Scruffy Posted January 17, 2023 Author Posted January 17, 2023 hi, by rtx 3080 support i have rtx support now and my 3080 works, but i have to mod inf driver each time. iahve dedicated programmer, but flashing with that mean take apart whole notebook and i dont want to do it now. i have flashed bios like 5 times always with fpt procedure. why i cant flash it with that way ? ps: looking for viktor heatsink reply ... where are u man ?
runix18 Posted January 17, 2023 Posted January 17, 2023 2 hours ago, Scruffy said: hi, by rtx 3080 support i have rtx support now and my 3080 works, but i have to mod inf driver each time. iahve dedicated programmer, but flashing with that mean take apart whole notebook and i dont want to do it now. i have flashed bios like 5 times always with fpt procedure. why i cant flash it with that way ? ps: looking for viktor heatsink reply ... where are u man ? If you have to install inf driver means you do not have proper bios support. Also flashing a custom unsigned bios without a programer could result in a no boot black screen. If you want a proper way to do it easy, follow my tutorial here. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
Scruffy Posted January 19, 2023 Author Posted January 19, 2023 solder an adapter on that notebook mean disassembly it and if i can skip that part is much better, so today i got the power to try flashing the bios , and in case of disaster, my steam deck was ready with programmer 😄 i used the fpt flash with viktor modded bios and all went super ok 😄 tried installing driver from latest nvidia driver file from nvidia site and all is perfectly working. best part was i didnt need to disassemble the notebook 🙂 now the last think i need to do is clean the cloudy inside lcd ..... so boring big tnx to everyone who helped me 2
srs2236 Posted January 19, 2023 Posted January 19, 2023 55 minutes ago, Scruffy said: solder an adapter on that notebook mean disassembly it and if i can skip that part is much better, so today i got the power to try flashing the bios , and in case of disaster, my steam deck was ready with programmer 😄 i used the fpt flash with viktor modded bios and all went super ok 😄 tried installing driver from latest nvidia driver file from nvidia site and all is perfectly working. best part was i didnt need to disassemble the notebook 🙂 now the last think i need to do is clean the cloudy inside lcd ..... so boring big tnx to everyone who helped me Good job! Did you flash the whole BIOS file or only the BIOS region with flash fpt? Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
Scruffy Posted January 19, 2023 Author Posted January 19, 2023 i flashed whole bios. "fpt -f biosname.rom -rewrite -y" as written on dsake guide. first "meset", with automatic reboot, then backup bios ;flash bios and then "fpt -greset" command 1
xapachewolfx Posted February 22, 2023 Posted February 22, 2023 Hi I just bought a clevo p870tm1-g and I'm trying to find a unlocked bios so i up grade to rtx30 series also I'm having trouble finding the back lit keyboard software if I get some help with that
Scruffy Posted February 27, 2023 Author Posted February 27, 2023 hi for the keyboad software look for HK.5.0001.1.54 on clevo official site. Hot Key software. for the bios ask viktor. he helped me with that. but better tell us what bios u currently have and what ec bios version u have too, because when i first flashed bios i had also to check gop version too.
Scruffy Posted June 14, 2023 Author Posted June 14, 2023 would be really cool if someone from russia can bring to europe the modded heatsink for the 3080. now that summer is coming im hitting the 86° gpu limit when gaming 😞
Developer79 Posted June 16, 2023 Posted June 16, 2023 On 2/22/2023 at 9:03 PM, xapachewolfx said: Hi I just bought a clevo p870tm1-g and I'm trying to find a unlocked bios so i up grade to rtx30 series also I'm having trouble finding the back lit keyboard software if I get some help with that Hi, you can use a modded bios from Dsanke or Prema made something for it in the past! But basically the original bios is good enough and the RTX30xx series runs without problems with this bios. I do not know why most people think you need a modified bios for the RTX30xx series!:-) Now you just need to modify the hardware accordingly. so the heatsinks etc...My heatsinks reach 53 degrees in full load and highest performance with RTX3080 in most games. The Vapourchamber offers the best air cooling. The RTX3070 in P870TM generate 50 Degree at full Load gaming performance... You can also see in my last test in comparison with the RTX4080/4090 that the RTX3080 is partly faster! I don't know why people want to get the latest laptops! My P870TM is in UHD 120/144 RTX 3080 / 9900KS still faster in pure gaming performance than latest Lapops:-) Look in the main post of ViktorV P870tm. There you can find the gaming test Greetz
Scruffy Posted June 17, 2023 Author Posted June 17, 2023 problem with the vapor chamber is that it's not available at all and at low costs. originally the normal one with gpu heatsink only was 150€ new, while the gpu+ cpu plate was 180€ new. now i cant find it cheap and cant find any tutorial to make it suitable for the 3080.
