, 2025 Author Posted December 18, 2025 43 minutes ago, Tetsu said: This contact will come from the import agent. Hello, what about ZRT? Did you read what I typed hours ago?
Tetsu Posted December 19, 2025 Posted December 19, 2025 It seems that eDP works on X-vision's RTX 4050-4070 models, but what would happen if this VBIOS was applied to the 4090? I haven't been able to purchase from ZRT. I haven't even submitted a quote to the import agent. Because the price is too high and I can't go ahead with the purchase. It would make it impossible for me to make a living.HAHAHA
SuperMG Posted December 19, 2025 Author Posted December 19, 2025 45 minutes ago, Tetsu said: It seems that eDP works on X-vision's RTX 4050-4070 models, but what would happen if this VBIOS was applied to the 4090? I haven't been able to purchase from ZRT. I haven't even submitted a quote to the import agent. Because the price is too high and I can't go ahead with the purchase. It would make it impossible for me to make a living.HAHAHA Hello. Let me write it again. You don't have to keep the ZRT GPU. You buy it, extract the VBIOS and return it. It's simple as that. You just tell them the GPU doesn't work in the system, like your system doesn't boot and they'll accept the return. I do not recommend X-VSION at all anymore. They have a bad customer service because they don't help people fix the drivers/VBIOS issues and are joking about your frustration. Only ZRT seems to have good quality cards (drivers and VBIOS). If I could flash ZRT VBIOS on 4080 or 4090 in X-VSION cards (which won't happen because no one cares and ZRT doesn't want to sell me anything anyway), it'll be a big win and a major fix for these high-tier cards. If you can't get the 4090, then get the ZRT 4080... Returning it, it will refund all the amount you spent on. Thanks...
Tetsu Posted December 20, 2025 Posted December 20, 2025 Hello. Are the RTX4080 and 4090 used in the morefine g1 manufactured by ZRT? It seems like buying these would be less expensive than buying the 4090 separately through an import agent. (Although it's still expensive 😢)
SuperMG Posted December 20, 2025 Author Posted December 20, 2025 45 minutes ago, Tetsu said: Hello. Are the RTX4080 and 4090 used in the morefine g1 manufactured by ZRT? It seems like buying these would be less expensive than buying the 4090 separately through an import agent. (Although it's still expensive 😢) No never. They aren't from ZRT. Two members confirmed it. They are from X-VSION with the same bad VBIOS. I told you, you can buy ZRT and then return the MXM card back to them so you can get a refund. Thanks.
Tetsu Posted December 21, 2025 Posted December 21, 2025 Hello. This is a GTX1070. I purchased the green board from Eurocom. However, part of the backside got burnt. So I purchased a GTX1070 with a black board. When I installed this GTX1070 with a black board in a P570WM, the three lights (Numlock, Scrolllock, and CapsLock) flashed and it wouldn't start up. I don't know if the GTX1070 is broken or if the VBIOS is incorrect. It doesn't look broken from the outside. Is there any way I can use this GTX1070 with a black board?
Tetsu Posted December 21, 2025 Posted December 21, 2025 I've attached a photo of some of the burnt parts.
SuperMG Posted December 21, 2025 Author Posted December 21, 2025 (edited) 4 hours ago, Tetsu said: I've attached a photo of some of the burnt parts. If the IC or a VRM chip is burnt, it won't work anymore. The IC is important because it can manage the VRAM chips or manage the sensor data too. VRM is important because of power delivery and stability. Also you're our only hope to obtain a 4080 or 4090 from ZRT. Edited December 21, 2025 by SuperMG
JadeRover Posted December 21, 2025 Posted December 21, 2025 8 hours ago, Tetsu said: I've attached a photo of some of the burnt parts. Hello, Clearly the card is in a dead short, judging by your pictures, the capacitors are burnt and shorted. The board layers look chared as well, meaning deep under the board layers the + and - are touching and shorting out. There is no way the card can turn on in this state as the main power rail is shorting out to ground. If you know professionals get them to diagnose the card, if it's a board layer short or a capacitor short on the main power rail the repair probability is actually pretty high. The GPU die and VRAM would not be affected by the damage (if I guessed correctly on board / capactor short). You need someone with the skill to dig trhough the board layers, rebuild them and install new capacitors. There are videos on youtube that explain this pretty well for desktop cards. Precision M6700 : i7-3740QM | M3000M 4gb +250mhz OC vbios | 20gb DDR3 | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | P3000 6gb modded imac vbios | 16gb DDR4 | FHD ips Precision 7720 : i7-6820HQ | GTX1060 6gb, 88w OC vbios | 16gb DDR4 | (crappy) FHD ips Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS -> attempting 4K120hz upgrade
