cathoderayfish Posted August 16 Posted August 16 I upgraded my p775dm3 to a 2080 super, and it all works OK; however the modifications I had to do to the cooler and unholy stacks of thermal pads I had to make to get contact with the VRM makes me weary of the 200w power limit of the card, I also notice that the system does experience a hard shutoff if I run a GPU stress test for an extended period of time. (I assume the VRM is having a thermal limit trip). MSI afterburner and similar linux utilities do not seem to know much about the card, and I am not able to lower the power limit in them. (I did have to do the inf mod for Windows drivers and I am on Wayland in Linux, so perhaps it is just a coincidence and both of those two are actually causing the issue). I know it may sound stupid, but I am pretty worried about the VRMs overheating and/or the card drawing too much power from the laptop not desiged for it, so I would like to find a way to lower the power limit maybe to 180w or 150w. Anybody have a VBIOS for the clevo 2080 super with a reduced power limit? Secondly, I am a bit confused about BIOSs for this laptop, as I understand there are some BIOSs that change the ID such that the inf mod is not needed on Windows. Currently, the laptop has an older version of Dsanke bios (had it when I got it), probably pre-rtx. For a daily-driver, would it be better to update to the latest dsanke version (maybe one with rtx support) or to go with a Prema bios? What is considered to be the 'best' bios for performance option unlocking as well as daily stability and full functionality?
SuperMG Posted August 16 Posted August 16 1 hour ago, cathoderayfish said: I upgraded my p775dm3 to a 2080 super, and it all works OK; however the modifications I had to do to the cooler and unholy stacks of thermal pads I had to make to get contact with the VRM makes me weary of the 200w power limit of the card, I also notice that the system does experience a hard shutoff if I run a GPU stress test for an extended period of time. (I assume the VRM is having a thermal limit trip). MSI afterburner and similar linux utilities do not seem to know much about the card, and I am not able to lower the power limit in them. (I did have to do the inf mod for Windows drivers and I am on Wayland in Linux, so perhaps it is just a coincidence and both of those two are actually causing the issue). I know it may sound stupid, but I am pretty worried about the VRMs overheating and/or the card drawing too much power from the laptop not desiged for it, so I would like to find a way to lower the power limit maybe to 180w or 150w. Anybody have a VBIOS for the clevo 2080 super with a reduced power limit? Secondly, I am a bit confused about BIOSs for this laptop, as I understand there are some BIOSs that change the ID such that the inf mod is not needed on Windows. Currently, the laptop has an older version of Dsanke bios (had it when I got it), probably pre-rtx. For a daily-driver, would it be better to update to the latest dsanke version (maybe one with rtx support) or to go with a Prema bios? What is considered to be the 'best' bios for performance option unlocking as well as daily stability and full functionality? Hello. Won't the RTX 4070 MXM fix your issue? It performs like the 3080 150W and it only uses 115W. You need to cool down its VRAM chips too. The GDDR6 on those can achieve 90C max if well cooled. The VRM don't get too hot and I never had any shutdown issue with it. Second option: You can use an older Nvidia driver, it's a bug that allows to set the power limit.
cathoderayfish Posted August 16 Author Posted August 16 33 minutes ago, SuperMG said: Hello. Won't the RTX 4070 MXM fix your issue? It performs like the 3080 150W and it only uses 115W. You need to cool down its VRAM chips too. The GDDR6 on those can achieve 90C max. Second option: You can use an older Nvidia driver, it's a bug that allows to set the power limit. It may, but I don't have one of those. I got the 2080 super at a very good price but don't exactly have the funds to go buying newer cards. Plus, the 4070 mxm is a different shape and does not have the clevo power connector, so it would likley be a chore to fit into the laptop. I think anything newer than the 20 series also requires an updated cooler because of hole spacing differences. The dram chips are fine, the spacing is similar enough to the old 10 series card that I could just reuse the thermal pads with slight adjustments to spacing and make fine contact with all of them, the vrm is the main thing I am worried about. Old nvidia driver is an interesting idea, I never knew that the powerlimit setting was not intended. Seems rather stupid to lock useful functionality for no reason.
SuperMG Posted August 17 Posted August 17 11 hours ago, cathoderayfish said: It may, but I don't have one of those. I got the 2080 super at a very good price but don't exactly have the funds to go buying newer cards. Plus, the 4070 mxm is a different shape and does not have the clevo power connector, so it would likley be a chore to fit into the laptop. I think anything newer than the 20 series also requires an updated cooler because of hole spacing differences. The dram chips are fine, the spacing is similar enough to the old 10 series card that I could just reuse the thermal pads with slight adjustments to spacing and make fine contact with all of them, the vrm is the main thing I am worried about. Old nvidia driver is an interesting idea, I never knew that the powerlimit setting was not intended. Seems rather stupid to lock useful functionality for no reason. I got that to work in the P870 and P775 without the power connector! You just need a new heatsink for it.
cathoderayfish Posted August 19 Author Posted August 19 On 8/17/2026 at 2:31 AM, SuperMG said: I got that to work in the P870 and P775 without the power connector! You just need a new heatsink for it. Interesting, all the functions work? any issues with some of the dp or hdmi ports? internal screen control? Did you make your own heatsink or did you source one from somewhere? This is not something I would be able to afford any time soon, but I will keep it in mind if the 40 series mxm ever becomes cheap and discarded.