Developer79 Posted June 17, 2023 Posted June 17, 2023 1 hour ago, Scruffy said: problem with the vapor chamber is that it's not available at all and at low costs. originally the normal one with gpu heatsink only was 150€ new, while the gpu+ cpu plate was 180€ new. now i cant find it cheap and cant find any tutorial to make it suitable for the 3080. Yes, that's a problem with availability! Corona has also increased inflation and with it everything old prices! The days of cheap are over and you really have to spend more than before! With appropriate adapters it is possible to make the Vapourchamber compatible with the RTX30xx series...
Statik Posted June 13, 2024 Posted June 13, 2024 Hi all Where can i found bios for rtx support on my clevo p870 km1g ? I got it with dansky bios v 1.07.15 please with a guide for flash it ? Thx for your reply and sorry for my bad english
olenbt Posted July 1, 2024 Posted July 1, 2024 man its been forever since I last posted here and nbr. glad to see og still around
ShifflyTheSHO Posted February 14, 2025 Posted February 14, 2025 My Heatsink Which heatsink should I get for the P750DM3 if I want the 3080 mxm card in place of my 1070 mxm? The heights of the heatsink parts are wildly different over the memory parts and what not… But Oh man!! I’m down the rabbit hole and its my first 17” Clevo/Sager!! (Still have a 16” Clevo with a 970m and sold a loaded Sager with a 1070 & 4k screen) But anyways I have a Xi PowerGo P750DM3 with a 7700k and 1070mxm now that I was going to fix and sell, but all I did was throw in an NVME and RAM from my trashed Gigabyte Aero 15 OLED with an i9-11980K and 3080 8GB (I kicked the power strip and now it dies on AC power and won’t charge!) and it ran perfectly! But I always loved the build quality of this make, and of I could upgrade to a 9700K or 9900K, I could care more about using a 45W processor and switch my to that epic 3080 16GB i saw listed… a 330W Power brick should be able to cover everything, right? And can we upgrade to the 120hz 3k (2880x1620) AMOLED screen? I have one on the way and with a dead Gigabyte, do we have an eDP cable for OLED? Oh wait, the Aero is a 15.6” laptop with terrible cooling and quality. And my dusty peach Laptop plus 3 possible options:
ShifflyTheSHO Posted March 13, 2025 Posted March 13, 2025 My new thread keeps getting deleted! Still trying to find what I need to get the 3K 120hz or 2.5k 240hz screen to work. is the P750dm3 a 30pin eDP? I want to know before I rip it apart… like, do I need to order one of those boards to merge the lanes or are the eDP cables fine with the right connectors/connections? do adaptors work? Is the 2880x1620 @ 120hz screen a 4lane or a two? IDK when my heatsink arrives but I’d like to only take apart my laptop once for the upgrades! thanks to anybody in the know!!
runix18 Posted March 13, 2025 Posted March 13, 2025 33 minutes ago, ShifflyTheSHO said: My new thread keeps getting deleted! Still trying to find what I need to get the 3K 120hz or 2.5k 240hz screen to work. is the P750dm3 a 30pin eDP? I want to know before I rip it apart… like, do I need to order one of those boards to merge the lanes or are the eDP cables fine with the right connectors/connections? do adaptors work? Is the 2880x1620 @ 120hz screen a 4lane or a two? IDK when my heatsink arrives but I’d like to only take apart my laptop once for the upgrades! thanks to anybody in the know!! https://eurocom.com/ec/lcd()upgrade Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
MatticMass Posted February 7 Posted February 7 I know I’m really late to the game here, but I finally got around to installing the danske 128gb (ram) bios on my p870km1. I did the 9900kf pin mod. Upgrade to WiFi 6 with WiFi 6 antennas and installed 2 rtx 3080 with the stock vapor chamber heatsink hits 89c under furmark at 4k, 71c with Fortnite max settings at 240fps at 4k res. My issue is even with the modified inf i don’t have gsync. And the bios reads vga unknown. I’m not sure what to do at this point. Origin eon17slx
runix18 Posted February 8 Posted February 8 On 2/7/2026 at 1:05 PM, MatticMass said: I know I’m really late to the game here, but I finally got around to installing the danske 128gb (ram) bios on my p870km1. I did the 9900kf pin mod. Upgrade to WiFi 6 with WiFi 6 antennas and installed 2 rtx 3080 with the stock vapor chamber heatsink hits 89c under furmark at 4k, 71c with Fortnite max settings at 240fps at 4k res. My issue is even with the modified inf i don’t have gsync. And the bios reads vga unknown. I’m not sure what to do at this point. Origin eon17slx You will never make Gsync work on P870 series with rtx 3080, as the gsync cookie does not exist for that model from Nvidia. 1 1 Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
