srs2236 Posted November 19, 2022 Posted November 19, 2022 I don't know why but I am wondering if both of your RTX 2080 are fine. @cylix@razor0601c What if for both of you the 2080 just died and that's how the motherboard acts when no GPU is connected? Did anyone tried a different GPU? I wish I could dissasemble mine and check if the motherboard acts same without GPU connected. But I can't because I moved countries and now even such things like good thermal paste will be expensive or just simply unavailable for me😥 I do plan to open mine up eventually, but not at the moment. Obviously, it's highly unlikely but you never know! Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
ViktorV Posted November 19, 2022 Posted November 19, 2022 2 hours ago, srs2236 said: I don't know why but I am wondering if both of your RTX 2080 are fine. @cylix@razor0601c What if for both of you the 2080 just died and that's how the motherboard acts when no GPU is connected? Did anyone tried a different GPU? I wish I could dissasemble mine and check if the motherboard acts same without GPU connected. But I can't because I moved countries and now even such things like good thermal paste will be expensive or just simply unavailable for me😥 I do plan to open mine up eventually, but not at the moment. Obviously, it's highly unlikely but you never know! When you start without a video card installed, there will be a black screen, but the laptop will boot into the system and after a while, due to the fact that there will be no information about the status of the card, its temperature, the laptop will go into emergency mode with maximum cooler speeds and turn off. When starting with a faulty video card, there can be 3 scenarios: 1) The laptop will boot into the system and give a picture, but when you try to install the driver, artifacts and error 31 or 43 will appear. 2) The laptop will boot with a black screen and will work normally without displaying images on the display, does not go into emergency mode. 3) When you press the power button, the laptop briefly flashes the LED and immediately turns off, this behavior is typical when there is a short circuit on the video card or any other equipment. Also, similar behavior can be with a damaged BIOS chip or a damaged BIOS file structure. Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
cylix Posted November 19, 2022 Author Posted November 19, 2022 11 hours ago, srs2236 said: I don't know why but I am wondering if both of your RTX 2080 are fine. @cylix@razor0601c What if for both of you the 2080 just died and that's how the motherboard acts when no GPU is connected? Did anyone tried a different GPU? I wish I could dissasemble mine and check if the motherboard acts same without GPU connected. But I can't because I moved countries and now even such things like good thermal paste will be expensive or just simply unavailable for me😥 I do plan to open mine up eventually, but not at the moment. Obviously, it's highly unlikely but you never know! I didnt try any other GPU, dont have any around, but i dont think th gpu is Dead, didnt experience any problems with it, no artefacts bsod prior. Also it ran cool everyday and guys from the service repair shop didnt find anything wrong with it aswell. Also why i think is the mainboard is because of the first symptom that i got was the complete failure of one of the SSD Sata ports, it was like it got fried. Didnt recognize any SSD that was inserted inside and i used 3 different ones. Also i tested all for 4 ram sticks and CPU in another system. All is working fine. I would try a different GPU aswell or mine in another Barbone but i dont konw anyone around me with a clevo system 😑. 7950X3D| Zotac 4090 AMP Extreme Airo| MSI MPG B650 Edge Wifi| Lian Li Galahad 360 V2| 48GB GSkillTrident Z RGB 7600|Kingston KC3000 2TB| Fury Renegade 2TB| Lian Li O11 Dynamic Evo| Corsair HX1500i| Samsung Odyssey G9 Neo Threadripper 7995WX Pro | AsRock WRX90 WS Evo | Kingston 128Gb DDR5 5600 ECC | Samsung 9100 Pro 2TB
ViktorV Posted November 20, 2022 Posted November 20, 2022 7 hours ago, cylix said: I didnt try any other GPU, dont have any around, but i dont think th gpu is Dead, didnt experience any problems with it, no artefacts bsod prior. Also it ran cool everyday and guys from the service repair shop didnt find anything wrong with it aswell. Also why i think is the mainboard is because of the first symptom that i got was the complete failure of one of the SSD Sata ports, it was like it got fried. Didnt recognize any SSD that was inserted inside and i used 3 different ones. Also i tested all for 4 ram sticks and CPU in another system. All is working fine. I would try a different GPU aswell or mine in another Barbone but i dont konw anyone around me with a clevo system 😑. In your video "Clevo p775tm1-g only cpu" I just now noticed a strange behavior of the power and battery indicators. Time code 2:08-2:12. It turns out that during startup the indicators do not light up and this is very strange. What parts are installed in this video? If you started only with the processor installed and without RAM and disks, then try starting the laptop without a video card, but with one RAM bar installed, a processor and a disk with Windows. Make a video and post it, it's interesting to see if the behavior changes. Also try starting without a battery installed, powered only by the laptop's power supply. Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
razor0601 Posted November 22, 2022 Posted November 22, 2022 On 11/19/2022 at 10:31 PM, cylix said: I didnt try any other GPU, dont have any around, but i dont think th gpu is Dead, didnt experience any problems with it, no artefacts bsod prior. Also it ran cool everyday and guys from the service repair shop didnt find anything wrong with it aswell. Also why i think is the mainboard is because of the first symptom that i got was the complete failure of one of the SSD Sata ports, it was like it got fried. Didnt recognize any SSD that was inserted inside and i used 3 different ones. Also i tested all for 4 ram sticks and CPU in another system. All is working fine. I would try a different GPU aswell or mine in another Barbone but i dont konw anyone around me with a clevo system 😑. It‘s not the GPU. I tested 3 different GPU‘s in my faulty Mainboard. 1 Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