SuperMG Posted August 19 Posted August 19 23 minutes ago, cathoderayfish said: Interesting, all the functions work? any issues with some of the dp or hdmi ports? internal screen control? Did you make your own heatsink or did you source one from somewhere? This is not something I would be able to afford any time soon, but I will keep it in mind if the 40 series mxm ever becomes cheap and discarded. None will get discarded, these cards will get rarer and stay expensive unless someone wants to get rid of them quickly. Heatsink prices are like 100 to 150USD depending the laptop. I developed my own backlight mod cable. It allows to enable the backlight of the EDP screen and it also allows to set a preferred brightness for it. There's a powerful watercooling shared heatpipes design heatsink for the RTX 40XX for the P775TM1. It can allow 9900KS at 5GHz all core and 4090 without any thermal throttle for 400USD!! HDMI, DP are working yes.
cathoderayfish Posted August 19 Author Posted August 19 3 hours ago, SuperMG said: None will get discarded, these cards will get rarer and stay expensive unless someone wants to get rid of them quickly. Heatsink prices are like 100 to 150USD depending the laptop. I developed my own backlight mod cable. It allows to enable the backlight of the EDP screen and it also allows to set a preferred brightness for it. There's a powerful watercooling shared heatpipes design heatsink for the RTX 40XX for the P775TM1. It can allow 9900KS at 5GHz all core and 4090 without any thermal throttle for 400USD!! HDMI, DP are working yes. Sad, but you are probably right:( I wish mxm had become a broader standard and the cards weren't so damn rare. A rare card plus 100+usd cooler is not something I can afford, but it is cool to know that solutions exist to bring these laptops forward, hopefully until the 9900k becomes totally obsolete. For now, in terms of the power limit, the old driver wouldn't work great for new games, plus most of my use of the computer is on Linux where I have no idea how the power limit thing works. It may be dumb, but would putting a higher value shunt in place of the default one be an acceptable way to bring the power limit down a bit? Is there a vbios that would lower it? can the stock vbios be modded for a lower limit? As much as I like the idea of crazy stationary watercooling or mods that stick out the bottom of the case, this laptop needs to be portable enouugh to take to classes and durable enough to get tossed around on unpaved highways washboards without a fragile mod breaking or a fitting leaking fluid everywhere. They are annoying contstraints to work within when a solution to all my problems may well be cutting the bottom off and directing a 120mm fan into the base of the laptop, but I do still have to use this laptop for things
SuperMG Posted August 19 Posted August 19 20 minutes ago, cathoderayfish said: Sad, but you are probably right:( I wish mxm had become a broader standard and the cards weren't so damn rare. A rare card plus 100+usd cooler is not something I can afford, but it is cool to know that solutions exist to bring these laptops forward, hopefully until the 9900k becomes totally obsolete. For now, in terms of the power limit, the old driver wouldn't work great for new games, plus most of my use of the computer is on Linux where I have no idea how the power limit thing works. It may be dumb, but would putting a higher value shunt in place of the default one be an acceptable way to bring the power limit down a bit? Is there a vbios that would lower it? can the stock vbios be modded for a lower limit? As much as I like the idea of crazy stationary watercooling or mods that stick out the bottom of the case, this laptop needs to be portable enouugh to take to classes and durable enough to get tossed around on unpaved highways washboards without a fragile mod breaking or a fitting leaking fluid everywhere. They are annoying contstraints to work within when a solution to all my problems may well be cutting the bottom off and directing a 120mm fan into the base of the laptop, but I do still have to use this laptop for things 4090 works very well on the 9900k better than on the i7 4940MX/4930K 390FPS on Heaven benchmark 1080p Ultra.
cathoderayfish Posted October 31 Author Posted October 31 Not the best solution, but ended up just limiting the max frequenmcy to 1650mhz through nvidia-smi on Linux and X1 on Windows, nvidia-settings now shows GPU drawing just around 180W at max load. I am no longer worried about cooling and power delivery, and the occasional bit of instability during certain high-power-draw applications is gone. I also found the latest 729 Dsanke BIOS and changed the IDs so that nvidia drivers install without inf modding. (Done based on this post: https://notebooktalk.net/topic/2409-clevo-p775dm-3-upgrade-adventures/?&_rid=2772#findComment-51479) but with the IDs needed for 20 series support, that is 7714. I have attached this BIOS below, for any future readers of this post, but use it at your own risk. Now the only real issue that remains is the loss of gsync from the builtin panel, which is annoying but I have no idea how to fix, based on a quick glance, it may not be something that can be fixed since all that gsync stuff is done with binary-blob-in-bios nonsense. P7xxDMx-0729-9900KS-128G_rtx20modded.zip 1
